nautilus: error while loading shared libraries: libgnome-desktop-3.so.17: cannot open shared object file: No such file or directory
Symlinked and now works, I have /usr/lib/libgnome-desktop-3.so.18
Any ideas?
Any ideas?
Are you using the nautilus-typeahead package? This issue is mentioned on the AUR page.
I also ran into this problem; I had to symlink the missing library as well.
If you are also using the typeahead package, I'd suggesting waiting a few days to see if the maintainer can push out an update to fix the issue.
Thanks, my internet foo was not strong!! I am stopping using gnome till it all stops hitting the fan
I know, I added the comment for reference since this thread was mentioned here:
Ahhh, makes sense.
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
