Mouse and DualShock 4 stop working
I'm reposting this from the Manjaro Subreddit, as they seem a little dead over there.
Hello all,
On my PC, I'm trying to run Manjaro to do some light Linux gaming. I would love to transition fully to Manjaro as opposed to using Windows for gaming, but there's a problem stopping me from doing so. I've been playing Minecraft Java Edition, Superhot Mind Control Delete and No Man's Sky, and almost every time, after a random length of time, my mouse will stop responding. Last time it happened, I rebooted, then plugged in my DualShock 4 via USB (Bluetooth is not being reliable either) and played for a little bit, but then that stopped responding too! I thought maybe it had something to do with running two programs fullscreen, but I tried playing Minecraft fullscreen and running YouTube in windowed, but it still happened. It even happened when I was typing something in LibreOffice Writer with Strawberry playing music in the background.
I'm really new to Linux. I used to play almost exclusively on Manjaro, for a few months up until Red Dead Redemption 2 launched, then I switched back fully to Windows. So, I'm not sure of how to begin troubleshooting this. My PC specs are as follows;
MB: Gigabyte X470 Gaming 7 WiFi rev 1.0
CPU: Ryzen R5 3600
RAM: GSkill Ripjaws V, 3600 CL19 (running at CL17 or 18, don't remember, hasn't been an issue)
GPU: Sapphire Vega 56 Pulse (V64 Nitro BIOS)
SSD: WD Black SN750 500GB NVMe drive
My main monitor is an Acer Nitro XV340CK, and my secondary is a BenQ 24" 1080p 60Hz VA basic monitor, I forget the model.
And it's a Glorious Model O- mouse and DualShock 4 controller that are causing me issue.
And here's my hardware/software info;
~ >>> inxi --full --verbosity=7 --filter --no-host
Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: Gnome 3.36.4 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: X470 AORUS GAMING 7 WIFI v: N/A
serial:
Mobo: Gigabyte model: X470 AORUS GAMING 7 WIFI-CF v: x.x serial:
UEFI: American Megatrends v: F50a date: 11/08/2019
RAM: total: 31.37 GiB used: 2.73 GiB (8.7%)
RAM Report:
Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen
L2 cache: 3072 KiB bogomips: 86435
Speed: 2150 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 1934 2: 2659 3: 2046 4: 2089 5: 2346 6: 2265 7: 2092 8: 2130 9: 1982
10: 2478 11: 2610 12: 2218
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd
wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Vega 10 XL/XT [Radeon RX Vega 56/64]
vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 0b:00.0
chip ID: 1002:687f
Display: x11 server: X.org 1.20.8 driver: amdgpu compositor: gnome-shell
resolution:
OpenGL:
renderer: Radeon RX Vega (VEGA10 DRM 3.36.0 5.6.19-2-MANJARO LLVM 10.0.0)
v: 4.6 Mesa 20.1.3 direct render: Yes
Device-1: AMD Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
v: kernel bus ID: 0b:00.1 chip ID: 1002:aaf8
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 0e:00.4 chip ID: 1022:1487
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus ID: 7-2:2 chip ID: 046d:082d
serial:
Device-4: Audio-Technica ATR USB microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 7-3:3 chip ID: 0909:001a
Sound Server: ALSA v: k5.6.19-2-MANJARO
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: 5.6.0-k port: f000 bus ID: 05:00.0 chip ID: 8086:1539
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: f000
bus ID: 06:00.0 chip ID: 8086:2526
IF: wlp6s0 state: down mac:
WAN IP:
Local Storage: total: 6.48 TiB used: 4.26 TiB (65.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G3X0C-00SJG0
size: 465.76 GiB speed: 31.6 Gb/s lanes: 4 serial: rev: 111110WD
scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 850 EVO 120GB size: 111.79 GiB
speed: 6.0 Gb/s serial: rev: 1B6Q scheme: GPT
ID-3: /dev/sdb vendor: Western Digital model: WDS500G2B0A-00SM50
size: 465.76 GiB speed: 6.0 Gb/s serial: rev: 40WD scheme: GPT
ID-4: /dev/sdc vendor: Toshiba model: DT01ACA300 size: 2.73 TiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: ABB0 scheme: GPT
ID-5: /dev/sdd vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: CC43 scheme: GPT
ID-6: /dev/sde vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: 0001 scheme: GPT
ID-1: / size: 457.16 GiB used: 70.27 GiB (15.4%) fs: ext4
dev: /dev/nvme0n1p2 label: N/A uuid: 828f67cf-a2cc-4771-80b2-dad3da0ebdd2
ID-2: /boot/efi size: 299.4 MiB used: 284 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 label: N/A uuid: 9CB5-082A
ID-3: /mnt/Games size: 1.82 TiB used: 1.51 TiB (83.2%) fs: ntfs
dev: /dev/sde2 label: Games uuid: E89ACB419ACB0B50
ID-4: /mnt/Mass Storage size: 2.73 TiB used: 2.50 TiB (91.5%) fs: ntfs
dev: /dev/sdc1 label: Mass Storage uuid: B83A3F113A3ECBDE
ID-5: /mnt/Media size: 931.50 GiB used: 186.46 GiB (20.0%) fs: ntfs
dev: /dev/sdd2 label: Media uuid: A246E26546E239A5
ID-1: /dev/sda1 size: 7.45 GiB fs: swap label: N/A
uuid: 41b9cbff-7322-469c-b026-3b203516108f
ID-2: /dev/sda2 size: 244.0 MiB fs: vfat label: N/A uuid: F220-1F54
ID-3: /dev/sda3 size: 103.59 GiB fs: ntfs label: Windows10
uuid: 1CDFFB391432DBE7
ID-4: /dev/sda4 size: 519.0 MiB fs: ntfs label: N/A uuid: D480A21F80A207D6
ID-5: /dev/sdb1 size: 16.0 MiB fs: label: N/A uuid: N/A
ID-6: /dev/sdb2 size: 279.45 GiB fs: label: N/A uuid: N/A
ID-7: /dev/sdb3 size: 186.30 GiB fs: label: N/A uuid: N/A
ID-8: /dev/sdd1 size: 16.0 MiB fs: label: N/A uuid: N/A
ID-9: /dev/sde1 size: 16.0 MiB fs: label: N/A uuid: N/A
Hub: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-2:2 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 8087:0025
Device-2: 1-9:3 info: SINOWEALTH Wired Gaming Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 258a:0036
Device-3: 1-14:4 info: NZXT NZXT USB Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip ID: 1e71:170e serial:
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Device-4: 2-4:2 info: Oculus VR Rift Sensor type:
driver: uvcvideo interfaces: 2 rev: 3.0 speed: 5 Gb/s chip ID: 2833:0211
serial:
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-5: 3-1:2 info: Input Club Keyboard - WhiteFox:aria PixelMap USB
type: Keyboard,HID,Abstract (modem),CDC-Data,Mouse
driver: cdc_acm,hid-generic,usbhid interfaces: 7 rev: 2.0 speed: 12 Mb/s
chip ID: 308f:0008 serial:
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Device-6: 6-1:2 info: Oculus VR Rift Sensor type:
serial:
Hub: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-7: 7-2:2 info: Logitech HD Pro Webcam C920 type: Video,Audio
chip ID: 046d:082d serial:
Device-8: 7-3:3 info: Audio-Technica ATR USB microphone type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s chip ID: 0909:001a
Hub: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Device-9: 8-4:2 info: Oculus VR Rift Sensor type:
serial:
System Temperatures: cpu: 45.5 C mobo: N/A gpu: amdgpu temp: 38 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1305
Processes: 321 Uptime: 7m Init: systemd v: 245 Compilers: gcc: 10.1.0
Shell: zsh v: 5.8 running in: gnome-terminal inxi: 3.0.37
