Hi, manjaro-log-helper
is a simple bash program with a GUI interface for creating and manage useful logs/information on the Manjaro system; it is based on the script made by EndeavourOS team but modified as i intend to need to work.
As you can see you can select what logs or information you need to share and also you can choose optionally to paste the logs in an online Pastebin service ( at the moment by default it share via Pastebin
service and stored for 30 days before Pastebin
remove it ).
By default only if you paste via web service the personal data are removed otherwise you need to explicitly remove them.
