@jonathon did that, but didn't change anything
Quite interestingly it stops at
started tlp system
Now when I turn off quiet
After searching some more I found out that lightdm fails to load.
Found the issue, was a typo in the setup script for lightdm.
But now I get: Could not find provider with name modesetting, for lightdm
If you're trying to set up PRIME, check step 4 of this:
Also, read the rest of it too.
Thanks, step 3 of this here: https://classicarchived.forum.manjaro.org/index.php?topic=31575.0
Solved the final problem!
