[pacman-mirrors-dev] Testing mirrors async
  • best is connexion and best are the results : you can have 50 download at same time
  • If we use a country, problem asyn is low : we have "only" 4..5 download at same time
The problem is big if user have not country filter and a bad bandwith - my all test is with 90 urls (with 16Mb/s i not have a bad connexion)
and yes, muti-thread with python is less efficient than Go - it's good in this case :wink:
for me -c all --test-async not pass all I'm frozen every time.
At iran ? but at same time , with go, all is ok and without --test-asyncit also ok ?
Duration: 496.655563ms Iran https://repo.iut.ac.ir/repo/manjaro/ 51
Duration: 9.068242877s Iran https://repo.sadjad.ac.ir/manjaro/ 50
^C^C
Error: interrupted by the user.
^CError in atexit._run_exitfuncs:
File "/usr/lib/python3.7/concurrent/futures/thread.py", line 40, in _python_exit
t.join()
File "/usr/lib/python3.7/threading.py", line 1032, in join
self._wait_for_tstate_lock()
File "/usr/lib/python3.7/threading.py", line 1048, in _wait_for_tstate_lock
elif lock.acquire(block, timeout):
KeyboardInterrupt
