Nvidia proprietary drivers not installable
So, I've been using Manjaro for a few years now as main OS and never had much problems I couldn't solve. But since my laptop died yesterday I bought a new one. I've gotten myself a Asus ROG GL753VD-GC366T, with a GTX1050, a i7-7700HQ, 16GB of DDR4 RAM.
When I tried to install Manjaro, I already can't get in without setting systemd.mask=mhwd-live.service . Then, in order to be able to even install I have to open /lib/calamares/modules/mhwdcfg/main.py and change de return from the def run(): function to None. After this, instalment goes well.
Then when I boot in the just installed OS, it runs on free drivers despite my choice for nonfree ones before install. Trying to install nonfree ones makes it hang. Trying to do anything that would normally use my GPU also makes it hang. The only thing I can do when that happens is simply press the power button until the laptop goes out.
I've tried the KDE versions of Manjaro 18.0 installer, the Manjaro 17.0.6 installer, the version linked in the Developers release page (a bit above 18.0), and their all the same. I also tried using the architect version, but it only results in not having to do those changes to make installation work, and still makes me install free drivers and unable to install nonfree nor use my GPU. I also tried multiple programs to write the bootable USBs, just in case.
I've tried adding acpi_osi=! acpi_osi="Windows 2009" to my grub and regenerated my Grub config. I've also tried manually installing the drivers, both on bumblebee as on other ways, but the best I got was that I could install it, but after reboot it wouldn't even get starting anything with a graphical interface.
Commands with mhwd crash, any command asking for my hardware specs or info about it crashes, making it near impossible for me to see much information.
Beside that, when I use poweroff or reboot Manjaro just hangs and stops reacting, just like when I try to update my graphics driver or use my GPU[/reboot]. Next to that, it for some reasons complains my CPU is getting to hot when booting Manjaro, even when I just got the laptop and everything is fine in BIOS and when I used Windows to set the LED colours in my keyboard (so I wouldn't assume hardware issues), I also haven't done any overlocks.
I can't find anything off in the BIOS, nor can I turn of any GPU. I just want to use dedicated graphics, I don't care for the Intel one, I prefer to run Nvidia only. Right now I'm seriously doubting if I should return the laptop for another that will work with Manjaro, or switch back to Windows if it can't be fixed. I just want it to work on this one, but I've spend 12+ hours (non-stop) trying to fix it and I feel like I'm getting out of options. I need a working laptop for work...
System info please ...
inxi -Fxxz
Was video-linux mhwd driver installed?
mhwd -li
This will install both intel and nouveau drivers and use video-hybrid-intel-nouveau-prime, to confirm use lsmod and ensure both i915 and nouveau are loaded ... all open source drivers are bundled into video-linux.
You could try removing video-linux and installing video-hybrid-intel-nvidia-bumblebee, which may involve setting some acpi boot options to get working.
But as you would prefer nvidia gpu enabled by default maybe bumblebee is not suitable for you.
Some nvidia optimus laptops allow exclusive use of the nvidia gpu, others do not, if there is not a BIOS setting to select the discrete nvidia gpu then you cannot exclusively use the nvidia proprietary driver.
If you want the nvidia gpu used by default with proprietary drivers then you will have to use a prime setup, which mhwd doesn't currently support OOTB, you will have to set it up manually.
Make sure you remove video-linux using mhwd before beginning this installation process.
sudo mhwd -r pci video-linux
Nvidia optimus + Linux is still a bit of a minefield ... especially with the more recent laptops, for whatever reason.
mhwd freezes as soon as I press enter, so all commands involving that aren't working. It's not doing anything and in some cases causes my entire OS to freeze, same with anything asking for specs that include my GPU including inxi. That's why I didn't list any specs beside model number, gpu, cpu, and ram. Makes me feel quite stuck as it becomes much harder to trouble shoot as well as do stuff. The only way I've been able to change anything driver-wise is by manually installing package trough pacman, after which the OS breaks by the first reboot.
The only thing I can see is that in the settings manager under hardware configuration, both GPU are on free drivers and it doesn't notice anything else being installed. Just opening that page in settings already takes way to long tho. Next to that I can check what is installed in Pacman, and that's where it ends. Everything else just breaks, including commands like lspci | egrep 'VGA|3D'
Honestly I prefer nvidia to always be in used, but if I can use it properly when I need it I'm already happy. I've tried bumblebee, Xorg, Nvidia drivers. I've tried multiple drivers and multiple systems. I've tried pretty much any fix to make things work I could find online. I'm hoping I either missed something, or that someone knows something that hasn't been posted yet. There are no GPU settings in my BIOS beside RAM allocation for integrated graphics. I know I can't turn off my Intel graphics, I just meant I don't necessarily want it used. I don't care about Intel, as long as Nvidia can run when it has to Intel can be on or off at other times.
A quick internet search and these Asus gaming laptops seemingly don't play nice with Linux ... your symptoms of system freezing are a common theme.
Can you run any inxi -G or mhwd commands from tty2 without system freeze?
If so try removing video-linux and installing video-vesa, just to see if we can get you booting into a non freezing stable system.
I think the problem is this bloody video-linux abomination, which is defaulting to intel-nouveau-prime, when to get your system booting we should only be using an intel driver.
There used to be video-intel in mhwd, but it was lumped in with this default catch all video-linux and there seems no way to manually install an intel only driver.
Manjaro is a pretty great distro, but the haphazard way mhwd deals with optimus tech is a bit embarrassing TBH.
Yeah I noticed. I generally don't quickly ask for help, but this one has left me feel kinda helpless. I've been awake for 19 hours trying to fix this thing because I don't really want to switch laptop nor distro. Manjaro is indeed pretty amazing normally. Also, sorry if I come of bad. I'm really glad with the help, just tired.
inxi -G runs (first GPU related command that does), and it returns the following:
        Device-1: Intel driver: i915 v: kernel
        Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: nouveau v: kernel
        Display: x11 server: X.Org 1.20.3 driver: modesetting
        resolution: 1920x1080-60Hz
        OpenGL: renderer: Mesa DRI Intel HD Graphics 630 (Kaby Lake GT2) v: 4.5 Mesa 18.2.3
Trying to open TTY2 also seems to freeze the entire OS.
Within the Hardware Detection graphical user interface I can see video-linux, having a green filled square on Open-source for both dedicated and integrated GPU, and video-vesa only for integrated. Both version of the propriety (normal and 390xx) as well as both the bumblebee aren't for both integrated as dedicated. Nothing is checked on the Installed tab.
I'll try how well removing video-linux goes.
EDIT: I'm tired and can't remember how to deinstal them without mhwd, and the Manjaro wiki is giving me 502. I'll get back at it after some sleep. I'm reaching this point where I've stared too long at my PC and stop thinking that brightly. In the mean time, any ideas and insights are welcome.
You have both the i915 and nouveau kernel modules loaded, so video-linux is defaulting to an intel-nouveau-prime setup.
If you have both video-linux and video-nvidia installed that could be causing a conflict, but that technically shouldn't be causing system freezing.
i had a very similar if not exact experience last week when i tried installing kde on my optimus laptop and for some reason just like said, any attempt to do anything with mhwd would result in lockup , after a few hours i gave up because i have gnome on my other drive and i was frustrated, i dont usually give in that easy. my only afterthough was to just chroot in from my gnome or a live desktop and see if it would allow me to do what i wanted to do which was set it up for PRIME which is the only thing that ever seemed to work for me.
follow the tutorial that @sueridgepipe mentioned regarding PRIME, best of luck
the strangest part of it was that KDE installed and actually load the desktop environment whereas every other DE (gnome,deepin,budgie,xfce) would only make it to login and then go to black screen and i would have to chroot in and mess around and finally after days i got it working with prime. the point im trying to make is for some reason kde was behaving differently than the other DE's . got me pretty excited until i tried to do anything involving video settings or mhwd.
hope you get it worked out, im looking forward to seeing how it goes.
I'm gonna write this as I go, so might be a bit funny reading.
I chrooted into my system trough a liveboot, but the mhwd commands tell me I have no PCI nor USB devices nor configs. Could it be because I have to put the systemd.mask=mhwd-live.service in to be able to boot the live USB? Gonna try the architect image, as that one didn't need that setting.
Chrooting on Architect gives me the same warning messages that there are no devices or configs found. I guess it didn't matter that much which one I used. Gonna try to just install and do the next steps and see where it leads me.
installing video-nvidia gives success message. It now shows when trying to list it with mhwd -li
followed the rest of that tutorial for PRIME, reboot
Laptop now goes on till Started TLP system startup/shutdown, like before. However, this time it doesn't completely lock anymore. Before that little underscore would stop blinking and the fans on my laptop would start running 100%, whereas they are now both going on normally. Just the OS is not continuing. I'm going to check if I didn't make any spelling mistakes anywhere, or something like that. In the mean time, any ideas?
[OK] Started Login Service.
[OK] Reacher target Multi-User System.
     Starting TLP system startup/shutdown...
[OK] Started Simple Desktop Display Manager.
[OK] Reached target Graphical Interface.
     Starting WPA supplicant...
[OK] Started WPA supplicant.
[OK] Started TLP system startup/shutdown
Deleted my other comment because it was this one but I accidentally pressed enter halfway.
You can always edit any of your previous posts. It's a "modern" forum engine!! :grin:
I know, but I still needed to write half of it and due to me typing on a system that works next to my laptop that doesn't work yet I have to carefully type over from the other screen. I didn't want someone to see a half comment because I wasn't finished yet, so I "edited" to get back what I had including formatting, put it in a new comment and deleted the first :wink:
It was more a notion for the curious because the message will be there for another 24 hours and I hope to have it fixed by than anyways.
You may want to have a look at the nvidia manual for 410.73:
Optimus
Common problems
Known issues
Xconfig options
I've gotten some further. I was being an idiot and used tabs in the xorg.conf :sweat_smile:
Now on to the next problem. It get's a bit further but not looks at this when it stops:
     Starting Load/Save RF Kill Switch Status...
[OK] Started Load/Save RF Kill Switch Status.
[OK] Started Network Manager.
[OK] Reached target Network.
     Starting Permit User Sessions...
[OK] Started Permit User Sessions.
     Starting Hostname Service...
Then a big gap and continous:
Starting Bluetooth service...
[OK] Started Bluetooth service.
[OK] Started Authorization Manager.
[OK] Started Modem Manager.
[OK] Started Hostname Service.
     Starting Network Manager Script Dispatcher Service...
[OK] Reached target Multi-User System.
     Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
[OK] Reached target Bluetooth.
[OK] Started Load/Save Screen Backlight Brightness of backlight:intel_backlight...
[OK] Started Network Manager Script Dispatcher Service.
[OK] Reached target Sound Card.
[OK] Started TLP system startup/shutdown.
And then it stops without continuing. Again, it still not crashing on me anymore.
Other than that, I've checked all the files according to that tutorial, those should all be well now.
Any one of you an idea why it's not working yet?
@AgentS I'm reading up on those links in the mean time. Generally I learn my Linux stuff while doing, and never having had such issues before, I've learned a lot in the past day already :slight_smile:
Then you should provide your new logs even from TTY, - HowTo :
journalctl -b -p3
journalctl -b -g "NVIDIA|Nvidia|nvidia|NOUVEAU|nouveau"
cat /var/log/Xorg.0.log
mhwd -li
Did you try booting with such kernel parametres: acpi_osi=! acpi_osi='Windows 2015'?
Thanks, I didn't know I could still get into TTY like that. That's great!
journalctl -b -p3 returns the next for me:
-- Logs begin at Sun 2018-11-11 05:24:02 CET, end at SUN 2018-11-11 16:50_05 CET. --
nov 11 16:49:33 cambionn-laptop kernel: ACPI BIOS Error (bug): Failure creating [\_SB.PCT0.SATO.PRT0], AE_ALREADY_EXISTS (20180810/dswload2-316)
nov 11 16:49:33 cambionn-laptop kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180810/psobject-221)
nov 11 16:49:33 cambionn-laptop kernel: ACPI ERROR: Skip parsing opcode Device (20180810/psloop-543)
nov 11 16:49:33 cambionn-laptop systemd-modules-load[252]: Failed to insert 'nvidia': Exec format error
nov 11 16:49:33 cambionn-laptop systemd-udevd[272]: SPecified group 'plugdev' unknown
nov 11 16:49:33 cambionn-laptop systemd-modules-load[252]: Failed to insert 'nvidia_drm': Exec format error
nov 11 16:49:33 cambionn-laptop systemd[1]: Failed to Load Kernel Modules.
nov 11 16:49:33 cambionn-laptop kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/responce buffer. [mem oxfed40000-0xfed4087f flags 0x200] vs fed 40080 f80
nov 11 16:49:34 cambionn-laptop kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/responce buffer. [mem oxfed40000-0xfed4087f flags 0x200] vs fed 40080 f80
nov 11 16:49:34 cambionn-laptop systemd-modules-load[393]: Failed to insert 'nvidia' : Exec format error
nov 11 16:49:34 cambionn-laptop systemd-modules-load[393]: Failed to insert 'nvidia_drm' Exec format error
nov 11 16:49:34 cambionn-laptop systemd[1]: Failed to start Load Kernel Modules.
nov 11 16:49:35 cambionn-laptop systemd-modules-load[548]: Failed to insert 'nvidia': Exec format error
nov 11 16:49:35 cambionn-laptop systemd-modules-load[548]: Failed to insert 'nvidia_drm': Exec format error
nov 11 16:49:35 cambionn-laptop systemd[1]: Failed to start Load Kernel Modules.
then journalctl -b -g "NVIDIA|Nvidia|nvidia|NOUVEAU|nouveau" returns the next
-- Logs begin at Sun 2018-11-11 05:24:02 CET, end at Sun 2018-11-11 17:05:51 CET. --
nov 11 16:49:33 cambionn-laptop kernel: nvidia: disagrees about version of symbol module_layout
nov 11 16:49:34 cambionn-laptop kernel: nvidia: disagrees about version of symbol module_layout
nov 11 16:49:34 cambionn-laptop systemd-modules-load[393]: Failed to insert 'nvidia': Exec format error
nov 11 16:49:34 cambionn-laptop systemd-modules-load[393]: Failed to insert 'nvidia_drm': Exec format error
nov 11 16:49:35 cambionn-laptop kernel: nvidia: diagrees about version of symbol module_layout
nov 11 16:49:35 cambionn-laptop systemd-modules-load[548]: Failed to instert 'nvidia_drm': Exec format error
nov 11 16:49:35 cambionn-laptop kernel: nvidia: disagrees about version of symbol module_layout
I'm getting back to you with the cat /var/log/Xorg.0.log output. It's really long to type over so you gotta give me a sec for that.
mhwd -li returns the following:
>Installed PCI configs:
NAME                      VERSION                          FREEDRIVER                    TYPE
video-nvidia             2018.08.09                        false                                PCI
within /etc/modprobe.d/nvidia.conf stands the following:
blacklist nouveau
blacklist nvidiafb
blacklist rivafb
within /etc/modprobe.d/nvidia-drm.conf stands:
options nvidia_drm modeset=1
As said previously, I followed the tutorial for using PRIME that @sueridgepipe had linked, beside that I didn't remove any drivers as according to mhwd -li there where none to be found.
@openminded I did that in the beginning (but then 2009), but I've got to admit I've forgotten to test that now that stuff is working a little bit more. However, I just tested. Both 2015 and 2009 don't change a thing.
Have you fully updated your system? I missed it if you said so.
Not my OS, I'm on the stock version of Manjaro 18.0 KDE. After hadding done multiple re-installs yesterday I was a bit done with it and figured I want to make stuff work first as I kept updating my OS and such. There where 76 packages not up to date last time I did get into the OS.
Funny enough, for some reason I had to manually update the pacman-key thing, it didn't do well automatically during update, even trough I think I saw it trying to go trough that in console. Would you recommend me to update with pacman -Syu trough TTY now?
I did make sure my BIOS and such are up to date.
Yes!
Stop whatever you are doing and update your system!
No panic.. :expressionless: I am just saying, there are clues, your issues are due to not updated system.
Now that you mention updates, that makes sense when it repeating said :sweat_smile:
(although in my defence, I didn't even get so far to get that log on my own. After a while you think you quite know some, and compared to those around me it might be true, but then when issues like this arise I go back to feeling like a noob compared to you guys :joy::joy::joy:)
It's updated now. I wasn't doing much more useful than writing the important part of that last log for you. I already spend around 17 or so hours trying to figure stuff out myself before I came to ask. I know my limits, unless I know what I'm doing with it and realise something (or find something) thanks to said help, I'm not going to play too much around while getting help. I know how much I dislike it when I help people at work and they change tons of stuff themselves trying to fix it making stuff more often only more complex. I don't want to accidentally make it worse.
Like I said, I updated in the beginning, but after a while I was so done with reinstalling, I wanted to make some steps forward first. Anyways, after updating I'm in my system again.
And it seems like stuff is working.
$ glxinfo | grep -i vendor
server glx vendor string: NVIDIA Corporation
client glx vendor string: NVIDIA Corporation
OpenGL vendor string: NVIDIA Corporation
Thank you guys so much! All of you who helped me out passed two days! Learned a lot. Never had issues with video drivers nor the default installations before (I tend to just break stuff myself), so lot of new stuff. Now I've got one evening to set stuff up for work, but that's the easy part ^^.
