Manjaro does not start after cinamon install
God day, friends! PLEASE HELP ME! i had kde version manjaro, and i desided to try cinamon de. I install it like wiki say:
sudo pacman -S cinnamon
sudo pacman -S cinnamon-wallpapers cinnamon-sounds gnome-terminal
sudo pacman -S lightdm lightdm-slick-greeter lightdm-settings
sudo systemctl enable lightdm.service --force
Thats all. After reboot system does not start, what i see:
P_20181103_125018
PLEASE HELP. I DONT HAVE ANY OTHER DEVICE TO WORK FROM. AND FLASH DRIVES OR DVD TO BOOT. i see thar is becouse of light display manager i installed? May be i am wrong.
HOW CAN I ENTER MAYBE TERMINAL AND REMOVE CINAMON PACKAGES. HELP, BROTHERS!
Please don't shout (CAPITALS is shouting).
Which wiki?
Lightdm is not starting
Switch to another TTY using e.g. Ctrl+F4, login and enter command
journalctl -xe
What is error message displayed for lightdm?
You can also remove the package when on the other terminal
Never install a package using only -S or -Sy always use -Syu
https://wiki.manjaro.org/System_Maintenance
I used manjaro wiki: https://wiki.manjaro.org/index.php/Install_Desktop_Environments#Cinnamon
Thank for answer.
how can i do this? Please, explain me.
journalctl -xe when and where should i enter this command?
It says failed to start light display manager
It says so in the quote.
Use CtrlAltF4
Then supply your username and press Enter
Then supply your password and press Enter
Then input the command journalctl -xe and press Enter
What is the output of the journalctl -xe command?
sudo systemctl disable lightdm
sudo systemctl enable sddm
reboot
Sorry, but a cant understand. I turn on my comp and when i must do ctrl f4?
Yes - that implies you turn on your computer.
I do ctrl f4, nothinng happpens. I see this screen
P_20181103_133337
here i can enter grub comand lind and thats all.
Please start Manjaro and when the error prevents the startup you change to another terminal using the describe sequence.
The deal is that when i see error (on first screen) and i type crtl f4 nothing happens. I mean i really try to do so, but nothing happens. Is there way to enter terminal without running display?
try crtl + alt + f4
What i seeP_20181103_140311
But you did manage to get to a terminal?
Just press q and back in the terminal do
reboot
CtrlAltF4
Yes - I forgot the Alt - sorry @jorikello
Yes! THANK YOU MAN! Sorry for caps, but it works! Brothers! You are so king! Thank you! I boot up my system!
