Oh no! Something has gone wrong.
Hello everybody,
I just wanted to install Blender to learn some 3D modeling (which did not work out because my graphics driver is not supported, but that's not the main issue here) and when I rebooted the following was shown:
wrong
I have to mention that for some reason the system did not shut down correctly before the restart. It was somehow stuck and just a black screen was shown so I had to press the power button several seconds to finish the shutdown process.
I am using dual boot with Windows 10 and Manjaro.
Here is some information about my system (I took this screenshot some time ago):
Might there be a quick solution to fix this problem or should I just reinstall the system?
Thanks in advance,
David
Please don't. Text information is way more practical when copy/pasted rather than screenshot.
Thanks, I will keep that in mind for the next time. But for now that's all I have because I can unfortunately not login and copy/paste.
What Gnome theme and extensions did you use on that machine?
When you see that oh no! go to TTY login there try to update.
I did TTY into it but the system is already up to date.
Not really sure what Gnome theme I was using. At least I did not change the theme that was installed from the beginning.
What are extensions?
Some plugins to the panel, I know from my short experience those extensions can cause problems as you have, can be something different.
I don't think I installed any plugins.
This might have lead to filesystem corruption. The following won't hurt to try:
  1. boot up your live usb
  2. launch gparted
  3. right-click on your system partition(s) and "Check". Apply the operations from the toolbar.
  4. when done, reboot
Hope this helps. If not one possible cause is eliminated.
Maybe the blender installed something what is causing this problem, you can check the log in
/var/log/pacman.log you will find what was installed.
All checks were successful.
There was quite some stuff installed it seems.
inst
I would remove cuda and nvidia
Awesome, that worked!
Thank you so much for your help. That really made my day!
OP would probably have a better experience with a handle on the gfx and/or mhwd ..
hey @david2 now that we have a working system .. can we look at a few things?
inxi -G
mhwd -li && mhwd -l
cuda is only for NVIDIA cards and only for some of them not for gaming cards, for professional cards like quadro.
$ inxi -G
Graphics:  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics driver: i915 v: kernel
           Device-2: NVIDIA GK106 [GeForce GTX 650 Ti] driver: nouveau v: kernel
           Display: x11 server: X.org 1.20.8 driver: nouveau resolution: <xdpyinfo missing>
           OpenGL: renderer: NVE6 v: 4.3 Mesa 20.1.3
$ mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
$ mhwd -l
> 0000:01:00.0 (0300:10de:11c6) Display controller nVidia Corporation:
    video-nvidia-440xx            2019.10.25               false            PCI
    video-nvidia-435xx            2019.10.25               false            PCI
    video-nvidia-430xx            2019.10.25               false            PCI
    video-nvidia-418xx            2019.10.25               false            PCI
    video-nvidia-390xx            2019.10.25               false            PCI
    video-nvidia-340xx            2019.10.25               false            PCI
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:00:02.0 (0380:8086:0152) Display controller Intel Corporation:
Thats a bit odd.
If your nvidia card supports drivers like 440x .. then it makes sense you should be able to use PRIME.
If you want .. check trying this:
sudo mhwd -f -i pci video-hybrid-intel-nvidia-440xx-prime
(and restart)
Thanks for your time!
There were not problems during the installation or restart.
$ inxi -G
           Device-2: NVIDIA GK106 [GeForce GTX 650 Ti] driver: nvidia v: 440.100
           Display: x11 server: X.org 1.20.8 driver: modesetting,nvidia unloaded: intel,nouveau resolution: <xdpyinfo missing>
           OpenGL: renderer: GeForce GTX 650 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
$ mhwd -li && mhwd -l
video-hybrid-intel-nvidia-440xx-prime            2019.10.25               false            PCI
Great.
Lets check this:
glxinfo | grep 'renderer string'
prime-run glxinfo | grep 'renderer string'
PS
No problem, compa.
$ glxinfo | grep 'renderer string'
OpenGL renderer string: GeForce GTX 650 Ti/PCIe/SSE2
$ prime-run glxinfo | grep 'renderer string'
