I have Asus X555lf with Manjaro KDE installed and my problem is im getting like higher speeds on other wifi networks but not on mine,my wifi network is stuck at 0.50mbps but when i speedtest my wifi from other pcs,phones it goes much higher than that.Tried older karnels,headers everything.Seems like my wifi does not like manjaro *jk.But its weird why im getting high internet speeds on other networks but not on mine.
Thanks,
If you get good speeds with the same laptop on other networks while running manaro KDE then the compatibility problem is between your router and the adaptor, not the operating system
Try disabling IPv6 in your router and network manager. You can search the forum for more info on how to do that.
If there is no big improvement then you will need to provide your system info. Please post the output from:
inxi -Fxxxz
In the "network" section of that terminal output will be your adapter model and your driver. Search both your adapter and driver on the forum for common issues and fixes.
Please read this thread on how to post required information properly:
Well the router is flirtz box and did some research changed it from wpa/wpa2 mixed to just wpa2 and disabled auto channel select and that kinda fixed it but now the speed is not constant like it will go to normal speeds and then it wil drop to 5kbs.
Perhaps look for a router firmware update if available. Otherwise try locking your BSSID to your preferred access point in your connections properties in NM. Also try setting a static IP through your router via mac address association.
If you cannot find anything to fix your problems I have written a service that might help with your issue. Worth a try I guess.
Not a fix, but it usually brings my connection back up in 5-6 seconds on my system.
Just this router is absolute garbage ffs.All other devices get high speeds on this router but not me,tho when i connect to another network i get expected speeds.So idk if its my PC or this crap router.
This sounds like a combination of your router and driver not working well together, but it can also be some strange component your ISP uses that your laptop isn't liking.
You need to go through every suggestion in my router guide and test everything I recommended.
