I can't find the proper driver/get a driver to install for this thing. I'm pretty sure I need the R8169 driver but whenever I install it I get an error message. Here's my results for inxi -Fxxxz
\System: Host: The-Secret-Library Kernel: 5.4.40-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Gnome 3.36.2
wm: gnome-shell dm: GDM 3.34.1 Distro: Manjaro Linux
Machine: Type: Desktop System: Gigabyte product: B360M-DS3H v: N/A serial:
Mobo: Gigabyte model: B360M DS3H v: x.x serial: UEFI: American Megatrends v: F3 date: 03/01/2018
CPU: Topology: 6-Core model: Intel Core i5-8400 bits: 64 type: MCP arch: Kaby Lake rev: A L2 cache: 9216 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 33613
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: Gigabyte
driver: amdgpu v: kernel bus ID: 03:00.0 chip ID: 1002:731f
Display: x11 server: X.org 1.20.8 driver: amdgpu compositor: gnome-shell resolution:
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.35.0 5.4.40-1-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.0.6
direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:ab38
Device-3: Texas Instruments PCM2902 Audio Codec type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-1:2
chip ID: 08bb:2902
Sound Server: ALSA v: k5.4.40-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: 3000 bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: down mac:
IF-ID-1: enp0s20f0u3 state: unknown speed: N/A duplex: N/A mac:
Drives: Local Storage: total: 2.51 TiB used: 276.33 GiB (10.8%)
ID-1: /dev/sda vendor: Silicon Power model: SPCC Solid State Disk size: 238.47 GiB speed: 6.0 Gb/s serial:
rev: 61.2 scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD20EZRZ-00Z5HB0 size: 1.82 TiB speed: 6.0 Gb/s rotation: 5400 rpm
serial: rev: 0A80 scheme: MBR
ID-3: /dev/sdc type: USB vendor: Seagate model: ST9500325AS size: 465.76 GiB rotation: 5400 rpm serial:
rev: 102E scheme: MBR
Partition: ID-1: / size: 233.43 GiB used: 52.29 GiB (22.4%) fs: ext4 dev: /dev/dm-0
Sensors: System Temperatures: cpu: 51.0 C mobo: 27.8 C gpu: amdgpu temp: 0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 241 Uptime: 6m Memory: 7.71 GiB used: 1.48 GiB (19.2%) Init: systemd v: 245 Compilers: gcc: 9.3.0
Shell: bash v: 5.0.16 running in: gnome-terminal inxi: 3.0.37
And here's what I get with lsmod
Module Size Used by
rndis_host 20480 0
cdc_ether 24576 1 rndis_host
usbnet 49152 2 rndis_host,cdc_ether
mii 16384 1 usbnet
fuse 139264 5
rfcomm 90112 16
squashfs 69632 0
loop 40960 0
cmac 16384 3
algif_hash 16384 1
algif_skcipher 16384 1
af_alg 28672 6 algif_hash,algif_skcipher
bnep 28672 2
nls_iso8859_1 16384 1
nls_cp437 20480 1
vfat 24576 1
fat 86016 1 vfat
btusb 65536 0
btrtl 24576 1 btusb
btbcm 16384 1 btusb
btintel 28672 1 btusb
bluetooth 671744 43 btrtl,btintel,btbcm,bnep,btusb,rfcomm
snd_usb_audio 299008 1
snd_usbmidi_lib 40960 1 snd_usb_audio
ecdh_generic 16384 2 bluetooth
snd_rawmidi 45056 1 snd_usbmidi_lib
rfkill 28672 5 bluetooth
ecc 32768 1 ecdh_generic
snd_seq_device 16384 1 snd_rawmidi
mc 61440 1 snd_usb_audio
input_leds 16384 0
mousedev 24576 0
joydev 28672 0
snd_sof_pci 20480 0
snd_sof_intel_byt 20480 1 snd_sof_pci
snd_sof_intel_ipc 20480 1 snd_sof_intel_byt
intel_rapl_msr 20480 0
snd_sof_xtensa_dsp 16384 1 snd_sof_pci
intel_rapl_common 28672 1 intel_rapl_msr
snd_sof_intel_hda_common 73728 1 snd_sof_pci
snd_soc_hdac_hda 24576 1 snd_sof_intel_hda_common
snd_sof_intel_hda 20480 1 snd_sof_intel_hda_common
snd_sof 118784 4 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_byt,snd_sof_intel_ipc
iTCO_wdt 16384 0
iTCO_vendor_support 16384 1 iTCO_wdt
mei_hdcp 24576 0
ppdev 24576 0
snd_soc_skl 180224 0
wmi_bmof 16384 0
snd_soc_sst_ipc 20480 1 snd_soc_skl
snd_soc_sst_dsp 40960 1 snd_soc_skl
x86_pkg_temp_thermal 20480 0
snd_hda_ext_core 32768 4 snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
intel_powerclamp 20480 0
snd_soc_acpi_intel_match 32768 3 snd_sof_pci,snd_sof_intel_hda_common,snd_soc_skl
coretemp 20480 0
amdgpu 5136384 15
snd_hda_codec_realtek 131072 1
snd_soc_acpi 16384 3 snd_sof_pci,snd_soc_acpi_intel_match,snd_soc_skl
kvm_intel 323584 0
snd_hda_codec_generic 94208 1 snd_hda_codec_realtek
snd_soc_core 290816 4 snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl
ledtrig_audio 16384 2 snd_hda_codec_generic,snd_hda_codec_realtek
kvm 798720 1 kvm_intel
irqbypass 16384 1 kvm
snd_hda_codec_hdmi 73728 1
snd_compress 28672 1 snd_soc_core
ac97_bus 16384 1 snd_soc_core
intel_cstate 16384 0
snd_pcm_dmaengine 16384 1 snd_soc_core
intel_uncore 147456 0
snd_hda_intel 57344 4
intel_rapl_perf 16384 0
snd_intel_nhlt 20480 3 snd_hda_intel,snd_sof_intel_hda_common,snd_soc_skl
pcspkr 16384 0
r8169 98304 0
snd_hda_codec 155648 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda
gpu_sched 36864 1 amdgpu
realtek 24576 1
i2c_i801 36864 0
i2c_algo_bit 16384 1 amdgpu
libphy 102400 2 r8169,realtek
snd_hda_core 102400 10 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_soc_skl,snd_sof_intel_hda
ttm 122880 1 amdgpu
snd_hwdep 16384 2 snd_usb_audio,snd_hda_codec
snd_pcm 135168 10 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_sof,snd_sof_intel_hda_common,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
drm_kms_helper 217088 1 amdgpu
snd_timer 40960 1 snd_pcm
snd 106496 24 snd_hda_codec_generic,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm,snd_rawmidi
mei_me 45056 1
syscopyarea 16384 1 drm_kms_helper
mei 122880 3 mei_hdcp,mei_me
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
soundcore 16384 1 snd
fb_sys_fops 16384 1 drm_kms_helper
intel_pch_thermal 16384 0
ie31200_edac 16384 0
parport_pc 53248 0
wmi 36864 1 wmi_bmof
parport 61440 2 parport_pc,ppdev
evdev 24576 16
mac_hid 16384 0
drm 520192 7 gpu_sched,drm_kms_helper,amdgpu,ttm
uinput 20480 0
crypto_user 16384 0
agpgart 53248 2 ttm,drm
ip_tables 36864 0
x_tables 49152 1 ip_tables
ext4 786432 1
crc32c_generic 16384 0
crc16 16384 2 bluetooth,ext4
mbcache 16384 1 ext4
jbd2 135168 1 ext4
uas 32768 0
usb_storage 81920 2 uas
dm_crypt 53248 1
dm_mod 159744 3 dm_crypt
hid_generic 16384 0
usbhid 65536 0
hid 143360 2 usbhid,hid_generic
sd_mod 57344 5
crct10dif_pclmul 16384 1
crc32_pclmul 16384 0
crc32c_intel 24576 2
ghash_clmulni_intel 16384 0
ahci 40960 2
libahci 40960 1 ahci
aesni_intel 372736 6
libata 278528 2 libahci,ahci
crypto_simd 16384 1 aesni_intel
xhci_pci 20480 0
cryptd 24576 4 crypto_simd,ghash_clmulni_intel
glue_helper 16384 1 aesni_intel
xhci_hcd 282624 1 xhci_pci
scsi_mod 249856 4 sd_mod,usb_storage,uas,libata
So does anyone know how to help? Thank you
