Power management in KDE 5 doesn't work
Hello again,
I have noticed that Power Management in Manjaro Plasma doesn't work. Well it work with its default 10 min switch off, but whatever changes you make in there haven't any affect.
Anyone else noticed this? And is there a fix for it ?
best regards
Storm
Screenshot_20200629_143026
Some more info:
[storm@universe ~]$ inxi -Fxxxza --no-host
  Kernel: 5.6.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64
  root=UUID=b284a2e6-9b01-441b-b98c-8c10b0f51211 rw quiet
  udev.log_priority=3
  Desktop: KDE Plasma 5.18.5 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME X370-A v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 0805 date: 06/20/2017
  Device-1: hidpp_battery_0 model: Logitech Wireless Solar Keyboard K750
  serial: <filter> charge: 95% rechargeable: yes status: Charging
  Device-2: hidpp_battery_1
  model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  Topology: 8-Core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP
  arch: Zen family: 17 (23) model-id: 1 stepping: 1 microcode: 8001126
  L2 cache: 4096 KiB
  bogomips: 108625
  Speed: 2033 MHz min/max: 2200/3400 MHz boost: enabled
  Core speeds (MHz): 1: 1818 2: 1825 3: 1812 4: 1826 5: 1732 6: 1834
  7: 1715 8: 1804 9: 1745 10: 1729 11: 1730 12: 1734 13: 3324 14: 2525
  15: 1926 16: 2385
  Type: spectre_v2
  mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
  Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK
  driver: nvidia v: 440.82 bus ID: 2a:00.0 chip ID: 10de:1b81
  Display: x11 server: X.Org 1.20.8 driver: nvidia compositor: kwin_x11
  resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 440.82
  direct render: Yes
  Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 2a:00.1 chip ID: 10de:10f0
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 2c:00.3 chip ID: 1022:1457
  Sound Server: ALSA v: k5.6.16-1-MANJARO
  Device-1: Qualcomm Atheros AR9227 Wireless Network Adapter
  driver: ath9k v: kernel bus ID: 27:01.0 chip ID: 168c:002d
  IF: wlp39s1 state: up mac: <filter>
  vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 28:00.0
  chip ID: 10ec:8168
  IF: enp40s0 state: down mac: <filter>
  Local Storage: total: 1.14 TiB used: 12.96 GiB (1.1%)
  ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB
  size: 232.89 GiB block size: physical: 512 B logical: 512 B
  speed: 6.0 Gb/s serial: <filter> rev: 2B6Q scheme: MBR
  ID-2: /dev/sdb vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
  block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: A750 scheme: GPT
  ID-1: / raw size: 232.42 GiB size: 227.77 GiB (98.00%)
  used: 9.38 GiB (4.1%) fs: ext4 dev: /dev/sda5
  ID-2: /home raw size: 931.51 GiB size: 915.89 GiB (98.32%)
  used: 3.57 GiB (0.4%) fs: ext4 dev: /dev/sdb1
  System Temperatures: cpu: 48.1 C mobo: N/A gpu: nvidia temp: 52 C
  Processes: 325 Uptime: 1h 10m Memory: 31.36 GiB used: 2.74 GiB (8.7%)
  Init: systemd v: 245 Compilers: gcc: 10.1.0 Shell: bash v: 5.0.17
  running in: konsole inxi: 3.0.37
[storm@universe ~]$
I found out that it's the powerdevil that is not working properly.
Here's the output:
Couldn't load plugin "kcms/kcm_powerdevilprofilesconfig" : "The shared library was not found."  -- falling back to old-style loading from desktop file
powerdevil: ("LowBattery", "migration", "Battery", "AC") ()
powerdevil: "Keyboard backlight"  has a runtime requirement
powerdevil: The action  QVariant(QString, "KeyboardBrightnessControl")  appears not to be supported by the core.
powerdevil: "Wireless"  has a runtime requirement
powerdevil: "Screen brightness"  has a runtime requirement
powerdevil: The action  QVariant(QString, "BrightnessControl")  appears not to be supported by the core.
powerdevil: "Screen Energy Saving"  has a runtime requirement
powerdevil: "Button events handling"  has a runtime requirement
powerdevil: "Dim screen"  has a runtime requirement
powerdevil: The action  QVariant(QString, "DimDisplay")  appears not to be supported by the core.
powerdevil: Loading routine called
powerdevil: ()
powerdevil: Ok, KConfigGroup ready ("icon")
powerdevil: ()
powerdevil: ()
Switching to unstable to see if it fixes the problem.
Now I'm living on the edge :smiley:
