Making music with: echo -e '\a'
Manjaro has the default (annoying) beep, which can be modified with xset, but still isnt pleasant to the ear when an error happens out of nowhere. I solved that by using the bell.oga sound, as i have descibed it in HERE . Doing that even the beep in the terminal i changed.
I want the terminal to use the default system generated beep from xset. (example xset b 50 21 120 )
By doing that i will set the sound in different volume;frequency;length, then with echo -e '\a' generating that sound, with which in theory in a shell script one could make music.
Maybe there is a totally different approach in which one could generate sound which could be much easier. (its my first time posting here, if im wrong i will move elsewhere)
