"Plastik" decorations cause crashes on shutdown
Hi all,
I am experiencing crashes at shutdown since yesterday when I messed around with plasma themes and did some (cosmetic) tweaks. Still pretty new to linux, so I was hoping I can get some help in tracking this down. I found the relevant part in the logs [1] which suggests to me that sddm the "plastik" window decorations are involved. My general system info can be found in this post.
The laptop has crashed on each attempted shutdown (about 3-4 times so far), basically the screen goes blank and then the fans start going crazy but nothing happens. One time I got into the tty using Ctrl-Alt-F2 but I wasn't sure what to do (forgive me, it was late) so I tried sudo shutdown without success. Also the REISUB trick didn't seem to work.
Update: It seems the problem exists only when using the "plastik" window border style, switching back to the default ("breeze") allows me to shutdown without problems. The plastik theme errors are near the start of the provided log. I will leave this post up since it is one of the default themes, so I would expect it to work.
If there's anything else I can provide, please ask. Thanks for your time.
Edit: More anecdotal detail.
Edit2: Fancy folding and title update.
[1] Output from `journalctl`, might be a bit lengthy because I didn't want to miss anything (yes, it really was 3am...)
-- Logs begin at Fri 2020-07-17 11:37:53 AEST, end at Wed 2020-07-29 09:06:30 AEST. --
Jul 29 03:31:58 dell-laptop org_kde_powerdevil[1170]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("Type", QVariant(uint, 16)))
Jul 29 03:31:58 dell-laptop dbus-daemon[1040]: [session uid=1000 pid=1040] Activating service name='org.kde.LogoutPrompt' requested by ':1.16' (uid=1000 pid=1128 comm="/usr/bin/ksmserver ")
Jul 29 03:31:58 dell-laptop dbus-daemon[1040]: [session uid=1000 pid=1040] Successfully activated service 'org.kde.LogoutPrompt'
Jul 29 03:31:58 dell-laptop ksmserver-logout-greeter[9493]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserDelegate.qml:41: ReferenceError: config is not defined
Jul 29 03:31:58 dell-laptop ksmserver-logout-greeter[9493]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserDelegate.qml:34: ReferenceError: model is not defined
Jul 29 03:31:58 dell-laptop ksmserver-logout-greeter[9493]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/ActionButton.qml:0: ReferenceError: config is not defined
Jul 29 03:31:58 dell-laptop ksmserver-logout-greeter[9493]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/ActionButton.qml:33: ReferenceError: config is not defined
Jul 29 03:31:58 dell-laptop kwin_x11[1101]: file:///usr/share/kwin/decorations/kwin4_decoration_qml_plastik/contents/ui/PlastikButton.qml:156:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 29 03:31:58 dell-laptop kwin_x11[1101]: file:///usr/share/kwin/decorations/kwin4_decoration_qml_plastik/contents/ui/PlastikButton.qml:152:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 29 03:31:58 dell-laptop kwin_x11[1101]: file:///usr/share/kwin/decorations/kwin4_decoration_qml_plastik/contents/ui/main.qml:417:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Jul 29 03:31:58 dell-laptop kwin_x11[1101]: file:///usr/share/kwin/decorations/kwin4_decoration_qml_plastik/contents/ui/main.qml:91: TypeError: Cannot read property 'borderSize' of null
Jul 29 03:31:58 dell-laptop kwin_x11[1101]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56990, resource id: 14800857, major code: 3 (GetWindowAttributes), minor code: 0
Jul 29 03:31:58 dell-laptop kwin_x11[1101]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 56991, resource id: 14800857, major code: 14 (GetGeometry), minor code: 0
Jul 29 03:32:00 dell-laptop dbus-daemon[1040]: [session uid=1000 pid=1040] Activating service name='org.kde.Shutdown' requested by ':1.16' (uid=1000 pid=1128 comm="/usr/bin/ksmserver ")
Jul 29 03:32:00 dell-laptop dbus-daemon[1040]: [session uid=1000 pid=1040] Successfully activated service 'org.kde.Shutdown'
Jul 29 03:32:00 dell-laptop kwin_x11[1101]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57651, resource id: 58720295, major code: 18 (ChangeProperty), minor code: 0
Jul 29 03:32:04 dell-laptop msm_kde_notifier[1185]: Shutting down MSM Notifier...
Jul 29 03:32:04 dell-laptop polkit-kde-authentication-agent-1[1139]: Destroying listener
Jul 29 03:32:04 dell-laptop polkit-kde-authentication-agent-1[1139]: Removing listener  PolkitQt1::Agent::Listener(0x5599f758e930)
Jul 29 03:32:04 dell-laptop kwin_x11[1101]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57806, resource id: 35651589, major code: 18 (ChangeProperty), minor code: 0
Jul 29 03:32:04 dell-laptop kded5[1097]: Service  ":1.31" unregistered
Jul 29 03:32:04 dell-laptop polkitd[784]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.45, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_AU.UTF-8)
Jul 29 03:32:04 dell-laptop kwin_x11[1101]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57810, resource id: 27262981, major code: 18 (ChangeProperty), minor code: 0
Jul 29 03:32:04 dell-laptop kwin_x11[1101]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57814, resource id: 60818441, major code: 18 (ChangeProperty), minor code: 0
Jul 29 03:32:04 dell-laptop kwin_x11[1101]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57818, resource id: 23068680, major code: 18 (ChangeProperty), minor code: 0
Jul 29 03:32:04 dell-laptop kwin_x11[1101]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 57822, resource id: 29360133, major code: 18 (ChangeProperty), minor code: 0
Jul 29 03:32:04 dell-laptop systemd-logind[560]: System is powering down.
Jul 29 03:32:04 dell-laptop sddm[641]: Authentication error: "Process crashed"
Jul 29 03:32:04 dell-laptop sddm[641]: Auth: sddm-helper crashed (exit code 15)
Jul 29 03:32:04 dell-laptop sddm[641]: Auth: sddm-helper exited with 15
Jul 29 03:32:04 dell-laptop sddm[641]: Socket server stopping...
Jul 29 03:32:04 dell-laptop sddm[641]: Socket server stopped.
Jul 29 03:32:04 dell-laptop sddm[641]: Display server stopping...
Jul 29 03:32:04 dell-laptop xembedsniproxy[1135]: The X11 connection broke (error 1). Did the X11 server die?
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Session 2 of user leon.
Jul 29 03:32:04 dell-laptop at-spi-bus-launcher[1284]: X connection to :0 broken (explicit kill or server shutdown).
Jul 29 03:32:04 dell-laptop systemd[1]: Removed slice system-getty.slice.
Jul 29 03:32:04 dell-laptop systemd[1]: Removed slice system-modprobe.slice.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped target Bluetooth.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped target Graphical Interface.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped target Sound Card.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped target Timers.
Jul 29 03:32:04 dell-laptop systemd[1]: logrotate.timer: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Daily rotation of log files.
Jul 29 03:32:04 dell-laptop systemd[1]: man-db.timer: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Daily man-db regeneration.
Jul 29 03:32:04 dell-laptop systemd[1]: pamac-cleancache.timer: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Monthly clean packages cache.
Jul 29 03:32:04 dell-laptop systemd[1]: pamac-mirrorlist.timer: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Generate mirrorlist weekly.
Jul 29 03:32:04 dell-laptop systemd[1]: shadow.timer: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Daily verification of password and group files.
Jul 29 03:32:04 dell-laptop systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
Jul 29 03:32:04 dell-laptop kded5[1097]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped target System Time Synchronized.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped target System Time Set.
Jul 29 03:32:04 dell-laptop systemd[1]: lvm2-lvmpolld.socket: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Closed LVM2 poll daemon socket.
Jul 29 03:32:04 dell-laptop systemd[1]: systemd-rfkill.socket: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jul 29 03:32:04 dell-laptop kactivitymanagerd[1118]: The X11 connection broke (error 1). Did the X11 server die?
Jul 29 03:32:04 dell-laptop kglobalaccel5[1125]: The X11 connection broke (error 1). Did the X11 server die?
Jul 29 03:32:04 dell-laptop kscreen_backend_launcher[1231]: The X11 connection broke (error 1). Did the X11 server die?
Jul 29 03:32:04 dell-laptop xdg-desktop-por[1274]: xdg-desktop-portal-gtk: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Jul 29 03:32:04 dell-laptop systemd[1018]: apps-konsole-35b40aa5df254aa6bd00ea51382c45bf.scope: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Starting Generate shutdown-ramfs...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping CUPS Scheduler...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Authorization Manager...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Simple Desktop Display Manager...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Load/Save Random Seed...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping TLP system startup/shutdown...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Disk Manager...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Daemon for power management...
Jul 29 03:32:04 dell-laptop dbus-daemon[1040]: [session uid=1000 pid=1040] Activating service name='org.kde.kglobalaccel' requested by ':1.11' (uid=1000 pid=1097 comm="/usr/bin/kded5 ")
Jul 29 03:32:04 dell-laptop systemd[1]: org.cups.cupsd.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped CUPS Scheduler.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop systemd[1]: rtkit-daemon.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.557:109): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.557:110): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop systemd-logind[560]: Session 2 logged out. Waiting for processes to exit.
Jul 29 03:32:04 dell-laptop systemd[1]: systemd-random-seed.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Load/Save Random Seed.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.563:111): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop systemd[1018]: xdg-desktop-portal-gtk.service: Main process exited, code=exited, status=1/FAILURE
Jul 29 03:32:04 dell-laptop systemd[1018]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Jul 29 03:32:04 dell-laptop udisksd[780]: udisks daemon version 2.9.0 exiting
Jul 29 03:32:04 dell-laptop systemd[1]: upower.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Daemon for power management.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.580:112): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop mkinitcpio[9516]: ==> Starting build: none
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.597:113): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop systemd[1]: udisks2.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Disk Manager.
Jul 29 03:32:04 dell-laptop systemd[1]: polkit.service: Succeeded.
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.597:114): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop kded5[1097]: The X11 connection broke: I/O error (code 1)
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Authorization Manager.
Jul 29 03:32:04 dell-laptop mkinitcpio[9516]:   -> Running build hook: [sd-shutdown]
Jul 29 03:32:04 dell-laptop systemd[1018]: pulseaudio.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1018]: apps-wmctrl-591cfd5056ff4be6a29a7c53725a5c09.scope: Succeeded.
Jul 29 03:32:04 dell-laptop tlp[9518]: Applying power save settings...done.
Jul 29 03:32:04 dell-laptop systemd[1]: tlp.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped TLP system startup/shutdown.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped target Multi-User System.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped target Login Prompts.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Periodic Command Scheduler...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Initialize hardware monitoring sensors...
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Samba SMB Daemon...
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.730:115): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop systemd[1]: smb.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Samba SMB Daemon.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop nmbd[849]: [2020/07/29 03:32:04.737640,  0] ../../source3/nmbd/nmbd.c:59(terminate)
Jul 29 03:32:04 dell-laptop systemd[1]: Stopping Samba NMB Daemon...
Jul 29 03:32:04 dell-laptop nmbd[849]:   Got SIGTERM: going down...
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.733:116): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=smb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop systemd[1]: nmb.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Samba NMB Daemon.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped target Network is Online.
Jul 29 03:32:04 dell-laptop systemd[1]: NetworkManager-wait-online.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Network Manager Wait Online.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.737:117): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nmb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop kernel: audit: type=1131 audit(1595957524.737:118): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop mkinitcpio[9516]: ==> Build complete.
Jul 29 03:32:04 dell-laptop systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Finished Generate shutdown-ramfs.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop crond[553]: (CRON) INFO (Shutting down)
Jul 29 03:32:04 dell-laptop systemd[1]: cronie.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Periodic Command Scheduler.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:04 dell-laptop systemd[1]: lm_sensors.service: Succeeded.
Jul 29 03:32:04 dell-laptop systemd[1]: Stopped Initialize hardware monitoring sensors.
Jul 29 03:32:04 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lm_sensors comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:05 dell-laptop kglobalaccel5[9521]: qt.qpa.xcb: could not connect to display :0
Jul 29 03:32:05 dell-laptop audit[9521]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=3 pid=9521 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
Jul 29 03:32:05 dell-laptop kglobalaccel5[9521]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
Jul 29 03:32:05 dell-laptop kglobalaccel5[9521]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                                 Available platform plugins are: wayland-org.kde.kwin.qpa, eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Jul 29 03:32:05 dell-laptop sddm[641]: Display server stopped.
Jul 29 03:32:05 dell-laptop sddm[641]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
Jul 29 03:32:05 dell-laptop dbus-daemon[1040]: [session uid=1000 pid=1040] Activated service 'org.kde.kglobalaccel' failed: Process org.kde.kglobalaccel received signal 6
Jul 29 03:32:05 dell-laptop sddm[641]: Removing display ":0" ...
Jul 29 03:32:05 dell-laptop sddm[641]: Adding new display on vt 1 ...
Jul 29 03:32:05 dell-laptop sddm[641]: Loading theme configuration from ""
Jul 29 03:32:05 dell-laptop sddm[641]: Display server starting...
Jul 29 03:32:05 dell-laptop sddm[641]: Running: /usr/bin/X -nolisten tcp -auth /var/run/sddm/{2487b00f-868f-4b1c-8331-8fb2c347a801} -background none -noreset -displayfd 18 -seat seat0 vt1
Jul 29 03:32:05 dell-laptop systemd[1]: Requested transaction contradicts existing jobs: Transaction for systemd-coredump@0-9740-0.service/start is destructive (tmp.mount has 'stop' job queued, but 'start' is included in transaction).
Jul 29 03:32:05 dell-laptop systemd[1]: systemd-coredump.socket: Failed to queue service startup job (Maybe the service file is missing or not a non-template unit?): Transaction for systemd-coredump@0-9740-0.service/start is destructive (tmp.mount has 'stop' job queued, but 'start' is included in transaction).
Jul 29 03:32:05 dell-laptop systemd[1]: systemd-coredump.socket: Failed with result 'resources'.
Jul 29 03:32:07 dell-laptop sddm[641]: Setting default cursor
Jul 29 03:32:07 dell-laptop sddm[641]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Jul 29 03:32:07 dell-laptop sddm[641]: Display server started.
Jul 29 03:32:07 dell-laptop sddm[641]: Socket server starting...
Jul 29 03:32:07 dell-laptop sddm[641]: Socket server started.
Jul 29 03:32:07 dell-laptop sddm[641]: Loading theme configuration from "/usr/share/sddm/themes/breeze/theme.conf"
Jul 29 03:32:07 dell-laptop sddm[641]: Greeter starting...
Jul 29 03:32:07 dell-laptop sddm[641]: Adding cookie to "/var/run/sddm/{2487b00f-868f-4b1c-8331-8fb2c347a801}"
Jul 29 03:32:07 dell-laptop sddm[641]: Signal received: SIGTERM
Jul 29 03:32:07 dell-laptop sddm[641]: Socket server stopping...
Jul 29 03:32:07 dell-laptop sddm[641]: Socket server stopped.
Jul 29 03:32:07 dell-laptop sddm[641]: Display server stopping...
Jul 29 03:32:07 dell-laptop sddm-helper[9758]: [PAM] Starting...
Jul 29 03:32:07 dell-laptop audit[9758]: USER_AUTH pid=9758 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:07 dell-laptop audit[9758]: USER_ACCT pid=9758 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jul 29 03:32:07 dell-laptop sddm-helper[9758]: [PAM] Authenticating...
Jul 29 03:32:07 dell-laptop sddm-helper[9758]: [PAM] returning.
Jul 29 03:32:08 dell-laptop sddm[641]: Display server stopped.
Jul 29 03:32:08 dell-laptop sddm[641]: Running display stop script  "/usr/share/sddm/scripts/Xstop"
Jul 29 03:32:08 dell-laptop sddm[641]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
Jul 29 03:32:08 dell-laptop systemd[1]: sddm.service: Succeeded.
Jul 29 03:32:08 dell-laptop systemd[1]: Stopped Simple Desktop Display Manager.
Jul 29 03:32:08 dell-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Hello,
As i read it, it seems you found the answer to your issue. If "plastik" fails to follow the new update that came into KDE Plasma and Frameworks, it means is no longer reliable. Maybe there will get fixed in future updates upstream.
Hopefully your findings will help other to avoid getting into same troubles, so thanks for posting it, but there is no much we can do to fix it "right now".
Hi,
Thanks for the reply, I will wait to see if the issue persists or if it is truly solved (I am using manjaro almost every day on this laptop so it will be quick to test). As you say, it seems the "plastik" theme doesn't work with the newer Qt/Plasma versions.
This is not a big deal for me, plastik theme was kinda ugly IMHO I was only using it because it inherits titlebar color from the plasma theme :smile: (but now I find that breeze-light does the same thing).
I will close this issue in a few days unless something happens. Can't lol
Off-topic: Thanks for the awesome distros, I tried a few others but Manjaro is the reason that I now use Linux for most of my work.
