Optimus manager errors
Hi all! I just installed and set up optimus-manager and it's "working" with some problems.
Info about my system:
Graphics cards:
Intel(R) HD Graphics 630 (KBL GT2)
Nvidia GeForce 1050M
Driver:
video-hybrid-intel-nvidia-440xx-prime
DE:
Gnome
The first time I switch to Nvidia (switch method set to none in optimus-manager settings) it kinda works: it logs out but then the graphical session freezes, but if I change to a tty and then back to the graphical session, it loads the login screen and can access perfectly and uses nvidia card (checked with "glxinfo | grep "OpenGL renderer"" and looking into nvidia card usage being >0%).
After that, if I want to go back to intel, the same happens: freeze, refresh, log in and intel card in use. However, in this step some error happens that prevents me to going back to nvidia again.
Here I leave optimus-manager logs when switching to nvidia:
[7] INFO: # Xorg pre-start hook
[7] INFO: Requested mode is: nvidia
[7] INFO: Checking for GDM display servers
[26] INFO: Found a Xorg GDM process (PID 1018), killing it...
[213] INFO: Available modules: ['nouveau', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[213] INFO: Unloading modules ['nouveau'] (if loaded)
[242] INFO: Loading module nvidia
[472] INFO: Loading module nvidia_drm
[2552] INFO: Loaded extra Intel Xorg options (0 lines)
[2552] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[2552] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20200610T124527', 'requested_mode': 'nvidia'}
[2553] INFO: Xorg pre-start hook completed successfully.
[3] INFO: # Xorg post-start hook
[3] INFO: Running xrandr commands
[747] INFO: Running /etc/optimus-manager/xsetup-nvidia.sh
[767] INFO: Writing state {'type': 'done', 'switch_id': '20200610T124527', 'current_mode': 'nvidia'}
[767] INFO: Xorg post-start hook completed successfully.
And here the one when going back to intel:
[6] INFO: # Xorg pre-start hook
[6] INFO: Requested mode is: intel
[6] INFO: Checking for GDM display servers
[22] INFO: Found a Xorg GDM process (PID 2114), killing it...
[226] INFO: Available modules: ['nouveau', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[227] INFO: Unloading modules ['nvidia_drm', 'nvidia_modeset', 'nvidia_uvm', 'nvidia'] (if loaded)
[229] ERROR: Xorg pre-start setup error
  File "/usr/lib/python3.8/site-packages/optimus_manager/bash.py", line 11, in exec_bash
    out = subprocess.check_output(
  File "/usr/lib/python3.8/subprocess.py", line 411, in check_output
    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
  File "/usr/lib/python3.8/subprocess.py", line 512, in run
    raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['bash', '-c', 'modprobe -r nvidia_drm nvidia_modeset nvidia_uvm nvidia']' returned non-zero exit status 1.
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3.8/site-packages/optimus_manager/kernel.py", line 196, in _unload_modules
    exec_bash("modprobe -r " + " ".join(modules_to_unload))
  File "/usr/lib/python3.8/site-packages/optimus_manager/bash.py", line 18, in exec_bash
    raise BashError(
optimus_manager.bash.BashError: Failed to execute 'modprobe -r nvidia_drm nvidia_modeset nvidia_uvm nvidia' :
modprobe: FATAL: Module nvidia_drm is in use.
  File "/usr/lib/python3.8/site-packages/optimus_manager/hooks/pre_xorg_start.py", line 33, in main
    setup_kernel_state(config, prev_state, requested_mode)
  File "/usr/lib/python3.8/site-packages/optimus_manager/kernel.py", line 24, in setup_kernel_state
    _nvidia_down(config)
  File "/usr/lib/python3.8/site-packages/optimus_manager/kernel.py", line 65, in _nvidia_down
    _unload_nvidia_modules(available_modules)
  File "/usr/lib/python3.8/site-packages/optimus_manager/kernel.py", line 148, in _unload_nvidia_modules
    _unload_modules(available_modules, ["nvidia_drm", "nvidia_modeset", "nvidia_uvm", "nvidia"])
  File "/usr/lib/python3.8/site-packages/optimus_manager/kernel.py", line 198, in _unload_modules
    raise KernelSetupError("Cannot unload modules %s : %s" % (str(modules_to_unload), str(e)))
optimus_manager.kernel.KernelSetupError: Cannot unload modules ['nvidia_drm', 'nvidia_modeset', 'nvidia_uvm', 'nvidia'] : Failed to execute 'modprobe -r nvidia_drm nvidia_modeset nvidia_uvm nvidia' :
[230] INFO: Removing /etc/X11/xorg.conf.d/10-optimus-manager.conf (if present)
[230] INFO: Writing state {'type': 'pre_xorg_start_failed', 'switch_id': '20200610T124705', 'requested_mode': 'intel'}
I don't know whats causing any of this. Any help is appreciated, don't hesitate to ask for more info if needed, I'm new and don't know which other files could be useful.
