Please help Cinnamon crashing every login No menu (panel?) Windowing and desktop work.
Every time I login I get an Error box that says
"Cinnamon just crashed
You are currently running in fallback mode....."
After hours and days of searching this seems that "Cinnamon crashed" is a symptom with a hundred different causes and resolutions and I can't figure out what is causing mine.
My system is a Dell 5559 laptop
Following one of the posts I checked to make sure my video driver was correct and up to date.
I completely updated the machine.
I reinstalled Cinnamon
I have a functioning desktop where I have created a bash script to open a terminal window becasue there is no "strart menu" no taskbar and my usual keyboard shortcuts don't seem to be working.
Following this post (and the 2 others that point to it) except I ran it after login
I created this Pastebin file
https://pastebin.com/E17KDk1n
I noticed that it said "no installed USB configs! during the mhwd -li command but searching around it sounded like the error was a bug.
I couldn't figure out what the ACPI warning was about.
I ran Journalctl and you can see Cinnamon crash and then the computer went to sleep and threw up a bunch of gkr-pam erors.
journalctl -b | grep cinnamon
Apr 25 15:41:09 ManjAragorn systemd-coredump[2047]: Process 2037 (cinnamon) of user 1000 dumped core.
                                                    #22 0x000055d869e8d159 n/a (cinnamon + 0x2159)
                                                    #24 0x000055d869e8d57e n/a (cinnamon + 0x257e)
Apr 25 15:47:25 ManjAragorn systemd-coredump[2598]: Process 2588 (cinnamon) of user 1000 dumped core.
                                                    #22 0x00005621eb736159 n/a (cinnamon + 0x2159)
                                                    #24 0x00005621eb73657e n/a (cinnamon + 0x257e)
Apr 25 15:47:52 ManjAragorn systemd-coredump[2646]: Process 2636 (cinnamon) of user 1000 dumped core.
                                                    #22 0x00005650bc059159 n/a (cinnamon + 0x2159)
                                                    #24 0x00005650bc05957e n/a (cinnamon + 0x257e)
Apr 25 15:50:16 ManjAragorn systemd-coredump[2700]: Process 2690 (cinnamon) of user 1000 dumped core.
                                                    #22 0x00005598ae293159 n/a (cinnamon + 0x2159)
                                                    #24 0x00005598ae29357e n/a (cinnamon + 0x257e)
Apr 25 15:54:30 ManjAragorn systemd-coredump[2790]: Process 2780 (cinnamon) of user 1000 dumped core.
                                                    #22 0x000055bb0b595159 n/a (cinnamon + 0x2159)
                                                    #24 0x000055bb0b59557e n/a (cinnamon + 0x257e)
Apr 25 16:04:57 ManjAragorn systemd-coredump[3133]: Process 3123 (cinnamon) of user 1000 dumped core.
                                                    #22 0x000055dd031da159 n/a (cinnamon + 0x2159)
                                                    #24 0x000055dd031da57e n/a (cinnamon + 0x257e)
Apr 25 16:05:02 ManjAragorn systemd-coredump[3171]: Process 3161 (cinnamon) of user 1000 dumped core.
                                                    #22 0x00005609aa4bb159 n/a (cinnamon + 0x2159)
                                                    #24 0x00005609aa4bb57e n/a (cinnamon + 0x257e)
Apr 25 18:51:10 ManjAragorn cinnamon-screensaver-pam-helper[4877]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 18:51:10 ManjAragorn cinnamon-screensaver-pam-helper[4877]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 25 18:51:10 ManjAragorn cinnamon-screensaver-pam-helper[4877]: gkr-pam: no password is available for user
Apr 25 19:01:01 ManjAragorn cinnamon-screensaver-pam-helper[4972]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:01:01 ManjAragorn cinnamon-screensaver-pam-helper[4972]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 25 19:01:01 ManjAragorn cinnamon-screensaver-pam-helper[4972]: gkr-pam: no password is available for user
Apr 25 19:03:29 ManjAragorn cinnamon-screensaver-pam-helper[5012]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:03:29 ManjAragorn cinnamon-screensaver-pam-helper[5012]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 25 19:03:29 ManjAragorn cinnamon-screensaver-pam-helper[5012]: gkr-pam: no password is available for user
Apr 25 19:19:05 ManjAragorn cinnamon-screensaver-pam-helper[5166]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:19:05 ManjAragorn cinnamon-screensaver-pam-helper[5166]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 25 19:19:05 ManjAragorn cinnamon-screensaver-pam-helper[5166]: gkr-pam: no password is available for user
Apr 25 19:24:07 ManjAragorn cinnamon-screensaver-pam-helper[5219]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:29:19 ManjAragorn cinnamon-screensaver-pam-helper[5277]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:29:19 ManjAragorn cinnamon-screensaver-pam-helper[5277]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 25 19:29:19 ManjAragorn cinnamon-screensaver-pam-helper[5277]: gkr-pam: no password is available for user
Apr 25 19:30:06 ManjAragorn cinnamon-screensaver-pam-helper[5289]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:30:06 ManjAragorn cinnamon-screensaver-pam-helper[5289]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 25 19:30:06 ManjAragorn cinnamon-screensaver-pam-helper[5289]: gkr-pam: no password is available for user
Apr 25 19:31:09 ManjAragorn cinnamon-screensaver-pam-helper[5306]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:40:18 ManjAragorn cinnamon-screensaver-pam-helper[5398]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:40:18 ManjAragorn cinnamon-screensaver-pam-helper[5398]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 25 19:40:18 ManjAragorn cinnamon-screensaver-pam-helper[5398]: gkr-pam: no password is available for user
Apr 25 19:41:42 ManjAragorn cinnamon-screensaver-pam-helper[5417]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:42:55 ManjAragorn cinnamon-screensaver-pam-helper[5427]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 25 19:42:55 ManjAragorn cinnamon-screensaver-pam-helper[5427]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 25 19:42:55 ManjAragorn cinnamon-screensaver-pam-helper[5427]: gkr-pam: no password is available for user
Apr 26 00:07:23 ManjAragorn cinnamon-screensaver-pam-helper[9866]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 26 00:07:23 ManjAragorn cinnamon-screensaver-pam-helper[9866]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 26 00:07:23 ManjAragorn cinnamon-screensaver-pam-helper[9866]: gkr-pam: no password is available for user
Apr 26 00:46:56 ManjAragorn cinnamon-screensaver-pam-helper[10234]: pam_uApr 25 15:41:09 ManjAragorn systemd-coredump[2047]: Process 2037 (cinnamon) of user 1000 dumped core.
Apr 26 00:46:56 ManjAragorn cinnamon-screensaver-pam-helper[10234]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 26 00:46:56 ManjAragorn cinnamon-screensaver-pam-helper[10234]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 26 00:46:56 ManjAragorn cinnamon-screensaver-pam-helper[10234]: gkr-pam: no password is available for user
Apr 26 00:48:05 ManjAragorn cinnamon-screensaver-pam-helper[10253]: pam_unix(cinnamon-screensaver:auth): conversation failed
Apr 26 00:48:05 ManjAragorn cinnamon-screensaver-pam-helper[10253]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mattbatt]
Apr 26 00:48:05 ManjAragorn cinnamon-screensaver-pam-helper[10253]: gkr-pam: no password is available for user
Apr 26 01:03:27 ManjAragorn cinnamon-screensaver-pam-helper[10421]: gkr-pam: unlocked login keyring
I tried to figure out he gkr-pam thing but I don't understand what it's supposed to be doing.
I have forgotten most of the stuff I have tried.
At this point I'd be happy with any Desktop environment as long as it works.
I also tried moving my ~/.config/dconf/user to user.bak and just ended up with default desktop settings.
UPDATE:
I just found this post and installed all the optional dependencies listed. I currently have a "start menu" and a more functioal desktop environemnt but It is still failing every time it tries to load cinnamon
Help!!
I thought for sure there would be at lest one response in the 3 days since I posted this. I guess I'll just reinstall.
Whelp I nuked the install and started from scratch.
I tried installing plasma next to cinnamon and it got worse https://wiki.manjaro.org/index.php/Install_Desktop_Environments#KDE_Plasma_5
So I am now running the plasma Official edition of Manjaro. I liked Cinnamon but it seemed like every time I was searching for help I had to type Manjaro and Cinnamon because I was never sure which one was broken at the time.
I have a fresh Install that I have to rebuild to a functional computer.
Thanks for all the help everyone.
scratch that I'm now using XFCE
