Here's some more info:
inxi -Fxxxz has the following output:
Host: johndoe Kernel: 4.19.2-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 8.2.1 Desktop: Gnome 3.30.1 wm: gnome-shell dm: GDM 3.30.2
Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 5559 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0K64R6 v: A00 serial: <filter> UEFI: Dell v: 1.4.1
date: 12/08/2017
ID-1: BAT0 charge: 17.4 Wh condition: 17.4/41.4 Wh (42%) volts: 17.0/14.8
model: SMP DELL VN3N047 type: Li-ion serial: <filter> status: Full
Topology: Dual Core model: Intel Core i7-6500U bits: 64 type: MT MCP
arch: Skylake rev: 3 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20744
Speed: 3000 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3001 2: 3075
3: 2999 4: 3099
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:1916
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / R7
M520]
vendor: Dell driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:6660
Display: x11 server: X.Org 1.20.3 driver: radeon compositor: gnome-shell
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
v: 4.5 Mesa 18.2.5 compat-v: 3.0 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d70
Sound Server: ALSA v: k4.19.2-1-MANJARO
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: e000
bus ID: 02:00.0 chip ID: 8086:08b3
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8136
Local Storage: total: 931.51 GiB used: 49.74 GiB (5.3%)
ID-1: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter> rev: 022 scheme: GPT
ID-1: / size: 95.62 GiB used: 6.97 GiB (7.3%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 819.48 GiB used: 42.77 GiB (5.2%) fs: ext4
dev: /dev/sda1
System Temperatures: cpu: 61.0 C mobo: 40.0 C sodimm: 31.0 C gpu: radeon
temp: 44 C
Fan Speeds (RPM): cpu: 2271
Processes: 230 Uptime: 4m Memory: 15.56 GiB used: 1.43 GiB (9.2%)
Init: systemd v: 239 Compilers: gcc: 8.2.1 Shell: bash v: 4.4.23
running in: gnome-terminal inxi: 3.0.27
dmesg has the following output:
[ 0.000000] microcode: microcode updated early to revision 0xc6, date = 2018-04-17
[ 0.000000] Linux version 4.19.2-1-MANJARO (builduser@development) (gcc version 8.2.1 20180831 (GCC)) #1 SMP PREEMPT Tue Nov 13 22:35:25 UTC 2018
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=1dd2f4c0-4ad5-4891-be00-23480ab3a05b rw
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000006a3bcfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000006a3bd000-0x000000006a3bdfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000006a3be000-0x000000006a3e7fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000006a3e8000-0x000000006a449fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000006a44a000-0x000000006abf9fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000006abfa000-0x0000000076c10fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000076c11000-0x0000000076c7cfff] type 20
[ 0.000000] BIOS-e820: [mem 0x0000000076c7d000-0x0000000077628fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000077629000-0x0000000077f98fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000077f99000-0x0000000077ffdfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000077ffe000-0x0000000077ffefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000078000000-0x00000000780fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x0000000482ffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.40 by American Megatrends
[ 0.000000] efi: ACPI=0x77fd4000 ACPI 2.0=0x77fd4000 SMBIOS=0xf05e0 ESRT=0x76fe8598 MPS=0xfcbe0
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: Dell Inc. Inspiron 5559/0K64R6, BIOS 1.4.1 12/08/2017
[ 0.000000] tsc: Detected 2600.000 MHz processor
[ 0.001676] tsc: Detected 2592.000 MHz TSC
[ 0.001676] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001678] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001685] last_pfn = 0x483000 max_arch_pfn = 0x400000000
[ 0.001687] MTRR default type: write-back
[ 0.001688] MTRR fixed ranges enabled:
[ 0.001689] 00000-9FFFF write-back
[ 0.001690] A0000-BFFFF uncachable
[ 0.001691] C0000-FFFFF write-protect
[ 0.001691] MTRR variable ranges enabled:
[ 0.001692] 0 base 0080000000 mask 7F80000000 uncachable
[ 0.001693] 1 base 007C000000 mask 7FFC000000 uncachable
[ 0.001694] 2 base 007A000000 mask 7FFE000000 uncachable
[ 0.001694] 3 base 0079800000 mask 7FFF800000 uncachable
[ 0.001695] 4 disabled
[ 0.001695] 5 disabled
[ 0.001696] 6 disabled
[ 0.001696] 7 disabled
[ 0.001696] 8 disabled
[ 0.001697] 9 disabled
[ 0.002660] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002899] last_pfn = 0x77fff max_arch_pfn = 0x400000000
[ 0.009228] found SMP MP-table at [mem 0x000fce10-0x000fce1f] mapped at [(____ptrval____)]
[ 0.009241] esrt: Reserving ESRT space from 0x0000000076fe8598 to 0x0000000076fe85d0.
[ 0.009248] Scanning 1 areas for low memory corruption
[ 0.009249] Base memory trampoline at [(____ptrval____)] 96000 size 24576
[ 0.009252] Using GB pages for direct mapping
[ 0.009253] BRK [0x11bc01000, 0x11bc01fff] PGTABLE
[ 0.009255] BRK [0x11bc02000, 0x11bc02fff] PGTABLE
[ 0.009255] BRK [0x11bc03000, 0x11bc03fff] PGTABLE
[ 0.009285] BRK [0x11bc04000, 0x11bc04fff] PGTABLE
[ 0.009287] BRK [0x11bc05000, 0x11bc05fff] PGTABLE
[ 0.009428] BRK [0x11bc06000, 0x11bc06fff] PGTABLE
[ 0.009460] BRK [0x11bc07000, 0x11bc07fff] PGTABLE
[ 0.009489] BRK [0x11bc08000, 0x11bc08fff] PGTABLE
[ 0.009533] BRK [0x11bc09000, 0x11bc09fff] PGTABLE
[ 0.009582] BRK [0x11bc0a000, 0x11bc0afff] PGTABLE
[ 0.009630] BRK [0x11bc0b000, 0x11bc0bfff] PGTABLE
[ 0.009672] Secure boot could not be determined
[ 0.009673] RAMDISK: [mem 0x36d5d000-0x376a5fff]
[ 0.009678] ACPI: Early table checksum verification disabled
[ 0.009680] ACPI: RSDP 0x0000000077FD4000 000024 (v02 DELL )
[ 0.009683] ACPI: XSDT 0x0000000077FD40B8 0000F4 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.009688] ACPI: FACP 0x0000000077FF1C90 00010C (v05 DELL CBX3 01072009 AMI 00010013)
[ 0.009692] ACPI: DSDT 0x0000000077FD4240 01DA4C (v02 DELL CBX3 01072009 INTL 20120913)
[ 0.009694] ACPI: FACS 0x0000000077F97F80 000040
[ 0.009696] ACPI: APIC 0x0000000077FF1DA0 000084 (v03 DELL CBX3 01072009 AMI 00010013)
[ 0.009699] ACPI: FPDT 0x0000000077FF1E28 000044 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.009701] ACPI: FIDT 0x0000000077FF1E70 00009C (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.009703] ACPI: MCFG 0x0000000077FF1F10 00003C (v01 DELL CBX3 01072009 MSFT 00000097)
[ 0.009705] ACPI: HPET 0x0000000077FF1F50 000038 (v01 DELL CBX3 01072009 AMI. 0005000B)
[ 0.009707] ACPI: SSDT 0x0000000077FF1F88 000315 (v01 SataRe SataTabl 00001000 INTL 20120913)
[ 0.009710] ACPI: LPIT 0x0000000077FF22A0 000094 (v01 INTEL SKL-ULT 00000000 MSFT 0000005F)
[ 0.009712] ACPI: SSDT 0x0000000077FF2338 000248 (v02 INTEL sensrhub 00000000 INTL 20120913)
[ 0.009714] ACPI: SSDT 0x0000000077FF2580 002BAE (v02 INTEL PtidDevc 00001000 INTL 20120913)
[ 0.009717] ACPI: SSDT 0x0000000077FF5130 000C45 (v02 INTEL Ther_Rvp 00001000 INTL 20120913)
[ 0.009719] ACPI: DBGP 0x0000000077FF5D78 000034 (v01 INTEL 00000000 MSFT 0000005F)
[ 0.009721] ACPI: DBG2 0x0000000077FF5DB0 000054 (v00 INTEL 00000000 MSFT 0000005F)
[ 0.009723] ACPI: SSDT 0x0000000077FF5E08 000740 (v02 INTEL xh_rvp07 00000000 INTL 20120913)
[ 0.009726] ACPI: BOOT 0x0000000077FF6548 000028 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.009728] ACPI: SSDT 0x0000000077FF6570 003531 (v02 SaSsdt SaSsdt 00003000 INTL 20120913)
[ 0.009730] ACPI: UEFI 0x0000000077FF9AA8 000042 (v01 00000000 00000000)
[ 0.009733] ACPI: SSDT 0x0000000077FF9AF0 000E58 (v02 CpuRef CpuSsdt 00003000 INTL 20120913)
[ 0.009735] ACPI: MSDM 0x0000000077FFA948 000055 (v03 DELL CBX3 06222004 AMI 00010013)
[ 0.009737] ACPI: SLIC 0x0000000077FFA9A0 000176 (v03 DELL CBX3 01072009 MSFT 00010013)
[ 0.009739] ACPI: BGRT 0x0000000077FFAB18 000038 (v00 \xf3\xee 01072009 AMI 00010013)
[ 0.009742] ACPI: SSDT 0x0000000077FFAB50 000527 (v02 SgRef SgPch 00001000 INTL 20120913)
[ 0.009744] ACPI: DMAR 0x0000000077FFB078 0000F0 (v01 INTEL SKL 00000001 INTL 00000001)
[ 0.009746] ACPI: TPM2 0x0000000077FFB168 000034 (v03 Tpm2Tabl 00000001 AMI 00000000)
[ 0.009749] ACPI: SSDT 0x0000000077FFB1A0 000DC8 (v01 AmdRef AmdTabl 00001000 INTL 20120913)
[ 0.009751] ACPI: ASF! 0x0000000077FFBF68 0000A5 (v32 INTEL HCG 00000001 TFSM 000F4240)
[ 0.009758] ACPI: Local APIC address 0xfee00000
[ 0.009918] No NUMA configuration found
[ 0.009919] Faking a node at [mem 0x0000000000000000-0x0000000482ffffff]
[ 0.009922] NODE_DATA(0) allocated [mem 0x482ffc000-0x482ffffff]
[ 0.009941] Zone ranges:
[ 0.009942] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.009943] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.009944] Normal [mem 0x0000000100000000-0x0000000482ffffff]
[ 0.009945] Device empty
[ 0.009946] Movable zone start for each node
[ 0.009946] Early memory node ranges
[ 0.009947] node 0: [mem 0x0000000000001000-0x0000000000057fff]
[ 0.009947] node 0: [mem 0x0000000000059000-0x000000000009efff]
[ 0.009948] node 0: [mem 0x0000000000100000-0x000000006a3bcfff]
[ 0.009948] node 0: [mem 0x000000006a3e8000-0x000000006a449fff]
[ 0.009949] node 0: [mem 0x000000006abfa000-0x0000000076c10fff]
[ 0.009949] node 0: [mem 0x0000000077ffe000-0x0000000077ffefff]
[ 0.009950] node 0: [mem 0x0000000100000000-0x0000000482ffffff]
[ 0.010037] Reserved but unavailable: 7212 pages
[ 0.010038] Initmem setup node 0 [mem 0x0000000000001000-0x0000000482ffffff]
[ 0.010039] On node 0 totalpages: 4166612
[ 0.010040] DMA zone: 64 pages used for memmap
[ 0.010041] DMA zone: 26 pages reserved
[ 0.010041] DMA zone: 3997 pages, LIFO batch:0
[ 0.010108] DMA32 zone: 7505 pages used for memmap
[ 0.010109] DMA32 zone: 480311 pages, LIFO batch:63
[ 0.019002] Normal zone: 57536 pages used for memmap
[ 0.019002] Normal zone: 3682304 pages, LIFO batch:63
[ 0.078352] Reserving Intel graphics memory at [mem 0x7a000000-0x7bffffff]
[ 0.078598] ACPI: PM-Timer IO Port: 0x1808
[ 0.078600] ACPI: Local APIC address 0xfee00000
[ 0.078604] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.078605] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.078605] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.078606] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.078632] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.078634] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.078635] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.078636] ACPI: IRQ0 used by override.
[ 0.078636] ACPI: IRQ9 used by override.
[ 0.078638] Using ACPI (MADT) for SMP configuration information
[ 0.078639] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.078645] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.078659] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.078660] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[ 0.078661] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.078662] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.078663] PM: Registered nosave memory: [mem 0x6a3bd000-0x6a3bdfff]
[ 0.078663] PM: Registered nosave memory: [mem 0x6a3be000-0x6a3e7fff]
[ 0.078664] PM: Registered nosave memory: [mem 0x6a44a000-0x6abf9fff]
[ 0.078665] PM: Registered nosave memory: [mem 0x76c11000-0x76c7cfff]
[ 0.078666] PM: Registered nosave memory: [mem 0x76c7d000-0x77628fff]
[ 0.078666] PM: Registered nosave memory: [mem 0x77629000-0x77f98fff]
[ 0.078667] PM: Registered nosave memory: [mem 0x77f99000-0x77ffdfff]
[ 0.078668] PM: Registered nosave memory: [mem 0x77fff000-0x77ffffff]
[ 0.078668] PM: Registered nosave memory: [mem 0x78000000-0x780fffff]
[ 0.078668] PM: Registered nosave memory: [mem 0x78100000-0x79ffffff]
[ 0.078669] PM: Registered nosave memory: [mem 0x7a000000-0x7bffffff]
[ 0.078669] PM: Registered nosave memory: [mem 0x7c000000-0xdfffffff]
[ 0.078670] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.078670] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.078671] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.078671] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[ 0.078672] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.078672] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[ 0.078672] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.078673] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.078673] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.078675] [mem 0x7c000000-0xdfffffff] available for PCI devices
[ 0.078676] Booting paravirtualized kernel on bare hardware
[ 0.078677] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.163599] random: get_random_bytes called from start_kernel+0x95/0x53f with crng_init=0
[ 0.163604] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.163731] percpu: Embedded 46 pages/cpu @(____ptrval____) s151552 r8192 d28672 u524288
[ 0.163736] pcpu-alloc: s151552 r8192 d28672 u524288 alloc=1*2097152
[ 0.163737] pcpu-alloc: [0] 0 1 2 3
[ 0.163752] Built 1 zonelists, mobility grouping on. Total pages: 4101481
[ 0.163753] Policy zone: Normal
[ 0.163754] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=1dd2f4c0-4ad5-4891-be00-23480ab3a05b rw
[ 0.166651] Calgary: detecting Calgary via BIOS EBDA area
[ 0.166652] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.198570] Memory: 16072068K/16666448K available (12300K kernel code, 1383K rwdata, 3688K rodata, 1536K init, 3804K bss, 594380K reserved, 0K cma-reserved)
[ 0.198645] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.198649] Kernel/User page tables isolation: enabled
[ 0.205029] ftrace: allocating 36074 entries in 141 pages
[ 0.216457] rcu: Preemptible hierarchical RCU implementation.
[ 0.216458] rcu: CONFIG_RCU_FANOUT set to non-default value of 32.
[ 0.216458] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.216459] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.216459] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.216460] Tasks RCU enabled.
[ 0.216461] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.217800] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[ 0.217991] rcu: Offload RCU callbacks from CPUs: (none).
[ 0.218102] Console: colour dummy device 80x25
[ 0.218106] console [tty0] enabled
[ 0.218117] ACPI: Core revision 20180810
[ 0.218400] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.218430] hpet clockevent registered
[ 0.218483] APIC: Switch to symmetric I/O mode setup
[ 0.218484] DMAR: Host address width 39
[ 0.218485] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.218489] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
[ 0.218490] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.218493] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.218494] DMAR: RMRR base: 0x0000007758b000 end: 0x000000775aafff
[ 0.218494] DMAR: RMRR base: 0x00000079800000 end: 0x0000007bffffff
[ 0.218498] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[ 0.218499] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[ 0.218500] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.218501] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.218501] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[ 0.218502] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[ 0.220006] DMAR-IR: Enabled IRQ remapping in xapic mode
[ 0.220007] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.223916] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.238439] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x255cb6cc5db, max_idle_ns: 440795203504 ns
[ 0.238449] Calibrating delay loop (skipped), value calculated using timer frequency.. 5186.00 BogoMIPS (lpj=8640000)
[ 0.238450] pid_max: default: 32768 minimum: 301
[ 0.239271] Security Framework initialized
[ 0.239272] Yama: becoming mindful.
[ 0.239276] AppArmor: AppArmor disabled by boot time parameter
[ 0.240865] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.241661] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.241692] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.241718] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.241877] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.241877] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.241882] mce: CPU supports 8 MCE banks
[ 0.241888] CPU0: Thermal monitoring enabled (TM1)
[ 0.241899] process: using mwait in idle threads
[ 0.241901] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.241902] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.241903] Spectre V2 : Mitigation: Full generic retpoline
[ 0.241903] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.241904] Spectre V2 : Spectre v2 mitigation: Enabling Indirect Branch Prediction Barrier
[ 0.241904] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.241905] Spectre V2 : Spectre v2 cross-process SMT mitigation: Enabling STIBP
[ 0.241906] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.245077] Freeing SMP alternatives memory: 28K
[ 0.252072] TSC deadline timer enabled
[ 0.252076] smpboot: CPU0: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz (family: 0x6, model: 0x4e, stepping: 0x3)
[ 0.271811] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.271836] ... version: 4
[ 0.271837] ... bit width: 48
[ 0.271837] ... generic registers: 4
[ 0.271838] ... value mask: 0000ffffffffffff
[ 0.271838] ... max period: 00007fffffffffff
[ 0.271839] ... fixed-purpose events: 3
[ 0.271839] ... event mask: 000000070000000f
[ 0.278457] rcu: Hierarchical SRCU implementation.
[ 0.301881] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.308481] smp: Bringing up secondary CPUs ...
[ 0.348482] x86: Booting SMP configuration:
[ 0.348483] .... node #0, CPUs: #1 #2 #3
[ 0.428867] smp: Brought up 1 node, 4 CPUs
[ 0.428867] smpboot: Max logical packages: 1
[ 0.428867] smpboot: Total of 4 processors activated (20744.00 BogoMIPS)
[ 0.432117] devtmpfs: initialized
[ 0.432117] x86/mm: Memory block size: 128MB
[ 0.432863] PM: Registering ACPI NVS region [mem 0x6a3bd000-0x6a3bdfff] (4096 bytes)
[ 0.432863] PM: Registering ACPI NVS region [mem 0x77629000-0x77f98fff] (9895936 bytes)
[ 0.432863] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.432863] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.432863] pinctrl core: initialized pinctrl subsystem
[ 0.432863] RTC time: 11:33:43, date: 11/18/18
[ 0.432863] NET: Registered protocol family 16
[ 0.432863] audit: initializing netlink subsys (disabled)
[ 0.432863] audit: type=2000 audit(1542540823.216:1): state=initialized audit_enabled=0 res=1
[ 0.432863] cpuidle: using governor ladder
[ 0.432863] cpuidle: using governor menu
[ 0.432863] Simple Boot Flag at 0x47 set to 0x80
[ 0.432863] KVM setup pv remote TLB flush
[ 0.432863] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.432863] ACPI: bus type PCI registered
[ 0.432863] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.432863] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.432863] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.432863] PCI: Using configuration type 1 for base access
[ 0.435524] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.435524] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.435524] ACPI: Added _OSI(Module Device)
[ 0.435524] ACPI: Added _OSI(Processor Device)
[ 0.435524] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.435524] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.435524] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.435524] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.468597] ACPI: 10 ACPI AML tables successfully acquired and loaded
[ 0.475059] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.484225] ACPI: Dynamic OEM Table Load:
[ 0.484231] ACPI: SSDT 0xFFFF91237067D800 000660 (v02 PmRef Cpu0Ist 00003000 INTL 20120913)
[ 0.484731] ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
[ 0.486094] ACPI: Dynamic OEM Table Load:
[ 0.486098] ACPI: SSDT 0xFFFF9123701D4000 00037F (v02 PmRef Cpu0Cst 00003001 INTL 20120913)
[ 0.487201] ACPI: Dynamic OEM Table Load:
[ 0.487206] ACPI: SSDT 0xFFFF91237067B800 0005AA (v02 PmRef ApIst 00003000 INTL 20120913)
[ 0.487937] ACPI: Dynamic OEM Table Load:
[ 0.487941] ACPI: SSDT 0xFFFF91237021EA00 000119 (v02 PmRef ApCst 00003000 INTL 20120913)
[ 0.490146] ACPI: EC: EC started
[ 0.490147] ACPI: EC: interrupt blocked
[ 0.492382] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as first EC
[ 0.492384] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x45, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.492386] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as boot DSDT EC to handle transactions
[ 0.492386] ACPI: Interpreter enabled
[ 0.492422] ACPI: (supports S0 S3 S4 S5)
[ 0.492423] ACPI: Using IOAPIC for interrupt routing
[ 0.492459] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.493099] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.494791] ACPI: Power Resource [PG00] (on)
[ 0.495153] ACPI: Power Resource [PG01] (on)
[ 0.495493] ACPI: Power Resource [PG02] (on)
[ 0.496908] ACPI: Power Resource [WRST] (off)
[ 0.497253] ACPI: Power Resource [WRST] (off)
[ 0.497600] ACPI: Power Resource [WRST] (off)
[ 0.497949] ACPI: Power Resource [WRST] (off)
[ 0.498300] ACPI: Power Resource [WRST] (off)
[ 0.498349] ACPI: Power Resource [PC09] (on)
[ 0.499422] ACPI: Power Resource [WRST] (off)
[ 0.499766] ACPI: Power Resource [WRST] (off)
[ 0.500116] ACPI: Power Resource [WRST] (off)
[ 0.500763] ACPI: Power Resource [WRST] (off)
[ 0.501120] ACPI: Power Resource [WRST] (off)
[ 0.501467] ACPI: Power Resource [WRST] (off)
[ 0.501829] ACPI: Power Resource [WRST] (off)
[ 0.502187] ACPI: Power Resource [WRST] (off)
[ 0.502530] ACPI: Power Resource [WRST] (off)
[ 0.502882] ACPI: Power Resource [WRST] (off)
[ 0.503236] ACPI: Power Resource [WRST] (off)
[ 0.503589] ACPI: Power Resource [WRST] (off)
[ 0.503938] ACPI: Power Resource [WRST] (off)
[ 0.504282] ACPI: Power Resource [WRST] (off)
[ 0.516499] ACPI: Power Resource [FN00] (off)
[ 0.516568] ACPI: Power Resource [FN01] (off)
[ 0.516637] ACPI: Power Resource [FN02] (off)
[ 0.516707] ACPI: Power Resource [FN03] (off)
[ 0.516773] ACPI: Power Resource [FN04] (off)
[ 0.518035] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.518041] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.518080] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[ 0.518867] PCI host bridge to bus 0000:00
[ 0.518869] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.518871] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.518872] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.518873] pci_bus 0000:00: root bus resource [mem 0x7c000000-0xdfffffff window]
[ 0.518874] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[ 0.518875] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.518882] pci 0000:00:00.0: [8086:1904] type 00 class 0x060000
[ 0.519005] pci 0000:00:02.0: [8086:1916] type 00 class 0x030000
[ 0.519014] pci 0000:00:02.0: reg 0x10: [mem 0xde000000-0xdeffffff 64bit]
[ 0.519019] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
[ 0.519022] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
[ 0.519035] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.519213] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[ 0.519235] pci 0000:00:14.0: reg 0x10: [mem 0xdf310000-0xdf31ffff 64bit]
[ 0.519303] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.519442] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[ 0.519463] pci 0000:00:14.2: reg 0x10: [mem 0xdf330000-0xdf330fff 64bit]
[ 0.519718] pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000
[ 0.519982] pci 0000:00:15.0: reg 0x10: [mem 0xdf32f000-0xdf32ffff 64bit]
[ 0.521016] pci 0000:00:15.1: [8086:9d61] type 00 class 0x118000
[ 0.521279] pci 0000:00:15.1: reg 0x10: [mem 0xdf32e000-0xdf32efff 64bit]
[ 0.522245] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[ 0.522272] pci 0000:00:16.0: reg 0x10: [mem 0xdf32d000-0xdf32dfff 64bit]
[ 0.522347] pci 0000:00:16.0: PME# supported from D3hot
[ 0.522499] pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601
[ 0.522517] pci 0000:00:17.0: reg 0x10: [mem 0xdf328000-0xdf329fff]
[ 0.522525] pci 0000:00:17.0: reg 0x14: [mem 0xdf32c000-0xdf32c0ff]
[ 0.522533] pci 0000:00:17.0: reg 0x18: [io 0xf090-0xf097]
[ 0.522540] pci 0000:00:17.0: reg 0x1c: [io 0xf080-0xf083]
[ 0.522547] pci 0000:00:17.0: reg 0x20: [io 0xf060-0xf07f]
[ 0.522555] pci 0000:00:17.0: reg 0x24: [mem 0xdf32b000-0xdf32b7ff]
[ 0.522597] pci 0000:00:17.0: PME# supported from D3hot
[ 0.522746] pci 0000:00:1c.0: [8086:9d10] type 01 class 0x060400
[ 0.522816] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.523000] pci 0000:00:1c.4: [8086:9d14] type 01 class 0x060400
[ 0.523070] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.523242] pci 0000:00:1c.5: [8086:9d15] type 01 class 0x060400
[ 0.523312] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.523497] pci 0000:00:1f.0: [8086:9d48] type 00 class 0x060100
[ 0.523736] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[ 0.523750] pci 0000:00:1f.2: reg 0x10: [mem 0xdf324000-0xdf327fff]
[ 0.523917] pci 0000:00:1f.3: [8086:9d70] type 00 class 0x040300
[ 0.523942] pci 0000:00:1f.3: reg 0x10: [mem 0xdf320000-0xdf323fff 64bit]
[ 0.523968] pci 0000:00:1f.3: reg 0x20: [mem 0xdf300000-0xdf30ffff 64bit]
[ 0.524016] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.524214] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
[ 0.524274] pci 0000:00:1f.4: reg 0x10: [mem 0xdf32a000-0xdf32a0ff 64bit]
[ 0.524343] pci 0000:00:1f.4: reg 0x20: [io 0xf040-0xf05f]
[ 0.524594] pci 0000:01:00.0: [1002:6660] type 00 class 0x038000
[ 0.524618] pci 0000:01:00.0: reg 0x10: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.524630] pci 0000:01:00.0: reg 0x18: [mem 0xdf200000-0xdf23ffff 64bit]
[ 0.524637] pci 0000:01:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.524652] pci 0000:01:00.0: reg 0x30: [mem 0xdf240000-0xdf25ffff pref]
[ 0.524659] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
[ 0.524661] pci 0000:01:00.0: enabling Extended Tags
[ 0.524713] pci 0000:01:00.0: supports D1 D2
[ 0.524714] pci 0000:01:00.0: PME# supported from D1 D2 D3hot
[ 0.524744] pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8 GT/s x4 link at 0000:00:1c.0 (capable of 63.008 Gb/s with 8 GT/s x8 link)
[ 0.524795] pci 0000:00:1c.0: ASPM: current common clock configuration is broken, reconfiguring
[ 0.531791] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.531794] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.531796] pci 0000:00:1c.0: bridge window [mem 0xdf200000-0xdf2fffff]
[ 0.531800] pci 0000:00:1c.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.532032] pci 0000:02:00.0: [8086:08b3] type 00 class 0x028000
[ 0.532133] pci 0000:02:00.0: reg 0x10: [mem 0xdf100000-0xdf101fff 64bit]
[ 0.532348] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.532421] pci 0000:02:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x1 link at 0000:00:1c.4 (capable of 7.876 Gb/s with 8 GT/s x1 link)
[ 0.532783] pci 0000:00:1c.4: PCI bridge to [bus 02]
[ 0.532787] pci 0000:00:1c.4: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.532880] pci 0000:03:00.0: [10ec:8136] type 00 class 0x020000
[ 0.532918] pci 0000:03:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.532948] pci 0000:03:00.0: reg 0x18: [mem 0xdf000000-0xdf000fff 64bit]
[ 0.532965] pci 0000:03:00.0: reg 0x20: [mem 0xd0000000-0xd0003fff 64bit pref]
[ 0.533072] pci 0000:03:00.0: supports D1 D2
[ 0.533073] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.533270] pci 0000:00:1c.5: PCI bridge to [bus 03]
[ 0.533273] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.533275] pci 0000:00:1c.5: bridge window [mem 0xdf000000-0xdf0fffff]
[ 0.533279] pci 0000:00:1c.5: bridge window [mem 0xd0000000-0xd00fffff 64bit pref]
[ 0.535366] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.535425] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.535483] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.535539] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.535596] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.535652] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.535709] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.535765] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.537678] ACPI: EC: interrupt unblocked
[ 0.537838] ACPI: EC: event unblocked
[ 0.537861] ACPI: \_SB_.PCI0.LPCB.ECDV: GPE=0x45, EC_CMD/EC_SC=0x934, EC_DATA=0x930
[ 0.537863] ACPI: \_SB_.PCI0.LPCB.ECDV: Used as boot DSDT EC to handle transactions and events
[ 0.538722] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.538722] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.538722] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.538722] vgaarb: loaded
[ 0.538722] ACPI: bus type USB registered
[ 0.538722] usbcore: registered new interface driver usbfs
[ 0.538722] usbcore: registered new interface driver hub
[ 0.538723] usbcore: registered new device driver usb
[ 0.538723] pps_core: LinuxPPS API ver. 1 registered
[ 0.538723] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.538723] PTP clock support registered
[ 0.538723] EDAC MC: Ver: 3.0.0
[ 0.539068] Registered efivars operations
[ 0.545194] PCI: Using ACPI for IRQ routing
[ 0.571315] PCI: pci_cache_line_size set to 64 bytes
[ 0.571700] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[ 0.571701] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.571702] e820: reserve RAM buffer [mem 0x6a3bd000-0x6bffffff]
[ 0.571702] e820: reserve RAM buffer [mem 0x6a44a000-0x6bffffff]
[ 0.571703] e820: reserve RAM buffer [mem 0x76c11000-0x77ffffff]
[ 0.571704] e820: reserve RAM buffer [mem 0x77fff000-0x77ffffff]
[ 0.571705] e820: reserve RAM buffer [mem 0x483000000-0x483ffffff]
[ 0.571777] NetLabel: Initializing
[ 0.571778] NetLabel: domain hash size = 128
[ 0.571778] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.571792] NetLabel: unlabeled traffic allowed by default
[ 0.575475] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.575480] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.577518] clocksource: Switched to clocksource tsc-early
[ 0.584075] VFS: Disk quotas dquot_6.6.0
[ 0.584087] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.584140] pnp: PnP ACPI init
[ 0.584377] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.584379] system 00:00: [io 0xffff] has been reserved
[ 0.584380] system 00:00: [io 0xffff] has been reserved
[ 0.584381] system 00:00: [io 0xffff] has been reserved
[ 0.584382] system 00:00: [io 0x1800-0x18fe] has been reserved
[ 0.584383] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.584387] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.584477] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.584514] system 00:02: [io 0x1854-0x1857] has been reserved
[ 0.584517] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.584543] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.584559] pnp 00:04: Plug and Play ACPI device, IDs DLLb6b2 PNP0f13 (active)
[ 0.584788] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.584789] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.584790] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.584792] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.584793] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.584794] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.584796] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.584797] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.584802] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.584803] system 00:05: [mem 0xdffe0000-0xdfffffff] has been reserved
[ 0.584806] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.584845] system 00:06: [mem 0xfd000000-0xfdabffff] has been reserved
[ 0.584846] system 00:06: [mem 0xfdad0000-0xfdadffff] has been reserved
[ 0.584847] system 00:06: [mem 0xfdb00000-0xfdffffff] has been reserved
[ 0.584849] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.584850] system 00:06: [mem 0xfe036000-0xfe03bfff] has been reserved
[ 0.584851] system 00:06: [mem 0xfe03d000-0xfe3fffff] has been reserved
[ 0.584852] system 00:06: [mem 0xfe410000-0xfe7fffff] has been reserved
[ 0.584855] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.585979] system 00:07: [mem 0xfe029000-0xfe029fff] has been reserved
[ 0.585980] system 00:07: [mem 0xfe028000-0xfe028fff] has been reserved
[ 0.585983] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.592790] pnp: PnP ACPI: found 8 devices
[ 0.598428] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.598454] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.598457] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.598461] pci 0000:00:1c.0: bridge window [mem 0xdf200000-0xdf2fffff]
[ 0.598464] pci 0000:00:1c.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.598468] pci 0000:00:1c.4: PCI bridge to [bus 02]
[ 0.598472] pci 0000:00:1c.4: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.598478] pci 0000:00:1c.5: PCI bridge to [bus 03]
[ 0.598480] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.598484] pci 0000:00:1c.5: bridge window [mem 0xdf000000-0xdf0fffff]
[ 0.598486] pci 0000:00:1c.5: bridge window [mem 0xd0000000-0xd00fffff 64bit pref]
[ 0.598492] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.598493] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.598495] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.598496] pci_bus 0000:00: resource 7 [mem 0x7c000000-0xdfffffff window]
[ 0.598497] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[ 0.598499] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.598500] pci_bus 0000:01: resource 1 [mem 0xdf200000-0xdf2fffff]
[ 0.598501] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.598503] pci_bus 0000:02: resource 1 [mem 0xdf100000-0xdf1fffff]
[ 0.598504] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.598505] pci_bus 0000:03: resource 1 [mem 0xdf000000-0xdf0fffff]
[ 0.598506] pci_bus 0000:03: resource 2 [mem 0xd0000000-0xd00fffff 64bit pref]
[ 0.598663] NET: Registered protocol family 2
[ 0.598782] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes)
[ 0.598831] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.598975] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.599065] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.599093] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.599129] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 0.599184] NET: Registered protocol family 1
[ 0.599188] NET: Registered protocol family 44
[ 0.599196] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.600293] PCI: CLS 0 bytes, default 64
[ 0.600323] Unpacking initramfs...
[ 0.694174] Freeing initrd memory: 9508K
[ 0.694205] DMAR: ACPI device "device:65" under DMAR at fed91000 as 00:15.0
[ 0.694207] DMAR: ACPI device "device:66" under DMAR at fed91000 as 00:15.1
[ 0.694223] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.694224] software IO TLB: mapped [mem 0x646b0000-0x686b0000] (64MB)
[ 0.694242] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255cb6cc5db, max_idle_ns: 440795203504 ns
[ 0.694257] clocksource: Switched to clocksource tsc
[ 0.694320] Scanning for low memory corruption every 60 seconds
[ 0.694769] Initialise system trusted keyrings
[ 0.694777] Key type blacklist registered
[ 0.694811] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.695903] zbud: loaded
[ 0.696137] pstore: using zstd compression
[ 0.697156] Key type asymmetric registered
[ 0.697157] Asymmetric key parser 'x509' registered
[ 0.697163] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.697188] io scheduler noop registered
[ 0.697189] io scheduler deadline registered
[ 0.697223] io scheduler cfq registered (default)
[ 0.697224] io scheduler mq-deadline registered
[ 0.697225] io scheduler kyber registered
[ 0.697242] io scheduler bfq registered
[ 0.697258] io scheduler bfq-sq registered
[ 0.697259] BFQ I/O-scheduler: v9 (with cgroups support)
[ 0.697260] blkcg_policy_register: BLKCG_MAX_POLS too small
[ 0.697854] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.697922] efifb: probing for efifb
[ 0.697933] efifb: framebuffer at 0xb0000000, using 8128k, total 8128k
[ 0.697934] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.697935] efifb: scrolling: redraw
[ 0.697936] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.697970] fbcon: Deferring console take-over
[ 0.697970] fb0: EFI VGA frame buffer device
[ 0.697976] intel_idle: MWAIT substates: 0x11142120
[ 0.697977] intel_idle: v0.4.1 model 0x4E
[ 0.698146] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.698213] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.698221] ACPI: Lid Switch [LID0]
[ 0.698244] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.698249] ACPI: Power Button [PBTN]
[ 0.698272] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.698277] ACPI: Sleep Button [SBTN]
[ 0.698302] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.698306] ACPI: Power Button [PWRF]
[ 0.700429] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.700430] ACPI: Thermal Zone [THM] (25 C)
[ 0.700827] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.700828] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.700969] thermal LNXTHERM:02: registered as thermal_zone2
[ 0.700970] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.701173] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.702251] usbcore: registered new interface driver usbserial_generic
[ 0.702255] usbserial: USB Serial support registered for generic
[ 0.702273] rtc_cmos 00:01: RTC can wake from S4
[ 0.702775] rtc_cmos 00:01: registered as rtc0
[ 0.702788] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.702832] intel_pstate: Intel P-state driver initializing
[ 0.702944] intel_pstate: HWP enabled
[ 0.702971] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.702994] intel_pmc_core: initialized
[ 0.703164] NET: Registered protocol family 10
[ 0.705957] Segment Routing with IPv6
[ 0.705998] NET: Registered protocol family 17
[ 0.706363] RAS: Correctable Errors collector initialized.
[ 0.706411] microcode: sig=0x406e3, pf=0x80, revision=0xc6
[ 0.706510] microcode: Microcode Update Driver: v2.2.
[ 0.706517] sched_clock: Marking stable (709484271, -2977232)->(711093419, -4586380)
[ 0.706718] registered taskstats version 1
[ 0.706723] Loading compiled-in X.509 certificates
[ 0.708261] Loaded X.509 cert 'Build time autogenerated kernel key: 7f6e4b3182e05b628a0542b67232d36148044914'
[ 0.708273] zswap: loaded using pool lzo/zbud
[ 0.710708] Key type big_key registered
[ 0.711642] Magic number: 10:578:580
[ 0.711663] pci_bus 0000:01: hash matches
[ 0.711665] acpi LNXPOWER:1b: hash matches
[ 0.711849] rtc_cmos 00:01: setting system clock to 2018-11-18 11:33:44 UTC (1542540824)
[ 0.929739] Freeing unused decrypted memory: 2040K
[ 1.093054] Freeing unused kernel image memory: 1536K
[ 1.093101] Write protecting the kernel read-only data: 18432k
[ 1.094156] Freeing unused kernel image memory: 2008K
[ 1.094325] Freeing unused kernel image memory: 408K
[ 1.100281] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.100281] x86/mm: Checking user space page tables
[ 1.106053] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.106054] Run /init as init process
[ 1.123165] fbcon: Taking over console
[ 1.123263] Console: switching to colour frame buffer device 240x67
[ 1.183186] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.183750] i8042: Warning: Keylock active
[ 1.185086] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.185133] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.196640] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.196646] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.196971] SCSI subsystem initialized
[ 1.197722] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000001109810
[ 1.197728] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.198025] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.198027] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.198029] usb usb1: Product: xHCI Host Controller
[ 1.198031] usb usb1: Manufacturer: Linux 4.19.2-1-MANJARO xhci-hcd
[ 1.198032] usb usb1: SerialNumber: 0000:00:14.0
[ 1.198147] hub 1-0:1.0: USB hub found
[ 1.198165] hub 1-0:1.0: 12 ports detected
[ 1.199686] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.199690] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.199693] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.199734] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.199736] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.199737] usb usb2: Product: xHCI Host Controller
[ 1.199739] usb usb2: Manufacturer: Linux 4.19.2-1-MANJARO xhci-hcd
[ 1.199740] usb usb2: SerialNumber: 0000:00:14.0
[ 1.199827] hub 2-0:1.0: USB hub found
[ 1.199839] hub 2-0:1.0: 6 ports detected
[ 1.205674] libata version 3.00 loaded.
[ 1.209351] ahci 0000:00:17.0: version 3.0
[ 1.209582] ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
[ 1.211359] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 1.219736] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 1.219739] ahci 0000:00:17.0: flags: 64bit ncq stag pm led clo only pio slum part deso sadm sds apst
[ 1.220143] scsi host0: ahci
[ 1.220348] scsi host1: ahci
[ 1.220378] ata1: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b100 irq 123
[ 1.220380] ata2: SATA max UDMA/133 abar m2048@0xdf32b000 port 0xdf32b180 irq 123
[ 1.528554] usb 1-5: new high-speed USB device number 2 using xhci_hcd
[ 1.533336] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.534291] ata1.00: supports DRM functions and may not be fully accessible
[ 1.534369] ata1.00: ATA-10: CT1000MX500SSD1, M3CR022, max UDMA/133
[ 1.534374] ata1.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.535533] ata1.00: supports DRM functions and may not be fully accessible
[ 1.536497] ata1.00: configured for UDMA/133
[ 1.546673] ahci 0000:00:17.0: port does not support device sleep
[ 1.547236] scsi 0:0:0:0: Direct-Access ATA CT1000MX500SSD1 022 PQ: 0 ANSI: 5
[ 1.738650] usb 1-5: New USB device found, idVendor=0c45, idProduct=6712, bcdDevice=51.05
[ 1.738656] usb 1-5: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 1.738660] usb 1-5: Product: Integrated_Webcam_HD
[ 1.738664] usb 1-5: Manufacturer: CN0V359T724875ADA5NLA00
[ 1.863200] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.864810] ata2.00: ATAPI: MATSHITA DVD+/-RW UJ8E2, 1.01, max UDMA/133
[ 1.867244] ata2.00: configured for UDMA/133
[ 1.868527] usb 1-6: new high-speed USB device number 3 using xhci_hcd
[ 1.870266] scsi 1:0:0:0: CD-ROM MATSHITA DVD+-RW UJ8E2 1.01 PQ: 0 ANSI: 5
[ 1.916748] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.916750] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.916759] sd 0:0:0:0: [sda] Write Protect is off
[ 1.916762] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.916775] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.919997] sda: sda1 sda2 sda3
[ 1.920523] sd 0:0:0:0: [sda] supports TCG Opal
[ 1.920525] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.947514] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.947518] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.947791] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.009771] usb 1-6: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[ 2.009777] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.009781] usb 1-6: Product: USB2.0-CRW
[ 2.009784] usb 1-6: Manufacturer: Generic
[ 2.009787] usb 1-6: SerialNumber: 20100201396000000
[ 2.017107] usbcore: registered new interface driver rtsx_usb
[ 2.085244] random: fast init done
[ 2.131916] usb 1-8: new full-speed USB device number 4 using xhci_hcd
[ 2.273133] usb 1-8: New USB device found, idVendor=8087, idProduct=07dc, bcdDevice= 0.01
[ 2.273140] usb 1-8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.379726] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.509815] systemd[1]: systemd 239 running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 2.525482] systemd[1]: Detected architecture x86-64.
[ 2.530305] systemd[1]: Set hostname to <daniel-pc>.
[ 2.689303] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.689373] systemd[1]: Listening on udev Kernel Socket.
[ 2.689510] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.690723] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.690812] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.690858] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.690943] systemd[1]: Reached target Swap.
[ 2.691007] systemd[1]: Reached target Login Prompts.
[ 2.691119] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.691231] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.708863] EXT4-fs (sda2): re-mounted. Opts: discard
[ 2.719177] audit: type=1130 audit(1542540826.503:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.727975] audit: type=1130 audit(1542540826.510:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.732004] audit: type=1130 audit(1542540826.516:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.733554] audit: type=1130 audit(1542540826.516:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.735049] audit: type=1130 audit(1542540826.516:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.751202] audit: type=1130 audit(1542540826.533:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.760684] systemd-journald[231]: Received request to flush runtime journal from PID 1
[ 2.772827] audit: type=1130 audit(1542540826.556:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.782329] audit: type=1130 audit(1542540826.566:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.805071] audit: type=1130 audit(1542540826.586:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.881207] ACPI: AC Adapter [AC] (on-line)
[ 2.903951] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 2.910838] input: DELL Wireless hotkeys as /devices/virtual/input/input6
[ 2.910928] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[ 2.914657] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[ 2.920816] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[ 2.923553] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.943479] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 2.943515] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 2.951797] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[ 2.970242] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 2.973755] Linux agpgart interface v0.103
[ 2.976973] i2c_hid i2c-DLLC6B2:00: i2c-DLLC6B2:00 supply vdd not found, using dummy regulator
[ 2.976988] i2c_hid i2c-DLLC6B2:00: Linked as a consumer to regulator.0
[ 2.976990] i2c_hid i2c-DLLC6B2:00: i2c-DLLC6B2:00 supply vddl not found, using dummy regulator
[ 2.985691] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 3.005891] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 3.022672] libphy: r8169: probed
[ 3.022841] r8169 0000:03:00.0 eth0: RTL8106e, f8:ca:b8:0f:e7:fd, XID 44900000, IRQ 125
[ 3.024781] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.025180] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[ 3.025524] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 3.041377] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 3.041379] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 3.041380] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 3.041381] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 3.041382] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 3.041383] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 3.045527] media: Linux media interface: v0.10
[ 3.068306] cryptd: max_cpu_qlen set to 1000
[ 3.074758] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.118688] AVX2 version of gcm_enc/dec engaged.
[ 3.118689] AES CTR mode by8 optimization enabled
[ 3.128965] videodev: Linux video capture interface: v2.00
[ 3.130275] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: discard
[ 3.176850] Intel(R) Wireless WiFi driver for Linux
[ 3.176851] Copyright(c) 2003- 2015 Intel Corporation
[ 3.177102] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[ 3.185053] iwlwifi 0000:02:00.0: loaded firmware version 17.3216344376.0 op_mode iwlmvm
[ 3.311702] random: crng init done
[ 3.311704] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.492610] Bluetooth: Core ver 2.22
[ 3.492624] NET: Registered protocol family 31
[ 3.492625] Bluetooth: HCI device and connection manager initialized
[ 3.492628] Bluetooth: HCI socket layer initialized
[ 3.492630] Bluetooth: L2CAP socket layer initialized
[ 3.492635] Bluetooth: SCO socket layer initialized
[ 3.500104] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 3.552944] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 3.570923] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 3160, REV=0x164
[ 3.592396] iwlwifi 0000:02:00.0: base HW address: 78:0c:b8:66:96:94
[ 3.596312] usbcore: registered new interface driver btusb
[ 3.619003] Bluetooth: hci0: read Intel version: 3707100100012d0d00
[ 3.620844] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
[ 3.649365] VFIO - User Level meta-driver version: 0.3
[ 3.665200] uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (0c45:6712)
[ 3.711126] input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input9
[ 3.718728] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 3.732246] Bluetooth: hci0: Intel firmware patch completed and activated
[ 3.736426] uvcvideo 1-5:1.0: Entity type for entity Extension 4 was not initialized!
[ 3.736429] uvcvideo 1-5:1.0: Entity type for entity Extension 3 was not initialized!
[ 3.736431] uvcvideo 1-5:1.0: Entity type for entity Processing 2 was not initialized!
[ 3.736433] uvcvideo 1-5:1.0: Entity type for entity Camera 1 was not initialized!
[ 3.736498] input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input10
[ 3.736567] usbcore: registered new interface driver uvcvideo
[ 3.736568] USB Video Class driver (1.1.1)
[ 3.744352] iTCO_vendor_support: vendor-support=0
[ 3.772922] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 3.772998] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[ 3.773127] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 3.799401] input: DLLC6B2:00 06CB:75BF Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-DLLC6B2:00/0018:06CB:75BF.0001/input/input11
[ 3.799548] input: DLLC6B2:00 06CB:75BF Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-DLLC6B2:00/0018:06CB:75BF.0001/input/input12
[ 3.799621] hid-generic 0018:06CB:75BF.0001: input,hidraw0: I2C HID v1.00 Mouse [DLLC6B2:00 06CB:75BF] on i2c-DLLC6B2:00
[ 3.867691] r8169 0000:03:00.0 enp3s0: renamed from eth0
[ 3.874462] checking generic (b0000000 7f0000) vs hw (b0000000 10000000)
[ 3.874463] fb: switching to inteldrmfb from EFI VGA
[ 3.874494] Console: switching to colour dummy device 80x25
[ 3.874568] [drm] Replacing VGA console driver
[ 3.879110] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.879112] [drm] Driver supports precise vblank timestamp query.
[ 3.879612] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.880382] [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[ 3.920320] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[ 3.921987] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 3.923165] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input14
[ 3.923332] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 3.932494] input: DLLC6B2:00 06CB:75BF Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-DLLC6B2:00/0018:06CB:75BF.0001/input/input16
[ 3.932570] hid-multitouch 0018:06CB:75BF.0001: input,hidraw0: I2C HID v1.00 Mouse [DLLC6B2:00 06CB:75BF] on i2c-DLLC6B2:00
[ 3.934279] fbcon: inteldrmfb (fb0) is primary device
[ 3.996118] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[ 3.996953] Generic PHY r8169-300:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
[ 4.035100] intel_rapl: Found RAPL domain package
[ 4.035101] intel_rapl: Found RAPL domain core
[ 4.035102] intel_rapl: Found RAPL domain uncore
[ 4.035103] intel_rapl: Found RAPL domain dram
[ 4.072572] [drm] radeon kernel modesetting enabled.
[ 4.072591] vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
[ 4.072728] ATPX version 1, functions 0x00000033
[ 4.072829] ATPX Hybrid Graphics
[ 4.080902] mousedev: PS/2 mouse device common for all mice
[ 4.261960] IPv6: ADDRCONF(NETDEV_UP): enp3s0: link is not ready
[ 4.263232] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[ 4.282460] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 4.426411] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 4.592415] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 5.068187] Console: switching to colour frame buffer device 240x67
[ 5.088664] radeon 0000:01:00.0: enabling device (0006 -> 0007)
[ 5.088812] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 5.091402] [drm] initializing kernel modesetting (HAINAN 0x1002:0x6660 0x1028:0x06B2 0x81).
[ 5.091421] vga_switcheroo: enabled
[ 5.170684] ATOM BIOS: DELL
[ 5.170694] [drm] GPU not posted. posting now...
[ 5.174997] radeon 0000:01:00.0: VRAM: 4096M 0x0000000000000000 - 0x00000000FFFFFFFF (4096M used)
[ 5.174999] radeon 0000:01:00.0: GTT: 2048M 0x0000000100000000 - 0x000000017FFFFFFF
[ 5.175011] [drm] Detected VRAM RAM=4096M, BAR=256M
[ 5.175012] [drm] RAM width 64bits DDR
[ 5.175634] [TTM] Zone kernel: Available graphics memory: 8157078 kiB
[ 5.175636] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 5.175636] [TTM] Initializing pool allocator
[ 5.175640] [TTM] Initializing DMA pool allocator
[ 5.175657] [drm] radeon: 4096M of VRAM memory ready
[ 5.175658] [drm] radeon: 2048M of GTT memory ready.
[ 5.175670] [drm] Loading hainan Microcode
[ 5.178669] [drm] Internal thermal controller without fan control
[ 5.186315] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.186317] Bluetooth: BNEP filters: protocol multicast
[ 5.186320] Bluetooth: BNEP socket layer initialized
[ 5.188920] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3234: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 5.188923] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 5.188925] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 5.188926] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 5.188928] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 5.188930] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x19
[ 5.188931] snd_hda_codec_realtek hdaudioC0D0: Headphone Mic=0x1a
[ 5.188933] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 5.190181] [drm] radeon: dpm initialized
[ 5.190185] [drm] GART: num cpu pages 524288, num gpu pages 524288
[ 5.192743] [drm] PCIE gen 3 link speeds already enabled
[ 5.211827] [drm] PCIE GART of 2048M enabled (table at 0x0000000000040000).
[ 5.211953] radeon 0000:01:00.0: WB enabled
[ 5.211956] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000100000c00 and cpu addr 0x00000000a7ec37bf
[ 5.211958] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000100000c04 and cpu addr 0x00000000d73b69e6
[ 5.211960] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000100000c08 and cpu addr 0x000000003c8a0c09
[ 5.211961] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000100000c0c and cpu addr 0x0000000063cb2fc8
[ 5.211963] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000100000c10 and cpu addr 0x00000000d6229349
[ 5.211964] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.211965] [drm] Driver supports precise vblank timestamp query.
[ 5.211966] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[ 5.212605] radeon 0000:01:00.0: radeon: using MSI.
[ 5.212623] [drm] radeon: irq initialized.
[ 5.228007] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 5.255270] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 5.256711] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 5.256766] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 5.257371] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 5.257425] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 5.257481] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 5.257530] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 5.428566] [drm] ring test on 0 succeeded in 2 usecs
[ 5.428571] [drm] ring test on 1 succeeded in 1 usecs
[ 5.428576] [drm] ring test on 2 succeeded in 1 usecs
[ 5.428584] [drm] ring test on 3 succeeded in 4 usecs
[ 5.428590] [drm] ring test on 4 succeeded in 3 usecs
[ 5.428752] [drm] ib test on ring 0 succeeded in 0 usecs
[ 5.428781] [drm] ib test on ring 1 succeeded in 0 usecs
[ 5.428851] [drm] ib test on ring 2 succeeded in 0 usecs
[ 5.428871] [drm] ib test on ring 3 succeeded in 0 usecs
[ 5.428894] [drm] ib test on ring 4 succeeded in 0 usecs
[ 5.429104] [drm] Radeon Display Connectors
[ 5.431191] [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 1
[ 5.636241] [drm] amdgpu kernel modesetting enabled.
[ 5.636260] vga_switcheroo: detected switching method \_SB_.PCI0.GFX0.ATPX handle
[ 5.636394] ATPX version 1, functions 0x00000033
[ 5.636492] ATPX Hybrid Graphics
[ 6.073915] kauditd_printk_skb: 32 callbacks suppressed
[ 6.073916] audit: type=1701 audit(1542540829.856:43): auid=4294967295 uid=120 gid=120 ses=4294967295 pid=1293 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
[ 6.086167] audit: type=1130 audit(1542540829.870:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1741-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.558661] audit: type=1131 audit(1542540830.340:45): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.586206] audit: type=1131 audit(1542540830.370:46): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.646083] audit: type=1131 audit(1542540830.430:47): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1741-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.651798] audit: type=1130 audit(1542540830.433:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.663012] audit: type=1006 audit(1542540830.446:49): pid=2033 uid=0 old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=2 res=1
[ 6.699775] audit: type=1130 audit(1542540830.483:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.127194] fuse init (API version 7.27)
[ 7.513423] audit: type=1130 audit(1542540831.296:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.890281] Bluetooth: RFCOMM TTY layer initialized
[ 7.890287] Bluetooth: RFCOMM socket layer initialized
[ 7.890292] Bluetooth: RFCOMM ver 1.11
[ 8.517896] audit: type=1130 audit(1542540832.300:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.006383] kauditd_printk_skb: 5 callbacks suppressed
[ 14.006384] audit: type=1131 audit(1542540837.793:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.929123] audit: type=1006 audit(1542540843.713:59): pid=5369 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 19.938893] audit: type=1130 audit(1542540843.723:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.948274] audit: type=1006 audit(1542540843.730:61): pid=9260 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=4 res=1
[ 19.986777] audit: type=1130 audit(1542540843.770:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.001631] audit: type=1112 audit(1542540843.783:63): pid=5369 uid=0 auid=1000 ses=3 msg='uid=1000 exe="/usr/lib/gdm-session-worker" hostname=? addr=? terminal=? res=success'
[ 20.851827] [drm] PCIE gen 3 link speeds already enabled
[ 20.862977] [drm] PCIE GART of 2048M enabled (table at 0x0000000000040000).
[ 20.863086] radeon 0000:01:00.0: WB enabled
[ 20.863089] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000100000c00 and cpu addr 0x00000000a7ec37bf
[ 20.863091] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000100000c04 and cpu addr 0x00000000d73b69e6
[ 20.863093] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000100000c08 and cpu addr 0x000000003c8a0c09
[ 20.863094] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000100000c0c and cpu addr 0x0000000063cb2fc8
[ 20.863096] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000100000c10 and cpu addr 0x00000000d6229349
[ 21.064970] [drm] ring test on 0 succeeded in 1 usecs
[ 21.064975] [drm] ring test on 1 succeeded in 1 usecs
[ 21.064980] [drm] ring test on 2 succeeded in 1 usecs
[ 21.064988] [drm] ring test on 3 succeeded in 4 usecs
[ 21.064994] [drm] ring test on 4 succeeded in 3 usecs
[ 21.065026] [drm] ib test on ring 0 succeeded in 0 usecs
[ 21.065050] [drm] ib test on ring 1 succeeded in 0 usecs
[ 21.065073] [drm] ib test on ring 2 succeeded in 0 usecs
[ 21.065086] [drm] ib test on ring 3 succeeded in 0 usecs
[ 21.065098] [drm] ib test on ring 4 succeeded in 0 usecs
[ 23.036483] audit: type=1130 audit(1542540846.820:64): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.349895] audit: type=1130 audit(1542540847.133:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 23.363981] rfkill: input handler disabled
[ 26.138010] audit: type=1130 audit(1542540849.920:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.142962] audit: type=1131 audit(1542540854.926:67): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 40.014248] audit: type=1131 audit(1542540863.796:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.007799] audit: type=1131 audit(1542540878.790:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.393246] audit: type=1131 audit(1542540879.176:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 57.943688] audit: type=1111 audit(1542540881.726:71): pid=344 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-add-activate uuid=4e2bc77b-cb7a-467c-85c4-bf998144e8ae name=486F6F6B20656D20486F726E73 pid=10232 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 57.951259] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
[ 69.026455] audit: type=1131 audit(1542540892.810:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 97.737561] wlp2s0: authenticate with 38:10:d5:30:65:fb
[ 97.742920] wlp2s0: send auth to 38:10:d5:30:65:fb (try 1/3)
[ 97.746139] wlp2s0: authenticated
[ 97.748532] wlp2s0: associate with 38:10:d5:30:65:fb (try 1/3)
[ 97.757032] wlp2s0: RX AssocResp from 38:10:d5:30:65:fb (capab=0x1511 status=0 aid=1)
[ 97.757589] wlp2s0: associated
[ 97.796131] wlp2s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 38:10:d5:30:65:fb
[ 97.796165] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 97.876122] audit: type=1130 audit(1542540921.660:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 108.006815] audit: type=1131 audit(1542540931.790:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 212.881867] audit: type=1130 audit(1542541036.666:75): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 212.881870] audit: type=1131 audit(1542541036.666:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 265.223545] [drm] PCIE gen 3 link speeds already enabled
[ 265.233615] [drm] PCIE GART of 2048M enabled (table at 0x0000000000040000).
[ 265.233732] radeon 0000:01:00.0: WB enabled
[ 265.233735] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000100000c00 and cpu addr 0x00000000a7ec37bf
[ 265.233736] radeon 0000:01:00.0: fence driver on ring 1 use gpu addr 0x0000000100000c04 and cpu addr 0x00000000d73b69e6
[ 265.233737] radeon 0000:01:00.0: fence driver on ring 2 use gpu addr 0x0000000100000c08 and cpu addr 0x000000003c8a0c09
[ 265.233738] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000100000c0c and cpu addr 0x0000000063cb2fc8
[ 265.233739] radeon 0000:01:00.0: fence driver on ring 4 use gpu addr 0x0000000100000c10 and cpu addr 0x00000000d6229349
[ 265.436636] [drm] ring test on 0 succeeded in 1 usecs
[ 265.436641] [drm] ring test on 1 succeeded in 1 usecs
[ 265.436645] [drm] ring test on 2 succeeded in 1 usecs
[ 265.436654] [drm] ring test on 3 succeeded in 4 usecs
[ 265.436661] [drm] ring test on 4 succeeded in 4 usecs
[ 265.436710] [drm] ib test on ring 0 succeeded in 0 usecs
[ 265.436744] [drm] ib test on ring 1 succeeded in 0 usecs
[ 265.436767] [drm] ib test on ring 2 succeeded in 0 usecs
[ 265.436779] [drm] ib test on ring 3 succeeded in 0 usecs
[ 265.436791] [drm] ib test on ring 4 succeeded in 0 usecs
dmesg | grep sd has the following output:
[ 0.009728] ACPI: SSDT 0x0000000077FF6570 003531 (v02 SaSsdt SaSsdt 00003000 INTL 20120913)
[ 0.009733] ACPI: SSDT 0x0000000077FF9AF0 000E58 (v02 CpuRef CpuSsdt 00003000 INTL 20120913)
If you need anything else let me know
