PC froze and I can't figure out why
So my Manjaro i3 PC just froze and I don't know why. I was able to mouse my mouse, but it moved very choppily. I could not scroll or click anything, nor could I use the keyboard or any keyboard shortcuts. The audio also stopped playing.
It somewhat fixed itself after a while, but even now I can not click on one Firefox window. I can scroll through the window, but can not click on anything not even the search bar or other tabs. I also can not close the window.
Does anyone know how to fix the freezing error or what to do with the Firefox window?
Did a reboot fix it?
Regarding the freezing. The system is not frozen, since you can move your mouse. And since it eventually got back, I would guess that the system started to swap a alot. Which would get "fixed" by a reboot.
If it does it again, try to get to a TTY with CTRL+ALT+F2 and run top when you are logged in.
in a terminal run
journalctl -p 3 -xb to show the errors of the last boot.
cat journalctl -p 3 -xb > errors.txt to save output to a file.
journalctl -p 3 all errors ever since...
journalctl -p 7 -xb | grep firefox all messages, even positive about firefox
Try installing a couple of different kernels through Manjaro settings manager if this problem keeps ocuring.
Yes, a reboot fixed the frozen Firefox window.
I tried this, but that also didn't work.
When I do this, it gave me the following output I am not sure what to make of it.
It is not a common issue and has only happened once. But what kernel should I be installing?
Please do not post pics for textual output. I am currently on a phone and I couldn't read a word of that if my life depended on it.
Boot errors are usually recorded in your dmesg logs.
That would depend on what kernel you are currently using. If you are on 4.19, test 4.20. If those don't work well for you then test 4.14.
My mistake.
It just happened to me again. The dmesg logs are as follows:
[    0.000000] Linux version 4.19.23-1-MANJARO (builduser@development) (gcc version 8.2.1 20181127 (GCC)) #1 SMP PREEMPT Fri Feb 15 21:27:33 UTC 2019
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=94d47185-81f8-448d-ab84-49182dbb19a2 rw quiet
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Centaur CentaurHauls
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000005efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000005f000-0x000000000005ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000060000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000008cd2dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000008cd2e000-0x000000008e599fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008e59a000-0x000000008e716fff] usable
[    0.000000] BIOS-e820: [mem 0x000000008e717000-0x000000008eb18fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008eb19000-0x000000008f320fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008f321000-0x000000008f40efff] type 20
[    0.000000] BIOS-e820: [mem 0x000000008f40f000-0x000000008f40ffff] usable
[    0.000000] BIOS-e820: [mem 0x000000008f410000-0x000000008fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000046dffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.70 by American Megatrends
[    0.000000] efi:  ACPI 2.0=0x8ea2a000  ACPI=0x8ea2a000  SMBIOS=0x8f17b000  SMBIOS 3.0=0x8f17a000  MEMATTR=0x89048018  MPS=0xfd9c0  ESRT=0x889c2298
[    0.000000] SMBIOS 3.1.1 present.
[    0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Z390M-ITX/ac, BIOS P1.10 08/17/2018
[    0.000000] tsc: Detected 3600.000 MHz processor
[    0.001044] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.001046] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001051] last_pfn = 0x46e000 max_arch_pfn = 0x400000000
[    0.001053] MTRR default type: uncachable
[    0.001053] MTRR fixed ranges enabled:
[    0.001054]   00000-9FFFF write-back
[    0.001055]   A0000-BFFFF uncachable
[    0.001055]   C0000-FFFFF write-protect
[    0.001056] MTRR variable ranges enabled:
[    0.001057]   0 base 00FF000000 mask 7FFF000000 write-protect
[    0.001057]   1 base 0000000000 mask 7F80000000 write-back
[    0.001058]   2 base 0080000000 mask 7FF0000000 write-back
[    0.001058]   3 base 0100000000 mask 7F00000000 write-back
[    0.001059]   4 base 0200000000 mask 7E00000000 write-back
[    0.001059]   5 base 0400000000 mask 7C00000000 write-back
[    0.001060]   6 disabled
[    0.001060]   7 disabled
[    0.001060]   8 disabled
[    0.001061]   9 disabled
[    0.002389] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002563] last_pfn = 0x8f410 max_arch_pfn = 0x400000000
[    0.008151] found SMP MP-table at [mem 0x000fdca0-0x000fdcaf] mapped at [(____ptrval____)]
[    0.008160] esrt: Reserving ESRT space from 0x00000000889c2298 to 0x00000000889c22d0.
[    0.008169] Scanning 1 areas for low memory corruption
[    0.008170] Base memory trampoline at [(____ptrval____)] 96000 size 24576
[    0.008181] Using GB pages for direct mapping
[    0.008182] BRK [0x45e201000, 0x45e201fff] PGTABLE
[    0.008183] BRK [0x45e202000, 0x45e202fff] PGTABLE
[    0.008184] BRK [0x45e203000, 0x45e203fff] PGTABLE
[    0.008198] BRK [0x45e204000, 0x45e204fff] PGTABLE
[    0.008199] BRK [0x45e205000, 0x45e205fff] PGTABLE
[    0.008263] BRK [0x45e206000, 0x45e206fff] PGTABLE
[    0.008284] BRK [0x45e207000, 0x45e207fff] PGTABLE
[    0.008311] BRK [0x45e208000, 0x45e208fff] PGTABLE
[    0.008312] BRK [0x45e209000, 0x45e209fff] PGTABLE
[    0.008339] BRK [0x45e20a000, 0x45e20afff] PGTABLE
[    0.008379] Secure boot could not be determined
[    0.008379] RAMDISK: [mem 0x36b79000-0x375b3fff]
[    0.008387] ACPI: Early table checksum verification disabled
[    0.008388] ACPI: RSDP 0x000000008EA2A000 000024 (v02 ALASKA)
[    0.008391] ACPI: XSDT 0x000000008EA2A0A8 0000D4 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008394] ACPI: FACP 0x000000008EA692E8 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.008398] ACPI: DSDT 0x000000008EA2A218 03F0CF (v02 ALASKA A M I    01072009 INTL 20160527)
[    0.008400] ACPI: FACS 0x000000008EB18080 000040
[    0.008402] ACPI: APIC 0x000000008EA69400 00012C (v04 ALASKA A M I    01072009 AMI  00010013)
[    0.008404] ACPI: FPDT 0x000000008EA69530 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008406] ACPI: FIDT 0x000000008EA69578 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008408] ACPI: MCFG 0x000000008EA69618 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.008409] ACPI: SSDT 0x000000008EA69658 000378 (v01 SataRe SataTabl 00001000 INTL 20160527)
[    0.008411] ACPI: SSDT 0x000000008EA699D0 0017C6 (v02 CpuRef CpuSsdt  00003000 INTL 20160527)
[    0.008414] ACPI: AAFT 0x000000008EA6B198 000206 (v01 ALASKA OEMAAFT  01072009 MSFT 00000097)
[    0.008415] ACPI: SSDT 0x000000008EA6B3A0 0031C6 (v02 SaSsdt SaSsdt   00003000 INTL 20160527)
[    0.008417] ACPI: SSDT 0x000000008EA6E568 002358 (v02 PegSsd PegSsdt  00001000 INTL 20160527)
[    0.008419] ACPI: HPET 0x000000008EA708C0 000038 (v01 INTEL  A M I    00000002      01000013)
[    0.008421] ACPI: SSDT 0x000000008EA708F8 00294F (v02 INTEL  xh_cfsd4 00000000 INTL 20160527)
[    0.008423] ACPI: UEFI 0x000000008EA73248 000048 (v01 ALASKA A M I    00000002      01000013)
[    0.008425] ACPI: LPIT 0x000000008EA73290 00005C (v01 INTEL  A M I    00000002      01000013)
[    0.008427] ACPI: SSDT 0x000000008EA732F0 0014E2 (v02 INTEL  TbtTypeC 00000000 INTL 20160527)
[    0.008429] ACPI: DBGP 0x000000008EA747D8 000034 (v01 ALASKA A M I    00000002      01000013)
[    0.008431] ACPI: DBG2 0x000000008EA74810 000054 (v00 ALASKA A M I    00000002      01000013)
[    0.008433] ACPI: SSDT 0x000000008EA74868 001B67 (v02 ALASKA UsbCTabl 00001000 INTL 20160527)
[    0.008434] ACPI: SSDT 0x000000008EA763D0 000144 (v02 Intel  ADebTabl 00001000 INTL 20160527)
[    0.008436] ACPI: DMAR 0x000000008EA76518 000070 (v01 INTEL  EDK2     00000002      01000013)
[    0.008438] ACPI: BGRT 0x000000008EA76588 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008440] ACPI: WSMT 0x000000008EA765C0 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.008446] ACPI: Local APIC address 0xfee00000
[    0.008730] No NUMA configuration found
[    0.008731] Faking a node at [mem 0x0000000000000000-0x000000046dffffff]
[    0.008733] NODE_DATA(0) allocated [mem 0x46dffc000-0x46dffffff]
[    0.008750] Zone ranges:
[    0.008750]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.008751]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.008752]   Normal   [mem 0x0000000100000000-0x000000046dffffff]
[    0.008753]   Device   empty
[    0.008754] Movable zone start for each node
[    0.008754] Early memory node ranges
[    0.008755]   node   0: [mem 0x0000000000001000-0x000000000005efff]
[    0.008755]   node   0: [mem 0x0000000000060000-0x000000000009ffff]
[    0.008756]   node   0: [mem 0x0000000000100000-0x000000008cd2dfff]
[    0.008756]   node   0: [mem 0x000000008e59a000-0x000000008e716fff]
[    0.008756]   node   0: [mem 0x000000008f40f000-0x000000008f40ffff]
[    0.008757]   node   0: [mem 0x0000000100000000-0x000000046dffffff]
[    0.008759] Reserved but unavailable: 97 pages
[    0.008760] Initmem setup node 0 [mem 0x0000000000001000-0x000000046dffffff]
[    0.008760] On node 0 totalpages: 4173386
[    0.008761]   DMA zone: 64 pages used for memmap
[    0.008761]   DMA zone: 27 pages reserved
[    0.008762]   DMA zone: 3998 pages, LIFO batch:0
[    0.008820]   DMA32 zone: 8955 pages used for memmap
[    0.008820]   DMA32 zone: 573100 pages, LIFO batch:63
[    0.017778]   Normal zone: 56192 pages used for memmap
[    0.017779]   Normal zone: 3596288 pages, LIFO batch:63
[    0.067681] ACPI: PM-Timer IO Port: 0x1808
[    0.067682] ACPI: Local APIC address 0xfee00000
[    0.067687] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.067687] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.067688] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.067688] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.067688] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.067689] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.067689] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.067690] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.067690] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.067690] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.067691] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.067691] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.067692] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.067692] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.067692] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.067693] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.067753] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.067754] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.067755] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.067756] ACPI: IRQ0 used by override.
[    0.067757] ACPI: IRQ9 used by override.
[    0.067758] Using ACPI (MADT) for SMP configuration information
[    0.067759] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.067763] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[    0.067774] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.067775] PM: Registered nosave memory: [mem 0x0005f000-0x0005ffff]
[    0.067776] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.067777] PM: Registered nosave memory: [mem 0x8cd2e000-0x8e599fff]
[    0.067777] PM: Registered nosave memory: [mem 0x8e717000-0x8eb18fff]
[    0.067778] PM: Registered nosave memory: [mem 0x8eb19000-0x8f320fff]
[    0.067778] PM: Registered nosave memory: [mem 0x8f321000-0x8f40efff]
[    0.067779] PM: Registered nosave memory: [mem 0x8f410000-0x8fffffff]
[    0.067779] PM: Registered nosave memory: [mem 0x90000000-0xdfffffff]
[    0.067780] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.067780] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.067781] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.067781] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.067781] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.067782] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.067782] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.067782] PM: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
[    0.067783] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.067783] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.067783] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.067785] [mem 0x90000000-0xdfffffff] available for PCI devices
[    0.067785] Booting paravirtualized kernel on bare hardware
[    0.067787] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.142764] random: get_random_bytes called from start_kernel+0x95/0x53f with crng_init=0
[    0.142768] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[    0.142996] percpu: Embedded 46 pages/cpu @(____ptrval____) s151552 r8192 d28672 u262144
[    0.143000] pcpu-alloc: s151552 r8192 d28672 u262144 alloc=1*2097152
[    0.143001] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.143017] Built 1 zonelists, mobility grouping on.  Total pages: 4108148
[    0.143017] Policy zone: Normal
[    0.143018] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=94d47185-81f8-448d-ab84-49182dbb19a2 rw quiet
[    0.145615] Calgary: detecting Calgary via BIOS EBDA area
[    0.145617] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.167912] Memory: 16286656K/16693544K available (12300K kernel code, 1383K rwdata, 3692K rodata, 1540K init, 3796K bss, 406888K reserved, 0K cma-reserved)
[    0.167986] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.167990] ftrace: allocating 36097 entries in 142 pages
[    0.177690] rcu: Preemptible hierarchical RCU implementation.
[    0.177690] rcu: 	CONFIG_RCU_FANOUT set to non-default value of 32.
[    0.177691] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.177691] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[    0.177692] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.177692] 	Tasks RCU enabled.
[    0.177693] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[    0.178854] NR_IRQS: 20736, nr_irqs: 2184, preallocated irqs: 16
[    0.179102] rcu: 	Offload RCU callbacks from CPUs: (none).
[    0.179350] Console: colour dummy device 80x25
[    0.179353] console [tty0] enabled
[    0.179364] ACPI: Core revision 20180810
[    0.179746] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.179816] hpet clockevent registered
[    0.179888] APIC: Switch to symmetric I/O mode setup
[    0.179889] DMAR: Host address width 39
[    0.179890] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.179893] DMAR: dmar0: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.179894] DMAR: RMRR base: 0x0000008edc4000 end: 0x0000008f00dfff
[    0.179895] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 0
[    0.179896] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.179896] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.182853] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.182854] x2apic enabled
[    0.182886] Switched APIC routing to cluster x2apic.
[    0.192426] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.206506] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x33e452fbb2f, max_idle_ns: 440795236593 ns
[    0.206513] Calibrating delay loop (skipped), value calculated using timer frequency.. 7202.00 BogoMIPS (lpj=12000000)
[    0.206515] pid_max: default: 32768 minimum: 301
[    0.207515] Security Framework initialized
[    0.207515] Yama: becoming mindful.
[    0.207519] AppArmor: AppArmor disabled by boot time parameter
[    0.208762] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.209522] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.209549] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.209569] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.209710] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.209711] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.209714] mce: CPU supports 14 MCE banks
[    0.209721] CPU0: Thermal monitoring enabled (TM1)
[    0.209741] process: using mwait in idle threads
[    0.209743] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.209743] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.209744] Spectre V2 : Mitigation: Full generic retpoline
[    0.209745] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.209745] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.209749] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.209750] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.209750] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.209921] Freeing SMP alternatives memory: 28K
[    0.211343] TSC deadline timer enabled
[    0.211354] smpboot: CPU0: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz (family: 0x6, model: 0x9e, stepping: 0xc)
[    0.229861] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.229933] ... version:                4
[    0.229933] ... bit width:              48
[    0.229934] ... generic registers:      4
[    0.229934] ... value mask:             0000ffffffffffff
[    0.229935] ... max period:             00007fffffffffff
[    0.229935] ... fixed-purpose events:   3
[    0.229935] ... event mask:             000000070000000f
[    0.236516] rcu: Hierarchical SRCU implementation.
[    0.260057] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.266531] smp: Bringing up secondary CPUs ...
[    0.306538] x86: Booting SMP configuration:
[    0.306541] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
[    0.867228] smp: Brought up 1 node, 16 CPUs
[    0.867228] smpboot: Max logical packages: 1
[    0.867228] smpboot: Total of 16 processors activated (115246.00 BogoMIPS)
[    0.870149] devtmpfs: initialized
[    0.870149] x86/mm: Memory block size: 128MB
[    0.870591] PM: Registering ACPI NVS region [mem 0x8e717000-0x8eb18fff] (4202496 bytes)
[    0.870591] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.870591] futex hash table entries: 4096 (order: 6, 262144 bytes)
[    0.870591] pinctrl core: initialized pinctrl subsystem
[    0.870591] RTC time: 20:56:25, date: 02/20/19
[    0.870591] NET: Registered protocol family 16
[    0.870591] audit: initializing netlink subsys (disabled)
[    0.870591] audit: type=2000 audit(1550696185.693:1): state=initialized audit_enabled=0 res=1
[    0.876530] cpuidle: using governor ladder
[    0.876560] cpuidle: using governor menu
[    0.876560] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.876560] ACPI: bus type PCI registered
[    0.876560] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.876594] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.876595] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.876603] PCI: Using configuration type 1 for base access
[    0.877419] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.877419] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.877419] ACPI: Added _OSI(Module Device)
[    0.877419] ACPI: Added _OSI(Processor Device)
[    0.877419] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.877419] ACPI: Added _OSI(Processor Aggregator Device)
[    0.877419] ACPI: Added _OSI(Linux-Dell-Video)
[    0.877419] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.925458] ACPI: 9 ACPI AML tables successfully acquired and loaded
[    0.936164] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.937552] ACPI: Dynamic OEM Table Load:
[    0.937556] ACPI: SSDT 0xFFFF8B67AA8A6000 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
[    0.938000] ACPI: Dynamic OEM Table Load:
[    0.938004] ACPI: SSDT 0xFFFF8B67AB0F4000 000777 (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
[    0.938539] ACPI: Dynamic OEM Table Load:
[    0.938542] ACPI: SSDT 0xFFFF8B67AA92D600 00011B (v02 PmRef  Cpu0Hwp  00003000 INTL 20160527)
[    0.938889] ACPI: Dynamic OEM Table Load:
[    0.938892] ACPI: SSDT 0xFFFF8B67AB0F3000 000724 (v02 PmRef  HwpLvt   00003000 INTL 20160527)
[    0.939571] ACPI: Dynamic OEM Table Load:
[    0.939576] ACPI: SSDT 0xFFFF8B67AA931000 000EF1 (v02 PmRef  ApIst    00003000 INTL 20160527)
[    0.940614] ACPI: Dynamic OEM Table Load:
[    0.940617] ACPI: SSDT 0xFFFF8B67AA8A6C00 000317 (v02 PmRef  ApHwp    00003000 INTL 20160527)
[    0.941033] ACPI: Dynamic OEM Table Load:
[    0.941036] ACPI: SSDT 0xFFFF8B67AA8A2000 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
[    0.947057] ACPI: Interpreter enabled
[    0.947088] ACPI: (supports S0 S3 S4 S5)
[    0.947089] ACPI: Using IOAPIC for interrupt routing
[    0.947186] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.948282] ACPI: Enabled 8 GPEs in block 00 to 7F
[    0.954329] ACPI: Power Resource [WRST] (on)
[    0.954577] ACPI: Power Resource [DRST] (on)
[    0.960962] ACPI: Power Resource [USBC] (on)
[    0.963843] ACPI: Power Resource [V0PR] (on)
[    0.964209] ACPI: Power Resource [V1PR] (on)
[    0.964569] ACPI: Power Resource [V2PR] (on)
[    0.973595] ACPI: Power Resource [WRST] (on)
[    0.978738] ACPI: Power Resource [PIN] (off)
[    0.979193] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.979197] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.979368] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[    0.979530] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR]
[    0.979531] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.980451] PCI host bridge to bus 0000:00
[    0.980452] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.980454] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.980455] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.980455] pci_bus 0000:00: root bus resource [mem 0x90000000-0xdfffffff window]
[    0.980456] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.980457] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.980463] pci 0000:00:00.0: [8086:3e30] type 00 class 0x060000
[    0.980792] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    0.980825] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.981206] pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    0.981238] pci 0000:00:12.0: reg 0x10: [mem 0xa443d000-0xa443dfff 64bit]
[    0.981502] pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    0.981535] pci 0000:00:14.0: reg 0x10: [mem 0xa4420000-0xa442ffff 64bit]
[    0.981637] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.982009] pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    0.982036] pci 0000:00:14.2: reg 0x10: [mem 0xa4436000-0xa4437fff 64bit]
[    0.982050] pci 0000:00:14.2: reg 0x18: [mem 0xa443c000-0xa443cfff 64bit]
[    0.982246] pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    0.982277] pci 0000:00:16.0: reg 0x10: [mem 0xa443b000-0xa443bfff 64bit]
[    0.982364] pci 0000:00:16.0: PME# supported from D3hot
[    0.982611] pci 0000:00:17.0: [8086:a352] type 00 class 0x010601
[    0.982638] pci 0000:00:17.0: reg 0x10: [mem 0xa4434000-0xa4435fff]
[    0.982649] pci 0000:00:17.0: reg 0x14: [mem 0xa443a000-0xa443a0ff]
[    0.982660] pci 0000:00:17.0: reg 0x18: [io  0x5050-0x5057]
[    0.982671] pci 0000:00:17.0: reg 0x1c: [io  0x5040-0x5043]
[    0.982682] pci 0000:00:17.0: reg 0x20: [io  0x5020-0x503f]
[    0.982693] pci 0000:00:17.0: reg 0x24: [mem 0xa4439000-0xa44397ff]
[    0.982755] pci 0000:00:17.0: PME# supported from D3hot
[    0.982981] pci 0000:00:1c.0: [8086:a33d] type 01 class 0x060400
[    0.983122] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.983150] pci 0000:00:1c.0: PTM enabled (root), 4dns granularity
[    0.983380] pci 0000:00:1c.6: [8086:a33e] type 01 class 0x060400
[    0.983518] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[    0.983546] pci 0000:00:1c.6: PTM enabled (root), 4dns granularity
[    0.983740] pci 0000:00:1f.0: [8086:a305] type 00 class 0x060100
[    0.984137] pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[    0.984210] pci 0000:00:1f.3: reg 0x10: [mem 0xa4430000-0xa4433fff 64bit]
[    0.984303] pci 0000:00:1f.3: reg 0x20: [mem 0xa4100000-0xa41fffff 64bit]
[    0.984440] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.985089] pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    0.985166] pci 0000:00:1f.4: reg 0x10: [mem 0xa4438000-0xa44380ff 64bit]
[    0.985250] pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
[    0.985475] pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    0.985495] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    0.985678] pci 0000:00:1f.6: [8086:15bc] type 00 class 0x020000
[    0.985735] pci 0000:00:1f.6: reg 0x10: [mem 0xa4400000-0xa441ffff]
[    0.985972] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    0.986122] pci 0000:01:00.0: [10de:1e07] type 00 class 0x030000
[    0.986140] pci 0000:01:00.0: reg 0x10: [mem 0xa3000000-0xa3ffffff]
[    0.986148] pci 0000:01:00.0: reg 0x14: [mem 0x90000000-0x9fffffff 64bit pref]
[    0.986157] pci 0000:01:00.0: reg 0x1c: [mem 0xa0000000-0xa1ffffff 64bit pref]
[    0.986163] pci 0000:01:00.0: reg 0x24: [io  0x4000-0x407f]
[    0.986168] pci 0000:01:00.0: reg 0x30: [mem 0xa4000000-0xa407ffff pref]
[    0.986182] pci 0000:01:00.0: BAR 3: assigned to efifb
[    0.986215] pci 0000:01:00.0: PME# supported from D0 D3hot
[    0.986243] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8 GT/s x16 link)
[    0.986274] pci 0000:01:00.1: [10de:10f7] type 00 class 0x040300
[    0.986286] pci 0000:01:00.1: reg 0x10: [mem 0xa4080000-0xa4083fff]
[    0.986385] pci 0000:01:00.2: [10de:1ad6] type 00 class 0x0c0330
[    0.986400] pci 0000:01:00.2: reg 0x10: [mem 0xa2000000-0xa203ffff 64bit pref]
[    0.986414] pci 0000:01:00.2: reg 0x1c: [mem 0xa2040000-0xa204ffff 64bit pref]
[    0.986458] pci 0000:01:00.2: PME# supported from D0 D3hot
[    0.986496] pci 0000:01:00.3: [10de:1ad7] type 00 class 0x0c8000
[    0.986509] pci 0000:01:00.3: reg 0x10: [mem 0xa4084000-0xa4084fff]
[    0.986575] pci 0000:01:00.3: PME# supported from D0 D3hot
[    0.986636] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.986638] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    0.986639] pci 0000:00:01.0:   bridge window [mem 0xa3000000-0xa40fffff]
[    0.986642] pci 0000:00:01.0:   bridge window [mem 0x90000000-0xa20fffff 64bit pref]
[    0.986752] pci 0000:02:00.0: [8086:1539] type 00 class 0x020000
[    0.986790] pci 0000:02:00.0: reg 0x10: [mem 0xa4300000-0xa431ffff]
[    0.986816] pci 0000:02:00.0: reg 0x18: [io  0x3000-0x301f]
[    0.986830] pci 0000:02:00.0: reg 0x1c: [mem 0xa4320000-0xa4323fff]
[    0.986965] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.987078] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.987082] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[    0.987085] pci 0000:00:1c.0:   bridge window [mem 0xa4300000-0xa43fffff]
[    0.987205] pci 0000:03:00.0: [8086:24fb] type 00 class 0x028000
[    0.987271] pci 0000:03:00.0: reg 0x10: [mem 0xa4200000-0xa4201fff 64bit]
[    0.987506] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[    0.987714] pci 0000:00:1c.6: PCI bridge to [bus 03]
[    0.987721] pci 0000:00:1c.6:   bridge window [mem 0xa4200000-0xa42fffff]
[    0.989306] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.989380] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[    0.989451] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.989522] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.989594] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.989665] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.989736] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.989807] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.993180] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.993181] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.993183] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.993183] vgaarb: loaded
[    0.993263] ACPI: bus type USB registered
[    0.993272] usbcore: registered new interface driver usbfs
[    0.993276] usbcore: registered new interface driver hub
[    0.993298] usbcore: registered new device driver usb
[    0.993310] pps_core: LinuxPPS API ver. 1 registered
[    0.993311] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.993313] PTP clock support registered
[    0.993317] EDAC MC: Ver: 3.0.0
[    0.993407] Registered efivars operations
[    1.013394] PCI: Using ACPI for IRQ routing
[    1.093942] PCI: pci_cache_line_size set to 64 bytes
[    1.094025] e820: reserve RAM buffer [mem 0x0005f000-0x0005ffff]
[    1.094025] e820: reserve RAM buffer [mem 0x8cd2e000-0x8fffffff]
[    1.094026] e820: reserve RAM buffer [mem 0x8e717000-0x8fffffff]
[    1.094027] e820: reserve RAM buffer [mem 0x8f410000-0x8fffffff]
[    1.094028] e820: reserve RAM buffer [mem 0x46e000000-0x46fffffff]
[    1.094083] NetLabel: Initializing
[    1.094083] NetLabel:  domain hash size = 128
[    1.094084] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.094092] NetLabel:  unlabeled traffic allowed by default
[    1.096844] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    1.096848] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    1.099851] clocksource: Switched to clocksource tsc-early
[    1.106112] VFS: Disk quotas dquot_6.6.0
[    1.106122] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.106157] pnp: PnP ACPI init
[    1.106416] system 00:00: [io  0x0280-0x028f] has been reserved
[    1.106417] system 00:00: [io  0x0290-0x029f] has been reserved
[    1.106418] system 00:00: [io  0x02a0-0x02af] has been reserved
[    1.106419] system 00:00: [io  0x02b0-0x02bf] has been reserved
[    1.106422] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.106550] system 00:01: [io  0x0680-0x069f] has been reserved
[    1.106551] system 00:01: [io  0x164e-0x164f] has been reserved
[    1.106553] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.106566] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    1.106646] system 00:03: [io  0x1854-0x1857] has been reserved
[    1.106648] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    1.106807] system 00:04: [mem 0xfed10000-0xfed17fff] has been reserved
[    1.106809] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
[    1.106810] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
[    1.106811] system 00:04: [mem 0xe0000000-0xefffffff] has been reserved
[    1.106812] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
[    1.106813] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
[    1.106814] system 00:04: [mem 0xfed45000-0xfed8ffff] has been reserved
[    1.106815] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[    1.106817] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.107009] system 00:05: [io  0x1800-0x18fe] could not be reserved
[    1.107011] system 00:05: [mem 0xfd000000-0xfd69ffff] has been reserved
[    1.107012] system 00:05: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[    1.107013] system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    1.107014] system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    1.107015] system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
[    1.107016] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[    1.107018] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.107276] system 00:06: [io  0x2000-0x20fe] has been reserved
[    1.107279] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.107511] system 00:07: [mem 0xfd6e0000-0xfd6effff] has been reserved
[    1.107512] system 00:07: [mem 0xfd6d0000-0xfd6dffff] has been reserved
[    1.107513] system 00:07: [mem 0xfd6b0000-0xfd6bffff] has been reserved
[    1.107514] system 00:07: [mem 0xfd6a0000-0xfd6affff] has been reserved
[    1.107516] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.108391] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.109165] pnp: PnP ACPI: found 9 devices
[    1.114457] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    1.114487] pci 0000:00:01.0: PCI bridge to [bus 01]
[    1.114488] pci 0000:00:01.0:   bridge window [io  0x4000-0x4fff]
[    1.114490] pci 0000:00:01.0:   bridge window [mem 0xa3000000-0xa40fffff]
[    1.114492] pci 0000:00:01.0:   bridge window [mem 0x90000000-0xa20fffff 64bit pref]
[    1.114494] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    1.114501] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[    1.114506] pci 0000:00:1c.0:   bridge window [mem 0xa4300000-0xa43fffff]
[    1.114515] pci 0000:00:1c.6: PCI bridge to [bus 03]
[    1.114520] pci 0000:00:1c.6:   bridge window [mem 0xa4200000-0xa42fffff]
[    1.114530] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    1.114531] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    1.114532] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    1.114533] pci_bus 0000:00: resource 7 [mem 0x90000000-0xdfffffff window]
[    1.114534] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[    1.114535] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    1.114536] pci_bus 0000:01: resource 1 [mem 0xa3000000-0xa40fffff]
[    1.114537] pci_bus 0000:01: resource 2 [mem 0x90000000-0xa20fffff 64bit pref]
[    1.114538] pci_bus 0000:02: resource 0 [io  0x3000-0x3fff]
[    1.114538] pci_bus 0000:02: resource 1 [mem 0xa4300000-0xa43fffff]
[    1.114539] pci_bus 0000:03: resource 1 [mem 0xa4200000-0xa42fffff]
[    1.114674] NET: Registered protocol family 2
[    1.114758] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes)
[    1.114792] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    1.114893] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    1.114955] TCP: Hash tables configured (established 131072 bind 65536)
[    1.114979] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[    1.115005] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[    1.115050] NET: Registered protocol family 1
[    1.115053] NET: Registered protocol family 44
[    1.133988] pci 0000:00:14.0: quirk_usb_early_handoff+0x0/0x6c6 took 18481 usecs
[    1.134037] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    1.134045] pci 0000:01:00.1: Linked as a consumer to 0000:01:00.0
[    1.134260] PCI: CLS 64 bytes, default 64
[    1.134279] Unpacking initramfs...
[    1.219840] Freeing initrd memory: 10476K
[    1.219875] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.219877] software IO TLB: mapped [mem 0x848c7000-0x888c7000] (64MB)
[    1.219892] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x33e452fbb2f, max_idle_ns: 440795236593 ns
[    1.219908] clocksource: Switched to clocksource tsc
[    1.220057] Scanning for low memory corruption every 60 seconds
[    1.220487] Initialise system trusted keyrings
[    1.220493] Key type blacklist registered
[    1.220523] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    1.221219] zbud: loaded
[    1.221416] pstore: using zstd compression
[    1.222108] Key type asymmetric registered
[    1.222109] Asymmetric key parser 'x509' registered
[    1.222113] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    1.222141] io scheduler noop registered
[    1.222142] io scheduler deadline registered
[    1.222157] io scheduler cfq registered
[    1.222158] io scheduler mq-deadline registered
[    1.222158] io scheduler kyber registered
[    1.222171] io scheduler bfq registered
[    1.222183] io scheduler bfq-sq registered (default)
[    1.222183] BFQ I/O-scheduler: v9 (with cgroups support)
[    1.222196] io scheduler bfq-mq registered
[    1.222197] BFQ I/O-scheduler: v9 (with cgroups support)
[    1.222710] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.222750] efifb: probing for efifb
[    1.222758] efifb: showing boot graphics
[    1.225512] efifb: framebuffer at 0xa1000000, using 8128k, total 8128k
[    1.225513] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    1.225513] efifb: scrolling: redraw
[    1.225514] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.225542] fbcon: Deferring console take-over
[    1.225543] fb0: EFI VGA frame buffer device
[    1.225549] intel_idle: MWAIT substates: 0x11142120
[    1.225550] intel_idle: v0.4.1 model 0x9E
[    1.226051] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.226108] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    1.226113] ACPI: Sleep Button [SLPB]
[    1.226132] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    1.226136] ACPI: Power Button [PWRB]
[    1.226155] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    1.226161] ACPI: Power Button [PWRF]
[    1.227997] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.229278] usbcore: registered new interface driver usbserial_generic
[    1.229281] usbserial: USB Serial support registered for generic
[    1.229301] rtc_cmos 00:02: RTC can wake from S4
[    1.230304] rtc_cmos 00:02: registered as rtc0
[    1.230312] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    1.230338] intel_pstate: Intel P-state driver initializing
[    1.231217] intel_pstate: HWP enabled
[    1.231451] ledtrig-cpu: registered to indicate activity on CPUs
[    1.231474] intel_pmc_core:  initialized
[    1.231597] NET: Registered protocol family 10
[    1.234435] Segment Routing with IPv6
[    1.234446] NET: Registered protocol family 17
[    1.235437] RAS: Correctable Errors collector initialized.
[    1.235455] microcode: sig=0x906ec, pf=0x2, revision=0x98
[    1.235892] microcode: Microcode Update Driver: v2.2.
[    1.235898] sched_clock: Marking stable (1238714199, -2823804)->(1251267407, -15377012)
[    1.236360] registered taskstats version 1
[    1.236363] Loading compiled-in X.509 certificates
[    1.237901] Loaded X.509 cert 'Build time autogenerated kernel key: 5273b8ae8bf6a2d073a6c9592ae30312cd425105'
[    1.237916] zswap: loaded using pool lzo/zbud
[    1.240253] Key type big_key registered
[    1.241571]   Magic number: 7:491:953
[    1.241603] processor cpu8: hash matches
[    1.241614] memory memory6: hash matches
[    1.241853] rtc_cmos 00:02: setting system clock to 2019-02-20 20:56:26 UTC (1550696186)
[    1.242783] Freeing unused decrypted memory: 2040K
[    1.243305] Freeing unused kernel image memory: 1540K
[    1.243306] Write protecting the kernel read-only data: 18432k
[    1.243822] Freeing unused kernel image memory: 2008K
[    1.243915] Freeing unused kernel image memory: 404K
[    1.248545] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.248548] Run /init as init process
[    1.337916] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.337919] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.338065] SCSI subsystem initialized
[    1.338990] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    1.338995] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.339129] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.339129] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.339130] usb usb1: Product: xHCI Host Controller
[    1.339131] usb usb1: Manufacturer: Linux 4.19.23-1-MANJARO xhci-hcd
[    1.339131] usb usb1: SerialNumber: 0000:00:14.0
[    1.339187] hub 1-0:1.0: USB hub found
[    1.339202] hub 1-0:1.0: 16 ports detected
[    1.340435] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.340437] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.340438] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    1.340460] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.340461] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.340461] usb usb2: Product: xHCI Host Controller
[    1.340462] usb usb2: Manufacturer: Linux 4.19.23-1-MANJARO xhci-hcd
[    1.340463] usb usb2: SerialNumber: 0000:00:14.0
[    1.340504] hub 2-0:1.0: USB hub found
[    1.340516] hub 2-0:1.0: 10 ports detected
[    1.341183] usb: port power management may be unreliable
[    1.341326] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.341328] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[    1.341920] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[    1.341996] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.341997] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.341998] usb usb3: Product: xHCI Host Controller
[    1.341998] usb usb3: Manufacturer: Linux 4.19.23-1-MANJARO xhci-hcd
[    1.341999] usb usb3: SerialNumber: 0000:01:00.2
[    1.342014] libata version 3.00 loaded.
[    1.342051] hub 3-0:1.0: USB hub found
[    1.342055] hub 3-0:1.0: 2 ports detected
[    1.342111] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    1.342113] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[    1.342114] xhci_hcd 0000:01:00.2: Host supports USB 3.10 Enhanced SuperSpeed
[    1.342129] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.342139] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.342140] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.342141] usb usb4: Product: xHCI Host Controller
[    1.342141] usb usb4: Manufacturer: Linux 4.19.23-1-MANJARO xhci-hcd
[    1.342142] usb usb4: SerialNumber: 0000:01:00.2
[    1.342177] hub 4-0:1.0: USB hub found
[    1.342182] hub 4-0:1.0: 4 ports detected
[    1.343615] ahci 0000:00:17.0: version 3.0
[    1.353948] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[    1.353949] ahci 0000:00:17.0: flags: 64bit ncq sntf clo only pio slum part ems deso sadm sds apst
[    1.405384] scsi host0: ahci
[    1.405985] scsi host1: ahci
[    1.406472] scsi host2: ahci
[    1.407015] scsi host3: ahci
[    1.407519] scsi host4: ahci
[    1.407946] scsi host5: ahci
[    1.408128] ata1: SATA max UDMA/133 abar m2048@0xa4439000 port 0xa4439100 irq 123
[    1.408133] ata2: SATA max UDMA/133 abar m2048@0xa4439000 port 0xa4439180 irq 123
[    1.408137] ata3: SATA max UDMA/133 abar m2048@0xa4439000 port 0xa4439200 irq 123
[    1.408141] ata4: SATA max UDMA/133 abar m2048@0xa4439000 port 0xa4439280 irq 123
[    1.408146] ata5: SATA max UDMA/133 abar m2048@0xa4439000 port 0xa4439300 irq 123
[    1.408150] ata6: SATA max UDMA/133 abar m2048@0xa4439000 port 0xa4439380 irq 123
[    1.669931] usb 1-9: new full-speed USB device number 2 using xhci_hcd
[    1.720445] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.720484] ata1: SATA link down (SStatus 4 SControl 300)
[    1.720524] ata5: SATA link down (SStatus 4 SControl 300)
[    1.720568] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.720604] ata3: SATA link down (SStatus 4 SControl 300)
[    1.722445] ata4.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.722454] ata4.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.722460] ata4.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.724184] ata6: SATA link down (SStatus 4 SControl 300)
[    1.724258] ata4.00: supports DRM functions and may not be fully accessible
[    1.725481] ata4.00: ATA-11: Samsung SSD 860 EVO 1TB, RVT01B6Q, max UDMA/133
[    1.725487] ata4.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    1.729704] ata4.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.729712] ata4.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.729718] ata4.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.730088] ata4.00: supports DRM functions and may not be fully accessible
[    1.733254] ata4.00: configured for UDMA/133
[    1.733277] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.733285] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.733291] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.770833] ata2.00: ATA-10: ST4000DM004-2CV104, 0001, max UDMA/133
[    1.770839] ata2.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.806050] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    1.806058] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    1.806064] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    1.813574] usb 1-9: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.07
[    1.813579] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.813583] usb 1-9: Product: USB Receiver
[    1.813587] usb 1-9: Manufacturer: Logitech
[    1.823233] hidraw: raw HID events driver (C) Jiri Kosina
[    1.831814] usbcore: registered new interface driver usbhid
[    1.831814] usbhid: USB HID core driver
[    1.833460] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-9/input2
[    1.843577] ata2.00: configured for UDMA/133
[    1.843680] scsi 1:0:0:0: Direct-Access     ATA      ST4000DM004-2CV1 0001 PQ: 0 ANSI: 5
[    1.843912] scsi 3:0:0:0: Direct-Access     ATA      Samsung SSD 860  1B6Q PQ: 0 ANSI: 5
[    1.848344] sd 1:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[    1.848345] sd 1:0:0:0: [sda] 4096-byte physical blocks
[    1.848348] sd 1:0:0:0: [sda] Write Protect is off
[    1.848349] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.848353] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.848361] ata4.00: Enabling discard_zeroes_data
[    1.848374] sd 3:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    1.848378] sd 3:0:0:0: [sdb] Write Protect is off
[    1.848379] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    1.848383] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.848442] ata4.00: Enabling discard_zeroes_data
[    1.850148]  sdb: sdb1 sdb2 sdb3 sdb4 sdb5
[    1.850411] ata4.00: Enabling discard_zeroes_data
[    1.851491] sd 3:0:0:0: [sdb] supports TCG Opal
[    1.851492] sd 3:0:0:0: [sdb] Attached SCSI disk
[    1.913121]  sda: sda1 sda2
[    1.914119] sd 1:0:0:0: [sda] Attached SCSI disk
[    1.939849] usb 1-11: new high-speed USB device number 3 using xhci_hcd
[    1.948523] random: fast init done
[    1.948592] input: Logitech Unifying Device. Wireless PID:4069 Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:046D:C52B.0003/0003:046D:4069.0004/input/input3
[    1.948608] input: Logitech Unifying Device. Wireless PID:4069 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:046D:C52B.0003/0003:046D:4069.0004/input/input4
[    1.948629] input: Logitech Unifying Device. Wireless PID:4069 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:046D:C52B.0003/0003:046D:4069.0004/input/input5
[    1.948641] input: Logitech Unifying Device. Wireless PID:4069 System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:046D:C52B.0003/0003:046D:4069.0004/input/input6
[    1.948688] hid-generic 0003:046D:4069.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4069] on usb-0000:00:14.0-9:1
[    2.050936] input: Logitech MX Master 2S as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.2/0003:046D:C52B.0003/0003:046D:4069.0004/input/input10
[    2.051111] logitech-hidpp-device 0003:046D:4069.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Master 2S] on usb-0000:00:14.0-9:1
[    2.081376] usb 1-11: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[    2.081382] usb 1-11: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.081386] usb 1-11: Product: USB2.0 Hub
[    2.082904] hub 1-11:1.0: USB hub found
[    2.083310] hub 1-11:1.0: 4 ports detected
[    2.206585] usb 1-12: new high-speed USB device number 4 using xhci_hcd
[    2.336263] random: crng init done
[    2.347837] usb 1-12: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[    2.347839] usb 1-12: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.347840] usb 1-12: Product: USB2.0 Hub
[    2.348737] hub 1-12:1.0: USB hub found
[    2.349022] hub 1-12:1.0: 4 ports detected
[    2.419879] usb 1-11.2: new full-speed USB device number 5 using xhci_hcd
[    2.511612] usb 1-11.2: New USB device found, idVendor=1e71, idProduct=170e, bcdDevice= 2.00
[    2.511613] usb 1-11.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.511614] usb 1-11.2: Product: NZXT USB Device
[    2.511616] usb 1-11.2: Manufacturer: NZXT.-Inc.
[    2.511617] usb 1-11.2: SerialNumber: 496D5754353
[    2.517684] hid-generic 0003:1E71:170E.0005: hiddev1,hidraw2: USB HID v1.10 Device [NZXT.-Inc. NZXT USB Device] on usb-0000:00:14.0-11.2/input0
[    2.633211] usb 1-14: new full-speed USB device number 6 using xhci_hcd
[    2.774455] usb 1-14: New USB device found, idVendor=8087, idProduct=0aa7, bcdDevice= 0.01
[    2.774456] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.798555] EXT4-fs (sdb5): 118 orphan inodes deleted
[    2.798556] EXT4-fs (sdb5): recovery complete
[    2.805037] EXT4-fs (sdb5): mounted filesystem with ordered data mode. Opts: (null)
[    2.846651] usb 1-11.3: new full-speed USB device number 7 using xhci_hcd
[    2.938513] usb 1-11.3: New USB device found, idVendor=1e71, idProduct=1714, bcdDevice= 2.00
[    2.938516] usb 1-11.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.938518] usb 1-11.3: Product: NZXT USB Device
[    2.938520] usb 1-11.3: Manufacturer: NZXT.-Inc.
[    2.938522] usb 1-11.3: SerialNumber: 499046493332
[    2.941024] systemd[1]: systemd 241.159-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    2.945073] hid-generic 0003:1E71:1714.0006: hiddev2,hidraw3: USB HID v1.10 Device [NZXT.-Inc. NZXT USB Device] on usb-0000:00:14.0-11.3/input0
[    2.956684] systemd[1]: Detected architecture x86-64.
[    2.960768] systemd[1]: Set hostname to <mohammed-pc>.
[    3.009887] usb 1-12.2: new full-speed USB device number 8 using xhci_hcd
[    3.026080] systemd[1]: Listening on LVM2 poll daemon socket.
[    3.026105] systemd[1]: Reached target Remote File Systems.
[    3.027305] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.027325] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    3.027331] systemd[1]: Reached target Swap.
[    3.027348] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.027351] systemd[1]: Reached target Login Prompts.
[    3.034277] EXT4-fs (sdb5): re-mounted. Opts: discard
[    3.038731] version 39.2
[    3.040301] ipmi device interface
[    3.042817] audit: type=1130 audit(1550696188.296:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.043583] audit: type=1130 audit(1550696188.299:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.047098] audit: type=1130 audit(1550696188.303:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.057542] audit: type=1130 audit(1550696188.313:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.060668] audit: type=1130 audit(1550696188.316:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.064923] systemd-journald[345]: Received request to flush runtime journal from PID 1
[    3.067147] audit: type=1130 audit(1550696188.323:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.071172] audit: type=1130 audit(1550696188.326:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.102807] usb 1-12.2: New USB device found, idVendor=7793, idProduct=2500, bcdDevice= 1.00
[    3.102808] usb 1-12.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.102809] usb 1-12.2: Product: Usb2I2C HID Device
[    3.102810] usb 1-12.2: Manufacturer: SeaSonic.
[    3.108793] hid-generic 0003:7793:2500.0007: hiddev3,hidraw4: USB HID v1.11 Device [SeaSonic. Usb2I2C HID Device] on usb-0000:00:14.0-12.2/input0
[    3.123879] nvidia: loading out-of-tree module taints kernel.
[    3.126346] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    3.132542] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[    3.132734] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[    3.142704] audit: type=1130 audit(1550696188.396:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.149514] audit: type=1130 audit(1550696188.403:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.181163] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[    3.184262] input: PC Speaker as /devices/platform/pcspkr/input/input11
[    3.188492] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    3.188837] dca service started, version 1.12.1
[    3.192814] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[    3.192815] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    3.192816] RAPL PMU: hw unit of domain package 2^-14 Joules
[    3.192816] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    3.192817] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    3.192821] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    3.201572] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    3.201582] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    3.201583] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.201839] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    3.232924] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  415.27  Thu Dec 20 17:25:03 CST 2018 (using threaded interrupts)
[    3.297375] iTCO_vendor_support: vendor-support=0
[    3.301226] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    3.301227] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.307283] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    3.307377] iTCO_wdt iTCO_wdt: can't request region for resource [mem 0x00c5fffc-0x00c5ffff]
[    3.307380] iTCO_wdt: probe of iTCO_wdt failed with error -16
[    3.308400] cryptd: max_cpu_qlen set to 1000
[    3.309846] mousedev: PS/2 mouse device common for all mice
[    3.309886] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.315716] Linux agpgart interface v0.103
[    3.318948] AVX2 version of gcm_enc/dec engaged.
[    3.318949] AES CTR mode by8 optimization enabled
[    3.319890] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.328958] Bluetooth: Core ver 2.22
[    3.328969] NET: Registered protocol family 31
[    3.328969] Bluetooth: HCI device and connection manager initialized
[    3.328972] Bluetooth: HCI socket layer initialized
[    3.328973] Bluetooth: L2CAP socket layer initialized
[    3.328977] Bluetooth: SCO socket layer initialized
[    3.329832] pps pps0: new PPS source ptp0
[    3.329834] igb 0000:02:00.0: added PHC on eth0
[    3.329834] igb 0000:02:00.0: Intel(R) Gigabit Ethernet Network Connection
[    3.329835] igb 0000:02:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 70:85:c2:a4:f4:8a
[    3.329836] igb 0000:02:00.0: eth0: PBA No: FFFFFF-0FF
[    3.329837] igb 0000:02:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[    3.331626] igb 0000:02:00.0 enp2s0: renamed from eth0
[    3.336476] snd_hda_intel 0000:01:00.1: Disabling MSI
[    3.336478] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    3.337031] Intel(R) Wireless WiFi driver for Linux
[    3.337032] Copyright(c) 2003- 2015 Intel Corporation
[    3.337077] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[    3.340803] iwlwifi 0000:03:00.0: loaded firmware version 29.1044073957.0 op_mode iwlmvm
[    3.344380] usbcore: registered new interface driver btusb
[    3.356008] nvidia_modeset: module license 'NVIDIA' taints kernel.
[    3.356009] Disabling lock debugging due to kernel taint
[    3.358886] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[    3.358887] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.358889] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    3.358890] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    3.358890] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    3.358892] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    3.358893] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    3.358894] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    3.359868] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  415.27  Thu Dec 20 17:06:08 CST 2018
[    3.361352] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    3.361353] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[    3.362845] fbcon: Taking over console
[    3.364425] Console: switching to colour frame buffer device 240x67
[    3.368434] Bluetooth: hci0: read Intel version: 370810225019140f34
[    3.368435] Bluetooth: hci0: Intel device is already patched. patch num: 34
[    3.378609] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[    3.393286] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[    3.393331] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[    3.393371] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[    3.393409] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[    3.412505] intel_rapl: Found RAPL domain package
[    3.412506] intel_rapl: Found RAPL domain core
[    3.412507] intel_rapl: Found RAPL domain dram
[    3.412525] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
[    3.423836] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[    3.430497] iwlwifi 0000:03:00.0: base HW address: 3c:6a:a7:36:92:87
[    3.462128] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    3.462446] thermal thermal_zone2: failed to read out thermal zone (-61)
[    3.463134] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[    3.511307] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 70:85:c2:a4:f4:8c
[    3.511308] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[    3.511400] e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
[    3.512142] e1000e 0000:00:1f.6 eno1: renamed from eth0
[    3.598096] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.598097] Bluetooth: BNEP filters: protocol multicast
[    3.598099] Bluetooth: BNEP socket layer initialized
[    3.817214] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[    3.967280] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[    3.967322] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[    3.967361] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[    3.967399] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
[    4.033658] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[    4.045000] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[    4.047746] ahci 0000:00:17.0: port does not support device sleep
[    4.068914] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[    4.070243] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[    4.136283] iwlwifi 0000:03:00.0: BIOS contains WGDS but no WRDS
[    4.136762] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[    4.215787] iwlwifi 0000:03:00.0: BIOS contains WGDS but no WRDS
[    4.216122] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[    4.334010] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[    6.088757] fuse init (API version 7.27)
[    6.174894] kauditd_printk_skb: 37 callbacks suppressed
[    6.174894] audit: type=1130 audit(1550696191.429:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.233743] audit: type=1130 audit(1550696191.489:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.236882] audit: type=1131 audit(1550696191.493:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.322536] audit: type=1130 audit(1550696191.576:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    7.487648] IPv6: ADDRCONF(NETDEV_UP): wlp3s0: link is not ready
[    7.505785] Bluetooth: RFCOMM TTY layer initialized
[    7.505788] Bluetooth: RFCOMM socket layer initialized
[    7.505790] Bluetooth: RFCOMM ver 1.11
[    8.467847] audit: type=1131 audit(1550696193.723:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.495147] wlp3s0: authenticate with 8c:3b:ad:f9:89:c0
[    8.499709] wlp3s0: send auth to 8c:3b:ad:f9:89:c0 (try 1/3)
[    8.500912] wlp3s0: authenticated
[    8.503219] wlp3s0: associate with 8c:3b:ad:f9:89:c0 (try 1/3)
[    8.504281] wlp3s0: RX AssocResp from 8c:3b:ad:f9:89:c0 (capab=0x1011 status=0 aid=2)
[    8.513293] wlp3s0: associated
[    8.535321] wlp3s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 8c:3b:ad:f9:89:c0
[    8.535557] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[   14.006037] audit: type=1131 audit(1550696199.259:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   30.513255] usb 1-8: new full-speed USB device number 9 using xhci_hcd
[   30.654562] usb 1-8: New USB device found, idVendor=04d9, idProduct=8008, bcdDevice= 1.00
[   30.654569] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   30.654573] usb 1-8: Product: USB-HID Keyboard
[   30.654577] usb 1-8: Manufacturer: OBINLB
[   30.654580] usb 1-8: SerialNumber: SN0000000001
[   30.659002] input: OBINLB USB-HID Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:04D9:8008.0008/input/input21
[   30.713702] hid-generic 0003:04D9:8008.0008: input,hidraw5: USB HID v1.10 Keyboard [OBINLB USB-HID Keyboard] on usb-0000:00:14.0-8/input0
[   30.714732] input: OBINLB USB-HID Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:04D9:8008.0009/input/input22
[   30.715095] hid-generic 0003:04D9:8008.0009: input,hidraw6: USB HID v1.10 Device [OBINLB USB-HID Keyboard] on usb-0000:00:14.0-8/input1
[   30.715908] input: OBINLB USB-HID Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.2/0003:04D9:8008.000A/input/input23
[   30.716181] hid-generic 0003:04D9:8008.000A: input,hidraw7: USB HID v1.10 Joystick [OBINLB USB-HID Keyboard] on usb-0000:00:14.0-8/input2
[   30.717267] input: OBINLB USB-HID Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.3/0003:04D9:8008.000B/input/input24
[   30.773615] hid-generic 0003:04D9:8008.000B: input,hidraw8: USB HID v1.10 Device [OBINLB USB-HID Keyboard] on usb-0000:00:14.0-8/input3
[   33.820420] audit: type=1131 audit(1550696219.076:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   63.418517] logitech-hidpp-device 0003:046D:4069.0004: HID++ 4.5 device connected.
[  154.528677] audit: type=1130 audit(1550696339.783:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  184.603581] audit: type=1131 audit(1550696369.859:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  195.934167] device-mapper: uevent: version 1.0.3
[  195.934257] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[  198.339803] SGI XFS with ACLs, security attributes, realtime, scrub, no debug enabled
[  198.349815] JFS: nTxBlock = 8192, nTxLock = 65536
[  198.362436] ntfs: driver 2.1.32 [Flags: R/W MODULE].
[  198.443139] raid6: sse2x1   gen() 16972 MB/s
[  198.499807] raid6: sse2x1   xor() 12539 MB/s
[  198.556462] raid6: sse2x2   gen() 21628 MB/s
[  198.613127] raid6: sse2x2   xor() 14424 MB/s
[  198.669795] raid6: sse2x4   gen() 25141 MB/s
[  198.726461] raid6: sse2x4   xor() 15289 MB/sjournalctl -p 3 -xb
-- Logs begin at Sat 2019-02-16 13:56:52 EST, end at Wed 2019-02-20 15:57:09 EST. --
Feb 20 15:56:28 mohammed-pc systemd-modules-load[339]: Failed to find module 'vboxdrv'
Feb 20 15:56:28 mohammed-pc systemd-modules-load[339]: Failed to find module 'vboxnetadp'
Feb 20 15:56:28 mohammed-pc systemd-modules-load[339]: Failed to find module 'vboxnetflt'
Feb 20 15:56:28 mohammed-pc systemd-modules-load[339]: Failed to find module 'vboxpci'
Feb 20 15:56:28 mohammed-pc systemd-udevd[358]: /etc/udev/rules.d/obinslab-starter.rules:3:
Feb 20 15:56:28 mohammed-pc systemd-udevd[358]: Specified group 'plugdev' unknown
Feb 20 15:56:28 mohammed-pc systemd-udevd[358]: /etc/udev/rules.d/obinslab-starter.rules:5:
Feb 20 15:56:28 mohammed-pc systemd-udevd[358]: /etc/udev/rules.d/obinslab-starter.rules:8:
Feb 20 15:56:28 mohammed-pc systemd-udevd[358]: /etc/udev/rules.d/obinslab-starter.rules:10:
Feb 20 15:56:28 mohammed-pc kernel: iTCO_wdt iTCO_wdt: can't request region for resource [me
Feb 20 15:56:28 mohammed-pc systemd[1]: Failed to start Load Kernel Modules.
-- Subject: A start job for unit systemd-modules-load.service has failed
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- A start job for unit systemd-modules-load.service has finished with a failure.
-- The job identifier is 43 and the job result is failed.
Feb 20 15:56:28 mohammed-pc systemd-modules-load[612]: Failed to find module 'vboxdrv'
Feb 20 15:56:28 mohammed-pc systemd-modules-load[612]: Failed to find module 'vboxnetadp'
Feb 20 15:56:28 mohammed-pc systemd-modules-load[612]: Failed to find module 'vboxnetflt'
Feb 20 15:56:28 mohammed-pc systemd-modules-load[612]: Failed to find module 'vboxpci'
-- The job identifier is 246 and the job result is failed.
Feb 20 15:56:29 mohammed-pc kernel: iwlwifi 0000:03:00.0: BIOS contains WGDS but no WRDS
[  198.783127] raid6: avx2x1   gen() 34955 MB/s
[  198.839793] raid6: avx2x1   xor() 24616 MB/s
[  198.896460] raid6: avx2x2   gen() 43181 MB/s
[  198.953127] raid6: avx2x2   xor() 27144 MB/s
[  199.009796] raid6: avx2x4   gen() 48632 MB/s
[  199.066459] raid6: avx2x4   xor() 29709 MB/s
[  199.066460] raid6: using algorithm avx2x4 gen() 48632 MB/s
[  199.066461] raid6: .... xor() 29709 MB/s, rmw enabled
[  199.066461] raid6: using avx2x2 recovery algorithm
[  199.069171] xor: automatically using best checksumming function   avx
[  199.117022] Btrfs loaded, crc32c=crc32c-intel
And here is what was requested earlier:
journalctl -p 3 -xb
Unfortunately, I do not know how to make heads nor tails of it.
I just installed 4.20. Will see if that improves the situation.
I lost a .tex file that I had been working on for the past few hours... I think I will switch to Ubuntu or Windows until I can figure out how to fix this.
error on disks in SATA-3 on raids with Btrfs
Thank you, but what do I do about that?
check also if motherboard can support
6 Sata in 6gb/s ( check also cables ) and so many Hub ( 3 Hubs with 4 ports each ) used
can you return
inxi -Fxxxz
and these errors on manual actions on rules udev and maybe blacklist ITCO_wdt
Judging by this, it should support 10Gb/s.
Yes, here is the output:
System:    Host: mohammed-pc Kernel: 4.19.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: i3 4.16.1
           info: i3bar dm: LightDM 1.28.0 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASRock model: Z390M-ITX/ac serial: <filter> UEFI: American Megatrends v: P1.10
           date: 08/17/2018
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S serial: <filter>
           charge: 100% (should be ignored) rechargeable: yes status: Discharging
CPU:       Topology: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Kaby Lake rev: C L2 cache: 16.0 MiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 115232
           Speed: 4075 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 863 2: 867 3: 808 4: 1516 5: 879 6: 808 7: 1481
           8: 1746 9: 3196 10: 963 11: 820 12: 1380 13: 1751 14: 1293 15: 1426 16: 1886
Graphics:  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti] vendor: eVga.com. driver: nvidia v: 415.27 bus ID: 01:00.0
           chip ID: 10de:1e07
           Display: x11 server: X.Org 1.20.3 driver: nvidia compositor: compton resolution: 3440x1440~60Hz
           OpenGL: renderer: GeForce RTX 2080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 415.27 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: ASRock driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:a348
           Device-2: NVIDIA TU102 High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 10de:10f7
           Sound Server: ALSA v: k4.19.23-1-MANJARO
Network:   Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
           chip ID: 8086:15bc
           Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: 5.4.0-k port: 3000 bus ID: 02:00.0
           chip ID: 8086:1539
           Device-3: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: 3000
           bus ID: 03:00.0 chip ID: 8086:24fb
Drives:    Local Storage: total: 4.55 TiB used: 26.06 GiB (0.6%)
           ID-1: /dev/sda vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB speed: 6.0 Gb/s rotation: 5425 rpm
           serial: <filter> rev: 0001 scheme: GPT
           ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB speed: 6.0 Gb/s serial: <filter>
           rev: 1B6Q scheme: GPT
Partition: ID-1: / size: 242.50 GiB used: 26.03 GiB (10.7%) fs: ext4 dev: /dev/sdb5
Sensors:   System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 36 C
Info:      Processes: 305 Uptime: 55m Memory: 15.58 GiB used: 10.69 GiB (68.6%) Init: systemd v: 241 Compilers:
           gcc: 8.2.1 clang: 7.0.1 Shell: bash v: 5.0.0 running in: urxvtd inxi: 3.0.30
check also power
sudo tlp-stat
or check with powertop
https://wiki.archlinux.org/index.php/powertop
Is this enough?
+++ Configured Settings: /etc/default/tlp
TLP_ENABLE=1
TLP_DEFAULT_MODE=AC
TLP_PERSISTENT_DEFAULT=0
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
CPU_HWP_ON_AC=balance_performance
CPU_HWP_ON_BAT=balance_power
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
ENERGY_PERF_POLICY_ON_AC=performance
ENERGY_PERF_POLICY_ON_BAT=power
DISK_DEVICES="sda sdb"
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="128 128"
SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
SATA_LINKPWR_ON_BAT="med_power_with_dipm max_performance"
AHCI_RUNTIME_PM_TIMEOUT=15
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
RADEON_POWER_PROFILE_ON_AC=default
RADEON_POWER_PROFILE_ON_BAT=low
RADEON_DPM_STATE_ON_AC=performance
RADEON_DPM_STATE_ON_BAT=battery
RADEON_DPM_PERF_LEVEL_ON_AC=auto
RADEON_DPM_PERF_LEVEL_ON_BAT=auto
WIFI_PWR_ON_AC=off
WIFI_PWR_ON_BAT=on
WOL_DISABLE=Y
SOUND_POWER_SAVE_ON_AC=0
SOUND_POWER_SAVE_ON_BAT=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_AC=0
BAY_POWEROFF_ON_BAT=0
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
RUNTIME_PM_DRIVER_BLACKLIST="amdgpu nouveau nvidia radeon pcieport"
USB_AUTOSUSPEND=0
USB_BLACKLIST_BTUSB=0
USB_BLACKLIST_PHONE=0
USB_BLACKLIST_PRINTER=1
USB_BLACKLIST_WWAN=1
RESTORE_DEVICE_STATE_ON_STARTUP=0
+++ System Info
System         =
BIOS           = P1.10
Release        = "Manjaro Linux"
Kernel         = 4.19.23-1-MANJARO #1 SMP PREEMPT Fri Feb 15 21:27:33 UTC 2019 x86_64
/proc/cmdline  = BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=94d47185-81f8-448d-ab84-49182dbb19a2 rw quiet
Init system    = systemd
Boot mode      = UEFI
+++ TLP Status
State          = enabled
Last run       = 05:17:05 PM,     16 sec(s) ago
Mode           = AC
Power source   = unknown
Notice: systemd-rfkill.service is not masked -- invoke "systemctl mask systemd-rfkill.service" to correct this!
+++ Processor
CPU model      = Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu10/cpufreq/scaling_driver   = intel_pstate
/sys/devices/system/cpu/cpu10/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu10/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu10/cpufreq/scaling_min_freq =   800000 [kHz]
/sys/devices/system/cpu/cpu10/cpufreq/scaling_max_freq =  5000000 [kHz]
/sys/devices/system/cpu/cpu10/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu10/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu11/cpufreq/scaling_driver   = intel_pstate
/sys/devices/system/cpu/cpu11/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu11/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu11/cpufreq/scaling_min_freq =   800000 [kHz]
/sys/devices/system/cpu/cpu11/cpufreq/scaling_max_freq =  5000000 [kHz]
/sys/devices/system/cpu/cpu11/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu11/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu12/cpufreq/scaling_driver   = intel_pstate
/sys/devices/system/cpu/cpu12/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu12/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu12/cpufreq/scaling_min_freq =   800000 [kHz]
/sys/devices/system/cpu/cpu12/cpufreq/scaling_max_freq =  5000000 [kHz]
/sys/devices/system/cpu/cpu12/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu12/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu13/cpufreq/scaling_driver   = intel_pstate
/sys/devices/system/cpu/cpu13/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu13/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu13/cpufreq/scaling_min_freq =   800000 [kHz]
/sys/devices/system/cpu/cpu13/cpufreq/scaling_max_freq =  5000000 [kHz]
/sys/devices/system/cpu/cpu13/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu13/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu14/cpufreq/scaling_driver   = intel_pstate
/sys/devices/system/cpu/cpu14/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu14/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu14/cpufreq/scaling_min_freq =   800000 [kHz]
/sys/devices/system/cpu/cpu14/cpufreq/scaling_max_freq =  5000000 [kHz]
/sys/devices/system/cpu/cpu14/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu14/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu15/cpufreq/scaling_driver   = intel_pstate
/sys/devices/system/cpu/cpu15/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu15/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu15/cpufreq/scaling_min_freq =   800000 [kHz]
/sys/devices/system/cpu/cpu15/cpufreq/scaling_max_freq =  5000000 [kHz]
/sys/devices/system/cpu/cpu15/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu15/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu1/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu2/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu2/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu2/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu3/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu3/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu3/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu4/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu4/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu4/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu4/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu4/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu5/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu5/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu5/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu5/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu5/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu5/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu5/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu6/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu6/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu6/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu6/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu6/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu6/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu6/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu7/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu7/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu7/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu7/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu7/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu7/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu7/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu8/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu8/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu8/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu8/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu8/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu8/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu8/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu9/cpufreq/scaling_driver    = intel_pstate
/sys/devices/system/cpu/cpu9/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu9/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu9/cpufreq/scaling_min_freq  =   800000 [kHz]
/sys/devices/system/cpu/cpu9/cpufreq/scaling_max_freq  =  5000000 [kHz]
/sys/devices/system/cpu/cpu9/cpufreq/energy_performance_preference = balance_performance
/sys/devices/system/cpu/cpu9/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/intel_pstate/min_perf_pct      =  16 [%]
/sys/devices/system/cpu/intel_pstate/max_perf_pct      = 100 [%]
/sys/devices/system/cpu/intel_pstate/no_turbo          =   0
/sys/devices/system/cpu/intel_pstate/turbo_pct         =  33 [%]
/sys/devices/system/cpu/intel_pstate/num_pstates       =  43
x86_energy_perf_policy: program not installed.
/sys/module/workqueue/parameters/power_efficient       = Y
/proc/sys/kernel/nmi_watchdog                          = 0
+++ Undervolting
PHC kernel not available.
+++ Temperatures
CPU temp               =    23 [°C]
Fan speed              = (not available)
+++ File System
/proc/sys/vm/laptop_mode               =     0
/proc/sys/vm/dirty_writeback_centisecs =  1500
/proc/sys/vm/dirty_expire_centisecs    =  1500
/proc/sys/vm/dirty_ratio               =    20
/proc/sys/vm/dirty_background_ratio    =    10
/proc/sys/fs/xfs/xfssyncd_centisecs    =  3000
+++ Storage Devices
/dev/sda:
  Model     = ST4000DM004-2CV104
  Firmware  = 0001
  APM Level = none/disabled
  Status    = unknown
  Scheduler = mq-deadline
  Runtime PM: control = on, autosuspend_delay = (not available)
/dev/sdb:
  Model     = Samsung SSD 860 EVO 1TB
  Firmware  = RVT01B6Q
  Status    = active/idle
  TRIM      = supported
+++ AHCI Link Power Management (ALPM)
/sys/class/scsi_host/host0/link_power_management_policy  = med_power_with_dipm
/sys/class/scsi_host/host1/link_power_management_policy  = med_power_with_dipm
/sys/class/scsi_host/host2/link_power_management_policy  = med_power_with_dipm
/sys/class/scsi_host/host3/link_power_management_policy  = med_power_with_dipm
/sys/class/scsi_host/host4/link_power_management_policy  = med_power_with_dipm
/sys/class/scsi_host/host5/link_power_management_policy  = med_power_with_dipm
+++ AHCI Host Controller Runtime Power Management
/sys/bus/pci/devices/0000:00:17.0/ata1/power/control = on
/sys/bus/pci/devices/0000:00:17.0/ata2/power/control = on
/sys/bus/pci/devices/0000:00:17.0/ata3/power/control = on
/sys/bus/pci/devices/0000:00:17.0/ata4/power/control = on
/sys/bus/pci/devices/0000:00:17.0/ata5/power/control = on
/sys/bus/pci/devices/0000:00:17.0/ata6/power/control = on
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default (using bios preferences)
+++ Wireless
bluetooth = on
wifi      = on
wwan      = none (no device)
hci0(btusb)                   : bluetooth, not connected
wlp3s0(iwlwifi)               : wifi, connected, power management = off
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save            = 0
/sys/module/snd_hda_intel/parameters/power_save_controller = N
+++ Runtime Power Management
Device blacklist = (not configured)
Driver blacklist = amdgpu nouveau nvidia radeon pcieport
/sys/bus/pci/devices/0000:00:00.0/power/control = on   (0x060000, Host bridge, skl_uncore)
/sys/bus/pci/devices/0000:00:01.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:12.0/power/control = on   (0x118000, Signal processing controller, intel_pch_thermal)
/sys/bus/pci/devices/0000:00:14.0/power/control = on   (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:14.2/power/control = on   (0x050000, RAM memory, no driver)
/sys/bus/pci/devices/0000:00:16.0/power/control = on   (0x078000, Communication controller, mei_me)
/sys/bus/pci/devices/0000:00:17.0/power/control = on   (0x010601, SATA controller, ahci)
/sys/bus/pci/devices/0000:00:1c.0/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1c.6/power/control = auto (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1f.0/power/control = on   (0x060100, ISA bridge, no driver)
/sys/bus/pci/devices/0000:00:1f.3/power/control = on   (0x040300, Audio device, snd_hda_intel)
/sys/bus/pci/devices/0000:00:1f.4/power/control = on   (0x0c0500, SMBus, i801_smbus)
/sys/bus/pci/devices/0000:00:1f.5/power/control = on   (0x0c8000, Serial bus controller [0c80], no driver)
/sys/bus/pci/devices/0000:00:1f.6/power/control = on   (0x020000, Ethernet controller, e1000e)
/sys/bus/pci/devices/0000:01:00.0/power/control = on   (0x030000, VGA compatible controller, nvidia)
/sys/bus/pci/devices/0000:01:00.1/power/control = on   (0x040300, Audio device, snd_hda_intel)
/sys/bus/pci/devices/0000:01:00.2/power/control = on   (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:01:00.3/power/control = on   (0x0c8000, Serial bus controller [0c80], no driver)
/sys/bus/pci/devices/0000:02:00.0/power/control = on   (0x020000, Ethernet controller, igb)
/sys/bus/pci/devices/0000:03:00.0/power/control = on   (0x028000, Network controller, iwlwifi)
+++ USB
Autosuspend         = disabled
Device whitelist    = (not configured)
Bluetooth blacklist = disabled
Phone blacklist     = disabled
WWAN blacklist      = enabled
Bus 002 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms =     0 -- Linux Foundation 3.0 root hub (hub)
Bus 001 Device 002 ID 046d:c52b control = on,   autosuspend_delay_ms =  2000 -- Logitech, Inc. Unifying Receiver (usbhid)
Bus 001 Device 009 ID 04d9:8008 control = on,   autosuspend_delay_ms =  2000 -- Holtek Semiconductor, Inc.  (usbhid)
Bus 001 Device 006 ID 8087:0aa7 control = auto, autosuspend_delay_ms =  2000 -- Intel Corp.  (btusb)
Bus 001 Device 008 ID 7793:2500 control = on,   autosuspend_delay_ms =  2000 -- <unknown> (usbhid)
Bus 001 Device 004 ID 05e3:0608 control = auto, autosuspend_delay_ms =     0 -- Genesys Logic, Inc. Hub (hub)
Bus 001 Device 007 ID 1e71:1714 control = on,   autosuspend_delay_ms =  2000 -- NZXT  (usbhid)
Bus 001 Device 005 ID 1e71:170e control = on,   autosuspend_delay_ms =  2000 -- NZXT  (usbhid)
Bus 001 Device 003 ID 05e3:0608 control = auto, autosuspend_delay_ms =     0 -- Genesys Logic, Inc. Hub (hub)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms =     0 -- Linux Foundation 2.0 root hub (hub)
Bus 004 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms =     0 -- Linux Foundation 3.0 root hub (hub)
Bus 003 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms =     0 -- Linux Foundation 2.0 root hub (hub)
+++ Battery Status
No batteries detected.
+++ Suggestions
* Install ethtool to disable Wake On LAN (WOL)
* Install smartmontools for disk drive health info
It happened again, but this time the mouse isn't even working. Audio seemed to be stuck on a loop for a while and then it stopped working as well. CTRL+ALT+F2 is also not working.
