Manjaro KDE freezes after suspension
Check the log
sudo cat /var/lib/sddm/.local/share/sddm/xorg-session.log
Thanks for taking over @AgentS. Hopefully you can pin down the cause.
Good luck.
Same result, no difference in journalctl
The file exists but it has size 0. If it helps, I am also experiencing an annoying problem related with KDE powerdevil (the problem persists after a completely fresh install), maybe they are related Problem with KDE power management (powerdevil)
suspension has nothing to do with power management, so you don't need to mention at all..
:upside_down_face:
Is there anything else I could try then to diagnose the problem? If it helps, the laptop has a LED on the power button. During suspension the LED is supposed to flicker but now when I close the laptop the LED just stays turned on as if nothing happened
I have tried executing /usr/lib/kscreenlocker_greet --immediateLock without any problems. The lock screen appears with the expected background image and I can type my password a go back the session without any further issue.
OpenGL vendor string:                   Intel Open Source Technology Center
OpenGL renderer string:                 Mesa DRI Intel(R) Sandybridge Mobile
OpenGL version string:                  3.0 Mesa 18.2.5
OpenGL shading language version string: 1.30
Driver:                                 Intel
GPU class:                              SandyBridge
OpenGL version:                         3.0
GLSL version:                           1.30
Mesa version:                           18.2.5
Linux kernel version:                   4.19.2
Requires strict binding:                yes
GLSL shaders:                           yes
Texture NPOT support:                   yes
Virtual Machine:                        no
kf5.kpackage: No metadata file in the package, expected it at: "/usr/share/wallpapers/Breath/contents/images/"
Locked at 1542837370
UdevQt: unable to create udev monitor connection
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
QXcbClipboard::setMimeData: Cannot set X11 selection owner
QObject::disconnect: No such signal QObject::screenChanged(QScreen*)
I have also tried uninstalling TLP, same results but the logs are slightly different with respect to systemd
nov 21 23:15:43 manjaro systemd-logind[453]: Lid closed.
nov 21 23:15:43 manjaro org_kde_powerdevil[747]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("Type", QVariant(uint, 1)))
nov 21 23:15:43 manjaro kernel: pci_bus 0000:01: Allocating resources
nov 21 23:15:43 manjaro kernel: pci_bus 0000:02: Allocating resources
nov 21 23:15:43 manjaro kernel: pci_bus 0000:03: Allocating resources
nov 21 23:15:43 manjaro kernel: pci_bus 0000:04: Allocating resources
nov 21 23:15:43 manjaro kernel: pci_bus 0000:05: Allocating resources
nov 21 23:15:44 manjaro org_kde_powerdevil[747]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("SkipFade", QVariant(bool, true))("Type", QVariant(uint, 1)))
nov 21 23:15:44 manjaro org_kde_powerdevil[747]: powerdevil: Starting Login1 suspend job
nov 21 23:15:44 manjaro org_kde_powerdevil[747]: powerdevil: Pausing all media players before suspending
nov 21 23:15:44 manjaro kdeinit5[623]: bluedevil: About to suspend
nov 21 23:15:44 manjaro ksmserver[650]: lock called
nov 21 23:15:44 manjaro NetworkManager[449]: <info>  [1542838544.1112] manager: sleep: sleep requested (sleeping: no  enabled: yes)
nov 21 23:15:44 manjaro NetworkManager[449]: <info>  [1542838544.1112] device (enp5s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
nov 21 23:15:44 manjaro ksmserver[650]: Lock window Id:  23068678
nov 21 23:15:44 manjaro NetworkManager[449]: <info>  [1542838544.1400] manager: NetworkManager state is now ASLEEP
nov 21 23:15:44 manjaro ksmserver[650]: CreateNotify: 23068678
nov 21 23:15:44 manjaro ksmserver[650]: CreateNotify: 23068680
nov 21 23:15:44 manjaro ksmserver[650]: CreateNotify: 69206020
nov 21 23:15:45 manjaro kscreenlocker_greet[1066]: Qt: Session management error: networkIdsList argument is NULL
nov 21 23:15:46 manjaro ksmserver[650]: CreateNotify: 69206024
nov 21 23:15:46 manjaro ksmserver[650]: CreateNotify: 69206032
nov 21 23:15:46 manjaro ksmserver[650]: CreateNotify: 69206037
nov 21 23:15:47 manjaro kscreenlocker_greet[1066]: kf5.kpackage: No metadata file in the package, expected it at: "/usr/share/wallpapers/Breath/contents/images/"
nov 21 23:15:47 manjaro ksmserver[650]: CreateNotify: 69206039
nov 21 23:15:47 manjaro ksmserver[650]: CreateNotify: 69206041
nov 21 23:15:47 manjaro ksmserver[650]: MapNotify: 69206039
nov 21 23:15:48 manjaro ksmserver[650]: CreateNotify: 69206043
nov 21 23:15:49 manjaro systemd-logind[453]: Delay lock is active (UID 1000/salvi, PID 650/ksmserver) but inhibitor timeout is reached.
nov 21 23:15:49 manjaro systemd[1]: Reached target Sleep.
nov 21 23:15:49 manjaro systemd[1]: Starting Suspend...
nov 21 23:15:49 manjaro kscreenlocker_greet[1066]: UdevQt: unable to create udev monitor connection
nov 21 23:15:49 manjaro ksmserver[650]: CreateNotify: 69206052
nov 21 23:15:49 manjaro kscreenlocker_greet[1066]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
nov 21 23:15:49 manjaro systemd-sleep[1079]: Suspending system...
nov 21 23:15:49 manjaro kernel: PM: suspend entry (deep)
nov 21 23:15:50 manjaro ksmserver[650]: MapNotify: 23068678
nov 21 23:15:50 manjaro kscreenlocker_greet[1066]: QXcbClipboard::setMimeData: Cannot set X11 selection owner
nov 21 23:15:50 manjaro ksmserver[650]: CreateNotify: 41943045
nov 21 23:15:50 manjaro ksmserver[650]: CreateNotify: 69206059
nov 21 23:15:50 manjaro plasmashell[667]: QXcbClipboard: SelectionRequest too old
nov 21 23:15:53 manjaro msm_kde_notifier[740]: error: failed to get installed kernels
nov 21 23:15:53 manjaro msm_kde_notifier[740]: QProcess: Destroyed while process ("pacman") is still running.
I have tested hibernation and it works flawlessly. I have check how a normal suspension should look like in the logs and there should be more PM entries after
nov 19 17:21:22 manjaro kernel: PM: suspend entry (deep)
Is there anyway I can check what kind of suspend I am using?
Good news kinda, my laptop has to modes of suspension in /sys/power/, deep (the default one) and s2idle, which does not save as much energy as deep, but it works, I am able to resume from suspension. Still I would like to know what's wrong with deep
I don't want to know.
Please use whatever works. Not everything offered by the system is equally usable on all HW combinations.
