nvidia.conf is empty
Hello everyone
I wanted to change xscreen settings to get rid of screen tearing
But strangely, there is NO xscreen
Also my nvidia.conf in /etc/X11/mhwd.d/ is empty
My specs:
System:    Kernel: 5.7.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: KDE Plasma 5.19.3
           tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A serial: <root required>
           Chassis: type: 10 serial: <root required>
           Mobo: HP model: 87B1 v: 31.17 serial: <root required> UEFI: AMI v: F.02 date: 05/14/2020
Battery:   ID-1: BAT0 charge: 35.9 Wh condition: 51.4/51.4 Wh (100%) volts: 11.8/11.6
           model: Hewlett-Packard Primary type: Li-ion serial:   status: Discharging cycles: 462
CPU:       Topology: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
           L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71897
           Speed: 1397 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1396
           4: 1393 5: 1397 6: 1397 7: 1395 8: 1396 9: 1396 10: 1396 11: 1398 12: 1393
Graphics:  Device-1: NVIDIA vendor: Hewlett-Packard driver: nvidia v: 440.100 bus ID: 01:00.0 chip ID: 10de:1f99
           Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
           bus ID: 05:00.0 chip ID: 1002:1636
           Display: x11 server: X.Org 1.20.8 driver: amdgpu,nvidia FAILED: ati unloaded: modesetting,nouveau
           alternate: fbdev,nv,vesa compositor: kwin_x11 resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD RENOIR (DRM 3.37.0 5.7.9-1-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.1.3
           direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
           vendor: Hewlett-Packard driver: N/A bus ID: 05:00.5 chip ID: 1022:15e2
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard
           driver: snd_hda_intel v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
           Sound Server: ALSA v: k5.7.9-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169
           v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
           IF: eno1 state: down mac: b0:5c:da:42:34:3f
           Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
           driver: rtw_pci v: N/A port: d000 bus ID: 03:00.0 chip ID: 10ec:c822
           IF: wlo1 state: up mac: 70:66:55:bb:04:b7
Drives:    Local Storage: total: 476.94 GiB used: 122.40 GiB (25.7%)
           ID-1: /dev/nvme0n1 model: KBG40ZNV512G KIOXIA size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
           serial: 306PEEC9PBV1 rev: HP00AE00 scheme: GPT
Partition: ID-1: / size: 459.50 GiB used: 122.06 GiB (26.6%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: swap-1 size: 8.80 GiB used: 348.2 MiB (3.9%) fs: swap dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 47.2 C mobo: N/A gpu: amdgpu temp: 46 C
Info:      Processes: 300 Uptime: 4h 28m Memory: 7.21 GiB used: 2.74 GiB (37.9%) Init: systemd v: 245 Compilers:
           gcc: 10.1.0 Shell: bash v: 5.0.18 running in: konsole inxi: 3.0.37
mhwd:
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0300:10de:1f99) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-440xx-prime            2020.03.26               false            PCI
    video-nvidia-440xx            2019.10.25               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:05:00.0 (0300:1002:1636) Display controller ATI Technologies Inc:
