Microphone disappeared from Skype
I don't use audio recording very often so this last worked about 2-3 months ago.
What I've done already:
pavucontrol
No devices listed! :-1:
alsamixer output:
┌────────────────────────────── AlsaMixer v1.2.2 ───────────────────────────────┐
│ Card: PulseAudio                                      F1:  Help               │
│ Chip: PulseAudio                                      F2:  System information │
│ View: F3: Playback  F4: Capture  F5:[All]             F6:  Select sound card  │
│ Item: Capture                                         Esc: Exit               │
│                                 │OO│                                          │
│                                 └──┘    L    R                                │
│                                        CAPTURE                                │
│                                39<>39   58<>58                                │
│                                Master <Capture >                              │
arecord --list-devices
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
So the device exists! :+1:
alsa info:
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Thu Jul  2 19:04:43 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      Acer
Product Name:      Predator G9-793
Product Version:   V1.13
Firmware Version:  V1.13
Board Vendor:      Acer
Board Name:        Challenger2_SKS
!!ACPI Device Status Information
/sys/bus/acpi/devices/10250759:00/status 	 15
/sys/bus/acpi/devices/ACPI000C:00/status 	 15
/sys/bus/acpi/devices/INT33A1:00/status 	 15
/sys/bus/acpi/devices/INT3F0D:00/status 	 15
/sys/bus/acpi/devices/LNXPOWER:00/status 	 1
/sys/bus/acpi/devices/LNXPOWER:01/status 	 1
/sys/bus/acpi/devices/LNXPOWER:02/status 	 1
/sys/bus/acpi/devices/LNXPOWER:03/status 	 1
/sys/bus/acpi/devices/LNXPOWER:04/status 	 1
/sys/bus/acpi/devices/LNXPOWER:05/status 	 1
/sys/bus/acpi/devices/LNXPOWER:06/status 	 1
/sys/bus/acpi/devices/LNXPOWER:07/status 	 1
/sys/bus/acpi/devices/LNXPOWER:08/status 	 1
/sys/bus/acpi/devices/LNXPOWER:09/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0a/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0b/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0c/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0d/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0e/status 	 1
/sys/bus/acpi/devices/LNXPOWER:0f/status 	 1
/sys/bus/acpi/devices/LNXPOWER:10/status 	 1
/sys/bus/acpi/devices/LNXPOWER:11/status 	 1
/sys/bus/acpi/devices/LNXPOWER:12/status 	 1
/sys/bus/acpi/devices/LNXPOWER:13/status 	 1
/sys/bus/acpi/devices/LNXPOWER:14/status 	 1
/sys/bus/acpi/devices/MSFT0101:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:00/status 	 3
/sys/bus/acpi/devices/PNP0C02:03/status 	 15
/sys/bus/acpi/devices/PNP0C02:04/status 	 3
/sys/bus/acpi/devices/PNP0C04:00/status 	 31
/sys/bus/acpi/devices/PNP0C0A:00/status 	 31
/sys/bus/acpi/devices/PNP0C0E:00/status 	 11
/sys/bus/acpi/devices/PNP0C0E:01/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 9
/sys/bus/acpi/devices/PNP0C0F:01/status 	 9
/sys/bus/acpi/devices/PNP0C0F:02/status 	 9
/sys/bus/acpi/devices/PNP0C0F:03/status 	 9
/sys/bus/acpi/devices/PNP0C0F:04/status 	 9
/sys/bus/acpi/devices/PNP0C0F:05/status 	 9
/sys/bus/acpi/devices/PNP0C0F:06/status 	 9
/sys/bus/acpi/devices/PNP0C0F:07/status 	 9
/sys/bus/acpi/devices/SYNA7B99:00/status 	 15
/sys/bus/acpi/devices/device:3e/status 	 15
/sys/bus/acpi/devices/device:90/status 	 11
!!Kernel Information
Kernel release:    5.7.0-3-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.7.0-3-MANJARO
Library version:    1.2.2
Utilities version:  1.2.2
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0x93520000 irq 128
 1 [NVidia         ]: HDA-Intel - HDA NVidia
                      HDA NVidia at 0x93000000 irq 17
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation CM238 HD Audio Controller [8086:a171] (rev 31)
	Subsystem: Acer Incorporated [ALI] CM238 HD Audio Controller [1025:1177]
01:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
	Subsystem: Acer Incorporated [ALI] GP104 High Definition Audio Controller [1025:1177]
!!Modprobe options (Sound related)
snd_hda_intel: patch=hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw,(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 0
	power_save_controller : N
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
	dmic_detect : Y
	enable_msi : -1
	pm_blacklist : Y
	power_save : 0
	single_cmd : -1
	snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC255
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0255
Subsystem Id: 0x10251177
Revision Id: 0x100002
No Modem Function Group found
Default PCM:
    rates [0x560]: 44100 48000 96000 192000
    bits [0xe]: 16 20 24
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3 D3cold CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Front Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Device: name="ALC255 Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
  Amp-Out vals:  [0x37 0x37]
  Converter: stream=1, channel=0
  PCM:
    rates [0x60]: 44100 48000
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Surround Playback Volume", index=0, device=0
  PCM:
    formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Converter: stream=0, channel=0
  Digital:
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    rates [0x5e0]: 44100 48000 88200 96000 192000
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
  Amp-In vals:  [0x27 0x27]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Amp-In vals:  [0x97 0x97]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Mic Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 5
     0x18 0x19 0x1a 0x1b 0x1d
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Audio Mixer] wcaps 0x20010a: Mono Amp-In
  Connection: 1
     0x0d
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
  Control: name="Internal Mic Boost Volume", index=0, device=0
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00000020: IN
  Pin Default 0x90a601c0: [Fixed] Mic at Int N/A
    Conn = Digital, Color = Unknown
    DefAssociation = 0xc, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Front Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x00010014: OUT EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x90171110: [Fixed] Speaker at Int N/A
    Conn = Analog, Color = Black
    DefAssociation = 0x1, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Unsolicited: tag=00, enabled=0
  Connection: 1
     0x0c
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Pin Complex] wcaps 0x40050c: Mono Amp-Out
  Amp-Out vals:  [0x80]
  Pincap 0x00000010: OUT
  Pin Default 0x40000000: [N/A] Line Out at Ext N/A
    Conn = Unknown, Color = Unknown
    DefAssociation = 0x0, Sequence = 0x0
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
  Pincap 0x00003724: IN Detect
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    DefAssociation = 0xf, Sequence = 0x0
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN VREF_HIZ
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
    Misc = NO_PRESENCE
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
  Control: name="Mic Boost Volume", index=0, device=0
  Pin Default 0x03a11030: [Jack] Mic at Ext Left
    DefAssociation = 0x3, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=02, enabled=1
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Surround Playback Switch", index=0, device=0
  Pincap 0x0001373c: IN OUT HP EAPD Detect
  EAPD 0x2: EAPD
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT VREF_HIZ
  Connection: 2
     0x0c 0x0d*
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x40e89b2d: [N/A] Reserved at Ext N/A
    Conn = DIN, Color = Pink
    DefAssociation = 0x2, Sequence = 0xd
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000014: OUT Detect
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=76
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x0001001c: OUT HP EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x03211020: [Jack] HP Out at Ext Left
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP
  Unsolicited: tag=01, enabled=1
  Connection: 2
     0x0c* 0x0d
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 6
     0x18 0x19 0x1a 0x1b 0x1d 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00]
  Connection: 7
     0x18 0x19 0x1a 0x1b 0x1d 0x0b 0x12
Codec: Nvidia GPU 83 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0083
Revision Id: 0x100100
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
  Power states:  D0 D1 D2 D3 CLKSTOP EPSS
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pincap 0x09000094: OUT Detect HBR HDMI DP
  Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
  Pin-ctls: 0x00:
  Devices: 4
     Dev 00: PD = 0, ELDV = 0, IA = 0
     Dev 01: PD = 0, ELDV = 0, IA = 0
     Dev 02: PD = 0, ELDV = 0, IA = 0
    *Dev 03: PD = 0, ELDV = 0, IA = 0
  Connection: 4
     0x0a* 0x0b 0x0c 0x0d
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Unsolicited: tag=05, enabled=1
  Devices: 4
  Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
  Pin-ctls: 0x00:
  Devices: 4
    *Dev 00: PD = 0, ELDV = 0, IA = 0
  Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Unsolicited: tag=09, enabled=1
  Devices: 4
  Connection: 4
Node 0x08 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Devices: 4
  Connection: 4
Node 0x09 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Devices: 4
  Connection: 4
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    formats [0x5]: PCM AC3
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
Node 0x0c [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
Node 0x0d [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 13 Jul  2 20:58 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  9 Jul  2 20:58 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 12 Jul  2 20:58 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116,  8 Jul  2 20:58 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 11 Jul  2 20:58 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 10 Jul  2 21:04 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116,  6 Jul  2 20:58 /dev/snd/pcmC1D10p
crw-rw----+ 1 root audio 116,  7 Jul  2 20:58 /dev/snd/pcmC1D11p
crw-rw----+ 1 root audio 116,  2 Jul  2 20:58 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116,  3 Jul  2 20:58 /dev/snd/pcmC1D7p
crw-rw----+ 1 root audio 116,  4 Jul  2 20:58 /dev/snd/pcmC1D8p
crw-rw----+ 1 root audio 116,  5 Jul  2 20:58 /dev/snd/pcmC1D9p
crw-rw----+ 1 root audio 116,  1 Jul  2 20:58 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Jul  2 20:58 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  80 Jul  2 20:58 .
drwxr-xr-x 3 root root 340 Jul  2 20:58 ..
lrwxrwxrwx 1 root root  12 Jul  2 20:58 pci-0000:00:1f.3 -> ../controlC0
lrwxrwxrwx 1 root root  12 Jul  2 20:58 pci-0000:01:00.1 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
  Subdevices: 0/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
  Subdevices: 1/1
ARECORD
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0x93520000 irq 128'
  Mixer name	: 'Realtek ALC255'
  Components	: 'HDA:10ec0255,10251177,00100002'
  Controls      : 24
  Simple ctrls  : 11
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 55 [63%] [-24.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pswitch
  Mono:
  Front Left: Playback [off]
  Front Right: Playback [off]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Surround',0
  Mono:
Simple mixer control 'Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 39 [62%] [12.00dB] [on]
  Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
!!-------Mixer controls for card NVidia
Card hw:1 'NVidia'/'HDA NVidia at 0x93000000 irq 17'
  Mixer name	: 'Nvidia GPU 83 HDMI/DP'
  Components	: 'HDA:10de0083,10251177,00100100'
  Controls      : 42
  Simple ctrls  : 6
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
Simple mixer control 'IEC958',5
  Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface MIXER
		name 'Front Playback Volume'
		value.0 87
		value.1 87
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.2 {
		iface MIXER
		name 'Front Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Surround Playback Volume'
		value.0 87
		value.1 87
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.4 {
		iface MIXER
		name 'Surround Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.5 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.6 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.7 {
		iface MIXER
		name 'Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.8 {
		iface MIXER
		name 'Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.9 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Enabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.10 {
		iface MIXER
		name 'Capture Volume'
		value.0 39
		value.1 39
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 63'
			dbmin -1725
			dbmax 3000
			dbvalue.0 1200
			dbvalue.1 1200
	control.11 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.12 {
		iface MIXER
		name 'Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.13 {
		iface MIXER
		name 'Internal Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.14 {
		iface MIXER
		name 'Master Playback Volume'
		value 55
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 -2400
	control.15 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.16 {
		iface CARD
		name 'Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.17 {
		iface CARD
		name 'Internal Mic Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.18 {
		iface CARD
		name 'Speaker Front Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.19 {
		iface CARD
		name 'Speaker Surround Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface CARD
		name 'Speaker CLFE Phantom Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.21 {
		iface CARD
		name 'Headphone Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.22 {
		iface PCM
		name 'Playback Channel Map'
		value.0 3
		value.1 4
		value.2 0
		value.3 0
		comment {
			access read
			type INTEGER
			count 4
			range '0 - 36'
	control.23 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.24 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 255
		value.1 255
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
state.NVidia {
	control.1 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.7 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.9 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.10 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.11 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.13 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.16 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.17 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.19 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.25 {
		iface CARD
		name 'HDMI/DP,pcm=10 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.28 {
		iface MIXER
		index 4
		comment {
			access 'read write'
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.31 {
		iface CARD
		name 'HDMI/DP,pcm=11 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.33 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.34 {
		iface MIXER
		index 5
		comment {
			access 'read write'
			type IEC958
			count 1
	control.35 {
		iface MIXER
		index 5
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		device 11
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.37 {
		iface PCM
		device 3
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.38 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.39 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.40 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.41 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.42 {
		iface PCM
		device 11
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
--endcollapse--
!!All Loaded Modules
ac
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
alx
ath
ath10k_core
ath10k_pci
atkbd
battery
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
i2c_hid
i2c_i801
i8042
iTCO_vendor_support
iTCO_wdt
idma64
input_leds
intel_cstate
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_rapl_perf
intel_uncore
intel_wmi_thunderbolt
ip_tables
ipmi_devintf
ipmi_msghandler
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libps2
mac80211
mac_hid
mbcache
mc
mdio
mei
mei_hdcp
mei_me
mousedev
mxm_wmi
nls_cp437
nls_iso8859_1
nvidia
nvidia_drm
nvidia_modeset
pcspkr
psmouse
rc_core
rfcomm
rfkill
rng_core
serio
serio_raw
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_seq
snd_seq_device
snd_seq_dummy
snd_timer
soundcore
sparse_keymap
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
uas
usb_storage
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x90a601c0
0x14 0x90171110
0x17 0x40000000
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x03a11030
0x1b 0x411111f0
0x1d 0x40e89b2d
0x1e 0x411111f0
0x21 0x03211020
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
0x12 0x90a60160
0x14 0x90170150
0x17 0x90170151
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x03a11030
0x1b 0x90170152
0x1d 0x40e89b2d
0x1e 0x411111f0
0x21 0x03211020
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x585600f0
0x07 0x185600f0
0x08 0x585600f0
0x09 0x585600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[    0.163696] ACPI: Added _OSI(Linux-Dell-Video)
[    0.163697] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.163697] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    3.485452] hid-generic 0018:06CB:7B99.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA7B99:00 06CB:7B99] on i2c-SYNA7B99:00
[    3.487113] snd_hda_intel 0000:00:1f.3: Applying patch firmware 'hda-jack-retask.fw'
[    3.487533] snd_hda_intel 0000:01:00.1: Disabling MSI
[    3.487539] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    3.487547] snd_hda_intel 0000:01:00.1: Applying patch firmware 'hda-jack-retask.fw'
[    3.493287] AVX2 version of gcm_enc/dec engaged.
[    3.541891] ahci 0000:00:17.0: port does not support device sleep
[    3.547736] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[    3.547790] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
[    3.547875] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input21
[    3.547923] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input22
[    3.547969] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input23
[    3.548014] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input24
[    3.568186] mousedev: PS/2 mouse device common for all mice
[    3.584238] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC255: line_outs=3 (0x14/0x1b/0x17/0x0/0x0) type:speaker
[    3.584240] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.584242] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    3.584243] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    3.584244] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    3.584245] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x1a
[    3.584246] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    3.584292] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[    3.631142] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[    3.631196] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[    3.758343] intel_rapl_common: Found RAPL domain package
[    5.825919] audit: type=1130 audit(1593716310.751:55): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:nvidia_0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.919445] audit: type=1130 audit(1593716311.844:56): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=boot_sound comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.919477] audit: type=1131 audit(1593716311.844:57): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=boot_sound comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.130044] audit: type=1100 audit(1593716313.054:58): pid=910 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
But in Skype:
2020-07-02_21-13
Where do I start investigating as the hardware seems to work but puleseaudio is not picking things up???
ALSA looks ok
(data does not show much about the jack retasking but i recall this from previous discussion and don't expect that is causing a problem)
  Subdevices: 0/1
0/1 indicator for subdevice suggests Pulseaudio is connected for playback (0=unavailable)
(subdevice could also be connected to JACK but it is not running)
but other subdevices are showing as available (1/1), including analog capture
and Skype is showing Speakers
check pacmd dump to see if sinks and sources are present and not muted/suspended
the source for microphone would be something like alsa_input... ...analog-stereo
if there is only source alsa_output... ...analog-stereo.monitor
check card Profiles - pacmd list-cards
pulseaudio may be using profile for output only instead of 'input+output' or 'Duplex'
or switching away from profiles showing as 'available: no'
In pacmd dump I can't see anything relating to a microphone:
### Configuration dump generated at Fri Jul  3 21:54:30 2020
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-rescue-streams
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0
load-module module-x11-xsmp display=:0 session_manager=local/fab-manjaro:@/tmp/.ICE-unix/1141,unix/fab-manjaro:/tmp/.ICE-unix/1141
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1f.3.analog-stereo 0x5709
set-sink-mute alsa_output.pci-0000_00_1f.3.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1f.3.analog-stereo no
set-source-volume alsa_output.pci-0000_00_1f.3.analog-stereo.monitor 0x9460
set-source-mute alsa_output.pci-0000_00_1f.3.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1f.3.analog-stereo.monitor no
set-card-profile alsa_card.pci-0000_01_00.1 off
set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo
set-default-sink alsa_output.pci-0000_00_1f.3.analog-stereo
set-default-source alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
### EOF
I'm going to test whether it works in Windows next to rule out a hardware problem...
Weird: pacmd list-cards shows a microphone...
2 card(s) available.
    index: 0
        driver: <module-alsa-card.c>
        owner module: 6
        properties:
                alsa.card = "1"
                alsa.card_name = "HDA NVidia"
                alsa.long_card_name = "HDA NVidia at 0x93000000 irq 17"
                device.bus_path = "pci-0000:01:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
                device.bus = "pci"
                device.vendor.id = "10de"
                device.vendor.name = "NVIDIA Corporation"
                device.product.id = "10f0"
                device.product.name = "GP104 High Definition Audio Controller"
                device.string = "1"
                device.description = "GP104 High Definition Audio Controller"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        profiles:
                output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
                output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
                output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
                output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
                output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
                output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
                output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
                output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
                output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
                output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
                output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
                output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
                output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
                output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
                output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
                output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (priority 5700, available: no)
                output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (priority 600, available: no)
                output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (priority 600, available: no)
                off: Off (priority 0, available: unknown)
        active profile: <off>
        ports:
                hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
                        properties:
    index: 1
        owner module: 7
        properties:
                alsa.card = "0"
                alsa.long_card_name = "HDA Intel PCH at 0x93520000 irq 128"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "a171"
                device.product.name = "CM238 HD Audio Controller"
                device.string = "0"
                device.description = "Built-in Audio"
        profiles:
                input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
                output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
                output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
                output:analog-surround-40: Analog Surround 4.0 Output (priority 1200, available: unknown)
                output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (priority 1265, available: unknown)
        active profile: <output:analog-stereo>
        sinks:
                alsa_output.pci-0000_00_1f.3.analog-stereo/#0: Built-in Audio Analog Stereo
        sources:
                alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
        ports:
                analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
                        properties:
                analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
                        properties:
                analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
                        properties:
                analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
                        properties:
:crazy_face:
P.S. Now you also know what I look like! :wink:
Did you try the 5.4 kernel by any chance? I've lost audio and Bluetooth and what not with some of the newer kernels occasionally. Actually just tried the 5.7 kernel yesterday Wi-Fi problems.
Every time I connect a microphone while Skype is running, the microphone isn't recognized by Skype. So for the microphone to be recognized I have to close Skype, connect the microphone, then start Skype again.
Another unrelated microphone problem I have on Manjaro is with Audacity. Every time I start Audacity after unplugging a microphone the computer become unresponsive, and the last few hundred milliseconds of sound play over and over even when the shutting down routine kicks in. In fact until the monitor won't shut down and the disk won't turn off the sound won't shut the hell up. It's like a broken gramophone. Very weird!
it does have the wrong profile - output only
but the right profile is there:
pacmd dump had most of the command needed to change profile:
pacmd set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo+input:analog-stereo
(i really want this to work so more people get to know about this command)
[the large round sphere behind you seems a bit ominous but that is probably just my paranoia from having watched The Prisoner too many times]
Skype only detects audio devices when it is started,
so a microphone must be connected and available before Skype is launched
i have also noticed that if microphone is disabled in Pulseaudio, Skype still appears to have the microphone available!
for the Audacity problem you should check the manual and Audacity forum for anything mentioning 'feedback loop'
i have heard about other users getting this sort of loop sound because of some configuration settings
but i do not know which specific settings to look at
You are amazing! :star_struck:
pacmd set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo+input:analog-stereo did the trick:
2020-07-04_09-18
Note: The large blue ominous sphere behind me is a desk chair I bought by recommendation of my physician because I was sitting still for too large stretches of time on a previous job and contrarily to a normal desk chair, with the sphere you naturally move around all day long without you even noticing after the first 3 days of being constantly annoyed that it moves around... :wink:
It's what I always recommend other people to do: Try another kernel! :joy: but it ended up being an audio profile setting that was set for output only and needed some @nikgnomic magic:
pacmd set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo+input:analog-stereo solved the issue!
:star_struck:
credit has to go to the pacmd command for doing the majority of the work on this
only other option i can think of if it had not worked would be to blame skype, delete the configuration folder in home and hope it works when restarted
i always turn off automatic level controls because i find the effect of volume level moving up and down very distracting. if microphone is set correctly it should not need much level adjusting. but i do have some external processing and JACK DSP when needed
