Manjaro xfce 20.0.3 as the client machine by VirtualBox 6.1.8, VBoxGuestAdditions error.
VBoxGuestAdditions_6.1.8.iso was installed to the system.
The two issue windows below are full of all the desktop.
vboxclient: failed to get display change request...
vboxclient: failed waiting for event...
2020-07-01_13-55
Mind you, but this should start with the host setup first, the packages installed on the host, then how the VM is configured ... From your host terminal run:
pacman -Qi virtualbox
and share that here.
I guess that the guest VM is set to use the VMSVGA ... change it to VBoxSVGA
The host and client machines are both Manjaro xfce 20.
The host terminal screenshot as follows:
Bye the way, there are some Simplified Chinese words.
I just prepare to reply another post about vboxclient by pacman -Qi virtualbox.
But another issue, the system language does not change to English after I change it manully and reboot.
2020-07-01_14-58
I deleted the virtual machine client, so over, thanks.
