Need help to set up prime-run %command% for steam games
I have been trying to set up prime-run %command% for Deus Ex and other games on steam (like recommended in various threads here) instead of running prime-run steam.
Short search on the web gives decent tutorials which have not worked so far for me (which means I am doing something wrong).
On steam support I followed https://support.steampowered.com/kb_article.php?ref=6316-GJKC-7437&l=portuguese
1 Right clicked the game and went into "Properties"
2 Clicked on SET LAUNCH OPTIONS (I had no launchers there to begin with) and did prime-run Deus. Rebooted and then tried the terminal prime-run Deus, prime-run %Deus%. I have also changed the SET LAUNCH OPTIONS to prime-run %Deus%, rebooted and tried the terminal like before which did not work.
3. Followed this guide https://cjenkins.wordpress.com/2013/01/01/steam-for-linux-on-optimus-enabled-computer-running-ubuntu-12-04-64bits/ (but only the last part, I DID NOT SET UP BUMBLEBEE
1) Add the OPTIMUS_PREFIX variable to your environment
sudo sh -c 'echo OPTIMUS_PREFIX="primusrun" >> /etc/environment'
2) Logout and login from you session
Seriously. Desktop session, not Steam session. Steam is closed.
3) Configure each game you want
For each game you want to launch using you high powered nVidia card do:
  1. Select a game from the Library page of the Steam client, right-click, and
    select Properties.
  2. Click the SET LAUNCH OPTIONS button and specify $OPTIMUS_PREFIX %command%
    for the command line.
  3. Save your changes.
So far none of this has worked for me.
I have ALL of my games located on an external HDD, don't know if that is relevant.
inxi -Fxxxza -no-host
~ >>> inxi -Fxxxza -no-host                                                 [1]
  Host: HP Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
  root=UUID=9a466d45-9706-4f31-8e9b-737ed449768e rw quiet apparmor=1
  Desktop: GNOME 3.36.4 tk: GTK 3.24.21 wm: gnome-shell dm: GDM 3.34.1
  Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: HP model: 8478 v: 70.57 serial: <filter> UEFI: Insyde v: F.22
  date: 04/21/2020
  ID-1: BAT1 charge: 36.9 Wh condition: 36.9/52.8 Wh (70%) volts: 12.8/11.6
  model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
  status: Full
  Topology: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10)
  microcode: D6 L2 cache: 8192 KiB
  bogomips: 36812
  Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
  driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:1c8d
  Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
  Integrated Webcam
  type: USB driver: uvcvideo bus ID: 1-5:5 chip ID: 05c8:03bc
  Display: x11 server: X.org 1.20.8 compositor: gnome-shell
  driver: modesetting,nvidia resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.5
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
  bus ID: 00:1f.3 chip ID: 8086:a348
  Sound Server: ALSA v: k5.7.14-1-MANJARO
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Hewlett-Packard driver: rtw_pci v: N/A modules: rtwpci port: 4000
  bus ID: 02:00.0 chip ID: 10ec:b822
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
  chip ID: 10ec:8168
  Local Storage: total: 1.60 TiB used: 653.15 GiB (39.9%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-000H1
  size: 238.47 GiB block size: physical: 512 B logical: 512 B
  speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: CXB73H1Q scheme: GPT
  ID-2: /dev/sda type: USB vendor: Western Digital
  model: WD My Passport 0740 size: 465.73 GiB block size: physical: 512 B
  logical: 512 B serial: <filter> rev: 1007 scheme: MBR
  ID-3: /dev/sdb type: USB vendor: Toshiba model: External USB 3.0
  size: 931.51 GiB block size: physical: 512 B logical: 512 B
  serial: <filter> rev: 5438 scheme: MBR
  ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
  used: 98.08 GiB (42.0%) fs: ext4 dev: /dev/nvme0n1p2
  System Temperatures: cpu: 48.0 C mobo: 29.8 C
  Processes: 290 Uptime: 42m Memory: 15.53 GiB used: 1.96 GiB (12.6%)
  Init: systemd v: 246 Compilers: gcc: 10.1.0 alt: 8/9 Packages: 1316
  pacman: 1307 lib: 361 flatpak: 0 snap: 9 Shell: Zsh v: 5.8
  running in: gnome-terminal inxi: 3.1.05
I know I am doing something wrong, just can't see what it is, so any help with that would be very appreciated.
Literally
prime-run %command%
For each game, assuming you have no other options.
(yes..we mean literally '%command%')
( Note - I kinda stopped reading part way through realizing this is your mistake .. but it seems you might have done a bunch of other things to try and make this work in your confusion. If any of those are hanging around you should probably undo them, like the example of what you added to /etc/environment )
if you have hybri optimus drivers, and want to use nvidia for gaming.
select Properties.
Click the SET LAUNCH OPTIONS button and specify __NV_PRIME_RENDER_OFFLOAD=1 __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia %command%
Save your changes.
~ >>> prime-run %command%                                                   [1]
/usr/bin/prime-run: line 2: fg: no job control
And this is after I have reverted that /etc/environment, and changed the SET LAUNCH OPTIONS to __NV_PRIME_RENDER_OFFLOAD=1
This is NOT this difficult, I guess this is just "my moment" :laughing:
Of course the main confusion was the %command% because I thought I could specify the what to use (which is not uncommon).
Still no.
Copy/paste exactly this into your options:
prime-run %command%
LOL :laughing:
and then I can launch it from terminal by using?? or does this enable the Nvidia card just by regular launching the game?
Because I thought I was supposed to run this command from terminal
just launch your game. thats it.
If you want to check via terminal (or instructive for other applications)
glxinfo | grep 'renderer string'
prime-run glxinfo | grep 'renderer string'
LOLS there is the biggest confusion, I had this in my head that the prime-run %command% was something I should use in terminal. Simple misunderstanding, hope it made someone smile :smiley:
Oh, I could see it, and it was funny. But nothing to be ashamed of. Cheers :slight_smile:
Adding to the list of useful commands
nvidia-smi
shows what processes are currently using your GPU, along with other stuff about the card
I knew about nvidia-smi and have used that, it was just the confusion about setting nvidia-prime %command% into game launchers instead of using terminal.
But thank you for the hint.
