megasync is core dumping
Hello,
The megasync tool used to work flawlessly but now I notice it's not starting. Launching from the command line shows:
$ megasync
Setting QT_SCREEN_SCALE_FACTORS= "eDP1=1"
Segmentation fault (core dumped)
Maybe it's a linking issue because now the dynamic library which the binary was linked has changed.
The fact is I've downloaded the last version from MEGA.nz site and installed using
$ sudo pacman -U https://mega.nz/linux/MEGAsync/Arch_Extra/x86_64/megasync-4.3.1-1-x86_64.pkg.tar.xz
 megasync-4.3.1-1-x86_64                                  12,6 MiB  3,67 MiB/s 00:03 [################################################] 100%
 megasync-4.3.1-1-x86_64.sig                             181,0   B  0,00   B/s 00:00 [################################################] 100%
loading packages...
resolving dependencies...
error: could not open file /var/lib/pacman/local/linux56-rt-5.6.10_rt5-1/desc: No such file or directory
Packages (2) qt5-tools-5.14.2-2  megasync-4.3.1-1
Total Installed Size:  56,81 MiB
(2/2) checking keys in keyring                                                       [################################################] 100%
(1/2) checking package integrity                                                     [################################################] 100%
(1/2) loading package files                                                          [################################################] 100%
(2/2) checking for file conflicts                                                    [################################################] 100%
(2/2) checking available disk space                                                  [################################################] 100%
(1/2) installing qt5-tools                                                           [################################################] 100%
Optional dependencies for qt5-tools
    clang: for qdoc [installed]
    qt5-webkit: for Qt Assistant
(2/2) installing megasync                                                            [################################################] 100%
==> Updating trust database...
gpg: next trustdb check due at 2020-05-31
  -> Locally signing key 8F208FBF12FEE766AA32AEAF03C3AD3A7F068E5D...
fs.inotify.max_user_watches = 524288
Optional dependencies for megasync
    sni-qt: fix systray issue on KDE and LXQt,
    nautilus-megasync: for integration with nautilus
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating icon theme caches...
(3/3) Updating the desktop file MIME type cache...
Anyone here can run megasync with ease? Maybe I should install some backward compatible libraries?
$ ld /usr/bin/megasync
ld: warning: cannot find entry symbol _start; not setting start address
$ file /usr/bin/megasync
/usr/bin/megasync: ELF 64-bit LSB pie executable, x86-64, version 1 (GNU/Linux), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=bf0ddb33baa26415707ac887d575e5a49f3d0fd5, for GNU/Linux 3.2.0, stripped
Regards,
Gabriel
This is an issue you should fix
You have tagged your topic with #deepin so just a reminder as Deepin is unsupported.
I would advise against changing system libraries - it will only worsen your situation.
No problems
➜  ~ pacman-mirrors -G
unstable
➜  ~ inxi -Sxxxxz --no-host
  Kernel: 5.6.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  Desktop: Openbox 3.6.1 info: polybar, tint2 dm: LXDM Distro: Manjaro Linux
Which branch is your system set to?
pacman-mirrors -G
Yes, I know. It used to be a lovely Desktop Environment. Now it has turned into an ungly one after the v20 redesign. The fact is my disk is too small to get another WM/DE and still need the computer on a daily basis so re-installing isn't planned in a short term.
As a matter of fact, any suggestion would be welcome... LXqt is nice but still not as pretty as Deeping used to be...
$ pacman-mirrors -G
stable
$ inxi -Sxxxxz --no-host
System:    Kernel: 5.4.40-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Deepin 20 tk: Qt 5.14.2 info: dde-dock
           wm: DeepinWM dm: LightDM 1.30.0 Distro: Manjaro Linux
Regards,
You're right. I don't know what's that. BTW, in my /boot partition there are still 5.6-rt images but the package isn't installed
$ ls /boot/ |grep rt
initramfs-5.6-rt-x86_64-fallback.img
initramfs-5.6-rt-x86_64.img
Megasync works fine on my side.
What is your side? :slightly_smiling_face:
libQT version maybe?
I mean on my Manjaro Plasma, testing branch
$ megasync
Not setting scale factors. Using predefined QT_SCREEN_SCALE_FACTORS= eDP-1=1;HDMI-1=1;DP-1=1;HDMI-2=1;
Qt 15.4.2
My qt-base package is 5.14.2-2.
I don't use Plasma and my Manjaro is on the stable branch.
How did you query your qt version?
Well I just looked in KInfoCentre, on installations other than Plasma one can look at packages in pacman database, for instance, pacman -Qi qt5-base.
Setting the correct environment variable got it finally to work. It was a QT thing and a Deepin 20 issue.
The solution was posted on Reddit and then I made my own CLI launcher (just the export and the binary invocation... rocket science :smile:).
There is a github issue open for this as well https://github.com/meganz/MEGAsync/issues/443
although it seems its more a qt5integration issue with the last push?
you can use "downgrade deepin-qt5integration" and downgrade to 5.1.0.1-1 and megasync will work again, however the deepin theme will be messed up, hence they pushed the 5.1.0.1-2 to fix the theme issues.
Hello.
Thanks for the link.
As you say, downgrading the qt5 deepin integration wouldn't be a good idea.
As I posted here the solition came in form of setting an environment variable.
