Clicked power button, a command “a start job is running for ....” then this
you should check in journal ,
error is coming from disk(s)
sudo journalctl -b0 -p4
I can’t copy/paste, it won’t even boot, I typed this from my phone
Hmmm...does reinstalling will fix it? Because I’m at that stage right now
Update,
> -- Logs begin at Tue 2019-12-10 19:34:25 UTC, end at Tue 2019-12-10 20:20:14 UTC. --
> Dec 10 19:34:25 manjaro kernel: ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 128/32 (20190703/tbfadt-564)
> Dec 10 19:34:25 manjaro kernel: ACPI: NMI not connected to LINT 1!
> Dec 10 19:34:25 manjaro kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
> Dec 10 19:34:25 manjaro kernel: hpet: number irqs doesn't agree with number of timers
> Dec 10 19:34:25 manjaro kernel: efivars: duplicate variable: AcpiGlobalVariable-c020489e-6db2-4ef2-9aa5-ca06fc11d36a
> Dec 10 19:34:25 manjaro kernel: r8169 0000:03:00.2: can't disable ASPM; OS doesn't have ASPM control
> Dec 10 19:34:25 manjaro kernel: overlayfs: null uuid detected in lower fs '/', falling back to index=off,nfs_export=off.
> Dec 10 19:34:26 manjaro kernel: mei_txe 0000:00:1a.0: can't derive routing for PCI INT A
> Dec 10 19:34:26 manjaro kernel: mei_txe 0000:00:1a.0: PCI INT A: not connected
> Dec 10 19:34:27 manjaro systemd-udevd[317]: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
> Dec 10 19:34:28 manjaro systemd-udevd[316]: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
> Dec 10 19:34:28 manjaro systemd-udevd[326]: Config file /usr/lib/systemd/network/99-default.link applies to device based on potentiall>
> Dec 10 19:34:29 manjaro kernel: uvcvideo 1-1.3:1.0: Entity type for entity Extension 7 was not initialized!
> Dec 10 19:34:29 manjaro kernel: uvcvideo 1-1.3:1.0: Entity type for entity Processing 2 was not initialized!
> Dec 10 19:34:29 manjaro kernel: uvcvideo 1-1.3:1.0: Entity type for entity Camera 1 was not initialized!
> Dec 10 19:34:29 manjaro kernel: uvcvideo 1-1.3:1.0: Entity type for entity Extension 4 was not initialized!
> Dec 10 19:34:31 manjaro kernel: kauditd_printk_skb: 1 callbacks suppressed
> Dec 10 19:34:36 manjaro NetworkManager[589]: <warn> [1576006476.2378] sup-iface: failed to cancel p2p connect: P2P cancel failed
> Dec 10 19:34:40 manjaro kernel: kauditd_printk_skb: 2 callbacks suppressed
> Dec 10 19:35:01 manjaro kernel: kauditd_printk_skb: 9 callbacks suppressed
> Dec 10 19:35:03 manjaro lightdm[1064]: gkr-pam: no password is available for user
> Dec 10 19:35:14 manjaro kernel: kauditd_printk_skb: 1 callbacks suppressed
> Dec 10 19:35:20 manjaro xfce4-notifyd[1409]: theme 'Matcha-sea' is not found anywhere is user themes directories
> Dec 10 19:35:22 manjaro xfconfd[1165]: Error parsing xfconf config file "/home/manjaro/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4->
> Dec 10 19:35:33 manjaro blueman-mechani[1619]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
> Dec 10 19:36:12 manjaro kernel: EXT4-fs (sda4): ext4_check_descriptors: Block bitmap for group 128 overlaps superblock
> Dec 10 19:36:12 manjaro kernel: EXT4-fs (sda4): group descriptors corrupted!
> Dec 10 19:36:16 manjaro kernel: EXT4-fs (sda4): ext4_check_descriptors: Block bitmap for group 128 overlaps superblock
> Dec 10 19:36:16 manjaro kernel: EXT4-fs (sda4): group descriptors corrupted!
> Dec 10 19:36:20 manjaro kernel: EXT4-fs (sda4): ext4_check_descriptors: Block bitmap for group 128 overlaps superblock
> Dec 10 19:36:20 manjaro kernel: EXT4-fs (sda4): group descriptors corrupted!
> Dec 10 19:38:03 manjaro kernel: EXT4-fs (sda4): ext4_check_descriptors: Block bitmap for group 128 overlaps superblock
> Dec 10 19:38:03 manjaro kernel: EXT4-fs (sda4): group descriptors corrupted!
> Dec 10 19:40:16 manjaro kernel: mmc0: cannot verify signal voltage switch
> Dec 10 19:40:16 manjaro kernel: mmc0: error -123 whilst initialising SD card
> Dec 10 19:40:19 manjaro kernel: mmc0: cannot verify signal voltage switch
> Dec 10 19:40:25 manjaro kernel: FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
> Dec 10 19:45:49 manjaro NetworkManager[589]: <warn> [1576007149.5359] sup-iface[0x56014b2cc120,wlp2s0]: connection disconnected (reas>
> Dec 10 19:47:54 manjaro NetworkManager[589]: <warn> [1576007274.5277] sup-iface[0x56014b2cc120,wlp2s0]: connection disconnected (reas>
> Dec 10 19:48:47 manjaro NetworkManager[589]: <warn> [1576007327.5257] sup-iface[0x56014b2cc120,wlp2s0]: connection disconnected (reas>
> Dec 10 19:50:37 manjaro kernel: EXT4-fs (sda4): ext4_check_descriptors: Block bitmap for group 128 overlaps superblock
> Dec 10 19:50:37 manjaro kernel: EXT4-fs (sda4): group descriptors corrupted!
> Dec 10 19:50:48 manjaro kernel: mmc0: cannot verify signal voltage switch
> ESCOC
> pressed
> pressed
> pressed
> lable for user
> pressed
> file "/home/manjaro/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-desktop.xml": Error on line 22 char 11: Element “channel” was close>
> orrupted!
> orrupted!
> orrupted!
> orrupted!
> orrupted!
> orrupted!
> switch
> g SD card
> switch
> 59] sup-iface[0x56014b2cc120,wlp2s0]: connection disconnected (reason -4)
> 77] sup-iface[0x56014b2cc120,wlp2s0]: connection disconnected (reason -4)
> 57] sup-iface[0x56014b2cc120,wlp2s0]: connection disconnected (reason -4)
> orrupted!
> switch
> ESCOD
> Dec 10 19:50:50 manjaro kernel: FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
> ESCOD
> ESCOD
> ESCOD
`Preformatted text`> Dec 10 19:40:19 manjaro kernel: mmc0: cannot verify signal voltage switch
You completely ignored what @anon34396487 invited you to consult in order to provide proper information about your system, then you mentioned:
Yet your last image is a screenshot that required a copy and paste "procedure" ... instead of copy and paste the text you chose to do that ... Why?
Is important to know if your system is UEFI or has a legacy BIOS to know if your partitioning will work as you did it, so please check again the second comment and post back as per tutorial.
Cheers!
Ok, I'm so sorry, I'm new to this Linux thing.. Let me edit that post for a second...
Oh yeah, how do I "copy and paste" the first image if I can't access anything? Because the second image, that I edited, is after I boot from usb..
No worries. Even from Live Media, if you share the output of
inxi -Fxxxz --no-host
will help us know the exact model of your machine and what you have installed as GPU drivers and what kernel. With that we can move on helping you out
Read this for troubleshooting help, how to use TTY etc.
Boot to TTY and update your system.
Check journal serious errors
journalctl -b -p3 --no-pager --no-hostname
For more reports you need to post, read the tutorial.
Is this a fresh installation? Was it working before?
Have you updated packages?
I'm currently at Live USB Boot, now I just need to copy that command, paste it on terminal, and send the result here? Btw how do I make the texts from the terminal formatted?(colors, bold, etc)
Just use ``` above and bellow it and will be formatted as it should for better reading.
Kernel: 5.3.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
Desktop: Xfce 4.14.1 tk: Gtk 3.24.12 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X453MA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X453MA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X453MA.211 date: 04/10/2015
ID-1: BAT0 charge: 24.2 Wh condition: 24.1/31.7 Wh (76%) volts: 7.6/7.6
model: ASUSTeK X453-42 type: Li-ion serial: <filter> status: Unknown
Topology: Dual Core model: Intel Celeron N2840 bits: 64 type: MCP
arch: Silvermont rev: 8 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8666
Speed: 2582 MHz min/max: 500/2582 MHz Core speeds (MHz): 1: 2582 2: 2582
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0f31
Display: x11 server: X.Org 1.20.5 driver: intel unloaded: modesetting
alternate: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Bay Trail v: 4.2 Mesa 19.2.4
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:0f04
Sound Server: ALSA v: k5.3.11-1-MANJARO
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: AzureWave AW-NE186H driver: ath9k v: kernel port: f000
bus ID: 02:00.0 chip ID: 168c:0032
Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel port: e000 bus ID: 03:00.2 chip ID: 10ec:8136
IF: enp3s0f2 state: down mac: <filter>
Local Storage: total: 509.71 GiB used: 8.92 GiB (1.7%)
ID-1: /dev/mmcblk0 model: SC16G size: 14.84 GiB serial: <filter>
scheme: MBR
ID-2: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
size: 465.76 GiB speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: AF10 scheme: GPT
ID-3: /dev/sdb type: USB vendor: SanDisk model: Cruzer Switch
size: 29.11 GiB serial: <filter> rev: 1.27 scheme: MBR
ID-1: / size: 2.80 GiB used: 150.7 MiB (5.3%) fs: overlay source: ERR-102
System Temperatures: cpu: 6280.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3600
Processes: 166 Uptime: 1h 53m Memory: 3.74 GiB used: 2.58 GiB (69.2%)
Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
running in: xfce4-terminal inxi: 3.0.36
For me this is a sign that you need to follow this
- It's a reinstall
- Yes it was, but I reinstalled it because I had problems with it(a bit hard to explain)
- I think I haven't?
A summary maybe? We can read minds as well, but we need a first glance!
For example, depending your reinstallation method, you may have chosen wrong partitions, or something else.
It seems your /home
partition is not found on boot.
Ok, before I answer your answers, I entered sudo e2fsck /dev/sda4
and turns out, that partition has problems, so I clicked y whenever the pacman asks, and finally now my laptop can boot by itself! I was so happy at the moment, but then, there's a little problem
That is not what my desktop looks like.. and now the data in that partition is missing
How, where? Did you try this from a Live ISO or other system, or from inside your running system?
Also post
grep -v ^# /etc/fstab | grep [[:alpha:]]
lsblk -f
Sorry, I cannot copy those logs because I cannot access anything
First fsck your root partition.
Then use [More Complicated Setups] section to boot up to Manjaro.
Provide output as stated in [If problem persists] section.
Probably your fstab uuid does not correspond with blkid.
And check if you have 'fsck' in your HOOKS line in /etc/mkinitcpio.conf
grep keymap /etc/mkinitcpio.conf
