Manjaro KDE freezes after suspension
Hey people, I have a fresh installation of Manjaro KDE. Everything works perfectly except for suspension. Whenever I suspend my laptop I just get a black screen. I have already tried to look for some posts but none seem to get the same kind of error I have
Here are my system specs. I am using bumblebee and intel pstate and have installed thermald as well as tlp.
System:    Host: manjaro Kernel: 4.19.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: KDE Plasma 5.14.3
           Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: K53SD v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: K53SD v: 1.0 serial: <filter> UEFI: American Megatrends v: K53SD.208 date: 08/10/2012
Battery:   ID-1: BAT0 charge: 43.9 Wh condition: 45.9/59.4 Wh (77%) model: ASUSTek K53--54 status: Unknown
CPU:       Topology: Quad Core model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge rev: 7 L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 35137
           Speed: 2650 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 949 2: 2888 3: 1405 4: 2945 5: 2871 6: 2874 7: 2881
           8: 950
Graphics:  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel
           bus ID: 00:02.0
           Device-2: NVIDIA GF119M [GeForce 610M] driver: N/A bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.3 driver: intel resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 18.2.5 direct render: Yes
Audio:     Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0
           Sound Server: ALSA v: k4.19.2-1-MANJARO
Network:   Device-1: Intel Centrino Wireless-N 100 driver: iwlwifi v: kernel port: e040 bus ID: 03:00.0
           Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK driver: atl1c v: 1.0.1.1-NAPI port: 9000
           bus ID: 05:00.0
           IF: enp5s0 state: down mac: <filter>
Drives:    Local Storage: total: 298.09 GiB used: 30.73 GiB (10.3%)
           ID-1: /dev/sda vendor: Hitachi model: HTS543232A7A384 size: 298.09 GiB
Partition: ID-1: / size: 46.22 GiB used: 14.85 GiB (32.1%) fs: ext4 dev: /dev/sda3
           ID-2: /home size: 237.97 GiB used: 15.88 GiB (6.7%) fs: ext4 dev: /dev/sda6
           ID-3: swap-1 size: 7.63 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 47.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 1600
Info:      Processes: 235 Uptime: 28m Memory: 5.60 GiB used: 1.49 GiB (26.6%) Init: systemd Compilers: gcc: 8.2.1 Shell: zsh
           v: 5.6.2 inxi: 3.0.27
Here is the journalctl just after I close the lid of my laptop
nov 19 17:21:19 manjaro systemd-logind[574]: Lid closed.
nov 19 17:21:19 manjaro kernel: pci_bus 0000:01: Allocating resources
nov 19 17:21:19 manjaro org_kde_powerdevil[1004]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("Type", QVariant(uint, 1)))
nov 19 17:21:19 manjaro kernel: pci_bus 0000:02: Allocating resources
nov 19 17:21:19 manjaro kernel: pci_bus 0000:03: Allocating resources
nov 19 17:21:19 manjaro kernel: pci_bus 0000:04: Allocating resources
nov 19 17:21:19 manjaro kernel: pci_bus 0000:05: Allocating resources
nov 19 17:21:19 manjaro org_kde_powerdevil[1004]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("SkipFade", QVariant(bool, true))("Type", QVariant(uint, 1)))
nov 19 17:21:19 manjaro org_kde_powerdevil[1004]: powerdevil: Starting Login1 suspend job
nov 19 17:21:19 manjaro org_kde_powerdevil[1004]: powerdevil: Pausing all media players before suspending
nov 19 17:21:19 manjaro ksmserver[903]: lock called
nov 19 17:21:19 manjaro kdeinit5[876]: bluedevil: About to suspend
nov 19 17:21:19 manjaro NetworkManager[570]: <info>  [1542644479.4960] manager: sleep: sleep requested (sleeping: no  enabled: yes)
nov 19 17:21:19 manjaro NetworkManager[570]: <info>  [1542644479.4961] device (enp5s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
nov 19 17:21:19 manjaro ksmserver[903]: Lock window Id:  23068678
nov 19 17:21:19 manjaro NetworkManager[570]: <info>  [1542644479.5248] manager: NetworkManager state is now ASLEEP
nov 19 17:21:19 manjaro ksmserver[903]: CreateNotify: 23068678
nov 19 17:21:19 manjaro ksmserver[903]: CreateNotify: 23068680
nov 19 17:21:19 manjaro ksmserver[903]: CreateNotify: 69206020
nov 19 17:21:19 manjaro kscreenlocker_greet[1330]: Qt: Session management error: networkIdsList argument is NULL
nov 19 17:21:20 manjaro ksmserver[903]: CreateNotify: 69206024
nov 19 17:21:20 manjaro ksmserver[903]: CreateNotify: 69206032
nov 19 17:21:20 manjaro ksmserver[903]: CreateNotify: 69206037
nov 19 17:21:20 manjaro kscreenlocker_greet[1330]: kf5.kpackage: No metadata file in the package, expected it at: "/home/salvi/Imágenes/"
nov 19 17:21:20 manjaro ksmserver[903]: CreateNotify: 69206039
nov 19 17:21:20 manjaro ksmserver[903]: CreateNotify: 69206041
nov 19 17:21:20 manjaro ksmserver[903]: MapNotify: 69206039
nov 19 17:21:20 manjaro ksmserver[903]: CreateNotify: 69206043
nov 19 17:21:21 manjaro kscreenlocker_greet[1330]: UdevQt: unable to create udev monitor connection
nov 19 17:21:21 manjaro ksmserver[903]: CreateNotify: 69206052
nov 19 17:21:21 manjaro kscreenlocker_greet[1330]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
nov 19 17:21:22 manjaro ksmserver[903]: MapNotify: 23068678
nov 19 17:21:22 manjaro systemd[1]: Starting TLP suspend/resume...
nov 19 17:21:22 manjaro kscreenlocker_greet[1330]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
nov 19 17:21:22 manjaro ksmserver[903]: CreateNotify: 46137349
nov 19 17:21:22 manjaro ksmserver[903]: CreateNotify: 69206059
nov 19 17:21:22 manjaro plasmashell[920]: QXcbClipboard: SelectionRequest too old
nov 19 17:21:22 manjaro systemd[1]: Started TLP suspend/resume.
nov 19 17:21:22 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
nov 19 17:21:22 manjaro systemd[1]: Reached target Sleep.
nov 19 17:21:22 manjaro systemd[1]: Starting Suspend...
nov 19 17:21:22 manjaro kernel: audit: type=1130 audit(1542644482.770:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
nov 19 17:21:22 manjaro systemd-sleep[1451]: Suspending system...
nov 19 17:21:22 manjaro kernel: PM: suspend entry (deep)
I turned it off like 5 min after the last entry. If you need the whole journalctl of this boot it's here https://pastebin.com/QwfMtHeM
Perhaps your network is preventing proper suspend. I have numerous posts on the forum on how to correct that issue by writing a systemd service.
I would also install and test different kernels to see if the issue persists on other kernels.
I tried the previous LTS kernel but same results. Sorry for my ignorance but a couple of lines before that error you get
doesn't that mean that the network manager is not the problem? in case it is is there any way I can diagnose it? I have gone through your post but in this case No Ethernet Network Connection after Resume; very recent problem the problem seems to be different since I am not able to resume after suspension. As pointed out also here Thinkpad X230T won't suspend under kernel 419rc4, 4.18, 4.17, 4.14, 4.9 Could this be a problem of sddm? Is the error
meaningful? Also, after I close the lid the laptop fan starts to make a lot of noise and the temperature increases, but I have no idea why because there is no information in journalctl that can point to that. Is there any other diagnosis command I can use to check this overheating and the suspend problem? Sorry if I missed something from your post history but there is too much information and you post a lot :slight_smile:
Another information I think could be useful. I had previously installed ubuntu on BIOS in this laptop without any suspension problem. However, I decided to install Manjaro on EFI since I read that it could lead to better power management.
Network manager is only one of the network components that can cause suspend to fail. The wifi modules, Bluetooth modules (and service), and the adapter itself can all contribute to suspension failing.
The easiest test is to stop Network Manager, bring the network adapter down, then rmmod the wifi module prior to suspending.
If you follow those steps and your suspend process works, then one of those network components is preventing suspension.
Bluetooth could also be a possibility, but I have only seen Bluetooth responsible very rarely.
Perform those tests and you will know if networking is the culprit.
Have you changed login screen wallpaper?
If yes, reset to default or use a system file from backgrounds.
I have tried the commands you post here Thinkpad X230T won't suspend under kernel 419rc4, 4.18, 4.17, 4.14, 4.9 to turn off the network manager but I get an error about not having installed -r module when trying to execute modprobe. I tried to suspend anyways after executing all the commands despite the errors with same results, only this time in journalctl I didn't get the messsage
but still got
The rest is the same I already post in my OP
I tried setting one of the default backgrounds in /usr/share/wallpapers but still got the same message
So you did have you wallpaper set to a non standard location. I have seen this prevent suspension before. You may want to double check on this.
Without knowing your entire networking details I can't speculate why your commands did not work. If I had to guess, I'd say you are using the iwlwifi module. It is a little more complicated to unload.
To get an idea of what may be causing this you need to post these commands outputs:
lsmod
inxi -Fxxxz
I tried to set it back to one of the default ones but the error still appears in journalctl with respect to the new location
Here is the output of lsmod
Module                  Size  Used by
ccm                    20480  3
fuse                  118784  3
bbswitch               16384  0
nls_iso8859_1          16384  1
nls_cp437              20480  1
vfat                   24576  1
fat                    81920  1 vfat
snd_hda_codec_hdmi     57344  1
snd_hda_codec_realtek   110592  1
snd_hda_codec_generic    86016  1 snd_hda_codec_realtek
uvcvideo              118784  0
videobuf2_vmalloc      16384  1 uvcvideo
videobuf2_memops       16384  1 videobuf2_vmalloc
videobuf2_v4l2         28672  1 uvcvideo
videobuf2_common       53248  2 videobuf2_v4l2,uvcvideo
videodev              217088  3 videobuf2_v4l2,uvcvideo,videobuf2_common
media                  45056  2 videodev,uvcvideo
intel_rapl             24576  0
x86_pkg_temp_thermal    16384  0
snd_hda_intel          45056  3
intel_powerclamp       16384  0
snd_hda_codec         151552  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
kvm_intel             245760  0
crct10dif_pclmul       16384  0
crc32_pclmul           16384  0
ghash_clmulni_intel    16384  0
snd_hda_core           94208  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hwdep              16384  1 snd_hda_codec
pcbc                   16384  0
i915                 2097152  27
joydev                 24576  0
aesni_intel           200704  2
mousedev               24576  0
arc4                   16384  2
snd_pcm               131072  4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
iwldvm                270336  0
kvmgt                  28672  0
aes_x86_64             20480  1 aesni_intel
crypto_simd            16384  1 aesni_intel
mac80211              929792  1 iwldvm
vfio_mdev              16384  0
cryptd                 28672  3 crypto_simd,ghash_clmulni_intel,aesni_intel
mdev                   20480  2 kvmgt,vfio_mdev
vfio_iommu_type1       28672  0
vfio                   32768  3 kvmgt,vfio_mdev,vfio_iommu_type1
glue_helper            16384  1 aesni_intel
intel_cstate           16384  0
snd_timer              36864  1 snd_pcm
kvm                   737280  2 kvmgt,kvm_intel
iwlwifi               344064  1 iwldvm
irqbypass              16384  1 kvm
i2c_algo_bit           16384  1 i915
iTCO_wdt               16384  0
iTCO_vendor_support    16384  1 iTCO_wdt
asus_nb_wmi            28672  0
intel_uncore          135168  0
asus_wmi               32768  1 asus_nb_wmi
wmi_bmof               16384  0
mxm_wmi                16384  0
atl1c                  53248  0
sparse_keymap          16384  1 asus_wmi
intel_rapl_perf        16384  0
snd                    98304  14 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
soundcore              16384  1 snd
psmouse               172032  0
drm_kms_helper        208896  1 i915
drm                   495616  12 drm_kms_helper,i915
cfg80211              778240  3 iwldvm,iwlwifi,mac80211
intel_gtt              24576  1 i915
agpgart                49152  2 intel_gtt,drm
pcspkr                 16384  0
syscopyarea            16384  1 drm_kms_helper
pcc_cpufreq            16384  0
input_leds             16384  0
rfkill                 28672  6 asus_wmi,cfg80211
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
fb_sys_fops            16384  1 drm_kms_helper
evdev                  24576  19
mei_me                 45056  0
mei                   114688  1 mei_me
i2c_i801               32768  0
mac_hid                16384  0
lpc_ich                28672  0
wmi                    28672  3 asus_wmi,wmi_bmof,mxm_wmi
ac                     16384  0
battery                24576  0
uinput                 20480  0
coretemp               16384  0
msr                    16384  0
crypto_user            16384  0
ip_tables              28672  0
x_tables               45056  1 ip_tables
ext4                  733184  2
crc32c_generic         16384  0
crc16                  16384  1 ext4
mbcache                16384  1 ext4
jbd2                  126976  1 ext4
fscrypto               32768  1 ext4
hid_generic            16384  0
usbhid                 57344  0
hid                   139264  2 usbhid,hid_generic
sr_mod                 28672  0
cdrom                  69632  1 sr_mod
sd_mod                 61440  5
ahci                   40960  4
libahci                40960  1 ahci
serio_raw              16384  0
atkbd                  32768  0
libata                278528  2 libahci,ahci
libps2                 16384  2 atkbd,psmouse
xhci_pci               16384  0
scsi_mod              253952  3 sd_mod,libata,sr_mod
xhci_hcd              262144  1 xhci_pci
ehci_pci               16384  0
crc32c_intel           24576  4
ehci_hcd               94208  1 ehci_pci
i8042                  32768  1 asus_nb_wmi
serio                  28672  9 serio_raw,atkbd,psmouse,i8042
Here is the output of inxi -Fxxz
           tk: Qt 5.11.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Battery:   ID-1: BAT0 charge: 43.8 Wh condition: 45.9/59.4 Wh (77%) volts: 12.3/10.8 model: ASUSTek K53--54 type: Li-ion
           serial: <filter> status: Unknown
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 35138
           Speed: 798 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798 5: 798 6: 798 7: 798 8: 798
           bus ID: 00:02.0 chip ID: 8086:0116
           Device-2: NVIDIA GF119M [GeForce 610M] driver: N/A bus ID: 01:00.0 chip ID: 10de:1058
           Display: x11 server: X.Org 1.20.3 driver: intel compositor: kwin_x11 resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 18.2.5 compat-v: 3.0 direct render: Yes
           bus ID: 00:1b.0 chip ID: 8086:1c20
Network:   Device-1: Intel Centrino Wireless-N 100 driver: iwlwifi v: kernel port: e040 bus ID: 03:00.0 chip ID: 8086:08ae
           bus ID: 05:00.0 chip ID: 1969:1083
Drives:    Local Storage: total: 298.09 GiB used: 30.84 GiB (10.3%)
           ID-1: /dev/sda vendor: Hitachi model: HTS543232A7A384 size: 298.09 GiB speed: 3.0 Gb/s rotation: 5400 rpm
           serial: <filter> rev: A60W scheme: MBR
Partition: ID-1: / size: 46.22 GiB used: 14.90 GiB (32.2%) fs: ext4 dev: /dev/sda3
           ID-2: /home size: 237.97 GiB used: 15.93 GiB (6.7%) fs: ext4 dev: /dev/sda6
Sensors:   System Temperatures: cpu: 48.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 1700
Info:      Processes: 228 Uptime: 1h 53m Memory: 5.60 GiB used: 1.47 GiB (26.2%) Init: systemd v: 239 Compilers: gcc: 8.2.1
           Shell: zsh v: 5.6.2 running in: konsole inxi: 3.0.27
Please, provide
mhwd -li
pacman -Qs acpi
cat /var/log/Xorg.0.log*
systemctl status bumblebeed
journalctl -g bbswitch | cat
cat /etc/modprobe.d/*.conf |  grep bbswitch
cat /etc/bumblebee/bumblebee.conf | grep -B2 "PMM\|TurnCard"
As I suspected the iwlwifi module would not unload because you must unload the associated module first. You could try this test before suspending.
sudo systemctl stop NetworkManager
sudo ip link set wlp3s0 down
sudo modprobe -r iwldvm
sudo modprobe -r iwlwifi
Then attempt suspending.
You also definitely want to resolve the wallpaper issue.
From mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-390xx-bumblebee            2018.08.09               false            PCI
From pacman -Qs acpi
local/acpi 1.7-2
    Client for battery, power, and thermal readings
local/acpid 2.0.30-1
    A daemon for delivering ACPI power management events with netlink support
From cat /var/log/Xorg.0.log*
[    33.539] (--) Log file renamed from "/var/log/Xorg.pid-624.log" to "/var/log/Xorg.0.log"
[    33.639]
X.Org X Server 1.20.3
[    33.639] Build Operating System: Linux Arch Linux
[    33.639] Current Operating System: Linux manjaro 4.19.2-1-MANJARO #1 SMP PREEMPT Tue Nov 13 22:35:25 UTC 2018 x86_64
[    33.640] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=0ac6bb9b-f8fc-4881-8e77-13fbd5411696 rw quiet resume=UUID=32a46540-ba6e-4d80-a310-4dc2896ef306
[    33.640] Build Date: 25 October 2018  04:42:32PM
[    33.640]
[    33.640] Current version of pixman: 0.34.0
[    33.640]    Before reporting problems, check http://wiki.x.org
[    33.640] Markers: (--) probed, (**) from config file, (==) default setting,
[    33.640] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 20 19:13:54 2018
[    33.679] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    33.680] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    34.048] (==) No Layout section.  Using the first Screen section.
[    34.048] (==) No screen section available. Using defaults.
[    34.048] (**) |-->Screen "Default Screen Section" (0)
[    34.048] (**) |   |-->Monitor "<default monitor>"
[    34.076] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[    34.076] (**) |   |-->Device "Device0"
[    34.077] (==) No monitor specified for screen "Default Screen Section".
[    34.077] (==) Automatically adding devices
[    34.077] (==) Automatically enabling devices
[    34.077] (==) Automatically adding GPU devices
[    34.077] (==) Automatically binding GPU devices
[    34.077] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    34.163] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    34.163]    Entry deleted from font path.
[    34.163] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    34.163] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[    34.163]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[    34.163] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[    34.164]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[    34.164] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[    34.164] (==) ModulePath set to "/usr/lib/xorg/modules"
[    34.164] (WW) Ignoring unrecognized extension "Composite"
[    34.164] (**) Extension "RENDER" is enabled
[    34.164] (II) The server relies on udev to provide the list of input devices.
[    34.164] (II) Module ABI versions:
[    34.164]    X.Org ANSI C Emulation: 0.4
[    34.164]    X.Org Video Driver: 24.0
[    34.164]    X.Org XInput driver : 24.1
[    34.164]    X.Org Server Extension : 10.0
[    34.166] (++) using VT number 1
[    34.166] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    34.168] (II) xfree86: Adding drm device (/dev/dri/card0)
[    34.195] (--) PCI:*(0@0:2:0) 8086:0116:1043:1652 rev 9, Mem @ 0xdc400000/4194304, 0xb0000000/268435456, I/O @ 0x0000e000/64, BIOS @ 0x????????/131072
[    34.196] (--) PCI: (1@0:0:0) 10de:1058:1043:1652 rev 161, Mem @ 0xdb000000/16777216, 0xc0000000/134217728, 0xc8000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
[    34.196] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    34.196] (II) LoadModule: "glx"
[    34.370] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    34.772] (II) Module glx: vendor="X.Org Foundation"
[    34.772]    compiled for 1.20.3, module version = 1.0.0
[    34.772]    ABI class: X.Org Server Extension, version 10.0
[    34.772] (II) LoadModule: "intel"
[    34.772] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    34.839] (II) Module intel: vendor="X.Org Foundation"
[    34.839]    compiled for 1.20.2, module version = 2.99.917
[    34.839]    Module class: X.Org Video Driver
[    34.839]    ABI class: X.Org Video Driver, version 24.0
[    34.839] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
        i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
        915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
        Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
        GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[    34.840] (II) intel: Driver for Intel(R) HD Graphics
[    34.840] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[    34.840] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[    34.856] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20180719
[    34.856] (II) intel(0): SNA compiled from 2.99.917-853-g0932a6b3
[    34.898] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 3000
[    34.898] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx; using a maximum of 4 threads
[    34.898] (II) intel(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[    34.898] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[    34.898] (==) intel(0): RGB weight 888
[    34.898] (==) intel(0): Default visual is TrueColor
[    34.899] (**) intel(0): Option "AccelMethod" "sna"
[    34.899] (**) intel(0): Option "DRI" "true"
[    34.900] (II) intel(0): Output LVDS1 has no monitor section
[    34.928] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output LVDS1
[    34.928] (II) intel(0): Enabled output LVDS1
[    34.928] (II) intel(0): Output VGA1 has no monitor section
[    34.928] (II) intel(0): Enabled output VGA1
[    34.928] (II) intel(0): Output HDMI1 has no monitor section
[    34.928] (II) intel(0): Enabled output HDMI1
[    34.928] (II) intel(0): Output DP1 has no monitor section
[    34.928] (II) intel(0): Enabled output DP1
[    34.928] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[    34.929] (II) intel(0): Output VIRTUAL1 has no monitor section
[    34.929] (II) intel(0): Enabled output VIRTUAL1
[    34.929] (--) intel(0): Output LVDS1 using initial mode 1366x768 on pipe 0
[    34.929] (==) intel(0): TearFree disabled
[    34.929] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[    34.929] (==) intel(0): DPI set to (96, 96)
[    34.929] (II) Loading sub module "dri3"
[    34.929] (II) LoadModule: "dri3"
[    34.929] (II) Module "dri3" already built-in
[    34.929] (II) Loading sub module "dri2"
[    34.929] (II) LoadModule: "dri2"
[    34.929] (II) Module "dri2" already built-in
[    34.929] (II) Loading sub module "present"
[    34.929] (II) LoadModule: "present"
[    34.929] (II) Module "present" already built-in
[    35.013] (II) intel(0): SNA initialized with Sandybridge (gen6, gt2) backend
[    35.013] (==) intel(0): Backing store enabled
[    35.013] (==) intel(0): Silken mouse disabled
[    35.013] (II) intel(0): HW Cursor enabled
[    35.014] (==) intel(0): DPMS enabled
[    35.014] (==) intel(0): Display hotplug detection enabled
[    35.037] (II) intel(0): [DRI2] Setup complete
[    35.037] (II) intel(0): [DRI2]   DRI driver: i965
[    35.038] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[    35.038] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[    35.038] (II) intel(0): hardware support for Present enabled
[    35.038] (II) Initializing extension Generic Event Extension
[    35.038] (II) Initializing extension SHAPE
[    35.039] (II) Initializing extension MIT-SHM
[    35.039] (II) Initializing extension XInputExtension
[    35.041] (II) Initializing extension XTEST
[    35.041] (II) Initializing extension BIG-REQUESTS
[    35.042] (II) Initializing extension SYNC
[    35.043] (II) Initializing extension XKEYBOARD
[    35.043] (II) Initializing extension XC-MISC
[    35.044] (II) Initializing extension SECURITY
[    35.044] (II) Initializing extension XFIXES
[    35.045] (II) Initializing extension RENDER
[    35.045] (II) Initializing extension RANDR
[    35.046] (II) Initializing extension COMPOSITE
[    35.047] (II) Initializing extension DAMAGE
[    35.048] (II) Initializing extension MIT-SCREEN-SAVER
[    35.048] (II) Initializing extension DOUBLE-BUFFER
[    35.048] (II) Initializing extension RECORD
[    35.049] (II) Initializing extension DPMS
[    35.049] (II) Initializing extension Present
[    35.049] (II) Initializing extension DRI3
[    35.049] (II) Initializing extension X-Resource
[    35.049] (II) Initializing extension XVideo
[    35.049] (II) Initializing extension XVideo-MotionCompensation
[    35.049] (II) Initializing extension GLX
[    35.360] (II) AIGLX: Loaded and initialized i965
[    35.360] (II) GLX: Initialized DRI2 GL provider for screen 0
[    35.360] (II) Initializing extension XFree86-VidModeExtension
[    35.360] (II) Initializing extension XFree86-DGA
[    35.361] (II) Initializing extension XFree86-DRI
[    35.361] (II) Initializing extension DRI2
[    35.381] (II) intel(0): switch to mode 1366x768@60.0 on LVDS1 using pipe 0, position (0, 0), rotation normal, reflection none
[    35.392] (II) intel(0): Setting screen physical size to 361 x 203
[    35.782] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    35.782] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    35.782] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    35.782] (**) Power Button: Applying InputClass "system-keyboard"
[    35.782] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    35.782] (II) LoadModule: "libinput"
[    35.782] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    35.876] (II) Module libinput: vendor="X.Org Foundation"
[    35.876]    compiled for 1.20.1, module version = 0.28.1
[    35.876]    Module class: X.Org XInput Driver
[    35.876]    ABI class: X.Org XInput driver, version 24.1
[    35.876] (II) Using input driver 'libinput' for 'Power Button'
[    35.876] (**) Power Button: always reports core events
[    35.876] (**) Option "Device" "/dev/input/event2"
[    35.876] (**) Option "_source" "server/udev"
[    35.951] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    35.951] (II) event2  - Power Button: device is a keyboard
[    35.951] (II) event2  - Power Button: device removed
[    35.999] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    35.999] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    35.999] (**) Option "xkb_model" "pc105"
[    35.999] (**) Option "xkb_layout" "es"
[    35.999] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.071] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    36.071] (II) event2  - Power Button: device is a keyboard
[    36.072] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[    36.072] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    36.072] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    36.072] (**) Video Bus: Applying InputClass "system-keyboard"
[    36.072] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    36.072] (II) Using input driver 'libinput' for 'Video Bus'
[    36.072] (**) Video Bus: always reports core events
[    36.072] (**) Option "Device" "/dev/input/event13"
[    36.073] (**) Option "_source" "server/udev"
[    36.075] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[    36.075] (II) event13 - Video Bus: device is a keyboard
[    36.075] (II) event13 - Video Bus: device removed
[    36.145] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input21/event13"
[    36.146] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    36.146] (**) Option "xkb_model" "pc105"
[    36.146] (**) Option "xkb_layout" "es"
[    36.146] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.149] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[    36.149] (II) event13 - Video Bus: device is a keyboard
[    36.150] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[    36.151] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    36.151] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    36.151] (**) Video Bus: Applying InputClass "system-keyboard"
[    36.151] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    36.151] (II) Using input driver 'libinput' for 'Video Bus'
[    36.151] (**) Video Bus: always reports core events
[    36.151] (**) Option "Device" "/dev/input/event12"
[    36.151] (**) Option "_source" "server/udev"
[    36.153] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[    36.153] (II) event12 - Video Bus: device is a keyboard
[    36.153] (II) event12 - Video Bus: device removed
[    36.212] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input20/event12"
[    36.212] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    36.212] (**) Option "xkb_model" "pc105"
[    36.212] (**) Option "xkb_layout" "es"
[    36.212] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.216] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[    36.216] (II) event12 - Video Bus: device is a keyboard
[    36.217] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    36.217] (II) No input driver specified, ignoring this device.
[    36.217] (II) This device may have been added with another device file.
[    36.218] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    36.218] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    36.218] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    36.218] (**) Sleep Button: Applying InputClass "system-keyboard"
[    36.218] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[    36.219] (II) Using input driver 'libinput' for 'Sleep Button'
[    36.219] (**) Sleep Button: always reports core events
[    36.219] (**) Option "Device" "/dev/input/event1"
[    36.219] (**) Option "_source" "server/udev"
[    36.221] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    36.221] (II) event1  - Sleep Button: device is a keyboard
[    36.221] (II) event1  - Sleep Button: device removed
[    36.252] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[    36.252] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[    36.252] (**) Option "xkb_model" "pc105"
[    36.252] (**) Option "xkb_layout" "es"
[    36.252] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.255] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    36.255] (II) event1  - Sleep Button: device is a keyboard
[    36.258] (II) config/udev: Adding input device ASUS USB2.0 WebCam: ASUS USB2.0 (/dev/input/event14)
[    36.258] (**) ASUS USB2.0 WebCam: ASUS USB2.0: Applying InputClass "evdev keyboard catchall"
[    36.258] (**) ASUS USB2.0 WebCam: ASUS USB2.0: Applying InputClass "libinput keyboard catchall"
[    36.258] (**) ASUS USB2.0 WebCam: ASUS USB2.0: Applying InputClass "system-keyboard"
[    36.258] (**) ASUS USB2.0 WebCam: ASUS USB2.0: Applying InputClass "Keyboard Defaults"
[    36.258] (II) Using input driver 'libinput' for 'ASUS USB2.0 WebCam: ASUS USB2.0'
[    36.259] (**) ASUS USB2.0 WebCam: ASUS USB2.0: always reports core events
[    36.259] (**) Option "Device" "/dev/input/event14"
[    36.259] (**) Option "_source" "server/udev"
[    36.262] (II) event14 - ASUS USB2.0 WebCam: ASUS USB2.0: is tagged by udev as: Keyboard
[    36.262] (II) event14 - ASUS USB2.0 WebCam: ASUS USB2.0: device is a keyboard
[    36.262] (II) event14 - ASUS USB2.0 WebCam: ASUS USB2.0: device removed
[    36.332] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input22/event14"
[    36.332] (II) XINPUT: Adding extended input device "ASUS USB2.0 WebCam: ASUS USB2.0" (type: KEYBOARD, id 10)
[    36.332] (**) Option "xkb_model" "pc105"
[    36.332] (**) Option "xkb_layout" "es"
[    36.332] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.337] (II) event14 - ASUS USB2.0 WebCam: ASUS USB2.0: is tagged by udev as: Keyboard
[    36.337] (II) event14 - ASUS USB2.0 WebCam: ASUS USB2.0: device is a keyboard
[    36.338] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event15)
[    36.338] (II) No input driver specified, ignoring this device.
[    36.338] (II) This device may have been added with another device file.
[    36.339] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event16)
[    36.339] (II) No input driver specified, ignoring this device.
[    36.339] (II) This device may have been added with another device file.
[    36.340] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event17)
[    36.340] (II) No input driver specified, ignoring this device.
[    36.340] (II) This device may have been added with another device file.
[    36.342] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver (/dev/input/event4)
[    36.342] (**) 2.4GHz 2way RF Receiver: Applying InputClass "evdev keyboard catchall"
[    36.342] (**) 2.4GHz 2way RF Receiver: Applying InputClass "libinput keyboard catchall"
[    36.342] (**) 2.4GHz 2way RF Receiver: Applying InputClass "system-keyboard"
[    36.342] (**) 2.4GHz 2way RF Receiver: Applying InputClass "Keyboard Defaults"
[    36.342] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver'
[    36.342] (**) 2.4GHz 2way RF Receiver: always reports core events
[    36.342] (**) Option "Device" "/dev/input/event4"
[    36.342] (**) Option "_source" "server/udev"
[    36.346] (II) event4  - 2.4GHz 2way RF Receiver: is tagged by udev as: Keyboard
[    36.346] (II) event4  - 2.4GHz 2way RF Receiver: device is a keyboard
[    36.346] (II) event4  - 2.4GHz 2way RF Receiver: device removed
[    36.386] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.0/0003:1BCF:05CA.0001/input/input8/event4"
[    36.386] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver" (type: KEYBOARD, id 11)
[    36.386] (**) Option "xkb_model" "pc105"
[    36.386] (**) Option "xkb_layout" "es"
[    36.386] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.390] (II) event4  - 2.4GHz 2way RF Receiver: is tagged by udev as: Keyboard
[    36.390] (II) event4  - 2.4GHz 2way RF Receiver: device is a keyboard
[    36.392] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver (/dev/input/event6)
[    36.393] (II) No input driver specified, ignoring this device.
[    36.393] (II) This device may have been added with another device file.
[    36.395] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver Consumer Control (/dev/input/event7)
[    36.395] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[    36.395] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[    36.395] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "system-keyboard"
[    36.395] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[    36.395] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver Consumer Control'
[    36.395] (**) 2.4GHz 2way RF Receiver Consumer Control: always reports core events
[    36.395] (**) Option "Device" "/dev/input/event7"
[    36.395] (**) Option "_source" "server/udev"
[    36.399] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: is tagged by udev as: Keyboard
[    36.399] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: device is a keyboard
[    36.399] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: device removed
[    36.425] (II) libinput: 2.4GHz 2way RF Receiver Consumer Control: needs a virtual subdevice
[    36.426] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.1/0003:1BCF:05CA.0002/input/input11/event7"
[    36.426] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver Consumer Control" (type: MOUSE, id 12)
[    36.426] (**) Option "AccelerationScheme" "none"
[    36.426] (**) 2.4GHz 2way RF Receiver Consumer Control: (accel) selected scheme none/0
[    36.426] (**) 2.4GHz 2way RF Receiver Consumer Control: (accel) acceleration factor: 2.000
[    36.426] (**) 2.4GHz 2way RF Receiver Consumer Control: (accel) acceleration threshold: 4
[    36.430] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: is tagged by udev as: Keyboard
[    36.430] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: device is a keyboard
[    36.432] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver System Control (/dev/input/event8)
[    36.432] (**) 2.4GHz 2way RF Receiver System Control: Applying InputClass "evdev keyboard catchall"
[    36.432] (**) 2.4GHz 2way RF Receiver System Control: Applying InputClass "libinput keyboard catchall"
[    36.432] (**) 2.4GHz 2way RF Receiver System Control: Applying InputClass "system-keyboard"
[    36.432] (**) 2.4GHz 2way RF Receiver System Control: Applying InputClass "Keyboard Defaults"
[    36.433] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver System Control'
[    36.433] (**) 2.4GHz 2way RF Receiver System Control: always reports core events
[    36.433] (**) Option "Device" "/dev/input/event8"
[    36.433] (**) Option "_source" "server/udev"
[    36.436] (II) event8  - 2.4GHz 2way RF Receiver System Control: is tagged by udev as: Keyboard
[    36.436] (II) event8  - 2.4GHz 2way RF Receiver System Control: device is a keyboard
[    36.436] (II) event8  - 2.4GHz 2way RF Receiver System Control: device removed
[    36.466] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.1/0003:1BCF:05CA.0002/input/input12/event8"
[    36.466] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver System Control" (type: KEYBOARD, id 13)
[    36.466] (**) Option "xkb_model" "pc105"
[    36.466] (**) Option "xkb_layout" "es"
[    36.466] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.470] (II) event8  - 2.4GHz 2way RF Receiver System Control: is tagged by udev as: Keyboard
[    36.470] (II) event8  - 2.4GHz 2way RF Receiver System Control: device is a keyboard
[    36.472] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver Mouse (/dev/input/event5)
[    36.472] (**) 2.4GHz 2way RF Receiver Mouse: Applying InputClass "evdev pointer catchall"
[    36.473] (**) 2.4GHz 2way RF Receiver Mouse: Applying InputClass "libinput pointer catchall"
[    36.473] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver Mouse'
[    36.473] (**) 2.4GHz 2way RF Receiver Mouse: always reports core events
[    36.473] (**) Option "Device" "/dev/input/event5"
[    36.473] (**) Option "_source" "server/udev"
[    36.476] (II) event5  - 2.4GHz 2way RF Receiver Mouse: is tagged by udev as: Mouse
[    36.476] (II) event5  - 2.4GHz 2way RF Receiver Mouse: device is a pointer
[    36.476] (II) event5  - 2.4GHz 2way RF Receiver Mouse: device removed
[    36.532] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.1/0003:1BCF:05CA.0002/input/input9/event5"
[    36.532] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver Mouse" (type: MOUSE, id 14)
[    36.533] (**) Option "AccelerationScheme" "none"
[    36.533] (**) 2.4GHz 2way RF Receiver Mouse: (accel) selected scheme none/0
[    36.533] (**) 2.4GHz 2way RF Receiver Mouse: (accel) acceleration factor: 2.000
[    36.533] (**) 2.4GHz 2way RF Receiver Mouse: (accel) acceleration threshold: 4
[    36.536] (II) event5  - 2.4GHz 2way RF Receiver Mouse: is tagged by udev as: Mouse
[    36.536] (II) event5  - 2.4GHz 2way RF Receiver Mouse: device is a pointer
[    36.538] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver Mouse (/dev/input/mouse0)
[    36.539] (II) No input driver specified, ignoring this device.
[    36.539] (II) This device may have been added with another device file.
[    36.540] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event10)
[    36.540] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    36.540] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    36.540] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[    36.540] (**) Asus WMI hotkeys: Applying InputClass "Keyboard Defaults"
[    36.540] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[    36.540] (**) Asus WMI hotkeys: always reports core events
[    36.540] (**) Option "Device" "/dev/input/event10"
[    36.540] (**) Option "_source" "server/udev"
[    36.542] (II) event10 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    36.542] (II) event10 - Asus WMI hotkeys: device is a keyboard
[    36.542] (II) event10 - Asus WMI hotkeys: device removed
[    36.612] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input19/event10"
[    36.612] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 15)
[    36.612] (**) Option "xkb_model" "pc105"
[    36.612] (**) Option "xkb_layout" "es"
[    36.612] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.615] (II) event10 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    36.615] (II) event10 - Asus WMI hotkeys: device is a keyboard
[    36.616] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[    36.617] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    36.617] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    36.617] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    36.617] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[    36.617] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    36.617] (**) AT Translated Set 2 keyboard: always reports core events
[    36.617] (**) Option "Device" "/dev/input/event3"
[    36.617] (**) Option "_source" "server/udev"
[    36.619] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    36.619] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    36.620] (II) event3  - AT Translated Set 2 keyboard: device removed
[    36.665] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[    36.666] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[    36.666] (**) Option "xkb_model" "pc105"
[    36.666] (**) Option "xkb_layout" "es"
[    36.666] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    36.669] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    36.669] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    36.671] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event11)
[    36.671] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[    36.671] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[    36.672] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad catchall"
[    36.672] (**) ETPS/2 Elantech Touchpad: Applying InputClass "Default clickpad buttons"
[    36.672] (II) LoadModule: "synaptics"
[    36.672] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[    36.695] (II) Module synaptics: vendor="X.Org Foundation"
[    36.695]    compiled for 1.20.0, module version = 1.9.1
[    36.695]    Module class: X.Org XInput Driver
[    36.695]    ABI class: X.Org XInput driver, version 24.1
[    36.695] (II) Using input driver 'synaptics' for 'ETPS/2 Elantech Touchpad'
[    36.695] (**) ETPS/2 Elantech Touchpad: always reports core events
[    36.695] (**) Option "Device" "/dev/input/event11"
[    36.746] (II) synaptics: ETPS/2 Elantech Touchpad: ignoring touch events for semi-multitouch device
[    36.746] (--) synaptics: ETPS/2 Elantech Touchpad: x-axis range 0 - 2508 (res 31)
[    36.746] (--) synaptics: ETPS/2 Elantech Touchpad: y-axis range 0 - 1320 (res 31)
[    36.746] (--) synaptics: ETPS/2 Elantech Touchpad: pressure range 0 - 255
[    36.746] (--) synaptics: ETPS/2 Elantech Touchpad: finger width range 0 - 15
[    36.746] (--) synaptics: ETPS/2 Elantech Touchpad: buttons: left right double triple
[    36.746] (--) synaptics: ETPS/2 Elantech Touchpad: Vendor 0x2 Product 0xe
[    36.746] (--) synaptics: ETPS/2 Elantech Touchpad: touchpad found
[    36.746] (**) ETPS/2 Elantech Touchpad: always reports core events
[    36.799] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input18/event11"
[    36.799] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 17)
[    36.799] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) MinSpeed is now constant deceleration 2.5
[    36.799] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) MaxSpeed is now 1.75
[    36.799] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) AccelFactor is now 0.071
[    36.800] (**) ETPS/2 Elantech Touchpad: (accel) keeping acceleration scheme 1
[    36.800] (**) ETPS/2 Elantech Touchpad: (accel) acceleration profile 1
[    36.800] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[    36.800] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[    36.800] (--) synaptics: ETPS/2 Elantech Touchpad: touchpad found
[    36.801] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse1)
[    36.801] (**) ETPS/2 Elantech Touchpad: Ignoring device from InputClass "touchpad ignore duplicates"
[    36.802] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[    36.802] (II) No input driver specified, ignoring this device.
[    36.802] (II) This device may have been added with another device file.
[    36.829] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[    36.830] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[    36.830] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "system-keyboard"
[    36.830] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[    36.830] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver Consumer Control'
[    36.830] (**) 2.4GHz 2way RF Receiver Consumer Control: always reports core events
[    36.830] (**) Option "Device" "/dev/input/event7"
[    36.830] (**) Option "_source" "_driver/libinput"
[    36.830] (II) libinput: 2.4GHz 2way RF Receiver Consumer Control: is a virtual subdevice
[    36.830] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.1/0003:1BCF:05CA.0002/input/input11/event7"
[    36.830] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver Consumer Control" (type: KEYBOARD, id 18)
[    36.830] (**) Option "xkb_model" "pc105"
[    36.830] (**) Option "xkb_layout" "es"
[    36.830] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    37.015] (II) intel(0): EDID vendor "LGD", prod id 732
[    37.015] (II) intel(0): Printing DDC gathered Modelines:
[    37.015] (II) intel(0): Modeline "1366x768"x0.0   70.00  1366 1402 1450 1492  768 771 776 782 -hsync -vsync (46.9 kHz eP)
[    23.700] (--) Log file renamed from "/var/log/Xorg.pid-631.log" to "/var/log/Xorg.0.log"
[    23.778]
[    23.778] Build Operating System: Linux Arch Linux
[    23.778] Current Operating System: Linux manjaro 4.19.2-1-MANJARO #1 SMP PREEMPT Tue Nov 13 22:35:25 UTC 2018 x86_64
[    23.778] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=0ac6bb9b-f8fc-4881-8e77-13fbd5411696 rw quiet resume=UUID=32a46540-ba6e-4d80-a310-4dc2896ef306
[    23.779] Build Date: 25 October 2018  04:42:32PM
[    23.779]
[    23.779] Current version of pixman: 0.34.0
[    23.779]    Before reporting problems, check http://wiki.x.org
[    23.779] Markers: (--) probed, (**) from config file, (==) default setting,
[    23.779] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 20 08:49:13 2018
[    23.818] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    23.818] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    23.887] (==) No Layout section.  Using the first Screen section.
[    23.887] (==) No screen section available. Using defaults.
[    23.887] (**) |-->Screen "Default Screen Section" (0)
[    23.887] (**) |   |-->Monitor "<default monitor>"
[    23.915] (==) No device specified for screen "Default Screen Section".
[    23.915] (**) |   |-->Device "Device0"
[    23.915] (==) No monitor specified for screen "Default Screen Section".
[    23.915] (==) Automatically adding devices
[    23.915] (==) Automatically enabling devices
[    23.915] (==) Automatically adding GPU devices
[    23.915] (==) Automatically binding GPU devices
[    23.915] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    23.980] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    23.980]    Entry deleted from font path.
[    23.980] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    23.981] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[    23.981]    Entry deleted from font path.
[    23.981]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[    23.981] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[    23.981]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[    23.981] (==) FontPath set to:
[    23.981] (==) ModulePath set to "/usr/lib/xorg/modules"
[    23.981] (WW) Ignoring unrecognized extension "Composite"
[    23.981] (**) Extension "RENDER" is enabled
[    23.982] (II) The server relies on udev to provide the list of input devices.
[    23.982] (II) Module ABI versions:
[    23.982]    X.Org ANSI C Emulation: 0.4
[    23.982]    X.Org Video Driver: 24.0
[    23.982]    X.Org XInput driver : 24.1
[    23.982]    X.Org Server Extension : 10.0
[    23.984] (++) using VT number 1
[    23.984] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    23.986] (II) xfree86: Adding drm device (/dev/dri/card0)
[    24.013] (--) PCI:*(0@0:2:0) 8086:0116:1043:1652 rev 9, Mem @ 0xdc400000/4194304, 0xb0000000/268435456, I/O @ 0x0000e000/64, BIOS @ 0x????????/131072
[    24.013] (--) PCI: (1@0:0:0) 10de:1058:1043:1652 rev 161, Mem @ 0xdb000000/16777216, 0xc0000000/134217728, 0xc8000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
[    24.013] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    24.013] (II) LoadModule: "glx"
[    24.142] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    24.268] (II) Module glx: vendor="X.Org Foundation"
[    24.268]    compiled for 1.20.3, module version = 1.0.0
[    24.268]    ABI class: X.Org Server Extension, version 10.0
[    24.268] (II) LoadModule: "intel"
[    24.268] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    24.311] (II) Module intel: vendor="X.Org Foundation"
[    24.311]    compiled for 1.20.2, module version = 2.99.917
[    24.311]    Module class: X.Org Video Driver
[    24.311]    ABI class: X.Org Video Driver, version 24.0
[    24.311] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[    24.312] (II) intel: Driver for Intel(R) HD Graphics
[    24.312] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[    24.312] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[    24.313] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20180719
[    24.313] (II) intel(0): SNA compiled from 2.99.917-853-g0932a6b3
[    24.348] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 3000
[    24.348] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx; using a maximum of 4 threads
[    24.348] (II) intel(0): Creating default Display subsection in Screen section
[    24.348] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[    24.348] (==) intel(0): RGB weight 888
[    24.348] (==) intel(0): Default visual is TrueColor
[    24.348] (**) intel(0): Option "AccelMethod" "sna"
[    24.348] (**) intel(0): Option "DRI" "true"
[    24.350] (II) intel(0): Output LVDS1 has no monitor section
[    24.375] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output LVDS1
[    24.376] (II) intel(0): Enabled output LVDS1
[    24.376] (II) intel(0): Output VGA1 has no monitor section
[    24.376] (II) intel(0): Enabled output VGA1
[    24.376] (II) intel(0): Output HDMI1 has no monitor section
[    24.376] (II) intel(0): Enabled output HDMI1
[    24.376] (II) intel(0): Output DP1 has no monitor section
[    24.377] (II) intel(0): Enabled output DP1
[    24.377] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[    24.377] (II) intel(0): Output VIRTUAL1 has no monitor section
[    24.377] (II) intel(0): Enabled output VIRTUAL1
[    24.378] (--) intel(0): Output LVDS1 using initial mode 1366x768 on pipe 0
[    24.378] (==) intel(0): TearFree disabled
[    24.378] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[    24.378] (==) intel(0): DPI set to (96, 96)
[    24.378] (II) Loading sub module "dri3"
[    24.378] (II) LoadModule: "dri3"
[    24.378] (II) Module "dri3" already built-in
[    24.378] (II) Loading sub module "dri2"
[    24.378] (II) LoadModule: "dri2"
[    24.378] (II) Module "dri2" already built-in
[    24.378] (II) Loading sub module "present"
[    24.378] (II) LoadModule: "present"
[    24.378] (II) Module "present" already built-in
[    24.405] (II) intel(0): SNA initialized with Sandybridge (gen6, gt2) backend
[    24.405] (==) intel(0): Backing store enabled
[    24.405] (==) intel(0): Silken mouse disabled
[    24.406] (II) intel(0): HW Cursor enabled
[    24.415] (==) intel(0): DPMS enabled
[    24.416] (==) intel(0): Display hotplug detection enabled
[    24.417] (II) intel(0): [DRI2] Setup complete
[    24.417] (II) intel(0): [DRI2]   DRI driver: i965
[    24.417] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[    24.417] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[    24.417] (II) intel(0): hardware support for Present enabled
[    24.417] (II) Initializing extension Generic Event Extension
[    24.417] (II) Initializing extension SHAPE
[    24.418] (II) Initializing extension MIT-SHM
[    24.418] (II) Initializing extension XInputExtension
[    24.431] (II) Initializing extension XTEST
[    24.432] (II) Initializing extension BIG-REQUESTS
[    24.432] (II) Initializing extension SYNC
[    24.433] (II) Initializing extension XKEYBOARD
[    24.433] (II) Initializing extension XC-MISC
[    24.434] (II) Initializing extension SECURITY
[    24.434] (II) Initializing extension XFIXES
[    24.435] (II) Initializing extension RENDER
[    24.435] (II) Initializing extension RANDR
[    24.436] (II) Initializing extension COMPOSITE
[    24.437] (II) Initializing extension DAMAGE
[    24.437] (II) Initializing extension MIT-SCREEN-SAVER
[    24.438] (II) Initializing extension DOUBLE-BUFFER
[    24.438] (II) Initializing extension RECORD
[    24.439] (II) Initializing extension DPMS
[    24.439] (II) Initializing extension Present
[    24.440] (II) Initializing extension DRI3
[    24.440] (II) Initializing extension X-Resource
[    24.441] (II) Initializing extension XVideo
[    24.441] (II) Initializing extension XVideo-MotionCompensation
[    24.441] (II) Initializing extension GLX
[    24.731] (II) AIGLX: Loaded and initialized i965
[    24.731] (II) GLX: Initialized DRI2 GL provider for screen 0
[    24.731] (II) Initializing extension XFree86-VidModeExtension
[    24.732] (II) Initializing extension XFree86-DGA
[    24.732] (II) Initializing extension XFree86-DRI
[    24.732] (II) Initializing extension DRI2
[    24.753] (II) intel(0): switch to mode 1366x768@60.0 on LVDS1 using pipe 0, position (0, 0), rotation normal, reflection none
[    24.758] (II) intel(0): Setting screen physical size to 361 x 203
[    25.135] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    25.135] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    25.135] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    25.135] (**) Power Button: Applying InputClass "system-keyboard"
[    25.135] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    25.135] (II) LoadModule: "libinput"
[    25.135] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    25.181] (II) Module libinput: vendor="X.Org Foundation"
[    25.181]    compiled for 1.20.1, module version = 0.28.1
[    25.181]    Module class: X.Org XInput Driver
[    25.181]    ABI class: X.Org XInput driver, version 24.1
[    25.181] (II) Using input driver 'libinput' for 'Power Button'
[    25.181] (**) Power Button: always reports core events
[    25.181] (**) Option "Device" "/dev/input/event2"
[    25.181] (**) Option "_source" "server/udev"
[    25.260] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    25.260] (II) event2  - Power Button: device is a keyboard
[    25.260] (II) event2  - Power Button: device removed
[    25.296] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    25.296] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    25.296] (**) Option "xkb_model" "pc105"
[    25.296] (**) Option "xkb_layout" "es"
[    25.296] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    25.364] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    25.364] (II) event2  - Power Button: device is a keyboard
[    25.366] (II) config/udev: Adding input device Video Bus (/dev/input/event14)
[    25.366] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    25.366] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    25.366] (**) Video Bus: Applying InputClass "system-keyboard"
[    25.366] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    25.366] (II) Using input driver 'libinput' for 'Video Bus'
[    25.366] (**) Video Bus: always reports core events
[    25.366] (**) Option "Device" "/dev/input/event14"
[    25.366] (**) Option "_source" "server/udev"
[    25.368] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[    25.368] (II) event14 - Video Bus: device is a keyboard
[    25.369] (II) event14 - Video Bus: device removed
[    25.442] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input22/event14"
[    25.442] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    25.442] (**) Option "xkb_model" "pc105"
[    25.442] (**) Option "xkb_layout" "es"
[    25.442] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    25.446] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[    25.446] (II) event14 - Video Bus: device is a keyboard
[    25.447] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[    25.447] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    25.447] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    25.447] (**) Video Bus: Applying InputClass "system-keyboard"
[    25.447] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    25.447] (II) Using input driver 'libinput' for 'Video Bus'
[    25.448] (**) Video Bus: always reports core events
[    25.448] (**) Option "Device" "/dev/input/event13"
[    25.448] (**) Option "_source" "server/udev"
[    25.450] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[    25.450] (II) event13 - Video Bus: device is a keyboard
[    25.450] (II) event13 - Video Bus: device removed
[    25.509] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input21/event13"
[    25.509] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    25.509] (**) Option "xkb_model" "pc105"
[    25.509] (**) Option "xkb_layout" "es"
[    25.509] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    25.512] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[    25.512] (II) event13 - Video Bus: device is a keyboard
[    25.514] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    25.514] (II) No input driver specified, ignoring this device.
[    25.514] (II) This device may have been added with another device file.
[    25.515] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    25.515] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    25.515] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    25.515] (**) Sleep Button: Applying InputClass "system-keyboard"
[    25.515] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[    25.515] (II) Using input driver 'libinput' for 'Sleep Button'
[    25.515] (**) Sleep Button: always reports core events
[    25.515] (**) Option "Device" "/dev/input/event1"
[    25.515] (**) Option "_source" "server/udev"
[    25.517] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    25.517] (II) event1  - Sleep Button: device is a keyboard
[    25.518] (II) event1  - Sleep Button: device removed
[    25.549] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[    25.549] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[    25.549] (**) Option "xkb_model" "pc105"
[    25.549] (**) Option "xkb_layout" "es"
[    25.549] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    25.552] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    25.552] (II) event1  - Sleep Button: device is a keyboard
[    25.555] (II) config/udev: Adding input device ASUS USB2.0 WebCam: ASUS USB2.0 (/dev/input/event12)
[    25.555] (**) ASUS USB2.0 WebCam: ASUS USB2.0: Applying InputClass "evdev keyboard catchall"
[    25.555] (**) ASUS USB2.0 WebCam: ASUS USB2.0: Applying InputClass "libinput keyboard catchall"
[    25.555] (**) ASUS USB2.0 WebCam: ASUS USB2.0: Applying InputClass "system-keyboard"
[    25.555] (**) ASUS USB2.0 WebCam: ASUS USB2.0: Applying InputClass "Keyboard Defaults"
[    25.555] (II) Using input driver 'libinput' for 'ASUS USB2.0 WebCam: ASUS USB2.0'
[    25.555] (**) ASUS USB2.0 WebCam: ASUS USB2.0: always reports core events
[    25.555] (**) Option "Device" "/dev/input/event12"
[    25.555] (**) Option "_source" "server/udev"
[    25.559] (II) event12 - ASUS USB2.0 WebCam: ASUS USB2.0: is tagged by udev as: Keyboard
[    25.559] (II) event12 - ASUS USB2.0 WebCam: ASUS USB2.0: device is a keyboard
[    25.559] (II) event12 - ASUS USB2.0 WebCam: ASUS USB2.0: device removed
[    25.616] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input20/event12"
[    25.616] (II) XINPUT: Adding extended input device "ASUS USB2.0 WebCam: ASUS USB2.0" (type: KEYBOARD, id 10)
[    25.616] (**) Option "xkb_model" "pc105"
[    25.616] (**) Option "xkb_layout" "es"
[    25.616] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    25.620] (II) event12 - ASUS USB2.0 WebCam: ASUS USB2.0: is tagged by udev as: Keyboard
[    25.620] (II) event12 - ASUS USB2.0 WebCam: ASUS USB2.0: device is a keyboard
[    25.621] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event15)
[    25.621] (II) No input driver specified, ignoring this device.
[    25.621] (II) This device may have been added with another device file.
[    25.622] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event16)
[    25.622] (II) No input driver specified, ignoring this device.
[    25.622] (II) This device may have been added with another device file.
[    25.623] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event17)
[    25.623] (II) No input driver specified, ignoring this device.
[    25.623] (II) This device may have been added with another device file.
[    25.625] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver (/dev/input/event4)
[    25.625] (**) 2.4GHz 2way RF Receiver: Applying InputClass "evdev keyboard catchall"
[    25.625] (**) 2.4GHz 2way RF Receiver: Applying InputClass "libinput keyboard catchall"
[    25.625] (**) 2.4GHz 2way RF Receiver: Applying InputClass "system-keyboard"
[    25.625] (**) 2.4GHz 2way RF Receiver: Applying InputClass "Keyboard Defaults"
[    25.625] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver'
[    25.626] (**) 2.4GHz 2way RF Receiver: always reports core events
[    25.626] (**) Option "Device" "/dev/input/event4"
[    25.626] (**) Option "_source" "server/udev"
[    25.629] (II) event4  - 2.4GHz 2way RF Receiver: is tagged by udev as: Keyboard
[    25.629] (II) event4  - 2.4GHz 2way RF Receiver: device is a keyboard
[    25.630] (II) event4  - 2.4GHz 2way RF Receiver: device removed
[    25.669] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.0/0003:1BCF:05CA.0001/input/input8/event4"
[    25.669] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver" (type: KEYBOARD, id 11)
[    25.669] (**) Option "xkb_model" "pc105"
[    25.669] (**) Option "xkb_layout" "es"
[    25.669] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    25.674] (II) event4  - 2.4GHz 2way RF Receiver: is tagged by udev as: Keyboard
[    25.674] (II) event4  - 2.4GHz 2way RF Receiver: device is a keyboard
[    25.676] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver (/dev/input/event6)
[    25.676] (II) No input driver specified, ignoring this device.
[    25.676] (II) This device may have been added with another device file.
[    25.678] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver Consumer Control (/dev/input/event7)
[    25.678] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[    25.678] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[    25.678] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "system-keyboard"
[    25.678] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[    25.678] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver Consumer Control'
[    25.678] (**) 2.4GHz 2way RF Receiver Consumer Control: always reports core events
[    25.678] (**) Option "Device" "/dev/input/event7"
[    25.678] (**) Option "_source" "server/udev"
[    25.682] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: is tagged by udev as: Keyboard
[    25.682] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: device is a keyboard
[    25.682] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: device removed
[    25.722] (II) libinput: 2.4GHz 2way RF Receiver Consumer Control: needs a virtual subdevice
[    25.722] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.1/0003:1BCF:05CA.0002/input/input11/event7"
[    25.723] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver Consumer Control" (type: MOUSE, id 12)
[    25.723] (**) Option "AccelerationScheme" "none"
[    25.723] (**) 2.4GHz 2way RF Receiver Consumer Control: (accel) selected scheme none/0
[    25.723] (**) 2.4GHz 2way RF Receiver Consumer Control: (accel) acceleration factor: 2.000
[    25.723] (**) 2.4GHz 2way RF Receiver Consumer Control: (accel) acceleration threshold: 4
[    25.727] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: is tagged by udev as: Keyboard
[    25.727] (II) event7  - 2.4GHz 2way RF Receiver Consumer Control: device is a keyboard
[    25.729] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver System Control (/dev/input/event8)
[    25.729] (**) 2.4GHz 2way RF Receiver System Control: Applying InputClass "evdev keyboard catchall"
[    25.729] (**) 2.4GHz 2way RF Receiver System Control: Applying InputClass "libinput keyboard catchall"
[    25.729] (**) 2.4GHz 2way RF Receiver System Control: Applying InputClass "system-keyboard"
[    25.729] (**) 2.4GHz 2way RF Receiver System Control: Applying InputClass "Keyboard Defaults"
[    25.729] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver System Control'
[    25.729] (**) 2.4GHz 2way RF Receiver System Control: always reports core events
[    25.729] (**) Option "Device" "/dev/input/event8"
[    25.729] (**) Option "_source" "server/udev"
[    25.733] (II) event8  - 2.4GHz 2way RF Receiver System Control: is tagged by udev as: Keyboard
[    25.733] (II) event8  - 2.4GHz 2way RF Receiver System Control: device is a keyboard
[    25.733] (II) event8  - 2.4GHz 2way RF Receiver System Control: device removed
[    25.762] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.1/0003:1BCF:05CA.0002/input/input12/event8"
[    25.762] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver System Control" (type: KEYBOARD, id 13)
[    25.762] (**) Option "xkb_model" "pc105"
[    25.762] (**) Option "xkb_layout" "es"
[    25.762] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    25.767] (II) event8  - 2.4GHz 2way RF Receiver System Control: is tagged by udev as: Keyboard
[    25.767] (II) event8  - 2.4GHz 2way RF Receiver System Control: device is a keyboard
[    25.769] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver Mouse (/dev/input/event5)
[    25.769] (**) 2.4GHz 2way RF Receiver Mouse: Applying InputClass "evdev pointer catchall"
[    25.769] (**) 2.4GHz 2way RF Receiver Mouse: Applying InputClass "libinput pointer catchall"
[    25.769] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver Mouse'
[    25.769] (**) 2.4GHz 2way RF Receiver Mouse: always reports core events
[    25.769] (**) Option "Device" "/dev/input/event5"
[    25.769] (**) Option "_source" "server/udev"
[    25.773] (II) event5  - 2.4GHz 2way RF Receiver Mouse: is tagged by udev as: Mouse
[    25.773] (II) event5  - 2.4GHz 2way RF Receiver Mouse: device is a pointer
[    25.773] (II) event5  - 2.4GHz 2way RF Receiver Mouse: device removed
[    25.829] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.1/0003:1BCF:05CA.0002/input/input9/event5"
[    25.829] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver Mouse" (type: MOUSE, id 14)
[    25.829] (**) Option "AccelerationScheme" "none"
[    25.830] (**) 2.4GHz 2way RF Receiver Mouse: (accel) selected scheme none/0
[    25.830] (**) 2.4GHz 2way RF Receiver Mouse: (accel) acceleration factor: 2.000
[    25.830] (**) 2.4GHz 2way RF Receiver Mouse: (accel) acceleration threshold: 4
[    25.833] (II) event5  - 2.4GHz 2way RF Receiver Mouse: is tagged by udev as: Mouse
[    25.833] (II) event5  - 2.4GHz 2way RF Receiver Mouse: device is a pointer
[    25.835] (II) config/udev: Adding input device 2.4GHz 2way RF Receiver Mouse (/dev/input/mouse0)
[    25.835] (II) No input driver specified, ignoring this device.
[    25.836] (II) This device may have been added with another device file.
[    25.837] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event10)
[    25.837] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    25.837] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    25.837] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[    25.837] (**) Asus WMI hotkeys: Applying InputClass "Keyboard Defaults"
[    25.837] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[    25.837] (**) Asus WMI hotkeys: always reports core events
[    25.837] (**) Option "Device" "/dev/input/event10"
[    25.837] (**) Option "_source" "server/udev"
[    25.839] (II) event10 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    25.839] (II) event10 - Asus WMI hotkeys: device is a keyboard
[    25.839] (II) event10 - Asus WMI hotkeys: device removed
[    25.896] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input19/event10"
[    25.896] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 15)
[    25.896] (**) Option "xkb_model" "pc105"
[    25.896] (**) Option "xkb_layout" "es"
[    25.896] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    25.898] (II) event10 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    25.898] (II) event10 - Asus WMI hotkeys: device is a keyboard
[    25.900] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[    25.900] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    25.900] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    25.900] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    25.900] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[    25.900] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    25.900] (**) AT Translated Set 2 keyboard: always reports core events
[    25.900] (**) Option "Device" "/dev/input/event3"
[    25.900] (**) Option "_source" "server/udev"
[    25.902] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    25.902] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    25.903] (II) event3  - AT Translated Set 2 keyboard: device removed
[    25.936] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[    25.936] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[    25.936] (**) Option "xkb_model" "pc105"
[    25.936] (**) Option "xkb_layout" "es"
[    25.936] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    25.939] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    25.939] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[    25.941] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event11)
[    25.942] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[    25.942] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[    25.942] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad catchall"
[    25.942] (**) ETPS/2 Elantech Touchpad: Applying InputClass "Default clickpad buttons"
[    25.942] (II) LoadModule: "synaptics"
[    25.942] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[    26.000] (II) Module synaptics: vendor="X.Org Foundation"
[    26.000]    compiled for 1.20.0, module version = 1.9.1
[    26.000]    Module class: X.Org XInput Driver
[    26.000]    ABI class: X.Org XInput driver, version 24.1
[    26.000] (II) Using input driver 'synaptics' for 'ETPS/2 Elantech Touchpad'
[    26.000] (**) ETPS/2 Elantech Touchpad: always reports core events
[    26.000] (**) Option "Device" "/dev/input/event11"
[    26.056] (II) synaptics: ETPS/2 Elantech Touchpad: ignoring touch events for semi-multitouch device
[    26.056] (--) synaptics: ETPS/2 Elantech Touchpad: x-axis range 0 - 2508 (res 31)
[    26.056] (--) synaptics: ETPS/2 Elantech Touchpad: y-axis range 0 - 1320 (res 31)
[    26.056] (--) synaptics: ETPS/2 Elantech Touchpad: pressure range 0 - 255
[    26.056] (--) synaptics: ETPS/2 Elantech Touchpad: finger width range 0 - 15
[    26.056] (--) synaptics: ETPS/2 Elantech Touchpad: buttons: left right double triple
[    26.056] (--) synaptics: ETPS/2 Elantech Touchpad: Vendor 0x2 Product 0xe
[    26.056] (--) synaptics: ETPS/2 Elantech Touchpad: touchpad found
[    26.056] (**) ETPS/2 Elantech Touchpad: always reports core events
[    26.109] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input18/event11"
[    26.109] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 17)
[    26.109] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) MinSpeed is now constant deceleration 2.5
[    26.109] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) MaxSpeed is now 1.75
[    26.109] (**) synaptics: ETPS/2 Elantech Touchpad: (accel) AccelFactor is now 0.071
[    26.110] (**) ETPS/2 Elantech Touchpad: (accel) keeping acceleration scheme 1
[    26.110] (**) ETPS/2 Elantech Touchpad: (accel) acceleration profile 1
[    26.110] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[    26.110] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[    26.110] (--) synaptics: ETPS/2 Elantech Touchpad: touchpad found
[    26.111] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse1)
[    26.111] (**) ETPS/2 Elantech Touchpad: Ignoring device from InputClass "touchpad ignore duplicates"
[    26.113] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[    26.113] (II) No input driver specified, ignoring this device.
[    26.113] (II) This device may have been added with another device file.
[    26.128] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[    26.128] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[    26.128] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "system-keyboard"
[    26.128] (**) 2.4GHz 2way RF Receiver Consumer Control: Applying InputClass "Keyboard Defaults"
[    26.128] (II) Using input driver 'libinput' for '2.4GHz 2way RF Receiver Consumer Control'
[    26.128] (**) 2.4GHz 2way RF Receiver Consumer Control: always reports core events
[    26.128] (**) Option "Device" "/dev/input/event7"
[    26.128] (**) Option "_source" "_driver/libinput"
[    26.128] (II) libinput: 2.4GHz 2way RF Receiver Consumer Control: is a virtual subdevice
[    26.128] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.1/0003:1BCF:05CA.0002/input/input11/event7"
[    26.128] (II) XINPUT: Adding extended input device "2.4GHz 2way RF Receiver Consumer Control" (type: KEYBOARD, id 18)
[    26.128] (**) Option "xkb_model" "pc105"
[    26.128] (**) Option "xkb_layout" "es"
[    26.128] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    26.416] (II) intel(0): EDID vendor "LGD", prod id 732
[    26.416] (II) intel(0): Printing DDC gathered Modelines:
[    26.416] (II) intel(0): Modeline "1366x768"x0.0   70.00  1366 1402 1450 1492  768 771 776 782 -hsync -vsync (46.9 kHz eP)
From systemctl status bumblebeed
â—Ź bumblebeed.service - Bumblebee C Daemon
   Loaded: loaded (/usr/lib/systemd/system/bumblebeed.service; enabled; vendor preset: disabled)
   Active: active (running) since Tue 2018-11-20 19:13:49 CET; 4h 3min ago
 Main PID: 580 (bumblebeed)
    Tasks: 1 (limit: 4915)
   Memory: 1.3M
   CGroup: /system.slice/bumblebeed.service
           └─580 /usr/bin/bumblebeed --use-syslog
nov 20 19:13:49 manjaro systemd[1]: Started Bumblebee C Daemon.
nov 20 19:13:49 manjaro bumblebeed[580]: /usr/bin/bumblebeed 3.2.1-2017-02-27-Format:%h$ started
From journalctl -g bbswitch | cat
-- Logs begin at Thu 2018-11-15 18:12:16 CET, end at Tue 2018-11-20 23:18:08 CET. --
nov 15 18:12:25 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 15 18:12:25 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 15 18:12:25 manjaro kernel: bbswitch: version 0.8
nov 15 18:12:25 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 15 18:12:25 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 15 18:12:25 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 15 18:12:25 manjaro kernel: bbswitch: disabling discrete graphics
nov 15 18:12:25 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 15 18:37:55 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 15 18:38:32 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 15 18:38:32 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 15 18:38:32 manjaro kernel: bbswitch: version 0.8
nov 15 18:38:32 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 15 18:38:32 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 15 18:38:32 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 15 18:38:32 manjaro kernel: bbswitch: disabling discrete graphics
nov 15 18:38:32 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 15 19:16:23 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 15 19:16:56 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 15 19:16:56 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 15 19:16:56 manjaro kernel: bbswitch: version 0.8
nov 15 19:16:56 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 15 19:16:56 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 15 19:16:56 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 15 19:16:56 manjaro kernel: bbswitch: disabling discrete graphics
nov 15 19:16:56 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 15 20:19:22 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 15 20:19:53 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 15 20:19:53 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 15 20:19:53 manjaro kernel: bbswitch: version 0.8
nov 15 20:19:53 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 15 20:19:53 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 15 20:19:53 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 15 20:19:53 manjaro kernel: bbswitch: disabling discrete graphics
nov 15 20:19:53 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
-- Reboot --
nov 15 23:31:03 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 15 23:31:03 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 15 23:31:03 manjaro kernel: bbswitch: version 0.8
nov 15 23:31:03 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 15 23:31:03 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 15 23:31:03 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 15 23:31:03 manjaro kernel: bbswitch: disabling discrete graphics
nov 15 23:31:03 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 16 00:45:32 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 16 09:06:57 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 16 09:06:57 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 16 09:06:57 manjaro kernel: bbswitch: version 0.8
nov 16 09:06:57 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 16 09:06:57 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 16 09:06:57 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 16 09:06:57 manjaro kernel: bbswitch: disabling discrete graphics
nov 16 09:06:57 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 16 17:24:24 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 16 17:24:53 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 16 17:24:53 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 16 17:24:53 manjaro kernel: bbswitch: version 0.8
nov 16 17:24:53 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 16 17:24:53 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 16 17:24:53 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 16 17:24:53 manjaro kernel: bbswitch: disabling discrete graphics
nov 16 17:24:53 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
-- Reboot --
nov 16 22:34:18 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 16 22:34:18 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 16 22:34:18 manjaro kernel: bbswitch: version 0.8
nov 16 22:34:18 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 16 22:34:18 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 16 22:34:18 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 16 22:34:18 manjaro kernel: bbswitch: disabling discrete graphics
nov 16 22:34:18 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 17 01:44:00 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 17 10:33:12 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 17 10:33:12 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 17 10:33:12 manjaro kernel: bbswitch: version 0.8
nov 17 10:33:12 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 17 10:33:12 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 17 10:33:12 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 17 10:33:12 manjaro kernel: bbswitch: disabling discrete graphics
nov 17 10:33:12 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 17 16:29:23 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 17 18:54:00 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 17 18:54:00 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 17 18:54:00 manjaro kernel: bbswitch: version 0.8
nov 17 18:54:00 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 17 18:54:00 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 17 18:54:00 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 17 18:54:00 manjaro kernel: bbswitch: disabling discrete graphics
nov 17 18:54:00 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
-- Reboot --
nov 17 19:12:50 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 17 19:12:50 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 17 19:12:50 manjaro kernel: bbswitch: version 0.8
nov 17 19:12:50 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 17 19:12:50 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 17 19:12:50 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 17 19:12:50 manjaro kernel: bbswitch: disabling discrete graphics
nov 17 19:12:50 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 18 01:16:30 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 18 10:02:46 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 18 10:02:46 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 18 10:02:46 manjaro kernel: bbswitch: version 0.8
nov 18 10:02:46 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 18 10:02:46 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 18 10:02:46 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 18 10:02:46 manjaro kernel: bbswitch: disabling discrete graphics
nov 18 10:02:46 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 19 01:57:07 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 19 08:16:44 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 19 08:16:44 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 19 08:16:44 manjaro kernel: bbswitch: version 0.8
nov 19 08:16:44 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 19 08:16:44 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 19 08:16:44 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 19 08:16:44 manjaro kernel: bbswitch: disabling discrete graphics
nov 19 08:16:44 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 19 17:17:40 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 19 17:18:31 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 19 17:18:31 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 19 17:18:31 manjaro kernel: bbswitch: version 0.8
nov 19 17:18:31 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 19 17:18:31 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 19 17:18:31 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 19 17:18:31 manjaro kernel: bbswitch: disabling discrete graphics
nov 19 17:18:31 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
-- Reboot --
nov 19 17:29:12 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 19 17:29:12 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 19 17:29:12 manjaro kernel: bbswitch: version 0.8
nov 19 17:29:12 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 19 17:29:12 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 19 17:29:12 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 19 17:29:12 manjaro kernel: bbswitch: disabling discrete graphics
nov 19 17:29:12 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
-- Reboot --
nov 19 21:40:30 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 19 21:40:30 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 19 21:40:30 manjaro kernel: bbswitch: version 0.8
nov 19 21:40:30 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 19 21:40:30 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 19 21:40:30 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 19 21:40:30 manjaro kernel: bbswitch: disabling discrete graphics
nov 19 21:40:30 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 19 21:48:09 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 19 21:48:40 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 19 21:48:40 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 19 21:48:40 manjaro kernel: bbswitch: version 0.8
nov 19 21:48:40 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 19 21:48:40 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 19 21:48:40 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 19 21:48:40 manjaro kernel: bbswitch: disabling discrete graphics
nov 19 21:48:40 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
nov 20 00:47:42 manjaro kernel: bbswitch: enabling discrete graphics
-- Reboot --
nov 20 08:49:07 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 20 08:49:07 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 20 08:49:07 manjaro kernel: bbswitch: version 0.8
nov 20 08:49:07 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 20 08:49:07 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 20 08:49:07 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 20 08:49:07 manjaro kernel: bbswitch: disabling discrete graphics
nov 20 08:49:07 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
-- Reboot --
nov 20 19:13:49 manjaro kernel: bbswitch: loading out-of-tree module taints kernel.
nov 20 19:13:49 manjaro kernel: bbswitch: module verification failed: signature and/or required key missing - tainting kernel
nov 20 19:13:49 manjaro kernel: bbswitch: version 0.8
nov 20 19:13:49 manjaro kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
nov 20 19:13:49 manjaro kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.GFX0
nov 20 19:13:49 manjaro kernel: bbswitch: detected an Optimus _DSM function
nov 20 19:13:49 manjaro kernel: bbswitch: disabling discrete graphics
nov 20 19:13:49 manjaro kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
From cat /etc/modprobe.d/*.conf | grep bbswitch
options bbswitch load_state=0 unload_state=0
From cat /etc/bumblebee/bumblebee.conf | grep -B2 "PMM\|TurnCard"
# Card power state at exit. Set to false if the card shoud be ON when Bumblebee
# server exits.
TurnCardOffAtExit=false
# parsed if the Driver setting in [bumblebeed] is set to NAME (or if auto-
# detection resolves to NAME).
# PMMethod: method to use for saving power by disabling the nvidia card, valid
# Module name to load, defaults to Driver if empty or unset
KernelDriver=nvidia
PMMethod=auto
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
I tried the commands here with no error in the terminal but still same situation and the error
nov 20 23:21:22 manjaro kscreenlocker_greet[4781]: Qt: Session management error: networkIdsList argument is NULL still appears in journalctl
Well then sadly I'm not sure what to say, other than the path to the wallpaper definitely must be set to a local path.
What do you mean with a local path? I am using right now one of the default wallpapers from /usr/share/wallpapers and the same error appears in journalctl
Please post the error you are receiving now regarding the wallpaper
Same error than before
nov 20 23:33:39 manjaro kscreenlocker_greet[1931]: kf5.kpackage: No metadata file in the package, expected it at: "/usr/share/wallpapers/Breath/contents/images/"
repeated 9 times
I am only on my phone, so I can't check my Manjaro install. Is the file path valid. Are the files actually in the expected location.
Yes the images are there, although the error makes reference to some metadata I don't know how to check
You may try changing PMMethod from auto to bbswitch. Reboot to make it take effect.
