Ok, I ran the update again and copied /var/log/Xorg.0.log using the live image:
[ 21366.783] (--) Log file renamed from "/var/log/Xorg.pid-23973.log" to "/var/log/Xorg.0.log"
[ 21366.783]
X.Org X Server 1.20.5
[ 21366.783] Build Operating System: Linux Arch Linux
[ 21366.783] Current Operating System: Linux daniel-pc 4.19.69-1-MANJARO #1 SMP PREEMPT Thu Aug 29 08:51:46 UTC 2019 x86_64
[ 21366.783] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=d435bb25-5a9e-4beb-811b-50226ad9f0a6 rw quiet resume=UUID=1b2ed8b2-fb9c-406e-bbb6-fb9f896db9a3
[ 21366.783] Build Date: 14 August 2019 10:50:56PM
[ 21366.783]
[ 21366.783] Current version of pixman: 0.38.4
[ 21366.783] Before reporting problems, check http://wiki.x.org
[ 21366.783] Markers: (--) probed, (**) from config file, (==) default setting,
[ 21366.783] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Oct 14 22:25:52 2019
[ 21366.784] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 21366.784] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 21366.784] (==) No Layout section. Using the first Screen section.
[ 21366.784] (==) No screen section available. Using defaults.
[ 21366.784] (**) |-->Screen "Default Screen Section" (0)
[ 21366.784] (**) | |-->Monitor "<default monitor>"
[ 21366.785] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 21366.785] (**) | |-->Device "AMD"
[ 21366.785] (==) No monitor specified for screen "Default Screen Section".
[ 21366.785] (==) Automatically adding devices
[ 21366.785] (==) Automatically enabling devices
[ 21366.785] (==) Automatically adding GPU devices
[ 21366.785] (==) Automatically binding GPU devices
[ 21366.785] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 21366.785] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 21366.785] Entry deleted from font path.
[ 21366.785] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 21366.785] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 21366.785] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 21366.785] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 21366.785] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 21366.785] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 21366.785] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 21366.785] (II) The server relies on udev to provide the list of input devices.
[ 21366.785] (II) Module ABI versions:
[ 21366.785] X.Org ANSI C Emulation: 0.4
[ 21366.785] X.Org Video Driver: 24.0
[ 21366.785] X.Org XInput driver : 24.1
[ 21366.785] X.Org Server Extension : 10.0
[ 21366.785] (++) using VT number 1
[ 21366.785] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 21366.786] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 21366.799] (--) PCI:*(11@0:0:0) 1002:687f:148c:2388 rev 195, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfcc00000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 21366.799] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 21366.799] (II) LoadModule: "glx"
[ 21366.800] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 21366.801] (II) Module glx: vendor="X.Org Foundation"
[ 21366.801] compiled for 1.20.5, module version = 1.0.0
[ 21366.801] ABI class: X.Org Server Extension, version 10.0
[ 21366.801] (II) LoadModule: "amdgpu"
[ 21366.801] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 21366.802] (II) Module amdgpu: vendor="X.Org Foundation"
[ 21366.802] compiled for 1.20.4, module version = 19.0.1
[ 21366.802] Module class: X.Org Video Driver
[ 21366.802] ABI class: X.Org Video Driver, version 24.0
[ 21366.802] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 21366.802] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[ 21366.802] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 21366.802] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 21366.802] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 21366.802] (==) AMDGPU(0): Default visual is TrueColor
[ 21366.802] (**) AMDGPU(0): Option "VariableRefresh" "true"
[ 21366.802] (==) AMDGPU(0): RGB weight 888
[ 21366.802] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 21366.802] (--) AMDGPU(0): Chipset: "Radeon RX Vega" (ChipID = 0x687f)
[ 21366.802] (II) Loading sub module "fb"
[ 21366.802] (II) LoadModule: "fb"
[ 21366.802] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 21366.802] (II) Module fb: vendor="X.Org Foundation"
[ 21366.802] compiled for 1.20.5, module version = 1.0.0
[ 21366.802] ABI class: X.Org ANSI C Emulation, version 0.4
[ 21366.802] (II) Loading sub module "dri2"
[ 21366.802] (II) LoadModule: "dri2"
[ 21366.802] (II) Module "dri2" already built-in
[ 21366.977] (II) Loading sub module "glamoregl"
[ 21366.977] (II) LoadModule: "glamoregl"
[ 21366.977] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 21366.980] (II) Module glamoregl: vendor="X.Org Foundation"
[ 21366.980] compiled for 1.20.5, module version = 1.0.1
[ 21366.980] ABI class: X.Org ANSI C Emulation, version 0.4
[ 21367.016] (II) AMDGPU(0): glamor X acceleration enabled on Radeon RX Vega (VEGA10, DRM 3.27.0, 4.19.69-1-MANJARO, LLVM 9.0.0)
[ 21367.016] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 21367.016] (==) AMDGPU(0): TearFree property default: auto
[ 21367.016] (**) AMDGPU(0): VariableRefresh: enabled
[ 21367.016] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 21367.017] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 21367.017] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 21367.017] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 21367.017] (II) AMDGPU(0): Output HDMI-A-1 has no monitor section
[ 21367.044] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 21367.044] (II) AMDGPU(0): Manufacturer: AOC Model: 2710 Serial#: 772
[ 21367.044] (II) AMDGPU(0): Year: 2016 Week: 51
[ 21367.044] (II) AMDGPU(0): EDID Version: 1.4
[ 21367.044] (II) AMDGPU(0): Digital Display Input
[ 21367.044] (II) AMDGPU(0): 8 bits per channel
[ 21367.044] (II) AMDGPU(0): Digital interface is DisplayPort
[ 21367.044] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 60 vert.: 34
[ 21367.044] (II) AMDGPU(0): Gamma: 2.20
[ 21367.044] (II) AMDGPU(0): DPMS capabilities: Off
[ 21367.044] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 21367.044] (II) AMDGPU(0): First detailed timing is preferred mode
[ 21367.044] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 21367.044] (II) AMDGPU(0): Display is continuous-frequency
[ 21367.044] (II) AMDGPU(0): redX: 0.650 redY: 0.338 greenX: 0.313 greenY: 0.626
[ 21367.044] (II) AMDGPU(0): blueX: 0.150 blueY: 0.052 whiteX: 0.313 whiteY: 0.329
[ 21367.044] (II) AMDGPU(0): Supported established timings:
[ 21367.044] (II) AMDGPU(0): 720x400@70Hz
[ 21367.044] (II) AMDGPU(0): 640x480@60Hz
[ 21367.044] (II) AMDGPU(0): 640x480@67Hz
[ 21367.044] (II) AMDGPU(0): 640x480@72Hz
[ 21367.044] (II) AMDGPU(0): 640x480@75Hz
[ 21367.044] (II) AMDGPU(0): 800x600@56Hz
[ 21367.044] (II) AMDGPU(0): 800x600@60Hz
[ 21367.044] (II) AMDGPU(0): 800x600@72Hz
[ 21367.044] (II) AMDGPU(0): 800x600@75Hz
[ 21367.044] (II) AMDGPU(0): 832x624@75Hz
[ 21367.044] (II) AMDGPU(0): 1024x768@60Hz
[ 21367.044] (II) AMDGPU(0): 1024x768@70Hz
[ 21367.044] (II) AMDGPU(0): 1024x768@75Hz
[ 21367.044] (II) AMDGPU(0): 1280x1024@75Hz
[ 21367.044] (II) AMDGPU(0): Manufacturer's mask: 0
[ 21367.044] (II) AMDGPU(0): Supported standard timings:
[ 21367.044] (II) AMDGPU(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 21367.044] (II) AMDGPU(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 21367.044] (II) AMDGPU(0): #2: hsize: 640 vsize 480 refresh: 100 vid: 26673
[ 21367.044] (II) AMDGPU(0): #3: hsize: 640 vsize 480 refresh: 120 vid: 31793
[ 21367.044] (II) AMDGPU(0): #4: hsize: 800 vsize 600 refresh: 100 vid: 26693
[ 21367.044] (II) AMDGPU(0): #5: hsize: 800 vsize 600 refresh: 120 vid: 31813
[ 21367.044] (II) AMDGPU(0): #6: hsize: 1024 vsize 768 refresh: 100 vid: 26721
[ 21367.044] (II) AMDGPU(0): #7: hsize: 1024 vsize 768 refresh: 120 vid: 31841
[ 21367.044] (II) AMDGPU(0): Supported detailed timing:
[ 21367.044] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 597 x 336 mm
[ 21367.044] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 21367.044] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 21367.044] (II) AMDGPU(0): clock: 592.0 MHz Image Size: 597 x 336 mm
[ 21367.044] (II) AMDGPU(0): h_active: 2560 h_sync: 2568 h_sync_end 2600 h_blank_end 2666 h_border: 0
[ 21367.044] (II) AMDGPU(0): v_active: 1440 v_sync: 1465 v_sync_end 1473 v_blanking: 1543 v_border: 0
[ 21367.044] (II) AMDGPU(0): Ranges: V min: 30 V max: 146 Hz, H min: 230 H max: 230 kHz, PixClock max 605 MHz
[ 21367.044] (II) AMDGPU(0): Monitor name: AG271QG4
[ 21367.044] (II) AMDGPU(0): clock: 487.9 MHz Image Size: 597 x 336 mm
[ 21367.044] (II) AMDGPU(0): v_active: 1440 v_sync: 1465 v_sync_end 1473 v_blanking: 1525 v_border: 0
[ 21367.044] (II) AMDGPU(0): clock: 402.6 MHz Image Size: 597 x 336 mm
[ 21367.044] (II) AMDGPU(0): v_active: 1440 v_sync: 1465 v_sync_end 1473 v_blanking: 1510 v_border: 0
[ 21367.044] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 597 x 336 mm
[ 21367.044] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 21367.044] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 21367.044] (II) AMDGPU(0): clock: 88.8 MHz Image Size: 597 x 336 mm
[ 21367.044] (II) AMDGPU(0): h_active: 1440 h_sync: 1488 h_sync_end 1520 h_blank_end 1600 h_border: 0
[ 21367.044] (II) AMDGPU(0): v_active: 900 v_sync: 903 v_sync_end 909 v_blanking: 926 v_border: 0
[ 21367.044] (II) AMDGPU(0): clock: 156.0 MHz Image Size: 597 x 336 mm
[ 21367.044] (II) AMDGPU(0): h_active: 1280 h_sync: 1376 h_sync_end 1512 h_blank_end 1744 h_border: 0
[ 21367.044] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1453 v_blanking: 1493 v_border: 0
[ 21367.044] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 21367.044] (II) AMDGPU(0): EDID (in hex):
[ 21367.044] (II) AMDGPU(0): 00ffffffffffff0005e3102704030000
[ 21367.044] (II) AMDGPU(0): 331a0104a53c22783ba595a65650a026
[ 21367.044] (II) AMDGPU(0): 0d5054bfef00d1c081803168317c4568
[ 21367.044] (II) AMDGPU(0): 457c6168617c565e00a0a0a029503020
[ 21367.044] (II) AMDGPU(0): 350055502100001e40e7006aa0a06750
[ 21367.044] (II) AMDGPU(0): 0820980455502100001a000000fd001e
[ 21367.044] (II) AMDGPU(0): 92e6e63c010a202020202020000000fc
[ 21367.044] (II) AMDGPU(0): 0041473237315147340a2020202001aa
[ 21367.044] (II) AMDGPU(0): 02031ef14b0103051404131f12021190
[ 21367.044] (II) AMDGPU(0): 230907078301000065030c00100093be
[ 21367.044] (II) AMDGPU(0): 006aa0a055500820980455502100001e
[ 21367.044] (II) AMDGPU(0): 409d006aa0a046500820980455502100
[ 21367.044] (II) AMDGPU(0): 001e023a801871382d40582c45005550
[ 21367.044] (II) AMDGPU(0): 2100001eab22a0a050841a3030203600
[ 21367.044] (II) AMDGPU(0): 55502100001af03c00d051a035506088
[ 21367.044] (II) AMDGPU(0): 3a0055502100001c00000000000000ac
[ 21367.044] (II) AMDGPU(0): Printing probed modes for output DisplayPort-0
[ 21367.044] (II) AMDGPU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync +vsync (88.8 kHz eP)
[ 21367.044] (II) AMDGPU(0): Modeline "2560x1440"x143.9 592.00 2560 2568 2600 2666 1440 1465 1473 1543 +hsync -vsync (222.1 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "2560x1440"x120.0 487.87 2560 2568 2600 2666 1440 1465 1473 1525 +hsync +vsync (183.0 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "2560x1440"x100.0 402.56 2560 2568 2600 2666 1440 1465 1473 1510 +hsync +vsync (151.0 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1920x1200"x60.0 241.50 1920 2608 2640 2720 1200 1443 1448 1481 +hsync +vsync (88.8 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1600x1200"x60.0 241.50 1600 2608 2640 2720 1200 1443 1448 1481 +hsync +vsync (88.8 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1280x1440"x59.9 156.00 1280 1376 1512 1744 1440 1443 1453 1493 -hsync +vsync (89.4 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1680x1050"x60.0 241.50 1680 2608 2640 2720 1050 1443 1448 1481 +hsync +vsync (88.8 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1280x800"x60.0 241.50 1280 2608 2640 2720 800 1443 1448 1481 +hsync +vsync (88.8 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 21367.044] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1024x768"x119.9 137.89 1024 1104 1208 1392 768 771 775 826 -hsync +vsync (99.1 kHz)
[ 21367.045] (II) AMDGPU(0): Modeline "1024x768"x100.0 112.27 1024 1096 1200 1376 768 771 775 816 -hsync +vsync (81.6 kHz)
[ 21367.045] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "800x600"x119.9 83.06 800 856 936 1072 600 603 607 646 -hsync +vsync (77.5 kHz)
[ 21367.045] (II) AMDGPU(0): Modeline "800x600"x99.9 67.39 800 848 928 1056 600 603 607 639 -hsync +vsync (63.8 kHz)
[ 21367.045] (II) AMDGPU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "640x480"x119.8 52.62 640 680 744 848 480 483 487 518 -hsync +vsync (62.1 kHz)
[ 21367.045] (II) AMDGPU(0): Modeline "640x480"x99.8 42.52 640 672 736 832 480 483 487 512 -hsync +vsync (51.1 kHz)
[ 21367.045] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 21367.045] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 21367.045] (II) AMDGPU(0): Manufacturer: AOC Model: 2460 Serial#: 1649
[ 21367.045] (II) AMDGPU(0): Year: 2017 Week: 3
[ 21367.045] (II) AMDGPU(0): EDID Version: 1.4
[ 21367.045] (II) AMDGPU(0): Digital Display Input
[ 21367.045] (II) AMDGPU(0): 8 bits per channel
[ 21367.045] (II) AMDGPU(0): Digital interface is DisplayPort
[ 21367.045] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 53 vert.: 30
[ 21367.045] (II) AMDGPU(0): Gamma: 2.20
[ 21367.045] (II) AMDGPU(0): DPMS capabilities: Off
[ 21367.045] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 21367.045] (II) AMDGPU(0): First detailed timing is preferred mode
[ 21367.045] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 21367.045] (II) AMDGPU(0): Display is continuous-frequency
[ 21367.045] (II) AMDGPU(0): redX: 0.646 redY: 0.330 greenX: 0.310 greenY: 0.617
[ 21367.045] (II) AMDGPU(0): blueX: 0.152 blueY: 0.073 whiteX: 0.313 whiteY: 0.329
[ 21367.045] (II) AMDGPU(0): Supported established timings:
[ 21367.045] (II) AMDGPU(0): 720x400@70Hz
[ 21367.045] (II) AMDGPU(0): 640x480@60Hz
[ 21367.045] (II) AMDGPU(0): 640x480@67Hz
[ 21367.045] (II) AMDGPU(0): 640x480@72Hz
[ 21367.045] (II) AMDGPU(0): 640x480@75Hz
[ 21367.045] (II) AMDGPU(0): 800x600@56Hz
[ 21367.045] (II) AMDGPU(0): 800x600@60Hz
[ 21367.045] (II) AMDGPU(0): 800x600@72Hz
[ 21367.045] (II) AMDGPU(0): 800x600@75Hz
[ 21367.045] (II) AMDGPU(0): 832x624@75Hz
[ 21367.045] (II) AMDGPU(0): 1024x768@60Hz
[ 21367.045] (II) AMDGPU(0): 1024x768@70Hz
[ 21367.045] (II) AMDGPU(0): 1024x768@75Hz
[ 21367.045] (II) AMDGPU(0): 1280x1024@75Hz
[ 21367.045] (II) AMDGPU(0): Manufacturer's mask: 0
[ 21367.045] (II) AMDGPU(0): Supported standard timings:
[ 21367.045] (II) AMDGPU(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 21367.045] (II) AMDGPU(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 21367.045] (II) AMDGPU(0): #2: hsize: 640 vsize 480 refresh: 100 vid: 26673
[ 21367.045] (II) AMDGPU(0): #3: hsize: 640 vsize 480 refresh: 120 vid: 31793
[ 21367.045] (II) AMDGPU(0): #4: hsize: 800 vsize 600 refresh: 100 vid: 26693
[ 21367.045] (II) AMDGPU(0): #5: hsize: 800 vsize 600 refresh: 120 vid: 31813
[ 21367.045] (II) AMDGPU(0): #6: hsize: 1024 vsize 768 refresh: 100 vid: 26721
[ 21367.045] (II) AMDGPU(0): #7: hsize: 1024 vsize 768 refresh: 120 vid: 31841
[ 21367.045] (II) AMDGPU(0): Supported detailed timing:
[ 21367.045] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 531 x 299 mm
[ 21367.045] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 21367.045] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 21367.045] (II) AMDGPU(0): clock: 325.1 MHz Image Size: 531 x 299 mm
[ 21367.045] (II) AMDGPU(0): h_active: 1920 h_sync: 1944 h_sync_end 1976 h_blank_end 2056 h_border: 0
[ 21367.045] (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1098 v_border: 0
[ 21367.045] (II) AMDGPU(0): Ranges: V min: 35 V max: 146 Hz, H min: 160 H max: 160 kHz, PixClock max 335 MHz
[ 21367.045] (II) AMDGPU(0): Monitor name: 2460G4
[ 21367.045] (II) AMDGPU(0): clock: 235.5 MHz Image Size: 531 x 299 mm
[ 21367.045] (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 21367.045] (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1133 v_border: 0
[ 21367.045] (II) AMDGPU(0): clock: 285.5 MHz Image Size: 531 x 299 mm
[ 21367.045] (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1144 v_border: 0
[ 21367.045] (II) AMDGPU(0): clock: 74.2 MHz Image Size: 531 x 299 mm
[ 21367.045] (II) AMDGPU(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 21367.045] (II) AMDGPU(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 21367.045] (II) AMDGPU(0): clock: 88.8 MHz Image Size: 531 x 299 mm
[ 21367.045] (II) AMDGPU(0): h_active: 1440 h_sync: 1488 h_sync_end 1520 h_blank_end 1600 h_border: 0
[ 21367.045] (II) AMDGPU(0): v_active: 900 v_sync: 903 v_sync_end 909 v_blanking: 926 v_border: 0
[ 21367.045] (II) AMDGPU(0): clock: 119.0 MHz Image Size: 531 x 299 mm
[ 21367.045] (II) AMDGPU(0): h_active: 1680 h_sync: 1728 h_sync_end 1760 h_blank_end 1840 h_border: 0
[ 21367.045] (II) AMDGPU(0): v_active: 1050 v_sync: 1053 v_sync_end 1059 v_blanking: 1080 v_border: 0
[ 21367.045] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 21367.045] (II) AMDGPU(0): EDID (in hex):
[ 21367.045] (II) AMDGPU(0): 00ffffffffffff0005e3602471060000
[ 21367.045] (II) AMDGPU(0): 031b0104a5351e783b6435a5544f9e27
[ 21367.045] (II) AMDGPU(0): 125054bfef00d1c081803168317c4568
[ 21367.045] (II) AMDGPU(0): 457c6168617c023a801871382d40582c
[ 21367.045] (II) AMDGPU(0): 4500132b2100001efc7e808870381240
[ 21367.045] (II) AMDGPU(0): 18203500132b2100001e000000fd0023
[ 21367.045] (II) AMDGPU(0): 92a0a021010a202020202020000000fc
[ 21367.045] (II) AMDGPU(0): 003234363047340a20202020202001dd
[ 21367.045] (II) AMDGPU(0): 02031ef14b0103051404131f12021190
[ 21367.045] (II) AMDGPU(0): 230907078301000065030c001000fe5b
[ 21367.045] (II) AMDGPU(0): 80a07038354030203500132b2100001e
[ 21367.045] (II) AMDGPU(0): 866f80a07038404030203500132b2100
[ 21367.045] (II) AMDGPU(0): 001e011d007251d01e206e285500132b
[ 21367.045] (II) AMDGPU(0): 2100001eab22a0a050841a3030203600
[ 21367.045] (II) AMDGPU(0): 132b2100001a7c2e90a0601a1e403020
[ 21367.045] (II) AMDGPU(0): 3600132b2100001a000000000000004e
[ 21367.045] (II) AMDGPU(0): Printing probed modes for output DisplayPort-1
[ 21367.045] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 21367.045] (II) AMDGPU(0): Modeline "1920x1080"x144.0 325.08 1920 1944 1976 2056 1080 1083 1088 1098 +hsync +vsync (158.1 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1920x1080"x120.0 285.50 1920 1968 2000 2080 1080 1083 1088 1144 +hsync +vsync (137.3 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1920x1080"x99.9 235.50 1920 1968 2000 2080 1080 1083 1088 1133 +hsync +vsync (113.2 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1280x800"x60.0 148.50 1280 2008 2052 2200 800 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 21367.045] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 21367.046] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 21367.046] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 21367.046] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 21367.046] (II) AMDGPU(0): Modeline "640x480"x119.8 52.62 640 680 744 848 480 483 487 518 -hsync +vsync (62.1 kHz)
[ 21367.046] (II) AMDGPU(0): Modeline "640x480"x99.8 42.52 640 672 736 832 480 483 487 512 -hsync +vsync (51.1 kHz)
[ 21367.046] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 21367.046] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 21367.046] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 21367.046] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21367.046] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21367.046] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 21367.046] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 21367.046] (II) AMDGPU(0): EDID for output HDMI-A-1
[ 21367.046] (II) AMDGPU(0): Output DisplayPort-0 connected
[ 21367.046] (II) AMDGPU(0): Output DisplayPort-1 connected
[ 21367.046] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 21367.046] (II) AMDGPU(0): Output HDMI-A-1 disconnected
[ 21367.046] (II) AMDGPU(0): Using spanning desktop for initial modes
[ 21367.046] (II) AMDGPU(0): Output DisplayPort-0 using initial mode 2560x1440 +0+0
[ 21367.046] (II) AMDGPU(0): Output DisplayPort-1 using initial mode 1920x1080 +2560+0
[ 21367.046] (II) AMDGPU(0): mem size init: gart size :1fe75e000 vram size: s:1fd206000 visible:e206000
[ 21367.046] (==) AMDGPU(0): DPI set to (96, 96)
[ 21367.046] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 21367.046] (II) Loading sub module "ramdac"
[ 21367.046] (II) LoadModule: "ramdac"
[ 21367.046] (II) Module "ramdac" already built-in
[ 21367.046] (II) AMDGPU(0): [DRI2] Setup complete
[ 21367.046] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 21367.046] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 21367.046] (II) AMDGPU(0): Front buffer pitch: 17920 bytes
[ 21367.046] (II) AMDGPU(0): SYNC extension fences enabled
[ 21367.046] (II) AMDGPU(0): Present extension enabled
[ 21367.046] (==) AMDGPU(0): DRI3 enabled
[ 21367.046] (==) AMDGPU(0): Backing store enabled
[ 21367.046] (II) AMDGPU(0): Direct rendering enabled
[ 21367.068] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 21367.068] (II) AMDGPU(0): Acceleration enabled
[ 21367.068] (==) AMDGPU(0): DPMS enabled
[ 21367.068] (==) AMDGPU(0): Silken mouse disabled
[ 21367.068] (II) AMDGPU(0): Set up textured video (glamor)
[ 21367.094] (II) Initializing extension Generic Event Extension
[ 21367.094] (II) Initializing extension SHAPE
[ 21367.094] (II) Initializing extension MIT-SHM
[ 21367.095] (II) Initializing extension XInputExtension
[ 21367.095] (II) Initializing extension XTEST
[ 21367.095] (II) Initializing extension BIG-REQUESTS
[ 21367.095] (II) Initializing extension SYNC
[ 21367.095] (II) Initializing extension XKEYBOARD
[ 21367.095] (II) Initializing extension XC-MISC
[ 21367.095] (II) Initializing extension SECURITY
[ 21367.095] (II) Initializing extension XFIXES
[ 21367.095] (II) Initializing extension RENDER
[ 21367.095] (II) Initializing extension RANDR
[ 21367.096] (II) Initializing extension COMPOSITE
[ 21367.096] (II) Initializing extension DAMAGE
[ 21367.096] (II) Initializing extension MIT-SCREEN-SAVER
[ 21367.096] (II) Initializing extension DOUBLE-BUFFER
[ 21367.096] (II) Initializing extension RECORD
[ 21367.096] (II) Initializing extension DPMS
[ 21367.096] (II) Initializing extension Present
[ 21367.096] (II) Initializing extension DRI3
[ 21367.096] (II) Initializing extension X-Resource
[ 21367.096] (II) Initializing extension XVideo
[ 21367.097] (II) Initializing extension XVideo-MotionCompensation
[ 21367.097] (II) Initializing extension GLX
[ 21367.122] (II) AIGLX: Loaded and initialized radeonsi
[ 21367.122] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 21367.122] (II) Initializing extension XFree86-VidModeExtension
[ 21367.122] (II) Initializing extension XFree86-DGA
[ 21367.122] (II) Initializing extension XFree86-DRI
[ 21367.122] (II) Initializing extension DRI2
[ 21367.123] (II) AMDGPU(0): Setting screen physical size to 1185 x 381
[ 21367.194] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 21367.195] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 21367.195] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 21367.195] (**) Power Button: Applying InputClass "system-keyboard"
[ 21367.195] (II) LoadModule: "libinput"
[ 21367.195] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 21367.197] (II) Module libinput: vendor="X.Org Foundation"
[ 21367.197] compiled for 1.20.5, module version = 0.29.0
[ 21367.197] Module class: X.Org XInput Driver
[ 21367.197] ABI class: X.Org XInput driver, version 24.1
[ 21367.197] (II) Using input driver 'libinput' for 'Power Button'
[ 21367.197] (**) Power Button: always reports core events
[ 21367.197] (**) Option "Device" "/dev/input/event1"
[ 21367.197] (**) Option "_source" "server/udev"
[ 21367.199] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 21367.199] (II) event1 - Power Button: device is a keyboard
[ 21367.199] (II) event1 - Power Button: device removed
[ 21367.212] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 21367.212] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 21367.212] (**) Option "xkb_model" "pc105"
[ 21367.212] (**) Option "xkb_layout" "de"
[ 21367.235] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 21367.235] (II) event1 - Power Button: device is a keyboard
[ 21367.236] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 21367.236] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 21367.236] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 21367.236] (**) Power Button: Applying InputClass "system-keyboard"
[ 21367.236] (II) Using input driver 'libinput' for 'Power Button'
[ 21367.236] (**) Power Button: always reports core events
[ 21367.236] (**) Option "Device" "/dev/input/event0"
[ 21367.236] (**) Option "_source" "server/udev"
[ 21367.236] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 21367.236] (II) event0 - Power Button: device is a keyboard
[ 21367.237] (II) event0 - Power Button: device removed
[ 21367.264] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 21367.264] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 21367.264] (**) Option "xkb_model" "pc105"
[ 21367.264] (**) Option "xkb_layout" "de"
[ 21367.265] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 21367.266] (II) event0 - Power Button: device is a keyboard
[ 21367.266] (II) config/udev: Adding input device Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard (/dev/input/event3)
[ 21367.266] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: Applying InputClass "evdev keyboard catchall"
[ 21367.266] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: Applying InputClass "libinput keyboard catchall"
[ 21367.266] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: Applying InputClass "system-keyboard"
[ 21367.266] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard'
[ 21367.266] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: always reports core events
[ 21367.266] (**) Option "Device" "/dev/input/event3"
[ 21367.266] (**) Option "_source" "server/udev"
[ 21367.268] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: is tagged by udev as: Keyboard
[ 21367.268] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: device is a keyboard
[ 21367.268] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: device removed
[ 21367.281] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-10/1-10:1.0/0003:1B1C:1B33.000A/input/input29/event3"
[ 21367.282] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard" (type: KEYBOARD, id 8)
[ 21367.282] (**) Option "xkb_model" "pc105"
[ 21367.282] (**) Option "xkb_layout" "de"
[ 21367.283] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: is tagged by udev as: Keyboard
[ 21367.284] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: device is a keyboard
[ 21367.285] (II) config/udev: Adding input device Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control (/dev/input/event8)
[ 21367.285] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21367.285] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21367.285] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 21367.285] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control'
[ 21367.285] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: always reports core events
[ 21367.285] (**) Option "Device" "/dev/input/event8"
[ 21367.285] (**) Option "_source" "server/udev"
[ 21367.286] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 21367.286] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: device is a keyboard
[ 21367.286] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: device removed
[ 21367.317] (II) libinput: Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: needs a virtual subdevice
[ 21367.317] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-10/1-10:1.0/0003:1B1C:1B33.000A/input/input30/event8"
[ 21367.317] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control" (type: MOUSE, id 9)
[ 21367.318] (**) Option "AccelerationScheme" "none"
[ 21367.318] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: (accel) selected scheme none/0
[ 21367.318] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 21367.318] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 21367.319] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 21367.319] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: device is a keyboard
[ 21367.319] (II) config/udev: Adding input device Corsair Corsair Gaming K70 LUX RGB Keyboard (/dev/input/event9)
[ 21367.319] (II) No input driver specified, ignoring this device.
[ 21367.319] (II) This device may have been added with another device file.
[ 21367.320] (II) config/udev: Adding input device Corsair Corsair Gaming K70 LUX RGB Keyboard (/dev/input/event10)
[ 21367.320] (II) No input driver specified, ignoring this device.
[ 21367.320] (II) This device may have been added with another device file.
[ 21367.320] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event13)
[ 21367.321] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=7 (/dev/input/event14)
[ 21367.321] (II) No input driver specified, ignoring this device.
[ 21367.321] (II) This device may have been added with another device file.
[ 21367.321] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=8 (/dev/input/event15)
[ 21367.321] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=9 (/dev/input/event16)
[ 21367.321] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=10 (/dev/input/event17)
[ 21367.322] (II) No input driver specified, ignoring this device.
[ 21367.322] (II) This device may have been added with another device file.
[ 21367.322] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=11 (/dev/input/event18)
[ 21367.323] (II) config/udev: Adding input device Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS (/dev/input/event11)
[ 21367.323] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "evdev keyboard catchall"
[ 21367.323] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "libinput keyboard catchall"
[ 21367.323] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "system-keyboard"
[ 21367.323] (II) Using input driver 'libinput' for 'Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS'
[ 21367.323] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: always reports core events
[ 21367.323] (**) Option "Device" "/dev/input/event11"
[ 21367.323] (**) Option "_source" "server/udev"
[ 21367.325] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: is tagged by udev as: Keyboard
[ 21367.325] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device is a keyboard
[ 21367.325] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device removed
[ 21367.335] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0c:00.3/usb3/3-2/3-2.1/3-2.1:1.1/0003:1B1C:1B3B.000D/input/input33/event11"
[ 21367.335] (II) XINPUT: Adding extended input device "Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS" (type: KEYBOARD, id 10)
[ 21367.335] (**) Option "xkb_model" "pc105"
[ 21367.335] (**) Option "xkb_layout" "de"
[ 21367.337] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: is tagged by udev as: Keyboard
[ 21367.337] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device is a keyboard
[ 21367.338] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/event4)
[ 21367.338] (**) Logitech Gaming Mouse G502: Applying InputClass "evdev pointer catchall"
[ 21367.338] (**) Logitech Gaming Mouse G502: Applying InputClass "libinput pointer catchall"
[ 21367.338] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502'
[ 21367.338] (**) Logitech Gaming Mouse G502: always reports core events
[ 21367.338] (**) Option "Device" "/dev/input/event4"
[ 21367.338] (**) Option "_source" "server/udev"
[ 21367.395] (II) event4 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[ 21367.395] (II) event4 - Logitech Gaming Mouse G502: device set to 2400 DPI
[ 21367.395] (II) event4 - Logitech Gaming Mouse G502: device is a pointer
[ 21367.396] (II) event4 - Logitech Gaming Mouse G502: device removed
[ 21367.442] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0c:00.3/usb3/3-2/3-2.2/3-2.2:1.0/0003:046D:C332.0004/input/input4/event4"
[ 21367.442] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502" (type: MOUSE, id 11)
[ 21367.442] (**) Option "AccelerationScheme" "none"
[ 21367.442] (**) Logitech Gaming Mouse G502: (accel) selected scheme none/0
[ 21367.442] (**) Logitech Gaming Mouse G502: (accel) acceleration factor: 2.000
[ 21367.442] (**) Logitech Gaming Mouse G502: (accel) acceleration threshold: 4
[ 21367.499] (II) event4 - Logitech Gaming Mouse G502: is tagged by udev as: Mouse
[ 21367.499] (II) event4 - Logitech Gaming Mouse G502: device set to 2400 DPI
[ 21367.499] (II) event4 - Logitech Gaming Mouse G502: device is a pointer
[ 21367.500] (II) config/udev: Adding input device Logitech Gaming Mouse G502 (/dev/input/mouse0)
[ 21367.500] (II) No input driver specified, ignoring this device.
[ 21367.500] (II) This device may have been added with another device file.
[ 21367.501] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Keyboard (/dev/input/event5)
[ 21367.501] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "evdev keyboard catchall"
[ 21367.501] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "libinput keyboard catchall"
[ 21367.501] (**) Logitech Gaming Mouse G502 Keyboard: Applying InputClass "system-keyboard"
[ 21367.501] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Keyboard'
[ 21367.501] (**) Logitech Gaming Mouse G502 Keyboard: always reports core events
[ 21367.501] (**) Option "Device" "/dev/input/event5"
[ 21367.501] (**) Option "_source" "server/udev"
[ 21367.503] (II) event5 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[ 21367.503] (II) event5 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[ 21367.503] (II) event5 - Logitech Gaming Mouse G502 Keyboard: device removed
[ 21367.531] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0c:00.3/usb3/3-2/3-2.2/3-2.2:1.1/0003:046D:C332.0005/input/input5/event5"
[ 21367.531] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Keyboard" (type: KEYBOARD, id 12)
[ 21367.531] (**) Option "xkb_model" "pc105"
[ 21367.531] (**) Option "xkb_layout" "de"
[ 21367.532] (II) event5 - Logitech Gaming Mouse G502 Keyboard: is tagged by udev as: Keyboard
[ 21367.532] (II) event5 - Logitech Gaming Mouse G502 Keyboard: device is a keyboard
[ 21367.533] (II) config/udev: Adding input device Logitech Gaming Mouse G502 Consumer Control (/dev/input/event6)
[ 21367.533] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21367.533] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21367.533] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[ 21367.533] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[ 21367.533] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[ 21367.533] (**) Option "Device" "/dev/input/event6"
[ 21367.533] (**) Option "_source" "server/udev"
[ 21367.534] (II) event6 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[ 21367.534] (II) event6 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[ 21367.534] (II) event6 - Logitech Gaming Mouse G502 Consumer Control: device removed
[ 21367.558] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: needs a virtual subdevice
[ 21367.558] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0c:00.3/usb3/3-2/3-2.2/3-2.2:1.1/0003:046D:C332.0005/input/input6/event6"
[ 21367.558] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: MOUSE, id 13)
[ 21367.558] (**) Option "AccelerationScheme" "none"
[ 21367.558] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) selected scheme none/0
[ 21367.558] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration factor: 2.000
[ 21367.558] (**) Logitech Gaming Mouse G502 Consumer Control: (accel) acceleration threshold: 4
[ 21367.560] (II) event6 - Logitech Gaming Mouse G502 Consumer Control: is tagged by udev as: Keyboard
[ 21367.560] (II) event6 - Logitech Gaming Mouse G502 Consumer Control: device is a keyboard
[ 21367.561] (II) config/udev: Adding input device Logitech Gaming Mouse G502 System Control (/dev/input/event7)
[ 21367.561] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "evdev keyboard catchall"
[ 21367.561] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "libinput keyboard catchall"
[ 21367.561] (**) Logitech Gaming Mouse G502 System Control: Applying InputClass "system-keyboard"
[ 21367.561] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 System Control'
[ 21367.561] (**) Logitech Gaming Mouse G502 System Control: always reports core events
[ 21367.561] (**) Option "Device" "/dev/input/event7"
[ 21367.561] (**) Option "_source" "server/udev"
[ 21367.562] (II) event7 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[ 21367.562] (II) event7 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[ 21367.563] (II) event7 - Logitech Gaming Mouse G502 System Control: device removed
[ 21367.611] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0c:00.3/usb3/3-2/3-2.2/3-2.2:1.1/0003:046D:C332.0005/input/input7/event7"
[ 21367.611] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 System Control" (type: KEYBOARD, id 14)
[ 21367.611] (**) Option "xkb_model" "pc105"
[ 21367.611] (**) Option "xkb_layout" "de"
[ 21367.613] (II) event7 - Logitech Gaming Mouse G502 System Control: is tagged by udev as: Keyboard
[ 21367.613] (II) event7 - Logitech Gaming Mouse G502 System Control: device is a keyboard
[ 21367.614] (II) config/udev: Adding input device Logitech BRIO (/dev/input/event24)
[ 21367.614] (**) Logitech BRIO: Applying InputClass "evdev keyboard catchall"
[ 21367.614] (**) Logitech BRIO: Applying InputClass "libinput keyboard catchall"
[ 21367.614] (**) Logitech BRIO: Applying InputClass "system-keyboard"
[ 21367.614] (II) Using input driver 'libinput' for 'Logitech BRIO'
[ 21367.614] (**) Logitech BRIO: always reports core events
[ 21367.614] (**) Option "Device" "/dev/input/event24"
[ 21367.614] (**) Option "_source" "server/udev"
[ 21367.615] (II) event24 - Logitech BRIO: is tagged by udev as: Keyboard
[ 21367.615] (II) event24 - Logitech BRIO: device is a keyboard
[ 21367.615] (II) event24 - Logitech BRIO: device removed
[ 21367.691] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0c:00.3/usb4/4-1/4-1:1.0/input/input26/event24"
[ 21367.691] (II) XINPUT: Adding extended input device "Logitech BRIO" (type: KEYBOARD, id 15)
[ 21367.691] (**) Option "xkb_model" "pc105"
[ 21367.691] (**) Option "xkb_layout" "de"
[ 21367.692] (II) event24 - Logitech BRIO: is tagged by udev as: Keyboard
[ 21367.692] (II) event24 - Logitech BRIO: device is a keyboard
[ 21367.693] (II) config/udev: Adding input device Logitech BRIO Consumer Control (/dev/input/event2)
[ 21367.693] (**) Logitech BRIO Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21367.693] (**) Logitech BRIO Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21367.693] (**) Logitech BRIO Consumer Control: Applying InputClass "system-keyboard"
[ 21367.693] (II) Using input driver 'libinput' for 'Logitech BRIO Consumer Control'
[ 21367.693] (**) Logitech BRIO Consumer Control: always reports core events
[ 21367.693] (**) Option "Device" "/dev/input/event2"
[ 21367.693] (**) Option "_source" "server/udev"
[ 21367.694] (II) event2 - Logitech BRIO Consumer Control: is tagged by udev as: Keyboard
[ 21367.694] (II) event2 - Logitech BRIO Consumer Control: device is a keyboard
[ 21367.694] (II) event2 - Logitech BRIO Consumer Control: device removed
[ 21367.757] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0c:00.3/usb4/4-1/4-1:1.5/0003:046D:085E.0001/input/input2/event2"
[ 21367.757] (II) XINPUT: Adding extended input device "Logitech BRIO Consumer Control" (type: KEYBOARD, id 16)
[ 21367.757] (**) Option "xkb_model" "pc105"
[ 21367.757] (**) Option "xkb_layout" "de"
[ 21367.759] (II) event2 - Logitech BRIO Consumer Control: is tagged by udev as: Keyboard
[ 21367.759] (II) event2 - Logitech BRIO Consumer Control: device is a keyboard
[ 21367.759] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event19)
[ 21367.759] (II) No input driver specified, ignoring this device.
[ 21367.759] (II) This device may have been added with another device file.
[ 21367.760] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event20)
[ 21367.760] (II) No input driver specified, ignoring this device.
[ 21367.760] (II) This device may have been added with another device file.
[ 21367.760] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event21)
[ 21367.760] (II) config/udev: Adding input device HD-Audio Generic Line Out (/dev/input/event22)
[ 21367.760] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event23)
[ 21367.761] (II) config/udev: Adding input device PC Speaker (/dev/input/event12)
[ 21367.761] (II) No input driver specified, ignoring this device.
[ 21367.761] (II) This device may have been added with another device file.
[ 21367.764] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21367.764] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21367.764] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 21367.764] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control'
[ 21367.764] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: always reports core events
[ 21367.764] (**) Option "Device" "/dev/input/event8"
[ 21367.764] (**) Option "_source" "_driver/libinput"
[ 21367.764] (II) libinput: Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: is a virtual subdevice
[ 21367.764] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-10/1-10:1.0/0003:1B1C:1B33.000A/input/input30/event8"
[ 21367.764] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control" (type: KEYBOARD, id 17)
[ 21367.764] (**) Option "xkb_model" "pc105"
[ 21367.764] (**) Option "xkb_layout" "de"
[ 21367.764] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21367.764] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21367.764] (**) Logitech Gaming Mouse G502 Consumer Control: Applying InputClass "system-keyboard"
[ 21367.764] (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G502 Consumer Control'
[ 21367.764] (**) Logitech Gaming Mouse G502 Consumer Control: always reports core events
[ 21367.764] (**) Option "Device" "/dev/input/event6"
[ 21367.764] (II) libinput: Logitech Gaming Mouse G502 Consumer Control: is a virtual subdevice
[ 21367.764] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0c:00.3/usb3/3-2/3-2.2/3-2.2:1.1/0003:046D:C332.0005/input/input6/event6"
[ 21367.764] (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G502 Consumer Control" (type: KEYBOARD, id 18)
[ 21367.765] (II) config/udev: Adding input device Corsair Corsair Gaming K70 LUX RGB Keyboard (/dev/input/event10)
[ 21367.765] (II) No input driver specified, ignoring this device.
[ 21367.765] (II) This device may have been added with another device file.
[ 21367.765] (II) config/udev: removing device Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard
[ 21367.765] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: device removed
[ 21367.794] (II) UnloadModule: "libinput"
[ 21367.795] (II) config/udev: Adding input device Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard (/dev/input/event3)
[ 21367.795] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: Applying InputClass "evdev keyboard catchall"
[ 21367.795] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: Applying InputClass "libinput keyboard catchall"
[ 21367.795] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: Applying InputClass "system-keyboard"
[ 21367.795] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard'
[ 21367.795] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: always reports core events
[ 21367.795] (**) Option "Device" "/dev/input/event3"
[ 21367.795] (**) Option "_source" "server/udev"
[ 21367.797] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: is tagged by udev as: Keyboard
[ 21367.797] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: device is a keyboard
[ 21367.797] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: device removed
[ 21367.830] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-10/1-10:1.0/0003:1B1C:1B33.000A/input/input29/event3"
[ 21367.830] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard" (type: KEYBOARD, id 8)
[ 21367.830] (**) Option "xkb_model" "pc105"
[ 21367.830] (**) Option "xkb_layout" "de"
[ 21367.832] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: is tagged by udev as: Keyboard
[ 21367.832] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: device is a keyboard
[ 21367.833] (II) config/udev: Adding input device Corsair Corsair Gaming K70 LUX RGB Keyboard (/dev/input/event9)
[ 21367.833] (II) No input driver specified, ignoring this device.
[ 21367.833] (II) This device may have been added with another device file.
[ 21367.833] (II) config/udev: removing device Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control
[ 21367.833] (II) UnloadModule: "libinput"
[ 21367.833] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: device removed
[ 21367.864] (II) UnloadModule: "libinput"
[ 21367.865] (II) config/udev: Adding input device Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control (/dev/input/event8)
[ 21367.865] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21367.865] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21367.865] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 21367.865] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control'
[ 21367.865] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: always reports core events
[ 21367.865] (**) Option "Device" "/dev/input/event8"
[ 21367.865] (**) Option "_source" "server/udev"
[ 21367.866] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 21367.866] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: device is a keyboard
[ 21367.866] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: device removed
[ 21367.891] (II) libinput: Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: needs a virtual subdevice
[ 21367.891] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-10/1-10:1.0/0003:1B1C:1B33.000A/input/input30/event8"
[ 21367.891] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control" (type: MOUSE, id 9)
[ 21367.891] (**) Option "AccelerationScheme" "none"
[ 21367.891] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: (accel) selected scheme none/0
[ 21367.891] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 21367.891] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 21367.893] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 21367.893] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: device is a keyboard
[ 21367.893] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 21367.893] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21367.893] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 21367.893] (II) Using input driver 'libinput' for 'Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control'
[ 21367.893] (**) Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: always reports core events
[ 21367.893] (**) Option "Device" "/dev/input/event8"
[ 21367.893] (**) Option "_source" "_driver/libinput"
[ 21367.893] (II) libinput: Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: is a virtual subdevice
[ 21367.893] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-10/1-10:1.0/0003:1B1C:1B33.000A/input/input30/event8"
[ 21367.893] (II) XINPUT: Adding extended input device "Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control" (type: KEYBOARD, id 17)
[ 21367.893] (**) Option "xkb_model" "pc105"
[ 21367.893] (**) Option "xkb_layout" "de"
[ 21367.893] (II) config/udev: removing device Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS
[ 21367.893] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device removed
[ 21367.918] (II) UnloadModule: "libinput"
[ 21367.918] (II) config/udev: Adding input device Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS (/dev/input/event11)
[ 21367.918] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "evdev keyboard catchall"
[ 21367.918] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "libinput keyboard catchall"
[ 21367.918] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: Applying InputClass "system-keyboard"
[ 21367.918] (II) Using input driver 'libinput' for 'Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS'
[ 21367.919] (**) Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: always reports core events
[ 21367.919] (**) Option "Device" "/dev/input/event11"
[ 21367.919] (**) Option "_source" "server/udev"
[ 21367.920] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: is tagged by udev as: Keyboard
[ 21367.920] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device is a keyboard
[ 21367.920] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device removed
[ 21367.944] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:0c:00.3/usb3/3-2/3-2.1/3-2.1:1.1/0003:1B1C:1B3B.000D/input/input33/event11"
[ 21367.944] (II) XINPUT: Adding extended input device "Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS" (type: KEYBOARD, id 10)
[ 21367.944] (**) Option "xkb_model" "pc105"
[ 21367.944] (**) Option "xkb_layout" "de"
[ 21367.946] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: is tagged by udev as: Keyboard
[ 21367.946] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device is a keyboard
[ 21367.947] (EE) Failed to open authorization file "/var/run/sddm/{d958fc6c-f86b-447d-a650-6bf908ba4b66}": No such file or directory
[ 21367.966] (II) event1 - Power Button: device removed
[ 21367.998] (II) event0 - Power Button: device removed
[ 21368.038] (II) event4 - Logitech Gaming Mouse G502: device removed
[ 21368.104] (II) event5 - Logitech Gaming Mouse G502 Keyboard: device removed
[ 21368.144] (II) event7 - Logitech Gaming Mouse G502 System Control: device removed
[ 21368.171] (II) event24 - Logitech BRIO: device removed
[ 21368.224] (II) event2 - Logitech BRIO Consumer Control: device removed
[ 21368.278] (II) event6 - Logitech Gaming Mouse G502 Consumer Control: device removed
[ 21368.305] (II) event3 - Corsair Corsair Gaming K70 LUX RGB Keyboard Keyboard: device removed
[ 21368.331] (II) event8 - Corsair Corsair Gaming K70 LUX RGB Keyboard Consumer Control: device removed
[ 21368.358] (II) event11 - Corsair Components, Inc. Corsair Gaming MM800 RGB POLARIS: device removed
[ 21368.399] (II) UnloadModule: "libinput"
[ 21368.400] (II) UnloadModule: "libinput"
[ 21368.404] (II) Server terminated successfully (0). Closing log file.
