Minimal brightness setting not remembered
Hi,
inxi: Dump your "inxi -Fxxxza --no-host" here and bookmark it
I set the slider in Battery and Brightness -> Display Brightness to minimum.
After reboot or logout/login this value is not remembered, instead it reverts to 5.00 according to light, https://github.com/haikarainen/light, which I installed from Official Repositories.
Is it possible to make it remember?
Furthermore, the Fn+F5/F6 keys works but in steps of 5.00.
Is there a way to adjust the step values?
I could write a startup script using light to set the value at boot but maybe there is a more sensible way?
Thanks.
Worked around it by creating a systemd service which runs a shell script at boot.
# cat /etc/systemd/system/low-brightness.service
[Unit]
After=upower.service
[Service]
ExecStart=/usr/local/bin/low-brightness.sh
[Install]
WantedBy=default.target
# cat /usr/local/bin/low-brightness.sh
#!bin/bash
# Set low-brightness at boot (See /etc/systemd/system/low-brightness.service)
light -S 0.1
Edit: changed Solved to Worked around it
2: changed mysql to upower.service
