Mono audio only on Acer Predator 17
Hello, I am getting mono audio from only the left speaker on my laptop, I did some searching around and it seems that it is a common issue, I fould a solution for ubuntu but I have no idea how to translate to arch/manjaro, any tips?
solution on ubuntu: https://ubuntuforums.org/showthread.php?t=2357875
hdajackretask is part of the alsa-tools package, i've never used it but maybe @nikgnomic is around for some guidance.
or you could just install and try it yourself according to the instructions on the ubuntu link you posted
It is exactly the same settings, not sure why it did not work before, but it did on second try
Screenshot_20190916_141525
solution should be post #3 as screenshot shows just what is needed
doesn't look like any guidance needed
good find on that Ubuntu post
'It's fairly easy to use graphical tool' isn't wrong
but knowing which pinIDs to go for in advance helps a lot
may help to post alsa-info.sh data with comment about hdajackretask to bugzilla:
https://bugzilla.kernel.org/show_bug.cgi?id=195049
original user appears to have worked this out with hdaanalyzer
if results are same with hdajackrestask will help progress to kernel fix
