I installed the tlp package and edited it's config file (/etc/default/tlp), uncommenting these two lines:
"START_CHARGE_THRESH_BAT1=75
STOP_CHARGE_THRESH_BAT1=80".
I also installed the tp_acpi-bat package.
However, when I type "tlp-stat -b", this is the output.
I look forward to being able to modify the charging thresholds for my Thinkpad battery.
My laptop model is Lenovo Thinkpad Yoga 11e with Intel Celeron 2940 CPU.
I was able to modify my charging thresholds in Windows, so I know for sure that my laptop has the hardware required for modifying the charging thresholds.
My current kernel version is 5.2.11-1-MANJARO. This problem also happens on the lts 4.1.9 Manjaro kernel.
Thank you in advance.
I don't know that specific Thinkpad, but many newer ones need the acpi_call
extramodules.
Then set thresholds with
sudo tlp setcharge 75 80 BAT1
(note: BAT1 is external battery on many ThinkPads, internal is BAT0)
5.2 is EOL.
Update to 5.3, or use your existing 4.19.
This topic was automatically closed after 180 days. New replies are no longer allowed.
