optimus-manager power management assistance needed
I've been trying set-up power management options for optimus-manager; however, it doesn't seem to disable the GPU at all.
I read the guide here on the forums, the ArchWiki, and the official GitHub.
I also read this.
I tried a lot of different configurations:
nouveau switching
[optimus]
switching=nouveau
pci_power_control=yes
pci_remove=no
pci_reset=no
This configuration prevents shutdown, makes boot time slower, and doesn't switch to GPU with optimus-manager --switch nvidia
Intel energy-rate: 12.3354 W
Nvidia energy-rate: Didn't switch so can't tell.
none switching, no pci_remove
[optimus]
switching=none
pci_remove=no
pci_reset=no
This configuration seems to work, but doesn't disable GPU.
Nvidia energy-rate: 12.3354 W
none switching, yes pci_remove
[optimus]
switching=nouveau
pci_remove=yes
pci_reset=no
bbswitch switching, no pci_remove
[optimus]
switching=bbswitch
pci_remove=no
pci_reset=no
Finally, I tried to remove the configuration with sudo rm /etc/optimus-manager/optimus-manager.conf
Then optimus-manager --set-startup hybrid
Hybrid energy-rate: 12.3354 W
Am I missing something?
Method for testing configuration
  1. Set startup to intel with optimus-manager --set-startup intel
  2. Changed the config file in /etc/optimus-manager/optimus-manager.conf (--temp-config PATH doesn't seem to work for me)
  3. Reboot
  4. Run glxspheres64 and watch upower -i /org/freedesktop/UPower/devices/battery_BAT0 until the energy-rate is updated
  5. Switch to nvidia with optimus-manager --switch nvidia
  6. Run glxspheres64 and watch upower -i /org/freedesktop/UPower/devices/battery_BAT0 until the energy-rate is updated
  7. Start again from step 2
inxi -Fxxxz
  Host: LAPTOP-4JDS3FOA Kernel: 5.3.6-1-MANJARO x86_64 bits: 64
  compiler: gcc v: 9.2.0 Desktop: Xfce 4.14.1 tk: Gtk 3.24.12
  info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: HP product: HP ENVY Laptop 13-aq0xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: HP model: 85E3 v: 29.26 serial: <filter> UEFI: Insyde v: F.07
  date: 08/01/2019
  ID-1: BAT0 charge: 52.6 Wh condition: 52.6/52.6 Wh (100%) volts: 17.5/15.4
  model: 333-2B-49-A KC04053XL type: Li-ion serial: <filter> status: Full
  Topology: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
  arch: Kaby Lake rev: C L2 cache: 8192 KiB
  bogomips: 32012
  Speed: 600 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 600 2: 600
  3: 600 4: 600 5: 600 6: 600 7: 600 8: 600
  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
  Device-2: NVIDIA GP108BM [GeForce MX250] vendor: Hewlett-Packard
  driver: nvidia v: 435.21 bus ID: 01:00.0 chip ID: 10de:1d52
  Display: server: X.Org 1.20.5 driver: modesetting,nvidia
  resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel UHD Graphics (Whiskey Lake 3x8 GT2)
  v: 4.5 Mesa 19.2.1 compat-v: 3.0 direct render: Yes
  Device-1: Intel Cannon Point-LP High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1f.3
  chip ID: 8086:9dc8
  Sound Server: ALSA v: k5.3.6-1-MANJARO
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
  v: kernel port: 4000 bus ID: 00:14.3 chip ID: 8086:9df0
  Local Storage: total: 953.87 GiB used: 49.28 GiB (5.2%)
  ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T8H size: 953.87 GiB
  speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: HPS0 scheme: GPT
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 4060 bus ID: 00:17.0 chip ID: 8086.282a rev: 30
  ID-1: / size: 475.40 GiB used: 24.61 GiB (5.2%) fs: ext4
  dev: /dev/nvme0n1p5
  ID-2: swap-1 size: 16.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-0
  System Temperatures: cpu: 48.0 C mobo: 36.0 C
  Processes: 298 Uptime: 3m Memory: 15.38 GiB used: 1.63 GiB (10.6%)
  Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash (sudo) v: 5.0.11
  running in: xfce4-terminal inxi: 3.0.36
EDIT: Just ran nvidia-smi while in intel mode, and I got this output:
nvidia-smi in intel mode
| NVIDIA-SMI 440.26       Driver Version: 440.26       CUDA Version: 10.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce MX250       Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   36C    P0    N/A /  N/A |      0MiB /  2002MiB |      2%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|  No running processes found                                                 |
Then, under nvidia mode:
nvidia-smi in nvidia mode
| N/A   48C    P0    N/A /  N/A |    159MiB /  2002MiB |      0%      Default |
|    0      3149      G   /usr/lib/Xorg                                157MiB |
|    0      3292      G   xfwm4                                          1MiB |
So obviously, it is not using the GPU under intel mode, but I can't tell if it's powered on or not because it says N/A under power usage.
Btw, this is using the "none switching, no pci_remove" configuration from above.
using upower to read power usage it not reliable. use powertop instead. if you tab over to devices and the nvidia shows 0% then it's powered down, if it shows anything above %0 then it's not
ON
100.0%        PCI Device: NVIDIA Corporation GM107M [GeForce GTX 960M]
OFF
Hi. Thanks for the reply.
I'm currently using the "none switching, no pci_remove" configuration.
When in intel mode, the graphics card does not show up at all, but when in nvidia mode, it shows 100%.
Is that supposed to happen? I have pci_remove set to no in /etc/optimus-manager/optimus-manager.conf.
Also, how can I be sure it is disabled when in intel mode if it is not showing up in powertop?
Edit: I also forgot to mention in the original post that a terminal is always open with nothing running on it when I login, even from a shutdown. I checked the Application Autostart, and I don't have a terminal set there.
i just wanted to suggest a better option for monitoring power usage, i try to stay away from optimus-manager problems. sorry. maybe @michaldybczak could answer that?
This looks like a question to optimus-manager developer. Please, start an issue here:
and give your hardware specs and driver version as well.
Personally, I never tested is so thoroughly when it comes to power usage so I can't tell anything.
I'm not very familiar with GitHub and such (still a newbie), but I always assumed that opening an issue meant that there was a bug with the program, not a personal problem(?)
So, should I open an issue asking for power monitoring options, or saying that the graphics card is not showing up in powertop even though I have pci_remove set to no?
Edit: Also should I open a separate issue about the terminal being launched automatically on login?
It turns out I was being stupid. :stuck_out_tongue:
The powertab out was full, so it didn't show the Nvidia card.
I couldn't scroll down with down arrow, so I thought that was it. Apparently it's a bug in version 2.1.
I ran powertab -C to generate a .csv file and saw the whole output (the GPU was indeed turned off).
Just edit your first reply and add that information, so I can mark it as a solution.
Edit: Also, in a situation like this, should I email the packager of powertop and ask for the patch to be added, or just wait for the next version to be released?
you should check if it's already reported as a bug first, if it's not then report it.
added, i think :man_shrugging:
he a question about this where do you put this configuration
[optimus]
switching=nouveau
pci_remove=yes
pci_reset=no
iirc there's an optimus-manager.conf and i think it's located /etc/optimus-manager/ or something like that
so just create the file and paste like that ?
thanks
no, there should already be an optimus manager .conf file somewhere
there is one here /usr/share/optimus-manager.conf . but it says it should not be edited when i try
a error occurer with optimus so maybe create one ?
If you don't have this file, create it. The inner structure looks like this:
[intel]
DRI=3
accel=
driver=modesetting
modeset=yes
tearfree=
[nvidia]
DPI=96
PAT=yes
ignore_abi=no
modeset=yes
options=overclocking
[optimus]
auto_logout=yes
pci_remove=yes
pci_reset=no
switching=bbswitch
Can SOmeone help with this issue?I too am facing this problem,My battery is getting hot, and drains quickly within 2 to 2:30 hours (it never happened in windows).
I am using intel gfx but still the powertop uses NVIDIA
The output of powertop Device Stats is:
The battery reports a discharge rate of 11.7 W
The power consumed was 0.00 J
System baseline power is estimated at 2.55 W
Power est.    Usage     Device name
  1.49 W      8.0%        CPU misc
  676 mW      8.0%        CPU core
  381 mW      8.0%        DRAM
    0 mW     30.0%        Display backlight
            100.0%        PCI Device: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16)
            100.0%        Radio device: iwlwifi
            100.0%        Radio device: ideapad_acpi
            100.0%        PCI Device: Intel Corporation Cannon Lake Mobile PCH SATA AHCI Controller
            100.0%        PCI Device: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
            100.0%        PCI Device: Intel Corporation Wireless-AC 9560 [Jefferson Peak]
            100.0%        PCI Device: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile]
            100.0%        PCI Device: Intel Corporation UHD Graphics 630 (Mobile)
            100.0%        PCI Device: Intel Corporation 8th Gen Core 4-core Processor Host Bridge/DRAM Registers [Coffee Lake H]
            100.0%        PCI Device: Intel Corporation Cannon Lake PCH Thermal Controller
            100.0%        PCI Device: Union Memory (Shenzhen) Device 5008
            100.0%        PCI Device: Intel Corporation Cannon Lake PCH PCI Express Root Port #9
              0.0%        USB device: xHCI Host Controller
It shows:
SO Nvidia gfx is still using power right?
How to swtich it off?
What should be the conf file /etc/optimus-manager/optimus-manager.conf
here is the my ouput:
[intel]
DRI=3
accel=
driver=intel
modeset=yes
tearfree=yes
[nvidia]
DPI=96
PAT=yes
ignore_abi=no
modeset=yes
[optimus]
auto_logout=yes
pci_power_control=no
pci_remove=no
pci_reset=no
switching=bbswitch
Any help is appreciated.
Sorry I am still new to this dealing with graphics drivers.
Thanks in advance.
Are you in Hybrid or Intel mode? The powertop suggests you are in Hybrid mode, if so, just use Intel mode. I don't know what hardware you have, but for older one (1-few years old), hybrid is hardly less energy consuming then Nvidia mode, so it's beneficial to not use it but use Intel mode as default and switch to Nvidia whenever you really need it.
the optimus-manager shows intel icon in the panel in the lower right side. So it should be intel right?Can you tell me how to switch to intel in command line.Sorry i am completely new to this thing
ok i tried sitching into intel using
optimus-manager --switch intel
but the powertop devuce stats still contains nvidia at 100%
            100.0%        PCI Device: Intel Corporation Cannon Lake PCH Shared SRAM
            100.0%        PCI Device: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller
            100.0%        PCI Device: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0
            100.0%        PCI Device: Intel Corporation Cannon Lake PCH cAVS
            100.0%        PCI Device: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
            100.0%        PCI Device: Intel Corporation Cannon Lake PCH SPI Controller
            100.0%        PCI Device: Intel Corporation Cannon Lake PCH Serial IO UART Host Controller
here it is
Then the optimus-manager configuration is wrong. Maybe you need to use different switch or you tampered with it somehow.
Show me output of:
cat /etc/X11/xorg.conf.d/10-optimus-manager.conf
systemctl status optimus-manager.service
Ok,
Here is the output for:
Section "Device"
        Identifier "intel"
        Driver "intel"
        BusID "PCI:0:2:0"
        Option "TearFree" "true"
        Option "DRI" "3"
EndSection
and the output for :
● optimus-manager.service - Optimus Manager Commands Daemon
   Loaded: loaded (/usr/lib/systemd/system/optimus-manager.service; enabled; vendor preset: disabled)
   Active: active (running) since Fri 2020-03-13 09:11:39 IST; 11min ago
  Process: 867 ExecStartPre=/usr/bin/prime-switch-boot (code=exited, status=0/SUCCESS)
 Main PID: 3226 (python3)
    Tasks: 1 (limit: 4915)
   Memory: 43.6M
   CGroup: /system.slice/optimus-manager.service
           └─3226 /usr/bin/python3 -u /usr/bin/optimus-manager-daemon
Mar 13 09:11:39 srinjoy-xavier prime-switch-boot[867]: Setting up Intel state
Mar 13 09:11:39 srinjoy-xavier prime-switch-boot[867]: Setting GPU power to OFF via bbswitch
Mar 13 09:11:39 srinjoy-xavier prime-switch-boot[867]: Loaded extra Intel Xorg options (0 lines)
Mar 13 09:11:39 srinjoy-xavier prime-switch-boot[867]: Loaded extra Nvidia Xorg options (0 lines)
Mar 13 09:11:39 srinjoy-xavier prime-switch-boot[867]: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
Mar 13 09:11:39 srinjoy-xavier systemd[1]: Started Optimus Manager Commands Daemon.
Mar 13 09:11:39 srinjoy-xavier python3[3226]: Optimus Manager (Daemon) version 1.2.2
Mar 13 09:11:39 srinjoy-xavier python3[3226]: Automatic log cropping
Mar 13 09:11:39 srinjoy-xavier python3[3226]: Opening UNIX socket
Mar 13 09:11:39 srinjoy-xavier python3[3226]: Awaiting commands
What should i change?
