Manjaro has lower sound than Windows
Integrated ALC 889, with full slider on Manjaro -mind you that's %150- it doesn't even come close to annoying my ears. On windows i usually have it around 50 percent.
Is there a better driver or a better way to get this right?
Hello :slightly_smiling_face:!
Could you try running the command
alsamixer
This will put you into a terminal-based UI.
First of all, check if the master is at 100. If not, try to raise it.
Then, press F6, select your sound card with the arrow keys and press enter.
You'll now see a lot of sliders for various outputs. Try raising them and check if that helps anything.
If you have any further questions, feel free to reply.
Sorry, it doesn't work. Still almost half the sound of windows.
it doesn't work
if you want help to get your audio issue resolved you need to post some relevant information
all i can assume from that response is that you failed to locate correct sound card in alsamixer
please post full responses to:
inxi -Fxxxz
aplay -l
and use </> or Ctrl + Shift + C to display text in correct format
Host: n-desktop Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.1.0 Console: tty 2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: GA-990XA-UD3 serial: N/A
UEFI: Award v: F13 date: 10/26/2012
Topology: 6-Core model: AMD FX-6300 bits: 64 type: MCP arch: Bulldozer
L1 cache: 256 KiB L2 cache: 2048 KiB L3 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 42301
Speed: 3810 MHz min/max: N/A Core speeds (MHz): 1: 3810 2: 3823 3: 3826
4: 3797 5: 3786 6: 3776
Device-1: AMD Cedar [Radeon HD 5000/6000/7350/8350 Series]
vendor: PC Partner Limited driver: radeon v: kernel bus ID: 01:00.0
chip ID: 1002:68f9
Display: server: X.Org 1.20.8 driver: radeon FAILED: ati
unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
tty: N/A
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.6.19-2-MANJARO LLVM 10.0.0)
v: 3.3 Mesa 20.1.3 compat-v: 3.1 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 00:14.2 chip ID: 1002:4383
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 1002:aa68
Sound Server: ALSA v: k5.6.19-2-MANJARO
vendor: Gigabyte driver: r8169 v: kernel port: ee00 bus ID: 03:00.0
chip ID: 10ec:8168
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac:
Device-2: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 port: ac00 bus ID: 05:07.0 chip ID: 10ec:8139
IF: enp5s7 state: down mac:
Local Storage: total: 931.51 GiB used: 333.73 GiB (35.8%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1CH162
size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm serial:
rev: CC47 scheme: GPT
ID-1: / size: 51.57 GiB used: 10.56 GiB (20.5%) fs: ext4 dev: /dev/sda6
ID-2: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 34.1 C mobo: N/A gpu: radeon temp: 57 C
Processes: 237 Uptime: 49m Memory: 7.75 GiB used: 2.86 GiB (36.9%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Shell: bash (sudo)
v: 5.0.18 running in: konsole inxi: 3.0.37
**** List of PLAYBACK Hardware Devices ****
card 0: SB [HDA ATI SB], device 0: ALC889 Analog [ALC889 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: SB [HDA ATI SB], device 1: ALC889 Digital [ALC889 Digital]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Well, i did select the correct device because it did lower but was already 100 so i could not get it higher.
aplay -l confirms onboard analog audio device is card 0, device 0
please post full response to
amixer -c0
this will show ALSA level controls for the card in text format
(text equivalent of controls that would be shown graphically in alsamixer -c0 --view=All)
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-62.00dB] [off]
Front Right: Playback 0 [0%] [-62.00dB] [off]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Front Left: Playback 64 [100%] [2.00dB] [on]
Front Right: Playback 64 [100%] [2.00dB] [on]
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 31 [100%] [12.00dB] [off]
Front Right: Playback 31 [100%] [12.00dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 3 [100%] [30.00dB]
Front Right: 3 [100%] [30.00dB]
Simple mixer control 'Surround',0
Mono:
Front Left: Playback 62 [97%] [0.00dB] [on]
Front Right: Playback 62 [97%] [0.00dB] [on]
Simple mixer control 'Center',0
Mono: Playback 62 [97%] [0.00dB] [on]
Simple mixer control 'LFE',0
Simple mixer control 'Side',0
Mono:
Simple mixer control 'Line',0
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 46
Front Left: Capture 28 [61%] [12.00dB] [on]
Front Right: Capture 28 [61%] [12.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-16.00dB] [off]
Front Right: Capture 0 [0%] [-16.00dB] [off]
Simple mixer control 'Capture',2
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Input Source',2
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
2 controls for audio playback from rear jacks Master and PCM are on 100%
but control for Headphone for audio to front panel is set to 0 and muted [off]
this is due to another setting in ALSA that will automatically mute speakers when headphones
are plugged in, or mute headphone output if headphones not plugged in
Capabilities: enum
Item0: 'Enabled'
please plug in headphones and use this command to find out audio level setting when Headphone control is unmuted
amixer -c0 sget Headphone
Mono:
I tested it and the front jack works much higher for some reason. Not sure if it's on the level of windows but much closer than mobo out.
How does a front panel audio connector work anyways? I see no microprocessors on it so it must be getting info from Alc 889 chip. In that case, the source and the driver are the same, how does it boost the sound then? It has no transistor either so it cannot be amplifying itself. The driver? Or the motherboard?
Thanks for all help, i feel like i'm on a wild goose chase, think i'll have to live with front panel. Hey, at least you gave me the drive to fix my long broken front panel lol. The only problem is that i shorted it and it thinks there is a headphone even when there isn't one, i'll solder properly later.
Btw thanks about this too: Manjaro: Unable to switch audiosource with headphones plugged in
front panel on a pc case would be just a simple board with connections to audio jacks
but in addition to audio connections to motherboard there is also a jack-sense connection so the audio codec is aware of a jack when plugged in
if front panel jack is incorrectly showing jack is plugged in at all times, probably best to change Auto-Mute Mode in ALSA to Disabled so it does not affect audio playback
any boosting of audio would be in the audio codec
it is possible that the built-in amplifier for the headphones may be more powerful than the speaker amplifier to cope with high impedance headphones
I don't think so. On windows front panel is about the same think.
On manjaro mobo out is really low compared to front. It's probably a driver issue.
Install pulseaudio equalizer from pamac(Add/remove software). Change the equalizer settings as per your choice. I did the same and am getting louder and crispier sound than windows 10.
