OpenBox and Polybar
Hello I am using Manjaro i3 and I installed OpenBox and I want to use Polybar. I have polybar pretty much the way I want it. However I can not get it to display my workspaces on the left. Any ideas? My config:
; To learn more about how to configure Polybar
; go to https://github.com/jaagr/polybar
; The README contains alot of information
[colors]
;background = ${xrdb:color0:#222}
background = #222
background-alt = #444
;foreground = ${xrdb:color7:#222}
foreground = #dfdfdf
foreground-alt = #555
primary = #ffb52a
secondary = #e60053
alert = #bd2c40
[bar/polybar]
;monitor = ${env:MONITOR:HDMI-1}
width = 100%
height = 27
;offset-x = 1%
;offset-y = 1%
radius = 6.0
fixed-center = false
background = ${colors.background}
foreground = ${colors.foreground}
line-size = 3
line-color = #f00
border-size = 4
border-color = #00000000
padding-left = 0
padding-right = 2
module-margin-left = 1
module-margin-right = 2
font-0 = fixed:pixelsize=10;1
font-1 = unifont:fontformat=truetype:size=8:antialias=false;0
font-2 = siji:pixelsize=10;1
modules-left = i3
modules-center = mpd
modules-right = filesystem xbacklight volume memory cpu temperature wlan eth battery date
; xkeyboard powermenu
tray-position = right
tray-padding = 2
;tray-transparent = true
;tray-background = #0063ff
; wm-restack = bspwm
wm-restack = i3
override-redirect = false
;scroll-up = bspwm-desknext
;scroll-down = bspwm-deskprev
scroll-up = i3wm-wsnext
scroll-down = i3wm-wsprev
cursor-click = pointer
cursor-scroll = ns-resize
[module/xwindow]
type = internal/xwindow
label = %title:0:30:...%
[module/xkeyboard]
type = internal/xkeyboard
blacklist-0 = num lock
format-prefix = "ξ‰― "
format-prefix-foreground = ${colors.foreground-alt}
format-prefix-underline = ${colors.secondary}
label-layout = %layout%
label-layout-underline = ${colors.secondary}
label-indicator-padding = 2
label-indicator-margin = 1
label-indicator-background = ${colors.secondary}
label-indicator-underline = ${colors.secondary}
[module/filesystem]
type = internal/fs
interval = 25
mount-0 = /
mount-1 = /home
label-mounted = %{F#0a81f5}%mountpoint%%{F-}: %percentage_used%%
label-unmounted = %mountpoint% not mounted
label-unmounted-foreground = ${colors.foreground-alt}
[module/bspwm]
type = internal/bspwm
label-focused = %index%
label-focused-background = ${colors.background-alt}
label-focused-underline= ${colors.primary}
label-focused-padding = 2
label-occupied = %index%
label-occupied-padding = 2
label-urgent = %index%!
label-urgent-background = ${colors.alert}
label-urgent-padding = 2
label-empty = %index%
label-empty-foreground = ${colors.foreground-alt}
label-empty-padding = 2
[module/i3]
type = internal/i3
format =
index-sort = false
wrapping-scroll = false
; Only show workspaces on the same output as the bar
pin-workspaces = true
; This will split the workspace name on ':'
; Default: false
strip-wsnumbers = false
; Create click handler used to focus workspace
; Default: true
enable-click = true
; Create scroll handlers used to cycle workspaces
; Default: true
enable-scroll = true
; Set the scroll cycle direction
; Default: true
reverse-scroll = false
; Use fuzzy (partial) matching on labels when assigning
; icons to workspaces
; Example: code;β™š will apply the icon to all workspaces
; containing 'code' in the label
; Default: false
fuzzy-match = false
label-mode-padding = 2
label-mode-foreground = #000
label-mode-background = ${colors.primary}
; focused = Active workspace on focused monitor
label-focused-background = ${module/bspwm.label-focused-background}
label-focused-underline = ${module/bspwm.label-focused-underline}
label-focused-padding = ${module/bspwm.label-focused-padding}
; unfocused = Inactive workspace on any monitor
label-unfocused = %index%
label-unfocused-padding = ${module/bspwm.label-occupied-padding}
; visible = Active workspace on unfocused monitor
label-visible = %index%
label-visible-background = ${self.label-focused-background}
label-visible-underline = ${self.label-focused-underline}
label-visible-padding = ${self.label-focused-padding}
; urgent = Workspace with urgency hint set
label-urgent-background = ${module/bspwm.label-urgent-background}
label-urgent-padding = ${module/bspwm.label-urgent-padding}
ws-icon-0 = 1;
ws-icon-1 = 2;
ws-icon-2 = 3;
ws-icon-3 = 4;
[module/mpd]
type = internal/mpd
format-online =
icon-prev = ξ‚–
icon-stop = ξ‚™
icon-play = ξ‚š
icon-pause = ξ‚›
icon-next = ξ‚œ
label-song-maxlen = 25
label-song-ellipsis = true
[module/xbacklight]
type = internal/xbacklight
format =
label = BL
bar-width = 10
bar-indicator = |
bar-indicator-foreground = #ff
bar-indicator-font = 2
bar-fill = ─
bar-fill-font = 2
bar-fill-foreground = #9f78e1
bar-empty = ─
bar-empty-font = 2
bar-empty-foreground = ${colors.foreground-alt}
[module/backlight-acpi]
inherit = module/xbacklight
type = internal/backlight
card = intel_backlight
[module/cpu]
type = internal/cpu
interval = 2
format-prefix = " "
format-underline = #f90000
label = %percentage:2%%
[module/memory]
type = internal/memory
interval = 2
format-prefix = " "
format-underline = #4bffdc
label = %percentage_used%%
[module/wlan]
type = internal/network
interface = wlp3s0
interval = 3.0
; format-connected =
format-connected-underline = #9f78e1
label-connected = %essid% %local_ip% (%signal%)
format-disconnected =
;format-disconnected =
;format-disconnected-underline = ${self.format-connected-underline}
;label-disconnected = %ifname% disconnected
;label-disconnected-foreground = ${colors.foreground-alt}
ramp-signal-0 = [0]
ramp-signal-1 = [1]
ramp-signal-2 = [2]
ramp-signal-3 = [3]
ramp-signal-4 = [4]
ramp-signal-foreground = ${colors.foreground-alt}
[module/eth]
interface = eno1
interval = 3.0
format-connected-underline = #55aa55
format-connected-prefix = "ξ†œ "
format-connected-prefix-foreground = ${colors.foreground-alt}
label-connected = %local_ip%
[module/date]
type = internal/date
interval = 5
date =
date-alt = " %Y-%m-%d"
time = %H:%M
time-alt = %H:%M:%S
format-prefix = ξ€–
format-underline = #0a6cf5
label = %date% %time%
[module/volume]
type = internal/volume
; format-volume =
format-volume =
; label-volume = VOL
label-volume = VOL %percentage%%
label-volume-foreground = ${root.foreground}
format-volume-underline = #303F9F
format-muted-prefix = "muted"
format-muted-foreground = ${colors.foreground-alt}
label-muted = %percentage%%
bar-volume-width = 10
bar-volume-foreground-0 = #55aa55
bar-volume-foreground-1 = #55aa55
bar-volume-foreground-2 = #55aa55
bar-volume-foreground-3 = #55aa55
bar-volume-foreground-4 = #55aa55
bar-volume-foreground-5 = #f5a70a
bar-volume-foreground-6 = #ff5555
bar-volume-gradient = false
bar-volume-indicator = |
bar-volume-indicator-font = 2
bar-volume-fill = ─
bar-volume-fill-font = 2
bar-volume-empty = ─
bar-volume-empty-font = 2
bar-volume-empty-foreground = ${colors.foreground-alt}
[module/battery]
type = internal/battery
battery = BAT0
adapter = ADP1
full-at = 89
label-charging = %percentage%%
label-discharging = %time% %consumption%
label-full = 100%
format-charging =
format-charging-underline = #ffb52a
format-discharging =
format-discharging-underline = ${self.format-charging-underline}
; format-discharging-underline = #f90000
format-full-prefix = " "
format-full-prefix-foreground = ${colors.foreground-alt}
format-full-underline = ${self.format-charging-underline}
ramp-capacity-0 = [0]
ramp-capacity-1 = [1]
ramp-capacity-2 = [2]
ramp-capacity-foreground = ${colors.foreground-alt}
animation-charging-0 = 
animation-charging-1 = 
animation-charging-2 = 
animation-charging-foreground = ${colors.foreground-alt}
animation-charging-framerate = 750
[module/temperature]
type = internal/temperature
thermal-zone = 0
warn-temperature = 60
format =
format-underline = #f50a4d
format-warn =
format-warn-underline = ${self.format-underline}
label = %temperature%
label-warn = %temperature%
label-warn-foreground = ${colors.secondary}
ramp-0 = 
ramp-1 = ξƒŠ
ramp-2 = 
ramp-foreground = ${colors.foreground-alt}
[module/powermenu]
type = custom/menu
expand-right = true
format-spacing = 1
label-open = ξ„Œ
label-open-foreground = ${colors.secondary}
label-close = ξ₯ cancel
label-close-foreground = ${colors.secondary}
label-separator = |
label-separator-foreground = ${colors.foreground-alt}
menu-0-0 = reboot
menu-0-0-exec = menu-open-1
menu-0-1 = power off
menu-0-1-exec = menu-open-2
menu-1-0 = cancel
menu-1-0-exec = menu-open-0
menu-1-1 = reboot
menu-1-1-exec = sudo reboot
menu-2-0 = power off
menu-2-0-exec = sudo poweroff
menu-2-1 = cancel
menu-2-1-exec = menu-open-0
[settings]
screenchange-reload = true
;compositing-background = xor
;compositing-background = screen
;compositing-foreground = source
;compositing-border = over
[global/wm]
margin-top = 5
margin-bottom = 5
; vim:ft=dosini
Have a look at this :slight_smile:
And the answer to your question - a snippet from my config
polybar-workspaces
;; Openbox Workspaces ;;
[module/workspaces]
type = internal/xworkspaces
pin-workspaces = false
enable-click = true
format-padding = 0
icon-0 = 1;
icon-1 = 2;
icon-2 = 3;
icon-3 = 4;
icon-4 = 5;
icon-5 = 6;
icon-6 = 7;οˆ›
icon-7 = 8;
icon-8 = 9;ξž•
icon-9 = 10;οŒ€
icon-default =
format = <label-state>
Very very nice edition. Excellent job! Kind of reminds me of Archlabs.
I have a lot of inspiration from that - and a lot of scripts :slight_smile:
2 posts were split to a new topic: Changing polybar colors
@linux-aarhus what font am I missing?
These fonts are installed with openbox
manjaro-openbox-fonts
ttf-dejavu
ttf-font-awesome
ttf-font-logos
ttf-icomoon-icons
ttf-material-icons
ttf-polybar-icons
ttf-roboto
You cannot judge from what is shown in the config - some of the chars does only show correct when rendered by polybar.
If anyone is still reading this thread.. and I'm not being criminal for a necropost, I have the following question. With bspwm & polybar, I have no problem showing/higlighting which workspaces are 'occupied'. I am unable to do something similar for Openbox with the ewmh workspaces (xworkspaces).
Is this doable? If so, ideas & guidance are most appreciated.
I dont't think openbox is capable.
That was my guess. Danke schΓΆn.
I'll use tint2 to accomplish something similar, then. ;
