The proprietary drivers doesn’t stay in a working condition
I install video-hybrid-intel-nvidia-bumblebee from system settings - Hardware Configuration
I reboot and the driver is there and working.
I shutdown and boot the driver is, well not really gone, but not working.
I have to uninstall the driver, shutdown, boot, install, shutdown and boot to make them work one more time.
Shutdown is needed it seems. A reboot seems not to install the driver in a working condition.
I have to do this on two laptops. The error is there with kernel 4.14 and 4.16.
I don’t know if the error was the before the 28-04-2018 stable update.
Anyone else have this problem or an idea about what is wrong?
I now run nvidia 396 from todays upgrade, but the errors are the same.
Driver installed and working
inxi without primusrun:
Graphics: Card-1:
Intel HD Graphics 620 driver: i915 v: kernel
Card-2: NVIDIA GM108M [GeForce 940MX] driver: N/A
Display: x11 server: X.Org 1.19.6 driver: intel resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.5 Mesa 18.0.1
inxi with primusrun:
Card-1: Intel HD Graphics 620 driver: i915 v: kernel
OpenGL: renderer: GeForce 940MX/PCIe/SSE2 v: 4.6.0 NVIDIA 390.48
Driver not working
Card-2: NVIDIA GM108M [GeForce 940MX] driver: nvidia v: 390.48
OpenGL: renderer: N/A v: N/A
sh: line 1: 2582 Segmentation fault (core dumped) /sbin/glxinfo 2> /dev/null
Message: No advanced graphics data found on this system.
From konsole when starting steam:
optirun /usr/bin/flatpak run --branch=stable --arch=x86_64 --command=/app/bin/steam-wrapper --file-forwarding com.valvesoftware.Steam @@u %U @@
Couldn’t find dpkg, please update steamdeps for your distribution.
Running Steam on org.freedesktop.platform 1.6 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Installing breakpad exception handler for appid(steam)/version(1522709999)
OpenGL GLX extension not supported by displayMain.cpp (323) : Assertion Failed: Fatal Error: OpenGL GLX extension not supported by display
Assert( Assertion Failed: Fatal Error: OpenGL GLX extension not supported by display ):Main.cpp:323
assert_20180506103129_5.dmp[130]: Uploading dump (out-of-process)
/tmp/dumps/assert_20180506103129_5.dmp
assert_20180506103129_5.dmp[130]: Finished uploading minidump (out-of-process): success = no
assert_20180506103129_5.dmp[130]: error: Couldn’t connect to server
assert_20180506103129_5.dmp[130]: file ‘’/tmp/dumps/assert_20180506103129_5.dmp’’, upload no: ‘‘Couldn’t connect to server’’
