I install steam-native, then I ran both commands:
steam
STEAM_RUNTIME=1 steam
both ways my FPS is extremely low
with STEAM_RUNTIME=1 steam this is what I get:
Running Steam on manjarolinux 18.0.3 64-bit
STEAM_RUNTIME is enabled by the user
Pins up-to-date!
Installing breakpad exception handler for appid(steam)/version(1550534751)
(steam:3836): Gtk-WARNING **: 06:47:44.335: Unable to locate theme engine in module_path: "murrine",
(steam:3836): Gtk-WARNING **: 06:47:44.338: Unable to locate theme engine in module_path: "murrine",
(steam:3836): Gtk-WARNING **: 06:47:44.341: Unable to locate theme engine in module_path: "murrine",
[0304/064745.839520:INFO:crash_reporting.cc(242)] Crash reporting enabled for process: browser
[0304/064745.924258:WARNING:crash_reporting.cc(281)] Failed to set crash key: UserID with value: 0
[0304/064745.924490:WARNING:crash_reporting.cc(281)] Failed to set crash key: BuildID with value: 1550527787
[0304/064745.924519:WARNING:crash_reporting.cc(281)] Failed to set crash key: SteamUniverse with value: Public
[0304/064745.924544:WARNING:crash_reporting.cc(281)] Failed to set crash key: Vendor with value: Valve
[0304/064745.954797:ERROR:gpu_process_transport_factory.cc(1026)] Lost UI shared context.
CApplicationManagerPopulateThread took 9 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
CAppInfoCacheReadFromDiskThread took 144 milliseconds to initialize
Opted-in Controller Mask for AppId 0: 0
(steam:3836): Gtk-WARNING **: 06:47:48.674: gtk_disable_setlocale() must be called before gtk_init()
roaming config store loaded successfully - 478 bytes.
migrating temporary roaming config store
[0304/064751.608613:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
[0304/064751.700395:WARNING:crash_reporting.cc(281)] Failed to set crash key: UserID with value: 0
[0304/064751.700634:WARNING:crash_reporting.cc(281)] Failed to set crash key: BuildID with value: 1550527787
[0304/064751.700663:WARNING:crash_reporting.cc(281)] Failed to set crash key: SteamUniverse with value: Public
[0304/064751.700688:WARNING:crash_reporting.cc(281)] Failed to set crash key: Vendor with value: Valve
[0304/064751.702940:INFO:crash_reporting.cc(242)] Crash reporting enabled for process: gpu-process
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/craig/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 9.94 seconds
[0304/064753.948958:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
JS method call WebChat.GetWebChatLanguage with 1 arguments
JS method call WebChat.RegisterForFriendPostMessage with 1 arguments
JS method call WebChat.RegisterOverlayChatBrowserInfoChanged with 1 arguments
JS method call WebChat.GetSignIntoFriendsOnStart with 1 arguments
JS method call WebChat.GetCurrentUserAccountID with 1 arguments
JS method call WebChat.GetWebChatURL with 1 arguments
JS method call FriendSettings.RegisterForSettingsChanges with 1 arguments
JS method call WebChat.RegisterForPushToTalkStateChange with 1 arguments
JS method call WebChat.SetVoiceChatActive with 1 arguments
JS method call WebChat.RegisterForComputerActiveStateChange with 1 arguments
JS method call SharedConnection.AllocateSharedConnection with 1 arguments
JS method call FriendSettings.GetEnabledFeatures with 1 arguments
JS method call SharedConnection.SubscribeToEMsg with 2 arguments
JS method call SharedConnection.SubscribeToClientServiceMethod with 2 arguments
JS method call SharedConnection.RegisterOnLogonInfoChanged with 2 arguments
[0304/064756.407310:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
JS method call SharedConnection.SendMsgAndAwaitResponse with 3 arguments
JS method call Storage.GetString with 2 arguments
JS method call WebChat.GetOverlayChatBrowserInfo with 1 arguments
JS method call Parental.RegisterForParentalSettingsChanges with 1 arguments
JS method call Broadcast.RegisterForBroadcastStatus with 1 arguments
JS method call Broadcast.RegisterForViewerRequests with 1 arguments
JS method call SharedConnection.RegisterOnMessageReceived with 2 arguments
JS method call SharedConnection.SendMsg with 2 arguments
JS method call WebChat.GetPushToTalkEnabled with 1 arguments
JS method call WebChat.SetNumChatsWithUnreadPriorityMessages with 1 arguments
JS method call WebChat.BSuppressPopupsInRestore with 1 arguments
GameAction [AppID 200510, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 200510, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 200510, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 200510, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 200510, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 200510, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask for AppId 200510: 0
Game update: AppID 200510 "", ProcID 4154, IP 0.0.0.0:0
>>> Adding process 4154 for game ID 200510
GameAction [AppID 200510, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 200510, ActionID 1] : LaunchApp changed task to Completed with ""
ERROR: ld.so: object '/home/craig/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
pid 4158 != 4157, skipping destruction (fork without exec?)
>>> Adding process 4157 for game ID 200510
>>> Adding process 4159 for game ID 200510
>>> Adding process 4160 for game ID 200510
Installing breakpad exception handler for appid(gameoverlayui)/version(20190218220903)
Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)
XCOM - XCOMLauncher returned Enemy Unknown
XCOM - Launching
pid 4195 != 4194, skipping destruction (fork without exec?)
>>> Adding process 4194 for game ID 200510
>>> Adding process 4196 for game ID 200510
[0304/064804.451246:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
Game update: AppID 200510 "", ProcID 4196, IP 0.0.0.0:0
Setting breakpad minidump AppID = 200510
Steam_SetMinidumpSteamID: Caching Steam ID: 76561197964562109 [API loaded no]
[0304/064808.737126:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
JS method call Storage.SetString with 2 arguments
Game removed: AppID 200510 "", ProcID 4196
No cached sticky mapping in ActivateActionSet.JS method call WebChat.GetOverlayChatBrowserInfo with 1 arguments
Exiting workitem thread
[2019-03-04 06:47:43] Startup - updater built Feb 18 2019 22:08:53
[2019-03-04 06:47:43] Verifying installation...
[2019-03-04 06:47:43] Verification complete
[2019-03-04 06:50:09] Shutdown
and with steam (steam native) I get:
steam
Manjaro steam native configuration found!
STEAM_RUNTIME is disabled by the user
(steam:3055): Gtk-WARNING **: 06:46:05.895: Unable to locate theme engine in module_path: "murrine",
(steam:3055): Gtk-WARNING **: 06:46:05.898: Unable to locate theme engine in module_path: "murrine",
(steam:3055): Gtk-WARNING **: 06:46:05.901: Unable to locate theme engine in module_path: "murrine",
[0304/064607.554903:INFO:crash_reporting.cc(242)] Crash reporting enabled for process: browser
[0304/064607.652256:WARNING:crash_reporting.cc(281)] Failed to set crash key: UserID with value: 0
[0304/064607.652502:WARNING:crash_reporting.cc(281)] Failed to set crash key: BuildID with value: 1550527787
[0304/064607.652538:WARNING:crash_reporting.cc(281)] Failed to set crash key: SteamUniverse with value: Public
[0304/064607.652570:WARNING:crash_reporting.cc(281)] Failed to set crash key: Vendor with value: Valve
[0304/064607.726185:ERROR:gpu_process_transport_factory.cc(1026)] Lost UI shared context.
CApplicationManagerPopulateThread took 5 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
CAppInfoCacheReadFromDiskThread took 142 milliseconds to initialize
(steam:3055): Gtk-WARNING **: 06:46:10.502: gtk_disable_setlocale() must be called before gtk_init()
[0304/064613.461423:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
[0304/064613.546961:WARNING:crash_reporting.cc(281)] Failed to set crash key: UserID with value: 0
[0304/064613.547202:WARNING:crash_reporting.cc(281)] Failed to set crash key: BuildID with value: 1550527787
[0304/064613.547230:WARNING:crash_reporting.cc(281)] Failed to set crash key: SteamUniverse with value: Public
[0304/064613.547254:WARNING:crash_reporting.cc(281)] Failed to set crash key: Vendor with value: Valve
[0304/064613.549354:INFO:crash_reporting.cc(242)] Crash reporting enabled for process: gpu-process
System startup time: 10.29 seconds
[0304/064615.834825:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
[0304/064618.324894:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
Game update: AppID 200510 "", ProcID 3381, IP 0.0.0.0:0
>>> Adding process 3381 for game ID 200510
pid 3387 != 3384, skipping destruction (fork without exec?)
>>> Adding process 3384 for game ID 200510
>>> Adding process 3388 for game ID 200510
>>> Adding process 3389 for game ID 200510
XCOM - Launching
pid 3425 != 3424, skipping destruction (fork without exec?)
>>> Adding process 3424 for game ID 200510
>>> Adding process 3426 for game ID 200510
[0304/064626.472265:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
Game update: AppID 200510 "", ProcID 3426, IP 0.0.0.0:0
[0304/064630.710010:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
>>> Adding process 3570 for game ID 200510
Game removed: AppID 200510 "", ProcID 3426
No cached sticky mapping in ActivateActionSet.Exiting workitem thread
[2019-03-04 06:46:04] Startup - updater built Feb 18 2019 22:08:53
[2019-03-04 06:46:04] Verifying installation...
[2019-03-04 06:46:05] Verification complete
[2019-03-04 06:47:35] Shutdown
is it strange that in both methods it loads this:
