Manjaro Deepin custom keyboard shortcut for volume control
Hi! I am trying to create a custom shortcut for controlling volume. What command should I use so that I get the level of the sound visible on the screen?
Tried 'amixer set Master 5%+' but it doesn't work properly. It just raises the volume, but I don't hear or see an indication of that.
In fact I am interested in controlling volume and brightness this way.
Would be grateful for any help!
This screenshot is for MATE, but you should probably be looking for something like:
shortcuts
Well, that's the thing. There is no such a shortcut in Deepin menu of shortcuts.
You can look in the dconf editor at /com/deepin/dde/keybinding/mediakey
It shows all the short-cuts that are used by default, and you should be able to edit them there.
