Manjaro wifi is fixed. So this from Manjaro.
inxi -Fxxxza --no-host
System: Kernel: 5.6.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64 root=UUID=5db6f147-2677-4161-a3bb-d832f9e89f0f rw quiet apparmor=1
security=apparmor resume=UUID=9b1c07c7-bd07-468a-93c8-2c5c8b3d629b udev.log_priority=3
Desktop: KDE Plasma 5.18.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP Laptop 17-bs0xx v: Type1ProductConfigId serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: HP model: 8339 v: 49.38 serial: <filter> UEFI: Insyde v: F.17 date: 02/26/2018
Battery: ID-1: BAT0 charge: 30.3 Wh condition: 30.3/30.3 Wh (100%) volts: 11.5/10.9 model: 133-42-6E-A JC03031 type: Li-ion
serial: <filter> status: Full
CPU: Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber Lake family: 6 model-id: 8E (142)
stepping: 9 microcode: CA L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 21607
Speed: 646 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 607 2: 600 3: 600 4: 600
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5916
Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
resolution: 1600x900~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.0.7 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.6.16-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8168
v: 8.048.03-NAPI port: 4000 bus ID: 01:00.0 chip ID: 10ec:8168
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard driver: rtw_8723de v: kernel
port: 3000 bus ID: 02:00.0 chip ID: 10ec:d723
Device-3: Realtek 802.11n WLAN Adapter type: USB driver: btusb bus ID: 1-5:2 chip ID: 0bda:b009 serial: <filter>
Drives: Local Storage: total: 931.51 GiB used: 8.13 GiB (0.9%)
ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-60JC3T1 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A02 scheme: GPT
Partition: ID-1: / raw size: 63.13 GiB size: 61.89 GiB (98.03%) used: 8.13 GiB (13.1%) fs: ext4 dev: /dev/sda10
ID-2: swap-1 size: 4.88 GiB used: 0 KiB (0.0%) fs: swap swappiness: 60 (default) cache pressure: 100 (default)
dev: /dev/sda11
Sensors: System Temperatures: cpu: 38.0 C mobo: 34.0 C
Info: Processes: 172 Uptime: 14m Memory: 7.65 GiB used: 1.01 GiB (13.2%) Init: systemd v: 245 Compilers: gcc: 10.1.0
Shell: bash v: 5.0.17 running in: konsole inxi: 3.0.37
Thanks.
