Missing packages from AUR
Just installed a fresh install of Manjaro Gnome and when I update AUR, I get the following message:
Missing AUR Packages: gnome-shell-extension-nightshellswitcher xorg-font-utils xorg-fonts-alias
This is packages that was installed by the installert... Are they safe to remove or?
xorg-font-util (without the s) is in the repos.
Otherwise none of the rest exist, so if you are up to date they should be safe to remove.
If something depends on them you will see.
