Hello,
I am being unable to install packages via either octopi or pamac and they both give me the same answer:
DEB_Arch_Extra: key "4B4E7A9523ACD201" is unknown
How do I fix this?
Thanks in advance
Hello,
How do I fix this?
Thanks in advance
Megasync issues? See here
This is not a Manjaro or Arch key.
Please check the instructions for whatever third-party repository you have added to your system.
The Google-Fu is strong with this one:
https://archived.forum.manjaro.org/search?q=key%20is%20unknown
I have already seen this thread but I do not use PGP keys.
Yes you do.
All package managers do.
I just opened the /etc/pacman.conf
file, and this text is already there.
Yes you do.
How do I check this?
It's built into the package manager.
But basiaclly, check the SigLevel
lines in your /etc/pacman.conf.
There's no need to make the signature checking Optional. The key is in the repo: https://mega.nz/linux/MEGAsync/Arch_Extra/x86_64/DEB_Arch_Extra.key
If you trust it then you can add it to pacman's keyring.
If you need more help with a piece of commercial software please also consider contacting the company who employ paid technical support personnel.
