You're welcome
although I suspect you may need someone with more knowledge and experience.
/etc/resolv.conf
is owned by the package filesystem
, so maybe try reinstalling that.
If the update was interrupted then you may have corrupted something, you could try reinstalling the last update, and/or reverting it. To find out what got updated you can view /var/log/pacman.log
The package files are in /var/cache/pacman/pkg
, you can list all the packages for something with ls | grep something
. You can install a local package with sudo pacman -U package
, if you're not in the package directory then you'll need the absolute path. Probably teaching a grandmother to suck eggs atm, but just in case.
Reinstalling all packages is probably overkill (or useless), but it is easier than reinstalling the update manually. Will take some time, I mention it in case you have trouble with reinstalling the update.
pacman -Qqn | sudo pacman -S -
List the installed kernels.
mhwd-kernel -li
List the available kernels.
mhwd-kernel -l
Install kernel 4.19
mhwd-kernel -i linux419
If none of that helps you may need a reinstall, unless someone more knowledgeable comes along with an answer. I don't know the cause so I'm not sure if a reinstall will be helpful, at least once you update.
For any further troubleshooting, the output of these commands may be useful inxi -Fxxxx --no-host
, mhwd-kernel -li
. Look through your logs to see if there are any errors relating to networking or the filesystem/storage etc. The post I linked to may help.
@ertan Read the link I posted above and start a thread of your own.
