Missing ZFS modules zpios splat
I'm trying to test zfs, just installed 'linux419-zfs' and 'zfs-utils' and created some test pools using .img files. Everything seems to work, except I'm missing two kernel modules for zfs: zpios and splat.
I can't find any packages that contain them using "pacman -Fs".
This means I can't rebuild my initramfs with zfs, so zfs-import-cache and zfs-mount both fail with:
The ZFS modules are not loaded
Try running '/sbin/modprobe zfs' as root to load them
I can 'modprobe zfs' after boot and import the pools individually or with the cache file, I could script it but that's just a workaround.
I've spent quite a while searching this forum and elsewhere to no avail.
What am I missing? (other than the modules)
I am using zfs and I do not have any zpios or splat module. I have the follwing services running without any issue:
zfs-import-cache.service        loaded active     exited    Import ZFS pools by cache file
zfs-mount.service        loaded active     exited    Mount ZFS filesystems
zfs-zed.service        loaded active     running   ZFS Event Daemon (zed)
zfs-import.target        loaded active     active    ZFS pool import target
zfs.target        loaded active     active    ZFS startup target
Why do you believe that modules zpios and splat are missing?
I was hoping you'd reply, you seem to know your stuff. Here's the output from mkinitcpio -p linux419:
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
  -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
==> Starting build: 4.19.69-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [zfs]
==> ERROR: module not found: `zpios'
==> ERROR: module not found: `splat'
==> ERROR: file not found: `zpios'
==> ERROR: file not found: `splat'
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
==> WARNING: errors were encountered during the build. The image may not be complete.
If I boot with the resulting initramfs it drops out into a rather limited system, the initramfs I assume, and I have to use a live USB to fix it.
I also have those services enabled, plus zfs-share, 4 fail telling me the ZFS modules aren't loaded and to use '/sbin/modprobe zfs':
zfs-import-cache
zfs-mount
zfs-zed
zfs-share
These two load and are active:
zfs-import.target
zfs.target
This means you have the wrong module versions for the kernel you are using.
Make sure you are fully up-to-date,
sudo pacman-mirrors -f5
sudo pacman -Syyu
and try again.
It's a fresh install and up to date. I did as you said and nothing was updated.
If everything is up-to-date it means that the extramodules for 4.19 were not rebuilt for 4.19.69.
Can you try with a different kernel, e.g.
sudo mhwd-kernel -i linux53
Still the same :frowning:
Error message please. If it's failing at 4.19 then that's to be expected.
I need more information about what you're doing. Providing inconsistent log output with no information about the rest of the setup doesn't help.
If you installed kernel 5.3 did you also boot into kernel 5.3?
What's the output of modprobe -vvv zfs ?
Sorry first time I've needed to ask on a forum, accidentally deleted the last msg, was trying edit it, not used to touchpads.
Yes I installed 5.3 and rebooted, wanted to add output of uname -a to last msg.
Linux lappy 5.3.0-1-MANJARO #1 SMP Mon Sep 2 18:26:38 UTC 2019 x86_64 GNU/Linux
modprobe: INFO: custom logging function 0x56001b4f0d00 registered
insmod /lib/modules/5.3.0-1-MANJARO/extramodules/spl.ko.gz
insmod /lib/modules/5.3.0-1-MANJARO/extramodules/icp.ko.gz
insmod /lib/modules/5.3.0-1-MANJARO/extramodules/zavl.ko.gz
insmod /lib/modules/5.3.0-1-MANJARO/extramodules/znvpair.ko.gz
insmod /lib/modules/5.3.0-1-MANJARO/extramodules/zcommon.ko.gz
insmod /lib/modules/5.3.0-1-MANJARO/extramodules/zlua.ko.gz
insmod /lib/modules/5.3.0-1-MANJARO/extramodules/zunicode.ko.gz
insmod /lib/modules/5.3.0-1-MANJARO/extramodules/zfs.ko.gz
modprobe: INFO: context 0x56001c26d4a0 released
OK, so the module loaded with kernel 5.3. This means the extramodule for 4.19 in the repository has the wrong ABI version for the available kernel version. That will already be resolved in the testing branch.
However, you will at least be able to test ZFS now.
The 'linux53-zfs' package got installed as a dependency along with 5.3. I should have posted the output, but I was keen to see if it worked and rebooted straight away.
$ pacman -Qs zfs
local/linux419-zfs 0.8.1-19 (linux419-extramodules)
    Kernel modules for the Zettabyte File System.
local/linux53-zfs 0.8.1-0.8 (linux53-extramodules)
local/zfs-utils 0.8.1-1 (manjarozfs)
    User-Mode utils for the Zettabyte File System.
Thank you very much for your help and patience, and your quick responces. However I could test it before, I've got a couple of pools with test data on, just can't auto import the pools at boot. I appolgize if I was unclear.
Manjaro is my favourite distro, and it's good to see we have such dedicated and helpful developers.
Edit:
Just to be clear, if I try to rebuild the initramfs with zfs, I still get the same errors as before (missing zpios and splat). Sorry I feel like I've been useless at providing the proper info, or at least explaining it well. I'll do better in future.
OK, so looking into this more there's an issue with the zfs-utils package.
I'll update the package into unstable shortly.
Edit: zfs-utils-0.8.2-2 is now in unstable.
Sorry for taking so long, was busy yesterday. If I'm not being helpful then please feel free to ignore me. I'm not actually using ZFS yet, just getting a feel for it, and I can make a script to import if I need to.
I did a fresh install, changed to unstable and updated using:
sudo pacman-mirrors --api --set-branch unstable
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
After a reboot I installed 'linux419-zfs' and 'zfs-utils'.
$ sudo pacman -S linux419-zfs
[sudo] password for test:
resolving dependencies...
Packages (2) zfs-utils-0.8.2-2.1  linux419-zfs-0.8.2-1
Total Download Size:   2.99 MiB
Total Installed Size:  8.60 MiB
:: Retrieving packages...
 zfs-utils-0.8.2-2.1-x86_64                       1627.1 KiB  4.18M/s 00:00 [###########################################] 100%
 linux419-zfs-0.8.2-1-x86_64                      1429.7 KiB  5.58M/s 00:00 [###########################################] 100%
(2/2) checking keys in keyring                                              [###########################################] 100%
(2/2) checking package integrity                                            [###########################################] 100%
(2/2) loading package files                                                 [###########################################] 100%
(2/2) checking for file conflicts                                           [###########################################] 100%
(2/2) checking available disk space                                         [###########################################] 100%
(1/2) installing zfs-utils                                                  [###########################################] 100%
Created symlink /etc/systemd/system/zfs-import.target.wants/zfs-import-scan.service โ†’ /usr/lib/systemd/system/zfs-import-scan.service.
Created symlink /etc/systemd/system/zfs.target.wants/zfs-import.target โ†’ /usr/lib/systemd/system/zfs-import.target.
Created symlink /etc/systemd/system/zfs.target.wants/zfs-mount.service โ†’ /usr/lib/systemd/system/zfs-mount.service.
Created symlink /etc/systemd/system/multi-user.target.wants/zfs.target โ†’ /usr/lib/systemd/system/zfs.target.
Optional dependencies for zfs-utils
    python: for arcstat/arc_summary/dbufstat [installed]
(2/2) installing linux419-zfs                                               [###########################################] 100%
(1/5) Updating linux419 module dependencies...
(2/5) Updating linux419 initcpios...
==> Starting build: 4.19.75-1-MANJARO
  -> Running build hook: [resume]
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
  -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
(3/5) Reloading system manager configuration...
(4/5) Reloading device manager configuration...
(5/5) Arming ConditionNeedsUpdate...
Rebooted again
$ sudo systemctl status zfs.*
โ— zfs.target - ZFS startup target
   Loaded: loaded (/usr/lib/systemd/system/zfs.target; enabled; vendor preset: enabled)
   Active: active since Mon 2019-09-30 16:23:01 EDT; 1min 22s ago
Sep 30 16:23:01 test-laptop systemd[1]: Reached target ZFS startup target.
$ sudo systemctl status zfs-*
โ— zfs-mount.service - Mount ZFS filesystems
   Loaded: loaded (/usr/lib/systemd/system/zfs-mount.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2019-09-30 16:23:01 EDT; 2min 17s ago
     Docs: man:zfs(8)
  Process: 465 ExecStart=/usr/bin/zfs mount -a (code=exited, status=1/FAILURE)
 Main PID: 465 (code=exited, status=1/FAILURE)
Sep 30 16:23:01 test-laptop systemd[1]: Starting Mount ZFS filesystems...
Sep 30 16:23:01 test-laptop zfs[465]: The ZFS modules are not loaded.
Sep 30 16:23:01 test-laptop zfs[465]: Try running '/sbin/modprobe zfs' as root to load them.
Sep 30 16:23:01 test-laptop systemd[1]: zfs-mount.service: Main process exited, code=exited, status=1/FAILURE
Sep 30 16:23:01 test-laptop systemd[1]: zfs-mount.service: Failed with result 'exit-code'.
Sep 30 16:23:01 test-laptop systemd[1]: Failed to start Mount ZFS filesystems.
โ— zfs-import-scan.service - Import ZFS pools by device scanning
   Loaded: loaded (/usr/lib/systemd/system/zfs-import-scan.service; enabled; vendor preset: disabled)
     Docs: man:zpool(8)
  Process: 460 ExecStart=/usr/bin/zpool import -aN -o cachefile=none (code=exited, status=1/FAILURE)
 Main PID: 460 (code=exited, status=1/FAILURE)
Sep 30 16:23:01 test-laptop systemd[1]: Starting Import ZFS pools by device scanning...
Sep 30 16:23:01 test-laptop zpool[460]: The ZFS modules are not loaded.
Sep 30 16:23:01 test-laptop zpool[460]: Try running '/sbin/modprobe zfs' as root to load them.
Sep 30 16:23:01 test-laptop systemd[1]: zfs-import-scan.service: Main process exited, code=exited, status=1/FAILURE
Sep 30 16:23:01 test-laptop systemd[1]: zfs-import-scan.service: Failed with result 'exit-code'.
Sep 30 16:23:01 test-laptop systemd[1]: Failed to start Import ZFS pools by device scanning.
โ— zfs-import.target - ZFS pool import target
   Loaded: loaded (/usr/lib/systemd/system/zfs-import.target; enabled; vendor preset: enabled)
   Active: active since Mon 2019-09-30 16:23:01 EDT; 2min 17s ago
Sep 30 16:23:01 test-laptop systemd[1]: Reached target ZFS pool import target.
Added 'zfs' before 'filesystems' in /etc/mkinicpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(piix ide_disk reiserfs)
MODULES=""
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image.  This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way.  This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file.  The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added.  Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
##   This setup specifies all modules in the MODULES setting above.
##   No raid, lvm2, or encrypted root is needed.
#    HOOKS=(base)
##   This setup will autodetect all modules for your system and should
##   work as a sane default
#    HOOKS=(base udev autodetect block filesystems)
##   This setup will generate a 'full' image which supports most systems.
##   No autodetection is done.
#    HOOKS=(base udev block filesystems)
##   This setup assembles a pata mdadm array with an encrypted root FS.
##   Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
#    HOOKS=(base udev block mdadm encrypt filesystems)
##   This setup loads an lvm2 volume group on a usb device.
#    HOOKS=(base udev block lvm2 filesystems)
##   NOTE: If you have /usr on a separate partition, you MUST include the
#    usr, fsck and shutdown hooks.
HOOKS="base udev autodetect modconf block keyboard keymap resume zfs filesystems"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
and ran mkinitcpio, which completed successfully :slight_smile:
$ sudo mkinitcpio -p linux419
and then rebooted again during which the following familar mesage came up, at the top of a blank screen
The ZFS modules aren't loaded.
   Active: active since Mon 2019-09-30 16:28:12 EDT; 24s ago
Sep 30 16:28:12 test-laptop systemd[1]: Reached target ZFS startup target.
   Active: active since Mon 2019-09-30 16:28:12 EDT; 1min 18s ago
Sep 30 16:28:12 test-laptop systemd[1]: Reached target ZFS pool import target.
   Active: failed (Result: exit-code) since Mon 2019-09-30 16:28:12 EDT; 1min 18s ago
     Docs: man:zpool(8)
  Process: 478 ExecStart=/usr/bin/zpool import -aN -o cachefile=none (code=exited, status=1/FAILURE)
 Main PID: 478 (code=exited, status=1/FAILURE)
Sep 30 16:28:12 test-laptop systemd[1]: Starting Import ZFS pools by device scanning...
Sep 30 16:28:12 test-laptop zpool[478]: The ZFS modules are not loaded.
Sep 30 16:28:12 test-laptop zpool[478]: Try running '/sbin/modprobe zfs' as root to load them.
Sep 30 16:28:12 test-laptop systemd[1]: zfs-import-scan.service: Main process exited, code=exited, status=1/FAILURE
Sep 30 16:28:12 test-laptop systemd[1]: zfs-import-scan.service: Failed with result 'exit-code'.
Sep 30 16:28:12 test-laptop systemd[1]: Failed to start Import ZFS pools by device scanning.
     Docs: man:zfs(8)
  Process: 479 ExecStart=/usr/bin/zfs mount -a (code=exited, status=1/FAILURE)
 Main PID: 479 (code=exited, status=1/FAILURE)
Sep 30 16:28:12 test-laptop systemd[1]: Starting Mount ZFS filesystems...
Sep 30 16:28:12 test-laptop zfs[479]: The ZFS modules are not loaded.
Sep 30 16:28:12 test-laptop zfs[479]: Try running '/sbin/modprobe zfs' as root to load them.
Sep 30 16:28:12 test-laptop systemd[1]: zfs-mount.service: Main process exited, code=exited, status=1/FAILURE
Sep 30 16:28:12 test-laptop systemd[1]: zfs-mount.service: Failed with result 'exit-code'.
Sep 30 16:28:12 test-laptop systemd[1]: Failed to start Mount ZFS filesystems.
$ zpool status
$ sudo modprobe zfs
$ zpool status
no pools available
$ sudo zpool import -d ~/zfstest/raidz11.img rz1
$ zpool status
  pool: rz1
 state: ONLINE
  scan: scrub repaired 0B in 0 days 00:00:04 with 0 errors on Thu Sep 26 10:11:39 2019
config:
	NAME                                STATE     READ WRITE CKSUM
	rz1                                 ONLINE       0     0     0
	  raidz1-0                          ONLINE       0     0     0
	    /home/test/zfstest/raidz11.img  ONLINE       0     0     0
	    /home/test/zfstest/raidz12.img  ONLINE       0     0     0
	    /home/test/zfstest/raidz13.img  ONLINE       0     0     0
errors: No known data errors
$ sudo zpool set cachefile=/etc/zfs/zpool.cache rz1
Another reboot and I can import manually using the cache file:
$ zpool status
$ sudo modprobe zfs
$ zpool status
no pools available
$ sudo zpool import -c /etc/zfs/zpool.cache -aN
$ zpool status
  pool: rz1
 state: ONLINE
config:
	rz1                                 ONLINE       0     0     0
   Active: failed (Result: exit-code) since Mon 2019-09-30 16:42:57 EDT; 7min ago
     Docs: man:zfs(8)
Sep 30 16:42:57 test-laptop systemd[1]: Starting Mount ZFS filesystems...
Sep 30 16:42:57 test-laptop zfs[479]: The ZFS modules are not loaded.
Sep 30 16:42:57 test-laptop zfs[479]: Try running '/sbin/modprobe zfs' as root to load them.
Sep 30 16:42:57 test-laptop systemd[1]: zfs-mount.service: Main process exited, code=exited, status=1/FAILURE
Sep 30 16:42:57 test-laptop systemd[1]: zfs-mount.service: Failed with result 'exit-code'.
Sep 30 16:42:57 test-laptop systemd[1]: Failed to start Mount ZFS filesystems.
   Active: active since Mon 2019-09-30 16:42:57 EDT; 7min ago
Sep 30 16:42:57 test-laptop systemd[1]: Reached target ZFS pool import target.
   Active: active since Mon 2019-09-30 16:42:57 EDT; 9min ago
Sep 30 16:42:57 test-laptop systemd[1]: Reached target ZFS startup target.
I hope I've provided enough to be helpful. Sorry if I've provided too much or irrelevant info (or if I've been an idiot and missed something obvious).
The zfs module will automatically load when a ZFS pool device is detected; otherwise you'll need to load the module manually (e.g. if you're using file-based pool devices).
The rest is working to design - if you add a /etc/zfs/zpool.cache you'll need to systemctl enable zfs-import-cache.service too. By default I have set zfs-import-scan to be enabled but it will fail to run if /etc/zfs/zpool.cache is present.
However, I've updated zfs-utils-0.8.2-2.2 to run modprobe zfs on first installation as it makes sense to make it available automatically first time around (i.e. so you can set up a new pool).
