Hi everyone!
I have a problem with Manjaro (Gnome, 20.0.3)- microphone wasn't found. I followed this instruction to fix it
https://wiki.archlinux.org/index.php/PulseAudio/Troubleshooting#Microphone
Now Manjaro detects microphone, but it doesn't record actually, only noise.
What should I do in order to fix it?
This is how my AlsaMixer looks like
Thanks for your help in advance!
Hello and welcome to Manjaro!
Could you press F4 to select the capture devices
in alsamixer and make another screenshot
Hi! Thanks for answer!
This is how capture devices looks like
You have Pulseaudio selected. Could you switch to your actual soundcard (F6) and look for the capture device?
Sorry for misunderstood.
This is Capture from my soundcard
The usual simple solution in these cases is to unmute the mic. Which is not the case here.
Could you provide more information on your hardware with
inxi --full --verbosity=7 --filter --no-host
and format the output properly as described in this article:
You may also want to install pavucontrol and look in the input tab. As you seem to have 2 mics, you can select the input method there.
This is output from terminal
~ >>> inxi --full --verbosity=7 --filter --no-host
Kernel: 5.6.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: Gnome 3.36.3 wm: gnome-shell dm: GDM 3.34.1
Distro: Manjaro Linux
Type: Convertible System: HP product: HP EliteBook x360 830 G6 v: N/A
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: HP model: 8548 v: KBC Version 58.3A.00 serial: <filter> UEFI: HP
v: R78 Ver. 01.05.03 date: 04/27/2020
ID-1: BAT0 charge: 54.2 Wh condition: 54.2/54.2 Wh (100%)
volts: 8.7/7.7 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Full
RAM: total: 30.72 GiB used: 4.38 GiB (14.3%)
RAM Report:
Topology: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Kaby Lake rev: C L2 cache: 8192 KiB bogomips: 32012
Speed: 800 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d
fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb
ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
Display: x11 server: X.org 1.20.8 driver: i915 compositor: gnome-shell
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
v: 4.6 Mesa 20.0.7 direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Hewlett-Packard driver: sof-audio-pci bus ID: 00:1f.3
chip ID: 8086:9dc8
Sound Server: ALSA v: k5.6.16-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: efa0
bus ID: 6d:00.0 chip ID: 8086:2723
IF: wlp109s0 state: up mac: <filter>
IP v6: <filter> type: deprecated dynamic noprefixroute scope: global
IF-ID-1: vpn0 state: up speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> type: noprefixroute scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Local Storage: total: 953.87 GiB used: 26.53 GiB (2.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB1T0HALR-000H1
size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: EXA73H1Q scheme: GPT
ID-1: / size: 95.62 GiB used: 18.10 GiB (18.9%) fs: ext4
dev: /dev/nvme0n1p7 label: N/A
uuid: d345aeeb-022c-4fac-8038-0df6a7fe377c
ID-2: /boot/efi size: 1.95 GiB used: 308 KiB (0.0%) fs: vfat
dev: /dev/nvme0n1p5 label: N/A uuid: 459F-218A
ID-3: /home size: 323.90 GiB used: 8.43 GiB (2.6%) fs: ext4
dev: /dev/nvme0n1p8 label: N/A
uuid: 7ab4b30a-0258-4734-957f-0308d2f9ecab
ID-4: /var/lib/snapd/snap/core/9289 raw size: 97.0 MiB
size: <root required> used: <root required> fs: squashfs
dev: /dev/loop5 label: N/A uuid: N/A
ID-5: /var/lib/snapd/snap/core18/1754 raw size: 54.9 MiB
dev: /dev/loop3 label: N/A uuid: N/A
ID-6: /var/lib/snapd/snap/gnome-3-28-1804/128 raw size: 161.4 MiB
dev: /dev/loop1 label: N/A uuid: N/A
ID-7: /var/lib/snapd/snap/gtk-common-themes/1506 raw size: 62.1 MiB
dev: /dev/loop0 label: N/A uuid: N/A
ID-8: /var/lib/snapd/snap/intellij-idea-ultimate/228
raw size: 700.2 MiB size: <root required> used: <root required>
fs: squashfs dev: /dev/loop4 label: N/A uuid: N/A
ID-9: /var/lib/snapd/snap/pycharm-professional/201 raw size: 444.6 MiB
dev: /dev/loop2 label: N/A uuid: N/A
ID-10: /var/lib/snapd/snap/snapd/7777 raw size: 30.3 MiB
dev: /dev/loop6 label: N/A uuid: N/A
ID-11: swap-1 size: 9.77 GiB used: 0 KiB (0.0%) fs: swap
dev: /dev/nvme0n1p6 label: N/A
uuid: c9f877ae-bc3a-4909-ac4a-8abcb0a5835f
ID-1: /dev/nvme0n1p1 size: 260.0 MiB fs: vfat label: SYSTEM
uuid: 3E04-BBF3
ID-2: /dev/nvme0n1p2 size: 16.0 MiB fs: <root required> label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 size: 513.19 GiB fs: bitlocker label: N/A
uuid: N/A
ID-4: /dev/nvme0n1p4 size: 969.0 MiB fs: ntfs label: Windows RE Tools
uuid: 8A828F74828F6413
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: Logitech Keyboard K120 type: Keyboard,HID
chip ID: 046d:c31c
Device-2: 1-2:3 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 1bcf:0005
Device-3: 1-8:4 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 06cb:00b7
serial: <filter>
Device-4: 1-9:5 info: Lite-On HP HD Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 04ca:7089 serial: <filter>
Device-5: 1-10:6 info: Intel type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1
speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1
System Temperatures: cpu: 51.0 C mobo: 47.0 C
Processes: 364 Uptime: 18h 54m Init: systemd v: 245 Compilers:
gcc: 10.1.0 Shell: zsh v: 5.8 running in: gnome-terminal inxi: 3.0.37
I have already installed pauvcontrol.
This is how it looks like, when I open it
If I select something and click on lock sign, mic doesn't work. After reopening pauvcontrol all microphones are not selected again.
The lock sign is only for locking the two channels together. What devices can you choose from in the dropdown menu? This maybe another case for our resident audio expert @nikgnomic .
Here are all input devices, which I have
By default Speaker+Headphones is selected. When I try to select another option, it selects again to Speaker+ Headphones.
It's good to have this overview, but I meant the menu near Port: (unplugged)
This is above my abilities. You should wait for our audio expert.
I have everywhere only one port option, which is selected. I can't select something else.
I also have only one Profile of Configuration
Cannon Point LP device appears have the right sof-firmware driver sof-hda-dsp
but pulseaudio may by to be trying to avoid the built-in digital microphone and headset microphone because they are detected as unplugged
suggest add kernel v5.7.0 using Manjaro Settings Manager
thesofproject had a lot of problems with many laptops but seem to be getting them fixed
the first 4 Input Devices are Monitor of the Output Devices
pavucontrol display can be changed to Show: All Except Monitors
the check-mark button in pavucontrol is not for default device
tooltip is 'Set as fallback'
to check default sink and source use pacmd dump
or pactl info
had exactly the same problem. its a pulseaudio issue that is solved in their upcoming release. in the meantime, install pulseaudio-git from aur. works like a charm for me!
thank you for confirming on that
i have seen mention in Archwiki of using pulseaudio-git to get v13.99
that may be what is needed here to resolve any issues with devices being detected as (unavailable) or (unplugged)
no problem.
my only issue was that after installing it from aur, pulseaudio did not start automatically anymore. so you need to do:
systemctl --user daemon-reload
systemctl --user enable pulseaudio pulseaudio.socket
systemctl --user restart pulseaudio pulseaudio.socket
