pamac not working not able to close
[manjaro@manjaro-pc ~]$ systemctl  --failed
  UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
● pamac-daemon.service loaded failed failed Pamac Daemon
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
pamac not working not able to close the application
pacman not able to update or not able to install any new application
suggest some way solve this problem ....
pamac has stopped working ,unable to close the application.
pamac-daemon.service -> what trouble is this causing??
[manjaro@manjaro-pc ~]$ sudo pacman -Syu
[sudo] password for manjaro:
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
error: failed retrieving file 'sublime-text.db' from download.sublimetext.com : error setting certificate verify locations:
  CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: none
error: failed to update sublime-text (download library error)
error: failed to synchronize all databases
HOW to delete sublime-text ...i dowmloadded via snap...but unable to uninstall it.
Would you mind to post inxi -Fxxxz? Please encase the output in ``` before and after in seperate lines to make it look like this
example beginning
example end
What the result of...
systemctl status pamac-daemon.service
As you have already been asked, please do not post screenshots. Post logs, inxi info, etc. using preformatted text using the </> button.
Please see:
You should share the errors you get then. We have no idea what they are.
But if you are in a partial-update or broken state .. then all sorts of things could be wrong besides pamac.. so maybe get a handle on that first.
Then when we can be sure you are all up to date we can look at pamac if it is still behaving badly.
sudo pacman-mirrors -f && sudo pacman -Syyu
What happens? Copy errors here and use the </> button to format.
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
