Performance hit after suspend or hibertation
Hi.
My Manjaro machine has some problems with the performance after waking up the machine after gets suspended or hibernated, it gets slower in some ways like moving the windows arround, and the system feels a bit weird.
The problem that I notice the most (and best comparable) is Youtube. If I reboot the machine I can go as high as 1440p in 60 Hz at 2x speed without a problem, but after I suspend/hibernate the machine it can't go beyond 720p at 60 Hz without getting video stuttering and my whole PC coming to a sluggy mess, animations go slowly and losing frames, the web browser gets slower, Code OSS etc.
First I thought that was my poor main GPU, the Radeon HD 5770 (I have a NVidia GTX 1060 but is getting passthrough to KVM for a VM that I run). But last week I reinstalled the drivers and the computer was working better than ever! (because I rebooted it for the install). But after some days I noticed the performance hit again, and after a lot of trial and error I discovered that suspending the PC was the culprit. (I suspend the PC a lot, I don't reboot it often).
The PC gets slower after suspending the PC, no matter if it's the first time I suspended it or not.
Maybe it's a problem with the Passtrough thing, it's a very rare thing to do and maybe there is not many help online (I searched a lot for this...)
I use KDE Plasma, and here is my inxi -Fxxxz log:
  Host: alberto-pc-manjaro Kernel: 5.4.35-1-MANJARO x86_64 bits: 64
  compiler: gcc v: 9.3.0 Desktop: KDE Plasma 5.18.4 tk: Qt 5.14.2
  wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
  Type: Desktop System: Gigabyte product: Z370 AORUS Gaming 3 v: N/A
  serial: <filter>
  Mobo: Gigabyte model: Z370 AORUS Gaming 3 v: x.x serial: <filter>
  UEFI: American Megatrends v: F15b date: 11/28/2019
  Device-1: sony_controller_battery_00:1b:fb:72:6f:a4 model: N/A serial: N/A
  charge: N/A status: Discharging
  Topology: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 12.0 MiB
  bogomips: 88824
  Speed: 4586 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4546 2: 4594
  3: 4574 4: 4541 5: 4597 6: 4598 7: 4538 8: 4517 9: 4567 10: 4559 11: 4512
  12: 4572
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
  driver: vfio-pci v: 0.2 bus ID: 01:00.0 chip ID: 10de:1c03
  Device-2: AMD Juniper XT [Radeon HD 5770] vendor: XFX Pine driver: radeon
  v: kernel bus ID: 08:00.0 chip ID: 1002:68b8
  Display: x11 server: X.Org 1.20.8 driver: radeon FAILED: ati
  unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
  resolution: 1920x1080~60Hz, 1920x1080~60Hz
  OpenGL: renderer: AMD JUNIPER (DRM 2.50.0 / 5.4.35-1-MANJARO LLVM 10.0.0)
  v: 3.3 Mesa 20.0.5 compat-v: 3.1 direct render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
  Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
  driver: vfio-pci v: 0.2 bus ID: 01:00.1 chip ID: 10de:10f1
  Device-3: AMD Juniper HDMI Audio [Radeon HD 5700 Series] vendor: XFX Pine
  driver: snd_hda_intel v: kernel bus ID: 08:00.1 chip ID: 1002:aa58
  Device-4: Nam Tai E&E Products or OmniVision Sony Playstation Eye
  type: USB driver: ov534,snd-usb-audio bus ID: 1-14:8 chip ID: 1415:2000
  Sound Server: ALSA v: k5.4.35-1-MANJARO
  Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
  driver: alx v: kernel port: d000 bus ID: 06:00.0 chip ID: 1969:e0b1
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  vendor: TP-LINK TG-3468 driver: r8168 v: 8.048.02-NAPI port: b000
  bus ID: 0b:00.0 chip ID: 10ec:8168
  IF: enp11s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  IF-ID-2: virbr0-nic state: down mac: <filter>
  Local Storage: total: 2.73 TiB used: 594.55 GiB (21.3%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
  size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXM7
  scheme: GPT
  ID-2: /dev/sda vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
  speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: ABB0 scheme: MBR
  ID-1: / size: 881.71 GiB used: 594.55 GiB (67.4%) fs: ext4
  dev: /dev/nvme0n1p2
  ID-2: swap-1 size: 34.44 GiB used: 0 KiB (0.0%) fs: swap
  dev: /dev/nvme0n1p3
  System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: radeon temp: 50 C
  Processes: 328 Uptime: 40m Memory: 31.37 GiB used: 5.19 GiB (16.6%)
  Init: systemd v: 244 Compilers: gcc: 9.3.0 clang: 10.0.0 Shell: bash
  v: 5.0.16 running in: tilix inxi: 3.0.37
Thank you!
:+1: Welcome back! Haven't seen you in a while! :+1:
Is there a difference between the inxi before and after suspension?
:innocent:
Yes, I had to abandon Linux 2 years ago since I needed Windows to finish my studies, but now I relegated it to a KVM VM and my computer and laptop are controlled by Manjaro, just as I like it :stuck_out_tongue:
I generated the same inxi in both a working properly state and in a bad state, I did not find any difference, but here they are just in case you see something I missed.
After Reboot (Working Fine)
  serial: <filter>
  bogomips: 88824
  Speed: 4437 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4587 2: 4585
  3: 4530 4: 4584 5: 4559 6: 4597 7: 4550 8: 4580 9: 4588 10: 4535 11: 4586
  12: 4529
  Local Storage: total: 2.73 TiB used: 594.54 GiB (21.3%)
  scheme: GPT
  ID-1: / size: 881.71 GiB used: 594.54 GiB (67.4%) fs: ext4
  dev: /dev/nvme0n1p2
  dev: /dev/nvme0n1p3
  System Temperatures: cpu: 36.0 C mobo: N/A gpu: radeon temp: 29 C
  Processes: 358 Uptime: 3m Memory: 31.37 GiB used: 2.48 GiB (7.9%)
After Suspend (Working Badly)
  serial: <filter>
  bogomips: 88824
  Speed: 4570 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4570 2: 4546
  3: 4535 4: 4594 5: 4545 6: 4593 7: 4600 8: 4575 9: 4543 10: 4595 11: 4431
  12: 4575
  scheme: GPT
  dev: /dev/nvme0n1p2
  dev: /dev/nvme0n1p3
  System Temperatures: cpu: 38.0 C mobo: N/A gpu: radeon temp: 29 C
  Processes: 439 Uptime: 5m Memory: 31.37 GiB used: 3.56 GiB (11.3%)
If you need anything else I will gladly send it to you.
Thanks!
In both cases I noticed:
but as I'm on nVidia, not AMD, so you'll have to resolve this in a new question and I'm 95% sure that will resolve your issue here.
¿Resolve this in a new question on the "Drivers" forum? Ok, Thanks! If I get the solution I will post link it here too.
Thank you ^·^
Thank me when the new question resolved your issue! :wink: :grin:
I posted the question here as you said, it seems that the "Radeon" driver is failing, but the ATI driver is working fine. Danielsuarez369 even tested the same GPU in a computer (which stills blows my mind when I think about it).
Maybe my particular configuration of the KVM, IOMMU, Dual GPU and with a decade old card is causing all of this. Since I'm going to upgrade the Radeon with a more modern card with better support (I'll ask for help to decide, I've never bought and AMD card before) I'll report about the change to see if that works.
Is the performance problem gone as well?
If not, another 2 inxi's please...
:innocent:
No, the problem is still there, here there are some fresh inxi -Fxxxz commands:
After a Reboot (Working Fine)
  serial: <filter>
  bogomips: 88824
  Speed: 4559 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4533 2: 4430
  3: 4509 4: 4508 5: 4563 6: 4537 7: 4470 8: 4495 9: 4582 10: 4471 11: 4498
  12: 4516
  type: USB driver: ov534,snd-usb-audio bus ID: 1-14:11 chip ID: 1415:2000
  Local Storage: total: 2.73 TiB used: 601.95 GiB (21.5%)
  scheme: GPT
  ID-1: / size: 881.71 GiB used: 601.95 GiB (68.3%) fs: ext4
  dev: /dev/nvme0n1p2
  dev: /dev/nvme0n1p3
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: radeon temp: 29 C
  Processes: 370 Uptime: 4m Memory: 31.37 GiB used: 3.19 GiB (10.2%)
After Sleep (Working Bad)
  serial: <filter>
  bogomips: 88824
  Speed: 4622 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4662 2: 4564
  3: 4611 4: 4696 5: 4575 6: 4611 7: 4619 8: 4632 9: 4647 10: 4527 11: 4631
  12: 4602
  scheme: GPT
  dev: /dev/nvme0n1p2
  dev: /dev/nvme0n1p3
  Processes: 329 Uptime: 15m Memory: 31.37 GiB used: 3.82 GiB (12.2%)
Thanks.
No clue from the inxi
How about:
free --human
for szFile in /proc/*/status ; do
  awk '/VmSwap|Name/{printf $2 "\t" $3}END{ print "" }' $szFile
done | sort --key 2 --numeric --reverse | head --lines=20
After a fresh reboot and after suspend?
[albertodiaz@alberto-pc-manjaro ~]  $ free --human
              total        used        free      shared  buff/cache   available
Mem:           31Gi       2,1Gi        27Gi       133Mi       1,8Gi        28Gi
Swap:          34Gi          0B        34Gi
[albertodiaz@alberto-pc-manjaro ~]  $ for szFile in /proc/*/status ; do
yakuake	0	kB
Xorg	0	kB
xembedsniproxy	0	kB
xdg-permission-	0	kB
xdg-document-po	0	kB
xdg-desktop-por	0	kB
xbrlapi
writeback
WebKitWebProces	0	kB
WebKitNetworkPr	0	kB
WebExtensions	0	kB
Web	Content0	kB
Web	Content0	kB
watchdogd
vfio-irqfd-clea
upowerd	0	kB
udisksd	0	kB
ttm_swap
Mem:           31Gi       2,8Gi        26Gi       140Mi       2,1Gi        27Gi
Swap:          34Gi          0B        34Gi
yakuake	0	kB
Xorg	0	kB
xembedsniproxy	0	kB
xbrlapi
writeback
WebExtensions	0	kB
Web	Content0	kB
watchdogd
vfio-irqfd-clea
upowerd	0	kB
udisksd	0	kB
ttm_swap
tracker-store	0	kB
I don't have much clue of what the command does, so I can't take conclusions from them (but surely you'll do :P)
Thanks!
Yeah, it all outputs 0s, so I can't draw any conclusion.
My apologies: I'm all out of bright ideas!
:sob:
Unless you're just imagining it!
:joy:
No need to apology, you did what you can. I'll buy a better GPU in the future to see if that helps.
I'll let this post open just in case someone else has the same problem or if someone knows what the problem could be.
Thank you very much for your time and pacience ^·^/
