Need help with the hdw error?(microcode?)
Hi i'm new to manjaro and arch linux distros(been using debaian and ubuntu before...)
I have a problem with these errors:
2019-06-23_08-37
Tried to fix and google those but notthing worked for me... Do you have any advices for me?
Regards
Hello,
Copy that output and paste it here using ``` above and bellow it. Images are not searchable ...
If the system performs ok, then you can disregard those errors.
Also provide inxi -Fxxxz to better know what setup you have.
can you also check your memory with memtest ? ( on start GRUB )
Sorry i totally understand :slight_smile: Here it is:
[aljaz@aljaz-pc ~]$ sudo dmesg | grep microcode
[sudo] password for aljaz:
[    0.000000] microcode: microcode updated early to revision 0x27, date = 2019-02-26
[    0.311038] mce: [Hardware Error]: PROCESSOR 0:306c3 TIME 1561444269 SOCKET 0 APIC 0 microcode 27
[    4.481768] microcode: sig=0x306c3, pf=0x20, revision=0x27
[    4.481880] microcode: Microcode Update Driver: v2.2.
[aljaz@aljaz-pc ~]$ inxi -Fxxxz
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "",
        LC_ALL = (unset),
        LC_ADDRESS = "sl_SI.UTF-8",
        LC_NAME = "sl_SI.UTF-8",
        LC_MONETARY = "sl_SI.UTF-8",
        LC_PAPER = "sl_SI.UTF-8",
        LC_IDENTIFICATION = "sl_SI.UTF-8",
        LC_TELEPHONE = "sl_SI.UTF-8",
        LC_MEASUREMENT = "sl_SI.UTF-8",
        LC_TIME = "sl_SI.UTF-8",
        LC_NUMERIC = "sl_SI.UTF-8",
        LANG = "en_SI.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
System:    Host: aljaz-pc Kernel: 4.19.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.15.5
           tk: Qt 5.12.3 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 20378 v: Lenovo Y50-70 serial: <filter> Chassis: type: 10 v: Lenovo Y50-70
           serial: <filter>
           Mobo: LENOVO model: Lenovo Y50-70 v: 31900058WIN serial: <filter> UEFI [Legacy]: LENOVO v: 9ECN43WW(V3.03)
           date: 08/12/2015
Battery:   ID-1: BAT1 charge: 28.4 Wh condition: 49.6/54.8 Wh (91%) volts: 7.6/7.4 model: LENOVO PABAS0241231 type: Li-ion
           serial: <filter> status: Unknown
CPU:       Topology: Quad Core model: Intel Core i7-4720HQ bits: 64 type: MT MCP arch: Haswell rev: 3 L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41522
           Speed: 2570 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 2570 2: 2816 3: 2930 4: 2573 5: 2017 6: 2497 7: 3007
           8: 2048
Graphics:  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:0416
           Device-2: NVIDIA GM107M [GeForce GTX 960M] driver: N/A bus ID: 01:00.0 chip ID: 10de:139b
           Display: x11 server: X.Org 1.20.5 driver: intel compositor: kwin_x11 resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 19.0.6 compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:03.0 chip ID: 8086:0c0c
           Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:8c20
           Sound Server: ALSA v: k4.19.49-1-MANJARO
Network:   Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: 5040 bus ID: 08:00.0 chip ID: 8086:08b2
           IF: wlp8s0 state: up mac: <filter>
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8168 v: 8.047.01-NAPI
           port: 3000 bus ID: 09:00.0 chip ID: 10ec:8168
           IF: enp9s0 state: down mac: <filter>
Drives:    Local Storage: total: 465.76 GiB used: 133.86 GiB (28.7%)
           ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB speed: 6.0 Gb/s serial: <filter> rev: 010
           scheme: MBR
Partition: ID-1: / size: 171.61 GiB used: 133.86 GiB (78.0%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 54.0 C mobo: N/A
Info:      Processes: 263 Uptime: 6h 35m Memory: 15.58 GiB used: 3.29 GiB (21.1%) Init: systemd v: 242 Compilers: gcc: 8.3.0
           Shell: bash v: 5.0.7 running in: konsole inxi: 3.0.34
Thanks
I did have some problems with memory in the past ill check it tonight and post the resoult :slight_smile:
Try putting in 'nomce' and 'noacpi' (no apostophes) in your kernel (linux line) of your grub and see if errors go away. However, it is best such parameters should not be needed; so try some (newer) kernels without these parameters and see if that solves it first.
