pacman-mirrors is way out of date
I have two Raspberry Pi 4s. One is updating and the other is not.
I checked pacman-mirrors for both. The one that is updating is has a version number on pacman-mirrors of 4.16.5 the other is at 2.0.
Also the one with pacman-mirrors at 2.0, responds to sudo pacman -Syu with 'there is nothing to do'.
How do I get update working again? I assume my pacman-mirrors us wrong, how do I fix it?
It seems you missed some posts in this category .. such as ..
Yes I missed it, thanks!
And I did make progress but it's not completing the upgrade....
error: failed to commit transaction (conflicting files)
nss: /usr/lib/p11-kit-trust.so exists in filesystem
compounding with another old manual intervention:
Yes, that did the trick. I'll have to find a way to keep up to date.
Those things dont always come up .. but in a rolling release they will from time to time.
Someone created a little newsfeeder if you are interested in that ..
(it is in the repos as mntray)
This topic was automatically closed after 90 days. New replies are no longer allowed.
