Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: GA-MA770T-UD3 serial: <filter>
BIOS: Award v: F10 date: 03/22/2011
RAM: total: 3.84 GiB used: 1.68 GiB (43.6%)
RAM Report:
Topology: Quad Core model: AMD Athlon II X4 645 bits: 64 type: MCP
arch: K10 rev: 3 L2 cache: 2048 KiB bogomips: 24923
Speed: 800 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800
Flags: 3dnow 3dnowext 3dnowprefetch abm apic clflush cmov cmp_legacy
constant_tsc cpuid cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr
fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext
monitor msr mtrr nonstop_tsc nopl npt nrip_save nx osvw pae pat pdpe1gb
pge pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a svm
svm_lock syscall tsc vme vmmcall wdt
Device-1: NVIDIA G96C [GeForce 9500 GT] driver: nvidia v: 340.108
bus ID: 01:00.0 chip ID: 10de:0640
Display: x11 server: X.Org 1.20.8 driver: nvidia
resolution: 1280x1024~60Hz
OpenGL: renderer: GeForce 9500 GT/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:14.2 chip ID: 1002:4383
Sound Server: ALSA v: k5.6.19-2-MANJARO
Device-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 port: de00 bus ID: 02:06.0 chip ID: 10ec:8139
IF: enp2s6 state: unknown speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 88.02 GiB (9.4%)
ID-1: /dev/sda vendor: Toshiba model: HDWD110 size: 931.51 GiB
speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A8J0 scheme: MBR
Floppy-1: /dev/fd0
Optical-1: /dev/sr0 vendor: _NEC model: DVD_RW ND-4570A rev: 1.02
dev-links: cdrom
ID-1: / size: 915.89 GiB used: 88.02 GiB (9.6%) fs: ext4 dev: /dev/sda1
label: N/A uuid: 0e1d1689-d61a-4d06-b763-ea2cf2f52429
Hub: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub: 3-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub: 4-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub: 5-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub: 6-0:1 info: Full speed (or root) Hub ports: 3 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Device-1: 6-3:2 info: A4Tech USB Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
chip ID: 09da:c10a
Hub: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
System Temperatures: cpu: 26.0 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 173 Uptime: 26m Init: systemd v: 245 Compilers: gcc: 10.1.0
Shell: bash v: 5.0.18 running in: xfce4-terminal inxi: 3.0.37
dmesg :
dmesg: read kernel buffer failed: Operation not permitted
journalctl
-- Logs begin at Mon 2020-08-03 10:24:43 EEST, end at Sat 2020-08-08 10:56:41 E>
авг 03 10:24:43 zumaha-pc kernel: Linux version 5.6.15-1-MANJARO (builder@601a6>
авг 03 10:24:43 zumaha-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.6-x8>
авг 03 10:24:43 zumaha-pc kernel: KERNEL supported cpus:
авг 03 10:24:43 zumaha-pc kernel: Intel GenuineIntel
авг 03 10:24:43 zumaha-pc kernel: AMD AuthenticAMD
авг 03 10:24:43 zumaha-pc kernel: Hygon HygonGenuine
авг 03 10:24:43 zumaha-pc kernel: Centaur CentaurHauls
авг 03 10:24:43 zumaha-pc kernel: zhaoxin Shanghai
авг 03 10:24:43 zumaha-pc kernel: x86/fpu: x87 FPU will use FXSAVE
авг 03 10:24:43 zumaha-pc kernel: BIOS-provided physical RAM map:
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x0000000000000000-0x00000000>
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x000000000009f800-0x00000000>
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x00000000000f0000-0x00000000>
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000>
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x00000000cfdf0000-0x00000000>
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x00000000cfdf3000-0x00000000>
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x00000000cfe00000-0x00000000>
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000>
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000>
авг 03 10:24:43 zumaha-pc kernel: BIOS-e820: [mem 0x0000000100000000-0x00000001>
авг 03 10:24:43 zumaha-pc kernel: NX (Execute Disable) protection: active
авг 03 10:24:43 zumaha-pc kernel: SMBIOS 2.4 present.
lines 1-23
dmesg | grep sd
dmesg | grep usb
dmesg | grep eth
journalctl -p3 -b -1
-- Logs begin at Mon 2020-08-03 10:24:43 EEST, end at Sat 2020-08-08 10:59:41 E>
авг 08 10:20:51 zumaha-pc kernel: do_IRQ: 1.55 No irq handler for vector
авг 08 10:20:51 zumaha-pc kernel: do_IRQ: 2.55 No irq handler for vector
авг 08 10:20:51 zumaha-pc kernel: do_IRQ: 3.55 No irq handler for vector
авг 08 10:20:51 zumaha-pc kernel: ACPI Error: AE_NOT_FOUND, While resolving a n>
ESCOC
EEST, end at Sat 2020-08-08 10:59:41 EEST. --
rror: AE_NOT_FOUND, While resolving a named reference package element - LNKC (2>
rror: AE_NOT_FOUND, While resolving a named reference package element - LNKD (2>
rror: AE_NOT_FOUND, While resolving a named reference package element - LNKA (2>
rror: AE_NOT_FOUND, While resolving a named reference package element - LNKB (2>
ESCOC
ST. --
med reference package element - LNKC (20200110/dspkginit-438)
med reference package element - LNKD (20200110/dspkginit-438)
med reference package element - LNKA (20200110/dspkginit-438)
med reference package element - LNKB (20200110/dspkginit-438)
ESCOC
ESCOC
ESCOC
ESCOC
ESCOD
ESCOD
ESCOD
ESCOD
ST. --
ESCOD
ESCOD
ESCOD
ESCOD
ESCOD
ESCOD
ESCOD
ESCOD
ESCOD
ESCOD
авг 08 10:20:51 zumaha-pc kernel: usb usb5-port3: Cannot enable. Maybe the USB >
авг 08 10:20:51 zumaha-pc kernel: usb usb5-port3: unable to enumerate USB device
авг 08 10:21:20 zumaha-pc esets_mac[760]: error[02f80000]: Cannot block removab>
авг 08 10:25:48 zumaha-pc lightdm[958]: gkr-pam: unable to locate daemon contro>
авг 08 10:26:10 zumaha-pc colord-sane[1213]: io/hpmud/pp.c 627: unable to read >
авг 08 10:27:41 zumaha-pc kernel: irq 22: nobody cared (try booting with the "i>
авг 08 10:27:41 zumaha-pc kernel: handlers:
авг 08 10:27:41 zumaha-pc kernel: [<000000002c541b95>] ahci_single_level_irq_in>
авг 08 10:27:41 zumaha-pc kernel: Disabling IRQ #22
lines 38-60/60 (END)
journalctl -p2 -b -0
-- Logs begin at Mon 2020-08-03 10:24:43 EEST, end at Sat 2020-08-08 11:01:11 E>
авг 08 10:28:59 zumaha-pc kernel: do_IRQ: 1.55 No irq handler for vector
авг 08 10:28:59 zumaha-pc kernel: do_IRQ: 2.55 No irq handler for vector
авг 08 10:28:59 zumaha-pc kernel: do_IRQ: 3.55 No irq handler for vector
ESCOC
EEST, end at Sat 2020-08-08 11:01:11 EEST. --
ESCOC
ST. --
ESCOC
ESCOC
ESCOC
ESCOC
lines 1-4/4 (END)
