Newbie with xorg error I can’t fix
image Before starting a new thread please read the pages from the following links:
Keep in mind that there's a lot of information in the User Guide and Wiki:
and many common questions have already been answered so read the FAQ posts and Tutorials:
Using these resources will help everyone! "Help us help you."
Hi!
Could you post the output of?
mhwd -li
cat ~/.xinitrc
cat /var/log/Xorg.0.log
cat /var/log/Xorg.0.log.old
Thank you!
PS: If you have a livecd. Start from there and login into your local system with manjaro-chroot -a and then run the commands and post it here :slight_smile:
Thanks I’ll be doing this when I get home from my shift at the hospital and post
image image image
The next commands just say no file directory
In regards to the live CD, I have the USB I installed it with; will that do?
Also how do you actually run chroot with that?
Typo :wink:
But however it is better to use a livecd for this. The logs can become verylong.
  1. Start Manjaro from USB
  2. Open a terminal
  3. type "manjaro-chroot -a"
  4. run the commands
You can pipe output to less so you can scroll.
Also you can make use of this for sharing output:
| curl -F 'f:1=<-' ix.io
ex:
echo hello | curl -F 'f:1=<-' ix.io
Thanks guys
It’s snowing here in Tasmania and so it’s looking like work is gonna have me stay in a hotel overnight
I’ll post ASAP though
[manjaro-gnome /]# cat ~/.xinitrc
#!/bin/sh
~/.xinitrc
Executed by startx (run your window manager from here)
userresources=$HOME/.Xresources
usermodmap=$HOME/.Xmodmap
sysresources=/etc/X11/xinit/.Xresources
sysmodmap=/etc/X11/xinit/.Xmodmap
DEFAULT_SESSION=gnome-session
merge in defaults and keymaps
if [ -f $sysresources ]; then
xrdb -merge $sysresources
fi
if [ -f $sysmodmap ]; then
xmodmap $sysmodmap
fi
if [ -f "$userresources" ]; then
xrdb -merge "$userresources"
fi
if [ -f "$usermodmap" ]; then
xmodmap "$usermodmap"
fi
start some nice programs
if [ -d /etc/X11/xinit/xinitrc.d ] ; then
for f in /etc/X11/xinit/xinitrc.d/?*.sh ; do
[ -x "$f" ] && . "$f"
done
unset f
fi
get_session(){
local dbus_args=(--sh-syntax --exit-with-session)
case $1 in
awesome) dbus_args+=(awesome) ;;
bspwm) dbus_args+=(bspwm-session) ;;
budgie) dbus_args+=(budgie-desktop) ;;
cinnamon) dbus_args+=(cinnamon-session) ;;
deepin) dbus_args+=(startdde) ;;
enlightenment) dbus_args+=(enlightenment_start) ;;
fluxbox) dbus_args+=(startfluxbox) ;;
gnome) dbus_args+=(gnome-session) ;;
i3|i3wm) dbus_args+=(i3 --shmlog-size 0) ;;
jwm) dbus_args+=(jwm) ;;
kde) dbus_args+=(startkde) ;;
lxde) dbus_args+=(startlxde) ;;
lxqt) dbus_args+=(lxqt-session) ;;
mate) dbus_args+=(mate-session) ;;
xfce) dbus_args+=(xfce4-session) ;;
openbox) dbus_args+=(openbox-session) ;;
*) dbus_args+=($DEFAULT_SESSION) ;;
esac
echo "dbus-launch ${dbus_args[*]}"
exec $(get_session)
manjaro-gnome /]# cat /var/log/Xorg.0.log
cat: /var/log/Xorg.0.log: No such file or directory
[manjaro-gnome /]# cat /var/log/Xorg.0.log.old
cat: /var/log/Xorg.0.log.old: No such file or directory
[manjaro-gnome /]# cat /var/log/xorg.0.log
cat: /var/log/xorg.0.log: No such file or directory
[manjaro-gnome /]# cat /var/log/xorg.0.log.old
cat: /var/log/xorg.0.log.old: No such file or directory
[manjaro-gnome /]#
what am i doing wrong here??
am in the chroot that you mentioned...
what says:
ls /var/log/ ?
It should work like this:
Bildschirmfoto_2020-08-04_07-59-56
btw... please use code blocks like this. thank you :wink:
code
Screenshot from 2020-08-05 03-26-26
does this help?
No... where is your Xorg.0.log? LOL
Please search it:
locate Xorg.0.log
Maybe in ~/.local/share/xorg/ or /home/<username>/.local/share/xorg/?
Screenshot from 2020-08-05 03-55-01
starting to think a reinstall using the architect may be easier
is this the xorg file
Then just install locate:
pamac install locate OR pacman -Syu locate
Then update the database:
updatedb
then search:
locate Xorg.0.log
And of course not on the live environment, but in manjaro-chroot :wink:
then do i reboot???
