Nitrogen on cinnamon
Output of inxi -Fx
System:    Host: annihilator Kernel: 4.8.13-1-vfio x86_64 (64 bit gcc: 6.2.1)
           Desktop: Cinnamon 3.2.8 (Gtk 3.22.6) Distro: Manjaro Linux
Machine:   Device: desktop Mobo: ASUSTeK model: MAXIMUS VIII HERO v: Rev 1.xx
           UEFI [Legacy]: American Megatrends v: 2202 date: 09/19/2016
CPU:       Quad core Intel Core i7-6700K (-HT-MCP-) cache: 8192 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 32076
           clock speeds: max: 4600 MHz 1: 799 MHz 2: 799 MHz 3: 799 MHz
           4: 799 MHz 5: 799 MHz 6: 799 MHz 7: 800 MHz 8: 799 MHz
Graphics:  Card-1: NVIDIA GK110 [GeForce GTX 780] bus-ID: 01:00.0
           Card-2: NVIDIA GP104 [GeForce GTX 1080] bus-ID: 02:00.0
           Display Server: X.Org 1.19.1 driver: nvidia
           Resolution: 2560x1080@60.00hz, 2560x1080@60.00hz, 2560x1080@60.00hz
           GLX Renderer: GeForce GTX 780/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 378.09 Direct Rendering: Yes
Audio:     Card-1 NVIDIA GK110 HDMI Audio
           driver: snd_hda_intel bus-ID: 01:00.1
           Card-2 NVIDIA GP104 High Definition Audio Controller
           driver: vfio-pci bus-ID: 02:00.1
           Card-3 Intel Sunrise Point-H HD Audio
           driver: snd_hda_intel bus-ID: 00:1f.3
           Card-4 Razer USA driver: USB Audio usb-ID: 001-006
           Sound: Advanced Linux Sound Architecture v: k4.8.13-1-vfio
Network:   Card-1: Intel Ethernet Connection (2) I219-V
           driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
           IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full
           mac: 9c:5c:8e:c2:c8:11
           Card-2: Microsoft Xbox 360 Wireless Adapter usb-ID: 001-005
           IF: null-if-id state: N/A mac: N/A
Drives:    HDD Total Size: 5251.1GB (1.6% used)
           ID-1: /dev/sda model: Samsung_SSD_850 size: 250.1GB
           ID-2: /dev/sdb model: ST3000DM001 size: 3000.6GB
           ID-3: /dev/sdc model: ST500DM002 size: 500.1GB
           ID-4: /dev/sdd model: WDC_WD10EZEX size: 1000.2GB
           ID-5: /dev/sde model: WDC_WD5000AAKS size: 500.1GB
Partition: ID-1: / size: 213G used: 7.7G (4%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 2.7T used: 6.9G (1%) fs: ext4 dev: /dev/sdb1
           ID-3: swap-1 size: 17.16GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 231 Uptime: 1:14 Memory: 2917.7/32167.9MB
           Init: systemd Gcc sys: 6.3.1
           Client: Shell (bash 4.4.51) inxi: 2.3.5
My issue is that after installing nitrogen with pacman -S nitrogen and running it, it only shows a screen without the ability to choose which display to apply to.
Any idea how to get the displays available so I can properly set multiple wallpapers? Thanks! Lmk if you need more system info.
Here's what I see:
Might help https://www.blackmoreops.com/2015/07/10/use-different-wallpapers-on-multiple-monitors-in-linux/
Think you will have to stop nemo managing your desktop.
Click where it says "Automatic" to manually select screen. And as mentioned, make sure your FM does not control the desktop.
Find the right command to run nitrogen at session start.
Try nitrogen --help
Thank you! That helped.
@AgentS Clicking automatic didn't do it for me, but it was Nemo.
Using gsettings set org.nemo.desktop show-desktop-icons false removed Nemo from handling the desktop. I then restarted cinnamon and opened nitrogen -- screens were there!
Awesome. Thanks both of you.
