Anytime I play any game, my temperatures get abnormally high, fan goes to max and eventually computer freezes up. Is this due not having good driver/library support for AMD GPUs or is there a way to troubleshoot and find out whats causing this?
I've cleaned the dust out of my GPU (and my tower) recently so that's not the problem.
System: Host: arbalasquide-pc Kernel: 4.19.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: i3 4.16.1
dm: LightDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: MSI model: Z97 PC Mate(MS-7850) v: 1.0 serial: <filter> UEFI [Legacy]: American Megatrends
v: 4.10 date: 08/11/2015
CPU: Topology: Quad Core model: Intel Core i5-4690 bits: 64 type: MCP arch: Haswell rev: 3 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28009
Speed: 1587 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 1765 2: 2063 3: 2123 4: 1598
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Hawaii XT / Grenada XT [Radeon R9 290X/390X] driver: amdgpu v: kernel
bus ID: 01:00.0 chip ID: 1002:67b0
Display: x11 server: X.Org 1.20.5 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
compositor: compton resolution: 1360x768~60Hz, 1440x900~60Hz
OpenGL: renderer: AMD Radeon R9 200 Series (HAWAII DRM 3.27.0 4.19.56-1-MANJARO LLVM 8.0.0) v: 4.5 Mesa 19.1.1
direct render: Yes
Audio: Device-1: Intel 9 Series Family HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:8ca0
Device-2: Advanced Micro Devices [AMD/ATI] Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X] driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 1002:aac8
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus ID: 2-2:3 chip ID: 046d:0825
Sound Server: ALSA v: k4.19.56-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8168
v: 8.047.01-NAPI port: d000 bus ID: 03:00.0 chip ID: 10ec:8168
Drives: Local Storage: total: 1.82 TiB used: 400.37 GiB (21.5%)
ID-1: /dev/sda vendor: Seagate model: ST2000DM001-9YN164 size: 1.82 TiB speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 1.79 TiB used: 400.37 GiB (21.8%) fs: ext4 dev: /dev/sda1
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 29 C
Info: Processes: 245 Uptime: 5h 23m Memory: 7.74 GiB used: 4.36 GiB (56.4%) Init: systemd v: 242 Compilers: gcc: 9.1.0
clang: 8.0.0 Shell: bash v: 5.0.7 running in: urxvtd inxi: 3.0.34
Any help would be appreciated, thanks!
