Hi people, sorry for everyday post new problems haha.
Firefox doesn't display radio buttons. I read and have tried with codes that I found in Google about this topic but nothing resolve the problem.
I attach a picture:
Thanks
I attach a picture:
Thanks
This is an issue with your theme.
Change your theme.
Also, this has already been posted in one of your other Firefox threads but you really should read it:
Thanks @jonathon I read and did the post indications, but the problem is not solve.
I tried with 11 differents themes (8 incluided in Manjaro Deepin and 3 downloaded by me) and with none have display the radio buttons.
Do you have a dark theme to recommend me for solve the problem?
Thanks again
Finally I found the solution.
With this simple line I have been able to solve 2 things:
The problem of displaying the radiobuttons, and also the problem of all the inputboxes with a black background (This last one was solved with 10 lines of CSS that I had copied from another place, but now with this line everything is solved)
Close (exit) all instances of Firefox.
Go to your profile folder. It is here:~/.mozilla/firefox/randomstring.default
. In there, look for a subfolder calledchrome
. If it doesn't exist, create it.
To create thechrome
folder you can use your file manager (or the command line withmkdir chrome
Ifchrome
does exist, look for a file calleduserContent.css
. Otherwise, create an empty text file with this name in thechrome
folder. Now openuserContent.css
with a text editor and paste in or append this code:
INPUT, TEXTAREA {color: black !important; background: #aaaaaa !important; }
Save the file (as plain text) and close the text editor. Restart Firefox. You should now have black text on a light gray background. You can use whatever color combination you prefer.
Notes:chrome
anduserContent.css
are case-sensitive and should be spelled correctly. The settings here will take precedence over those in the OS theme and will remain the same in Firefox irrespective of whichgtk
theme you switch to.
Thanks!
EDIT WITH OTHER SOLUTION
SOLVE INPUTBOX BLACK IN FIREFOX
In Firefox go to about:config
and set the following string value: widget.content.gtk-theme-override
= Adwaita:light
(You have to right-click and select New -> String. Searching for gtk-theme-override
won't find anything because the setting isn't there by default.)
Seriously, this is a theme issue. It's been posted about multiple times on the forum.
But - I'm glad you've found a solution for your specific case.
Yes, i read some posts about the theme also but I change my theme a lot of times and nothing solve the problem. And with this line all is OK and is not necessary change it
Thanks for your reply and help @jonathon
